je sais pas, j’ai essayé de transposer mais ca dépasse mes compétences
voici l’arbre des valeurs de la commande, le NodeIr y apparait bien, 149, mais pour le faire remonter dans une commande info, j’ai pas trouvé
"id" : 149,
"name" : "",
"loc" : "",
"values" : {
"38-0-currentValue" : {
"id" : "149-38-0-currentValue",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 38,
"commandClassName" : "Multilevel Switch",
"endpoint" : 0,
"property" : "currentValue",
"propertyName" : "currentValue",
"type" : "number",
"readable" : true,
"writeable" : false,
"label" : "Current value",
"stateless" : false,
"commandClassVersion" : 1,
"min" : 0,
"max" : 99,
"list" : false,
"value" : 0,
"isCurrentValue" : true,
"targetValue" : "38-0-targetValue",
"lastUpdate" : 1669285526633
"38-0-Up" : {
"id" : "149-38-0-Up",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "Up",
"propertyName" : "Up",
"type" : "boolean",
"readable" : false,
"writeable" : true,
"label" : "Perform a level change (Up)",
"ccSpecific" : {
"switchType" : 2
"list" : false,
"lastUpdate" : 1669285526634
"38-0-Down" : {
"id" : "149-38-0-Down",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "Down",
"propertyName" : "Down",
"type" : "boolean",
"readable" : false,
"writeable" : true,
"label" : "Perform a level change (Down)",
"ccSpecific" : {
"switchType" : 2
"list" : false,
"38-0-targetValue" : {
"id" : "149-38-0-targetValue",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "targetValue",
"propertyName" : "targetValue",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Target value",
"min" : 0,
"max" : 99,
"list" : false,
"lastUpdate" : 1669285526669
"38-0-duration" : {
"id" : "149-38-0-duration",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "duration",
"propertyName" : "duration",
"type" : "duration",
"readable" : true,
"label" : "Remaining duration",
"list" : false,
"value" : {
"unit" : "seconds"
"lastUpdate" : 1669285526670
"38-0-restorePrevious" : {
"id" : "149-38-0-restorePrevious",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "restorePrevious",
"propertyName" : "restorePrevious",
"type" : "boolean",
"readable" : false,
"writeable" : true,
"label" : "Restore previous value",
"list" : false,
"49-0-Air temperature" : {
"id" : "149-49-0-Air temperature",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 49,
"commandClassName" : "Multilevel Sensor",
"endpoint" : 0,
"property" : "Air temperature",
"propertyName" : "Air temperature",
"type" : "number",
"readable" : true,
"label" : "Air temperature",
"ccSpecific" : {
"sensorType" : 1,
"scale" : 0
"commandClassVersion" : 5,
"unit" : "°C",
"list" : false,
"value" : 20.02,
"lastUpdate" : 1669285526671
"64-0-mode" : {
"id" : "149-64-0-mode",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 64,
"commandClassName" : "Thermostat Mode",
"endpoint" : 0,
"property" : "mode",
"propertyName" : "mode",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Thermostat mode",
"commandClassVersion" : 3,
"min" : 0,
"max" : 255,
"list" : true,
"states" : [
"text" : "Off",
"value" : 0
"text" : "Heat",
"value" : 1
"text" : "Energy heat",
"value" : 11
"text" : "Full power",
"value" : 15
"value" : 1,
"64-0-manufacturerData" : {
"id" : "149-64-0-manufacturerData",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "manufacturerData",
"propertyName" : "manufacturerData",
"type" : "buffer",
"readable" : true,
"label" : "Manufacturer data",
"list" : false,
"67-0-setpoint-1" : {
"id" : "149-67-0-setpoint-1",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 67,
"commandClassName" : "Thermostat Setpoint",
"endpoint" : 0,
"property" : "setpoint",
"propertyName" : "setpoint",
"propertyKey" : 1,
"propertyKeyName" : "Heating",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Setpoint (Heating)",
"ccSpecific" : {
"setpointType" : 1
"min" : 8,
"max" : 28,
"unit" : "°C",
"list" : false,
"value" : 19,
"67-0-setpoint-11" : {
"id" : "149-67-0-setpoint-11",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"propertyKey" : 11,
"propertyKeyName" : "Energy Save Heating",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Setpoint (Energy Save Heating)",
"ccSpecific" : {
"setpointType" : 11
"min" : 8,
"max" : 28,
"unit" : "°C",
"list" : false,
"value" : 17,
"lastUpdate" : 1669285526672
"112-0-1" : {
"id" : "149-112-0-1",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 112,
"commandClassName" : "Configuration",
"endpoint" : 0,
"property" : 1,
"propertyName" : "LCD Invert",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "LCD Invert",
"default" : 0,
"min" : 0,
"max" : 1,
"list" : true,
"allowManualEntry" : false,
"states" : [
"text" : "LCD-content normal",
"value" : 0
"text" : "LCD-content inverted (UK Edition)",
"value" : 1
"value" : 0,
"112-0-2" : {
"id" : "149-112-0-2",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 2,
"propertyName" : "LCD Timeout",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "LCD Timeout",
"default" : 0,
"min" : 0,
"max" : 30,
"unit" : "seconds",
"list" : true,
"allowManualEntry" : true,
"states" : [
"text" : "No Timeout LCD always on",
"value" : 0
"value" : 5,
"112-0-3" : {
"id" : "149-112-0-3",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 3,
"propertyName" : "Backlight",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Backlight",
"default" : 1,
"min" : 0,
"max" : 1,
"list" : true,
"states" : [
"text" : "Backlight disabled",
"value" : 0
"text" : "Backlight enabled",
"value" : 1
"value" : 0,
"lastUpdate" : 1669285526673
"112-0-4" : {
"id" : "149-112-0-4",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 4,
"propertyName" : "Battery report",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Battery report",
"default" : 1,
"min" : 0,
"max" : 1,
"list" : true,
"states" : [
"text" : "system notification",
"value" : 0
"text" : "Send battery status unsolicited once a day.",
"value" : 1
"value" : 1,
"112-0-5" : {
"id" : "149-112-0-5",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 5,
"propertyName" : "Temperature Report Threshold",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Temperature Report Threshold",
"default" : 5,
"min" : 0,
"max" : 50,
"unit" : "0.1 °C",
"list" : false,
"value" : 5,
"112-0-6" : {
"id" : "149-112-0-6",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 6,
"propertyName" : "Valve opening percentage report",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Valve opening percentage report",
"default" : 0,
"min" : 0,
"max" : 100,
"unit" : "%",
"list" : false,
"value" : 5,
"112-0-7" : {
"id" : "149-112-0-7",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 7,
"propertyName" : "Window open detection",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Window open detection",
"default" : 2,
"min" : 0,
"max" : 3,
"list" : true,
"states" : [
"text" : "Disabled",
"value" : 0
"text" : "Sensitivity low",
"value" : 1
"text" : "Sensitivity medium",
"value" : 2
"text" : "Sensitivity high",
"value" : 3
"value" : 0,
"lastUpdate" : 1669285526674
"112-0-8" : {
"id" : "149-112-0-8",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : 8,
"propertyName" : "Temperature Offset",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Temperature Offset",
"default" : 0,
"min" : -128,
"max" : 50,
"unit" : "0.1 °C",
"list" : true,
"states" : [
"text" : "Ext temp sensor be used for regul",
"value" : -128
"value" : 10,
"113-0-Power Management-Battery maintenance status" : {
"id" : "149-113-0-Power Management-Battery maintenance status",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 113,
"commandClassName" : "Notification",
"endpoint" : 0,
"property" : "Power Management",
"propertyName" : "Power Management",
"propertyKey" : "Battery maintenance status",
"propertyKeyName" : "Battery maintenance status",
"type" : "number",
"readable" : true,
"label" : "Battery maintenance status",
"ccSpecific" : {
"notificationType" : 8
"commandClassVersion" : 8,
"min" : 0,
"max" : 255,
"list" : true,
"states" : [
"text" : "idle",
"value" : 0
"text" : "Replace battery soon",
"value" : 10
"text" : "Replace battery now",
"value" : 11
"value" : 0,
"113-0-System-Hardware status" : {
"id" : "149-113-0-System-Hardware status",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "System",
"propertyName" : "System",
"propertyKey" : "Hardware status",
"propertyKeyName" : "Hardware status",
"type" : "number",
"readable" : true,
"label" : "Hardware status",
"ccSpecific" : {
"notificationType" : 9
"min" : 0,
"max" : 255,
"list" : true,
"states" : [
"text" : "idle",
"value" : 0
"text" : "System hardware failure (with failure code)",
"value" : 3
"value" : 0,
"113-0-alarmType" : {
"id" : "149-113-0-alarmType",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "alarmType",
"propertyName" : "alarmType",
"type" : "number",
"readable" : true,
"label" : "Alarm Type",
"min" : 0,
"max" : 255,
"list" : false,
"113-0-alarmLevel" : {
"id" : "149-113-0-alarmLevel",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "alarmLevel",
"propertyName" : "alarmLevel",
"type" : "number",
"readable" : true,
"label" : "Alarm Level",
"min" : 0,
"max" : 255,
"list" : false,
"114-0-manufacturerId" : {
"id" : "149-114-0-manufacturerId",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 114,
"commandClassName" : "Manufacturer Specific",
"endpoint" : 0,
"property" : "manufacturerId",
"propertyName" : "manufacturerId",
"type" : "number",
"readable" : true,
"label" : "Manufacturer ID",
"min" : 0,
"max" : 65535,
"list" : false,
"value" : 328,
"lastUpdate" : 1669285526675
"114-0-productType" : {
"id" : "149-114-0-productType",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "productType",
"propertyName" : "productType",
"type" : "number",
"readable" : true,
"label" : "Product type",
"min" : 0,
"max" : 65535,
"list" : false,
"value" : 3,
"114-0-productId" : {
"id" : "149-114-0-productId",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "productId",
"propertyName" : "productId",
"type" : "number",
"readable" : true,
"label" : "Product ID",
"min" : 0,
"max" : 65535,
"list" : false,
"value" : 1,
"117-0-local" : {
"id" : "149-117-0-local",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 117,
"commandClassName" : "Protection",
"endpoint" : 0,
"property" : "local",
"propertyName" : "local",
"type" : "number",
"readable" : true,
"writeable" : true,
"label" : "Local protection state",
"list" : true,
"states" : [
"text" : "Unprotected",
"value" : 0
"text" : "ProtectedBySequence",
"value" : 1
"text" : "NoOperationPossible",
"value" : 2
"value" : 0,
"128-0-level" : {
"id" : "149-128-0-level",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 128,
"commandClassName" : "Battery",
"endpoint" : 0,
"property" : "level",
"propertyName" : "level",
"type" : "number",
"readable" : true,
"label" : "Battery level",
"min" : 0,
"max" : 100,
"unit" : "%",
"list" : false,
"value" : 90,
"128-0-isLow" : {
"id" : "149-128-0-isLow",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "isLow",
"propertyName" : "isLow",
"type" : "boolean",
"readable" : true,
"label" : "Low battery level",
"list" : false,
"value" : false,
"134-0-libraryType" : {
"id" : "149-134-0-libraryType",
"nodeId" : 149,
"toUpdate" : false,
"commandClass" : 134,
"commandClassName" : "Version",
"endpoint" : 0,
"property" : "libraryType",
"propertyName" : "libraryType",
"type" : "number",
"readable" : true,
"label" : "Library type",
"commandClassVersion" : 2,
"list" : true,
"states" : [
"text" : "Unknown",
"value" : 0
"text" : "Static Controller",
"value" : 1
"text" : "Controller",
"value" : 2
"text" : "Enhanced Slave",
"value" : 3
"text" : "Slave",
"value" : 4
"text" : "Installer",
"value" : 5
"text" : "Routing Slave",
"value" : 6
"text" : "Bridge Controller",
"value" : 7
"text" : "Device under Test",
"value" : 8
"text" : "N/A",
"value" : 9
"text" : "AV Remote",
"value" : 10
"text" : "AV Device",
"value" : 11
"value" : 3,
"lastUpdate" : 1669285526676
"134-0-protocolVersion" : {
"id" : "149-134-0-protocolVersion",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "protocolVersion",
"propertyName" : "protocolVersion",
"type" : "string",
"readable" : true,
"label" : "Z-Wave protocol version",
"list" : false,
"value" : "4.61",
"134-0-firmwareVersions" : {
"id" : "149-134-0-firmwareVersions",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "firmwareVersions",
"propertyName" : "firmwareVersions",
"type" : "string[]",
"readable" : true,
"label" : "Z-Wave chip firmware versions",
"list" : false,
"value" : [
"0.16",
"0.2"
"134-0-hardwareVersion" : {
"id" : "149-134-0-hardwareVersion",
"nodeId" : 149,
"toUpdate" : false,
"endpoint" : 0,
"property" : "hardwareVersion",
"propertyName" : "hardwareVersion",
"type" : "number",
"readable" : true,
"label" : "Z-Wave chip hardware version",
"list" : false,
"value" : 49,
"groups" : [
"text" : "Lifeline",
"endpoint" : 0,
"value" : 1,
"maxNodes" : 1,
"isLifeline" : true,
"multiChannel" : false
"neighbors" : "",
"ready" : true,
"available" : true,
"hassDevices" : [
"failed" : false,
"inited" : true,
"eventsQueue" : [
"time" : "2022-11-24T10:25:26.491Z",
"event" : "alive",
"args" : [
0
"time" : "2022-11-24T10:25:26.717Z",
"event" : "ready",
"args" : [
"status" : "Alive",
"interviewStage" : "Complete",
"hexId" : "0x0148-0x0003-0x0001",
"dbLink" : "https://devices.zwave-js.io/?jumpTo=0x0148:0x0003:0x0001:0.16",
"manufacturerId" : 328,
"productId" : 1,
"productType" : 3,
"deviceConfig" : {
"filename" : "/var/www/html/plugins/zwavejs/resources/zwave-js-ui/node_modules/@zwave-js/config/config/devices/0x0148/spirit.json",
"isEmbedded" : true,
"manufacturer" : "Eurotronics",
"label" : "Spirit",
"description" : "Thermostatic Valve",
"devices" : [
"productType" : 3,
"productId" : 1
"productType" : 3,
"productId" : 3
"firmwareVersion" : {
"min" : "0.0",
"max" : "255.255"
"paramInformation" : {
"_map" : [
"metadata" : {
"comments" : {
"level" : "warning",
"text" : "The thermostat is missing "Manufacturer Specific" from its list of supported modes, although the mode is supported. Application-specific workarounds may be necessary to switch to "Manufacturer Specific" mode."
"productLabel" : "Spirit",
"productDescription" : "Thermostatic Valve",
"firmwareVersion" : "0.16",
"protocolVersion" : 3,
"zwavePlusVersion" : 1,
"zwavePlusNodeType" : 0,
"zwavePlusRoleType" : 7,
"nodeType" : 1,
"endpointsCount" : 0,
"endpointIndizes" : [
"isSecure" : false,
"security" : "None",
"supportsSecurity" : false,
"supportsBeaming" : true,
"isControllerNode" : false,
"isListening" : false,
"isFrequentListening" : "1000ms",
"isRouting" : true,
"keepAwake" : false,
"maxDataRate" : 100000,
"deviceClass" : {
"basic" : 4,
"generic" : 8,
"specific" : 6
"firmwareCapabilities" : {
"firmwareUpgradable" : true,
"firmwareTargets" : [
0,
2
"continuesToFunction" : "unknown",
"supportsActivation" : "unknown"
"deviceId" : "328-1-3",
"statistics" : {
"commandsTX" : 1,
"commandsRX" : 0,
"commandsDroppedRX" : 0,
"commandsDroppedTX" : 0,
"timeoutResponse" : 0,
"rtt" : 1287.9
"lastActive" : 1669285526784,
"minBatteryLevel" : 90,
"batteryLevels" : [
90
"filename" : "spirit.json (Zwave-Js)",
"numberGroups" : 1,
"classBasic" : 4,
"classGeneric" : 8,
"classSpecific" : 6,
"deviceIdNew" : "328-3-1",
"confJeedom" : "eurotronic_328/eur.spiritz.wall.radiator.thermostat.json",
"confType" : "Configuration Jeedom <br>Commands : <br> - Commande Consigne Eco<br> - Consigne Eco<br> - Commande Consigne Chauffe<br> - Consigne Chauffe<br> - Position valve<br> - Etat valve (en manuel)<br> - Température<br> - Mode Actuel<br> - Eteindre<br> - Manuel<br> - Chauffage<br> - Pleine Chauffe<br> - Eco<br> - Batterie<br>",
"lastWakeup" : "N/A",
"nextWakeup" : "N/A",
"configWakeup" : "N/A"
