Ajout prise connectée Lexman
Serait-il possible d’ajouter cette prise connectée avec mesure de consommation?
LEXMAN SMART PLUG - 16A
https://www.leroymerlin.fr/produits/electricite-domotique/domotique-et-objets-connectes/domotique/solutions-de-commande/prise-connectee-16a-3680w-repeteur-lexman-82428895.html
Informations brutes
    "ieee": "5c:02:72:ff:fe:b1:44:0f",
    "nwk": 56055,
    "status": 2,
    "lqi": "255",
    "rssi": "-61",
    "last_seen": "1640699582.8663507",
    "node_descriptor": "01:40:8e:77:12:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 81,
            "profile_id": 260,
            "manufacturer": "ADEO",
            "model": "LDSENK02F",
            "output_clusters": [
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 1
                            "id": 2,
                            "name": "stack_version",
                            "value": 2
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "ADEO"
                            "id": 5,
                            "name": "model",
                            "value": "LDSENK02F"
                            "id": 6,
                            "name": "date_code",
                            "value": "20200217-586"
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                            "id": 16384,
                            "name": "sw_build_id",
                            "value": "2.6"
                    "id": 3,
                    "name": "Identify",
                    "attributes": []
                    "id": 4,
                    "name": "Groups",
                    "attributes": []
                    "id": 5,
                    "name": "Scenes",
                    "attributes": []
                    "id": 6,
                    "name": "On\/Off",
                    "attributes": [
                            "id": 0,
                            "name": "on_off",
                            "value": 0
                    "id": 1794,
                    "name": "Metering",
                    "attributes": []
                    "id": 2820,
                    "name": "Electrical Measurement",
                    "attributes": []
                    "id": 64642,
                    "name": "Manufacturer Specific",
                    "attributes": []
            "id": 242,
            "status": 1,
            "device_type": 97,
            "profile_id": 41440,
            "manufacturer": null,
            "model": null,
                    "id": 33,
                    "name": "GreenPowerProxy",
                    "attributes": []
            "input_clusters": []
    "signature": {
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4727,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 81,
                "input_clusters": [
                    0,
                    3,
                    4,
                    5,
                    6,
                    1794,
                    2820,
                    64642
                    3,
                    10,
                    25
            "242": {
                "device_type": 97,
                "input_clusters": [],
                    33
    "class": "zigpy.device"
Log debug
[2021-12-28 15:05:20][DEBUG] : {"devices":{"54:ef:44:10:00:0f:c4:58":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-12-28 15:05:20][DEBUG] : Search attribut for 54:ef:44:10:00:0f:c4:58 logicalId : 1::6::0 => Bool.false convert to 0
[2021-12-28 15:05:23][DEBUG] : http://xxx.x.x.x:xxxx/device/all?with_attributes=2 type : GET
[2021-12-28 15:05:23][DEBUG] : {"with_attributes":2}
[2021-12-28 15:05:23][DEBUG] : http://xxx.x.x.x:xxxx/group/all type : GET
[2021-12-28 15:05:23][DEBUG] : null
[2021-12-28 15:05:39][DEBUG] : http://xxx.x.x.x:xxxx/application/include type : PUT
[2021-12-28 15:05:39][DEBUG] : {"duration":180}
[2021-12-28 15:05:40][DEBUG] : ""
[2021-12-28 15:05:56][DEBUG] : {"device_joined":"5c:02:72:ff:fe:b1:44:0f"}
[2021-12-28 15:05:56][DEBUG] : {"device_initialized":"5c:02:72:ff:fe:b1:44:0f"}
[2021-12-28 15:05:57][DEBUG] : {"devices":{"04:cf:8c:df:3c:7d:6b:ba":{"1":{"64704":{"247":{"value":"b'\x01!\xfa\x0b\x03(\x19\x04!\xa8\x13\x05!)\x00\x06$\x01\x00\x00\x00\x00\x08!\x11\x01
!\x00\x00\x0c \x01d\x10\x00'","cluster_name":"OppleCluster"}}}}}}
[2021-12-28 15:05:57][DEBUG] : Search attribut for 04:cf:8c:df:3c:7d:6b:ba logicalId : 1::64704::247 => b'\x01!\xfa\x0b\x03(\x19\x04!\xa8\x13\x05!)\x00\x06$\x01\x00\x00\x00\x00\x08!\x11\x01
!\x00\x00\x0c \x01d\x10\x00' convert to b'\x01!\xfa\x0b\x03(\x19\x04!\xa8\x13\x05!)\x00\x06$\x01\x00\x00\x00\x00\x08!\x11\x01
[2021-12-28 15:06:19][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-12-28 15:06:19][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::6::0 => Bool.true convert to 1
[2021-12-28 15:06:26][DEBUG] : http://xxx.x.x.x:xxxx/device/all?with_attributes=2 type : GET
[2021-12-28 15:06:26][DEBUG] : {"with_attributes":2}
[2021-12-28 15:06:27][DEBUG] : http://xxx.x.x.x:xxxx/group/all type : GET
[2021-12-28 15:06:27][DEBUG] : null
[2021-12-28 15:06:27][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-12-28 15:06:27][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::6::0 => Bool.false convert to 0
[2021-12-28 15:07:20][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-12-28 15:07:20][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::6::0 => Bool.true convert to 1
[2021-12-28 15:07:29][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"2820":{"1291":{"value":"20","cluster_name":"Electrical Measurement"}}}}}}
[2021-12-28 15:07:29][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::2820::1291 => 20 convert to 20
[2021-12-28 15:07:56][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-12-28 15:07:56][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::6::0 => Bool.false convert to 0
[2021-12-28 15:07:59][DEBUG] : {"devices":{"5c:02:72:ff:fe:b1:44:0f":{"1":{"2820":{"1291":{"value":"0","cluster_name":"Electrical Measurement"}}}}}}
[2021-12-28 15:07:59][DEBUG] : Search attribut for 5c:02:72:ff:fe:b1:44:0f logicalId : 1::2820::1291 => 0 convert to 0
[2021-12-28 15:08:07][DEBUG] : {"devices":{"00:15:8d:00:04:7b:aa:71":{"1":{"1026":[{"value":"1823","cluster_name":"Temperature Measurement"}],"1029":[{"value":"6294","cluster_name":"Relative Humidity Measurement"}],"1027":[{"value":"990","cluster_name":"Pressure Measurement"}]}}}}
[2021-12-28 15:08:07][DEBUG] : Search attribut for 00:15:8d:00:04:7b:aa:71 logicalId : 1::1026::0 => 1823 convert to 1823
[2021-12-28 15:08:07][DEBUG] : Search attribut for 00:15:8d:00:04:7b:aa:71 logicalId : 1::1029::0 => 6294 convert to 6294
[2021-12-28 15:08:07][DEBUG] : Search attribut for 00:15:8d:00:04:7b:aa:71 logicalId : 1::1027::0 => 990 convert to 990
Merci beaucoup
Ci joint les fichiers de configuration pour l’intégration:
Cordialement,
Je suis également intéressé par le sujet ayant acheté ce genre de prise qui fonctionne bien sous deconz mais sans information de consommation.
C’est la première fois que j’essaie d’intégrer un équipement à l’aide d’un fichier json. Je n’ai pas su trouver l’information sur la manière d’utiliser les 2 fichiers . Pouvez vous me dire s’il existe une procédure documentée ou me dire comment vous avez fait . D’avance merci .
Cordialement Yannick
Cette prise remonte bien l’info de puissance dans le plugin zigbee svp ?
Je n’ai pas encore eu le temps de passé chez LM pour acheter cette prise.
Toutefois, il me semble avoir lu un autre post indiquant que les infos puissance et conso étaient remontées sur le #plugin-zigbee (pas sur Deconz)
Et si j’en crois les fichiers Json (html/plugins/zigbee/core/config/devices/adeo/ADEO.LDSENK02F.json
) ou dans les infos brutes joints plus haut les données y sont présentes : 1::2820::1291 et 1::1794::0
A confirmer à l’usage …
@Emlivyo Je confirme, j’en ai d’installées et la puissance remonte bien avec le plugin Zigbee.
Par contre si quelqu’un sait comment lui faire reprendre son dernier état en cas de coupure de courant je suis preneur de l’info.
Dans Configuration du module, Configuration est vide.
« Il n’éxiste aucun parametre spécifique de configuration connu pour ce module »
Je me répond à moi même pour donner l’info si ça intéresse.
Alors pour que la prise se mette sur On après une coupure de courant
Il faut aller dans Configuration du module Action et configurer l’attribut 16387 à 255 tel que ci-dessous.
Les valeurs possibles de cet attribut sont :
0 = éteint à la mise sous tension
1 = allumé à la mise sous tension
255 = reprend le dernier état
Mais c’est génial cette astuce car elle fonctionne également sur les lampes Lexman/Adeo.
Je n’ai plus besoin de mon scénario en cas de coupure EDF…
Il faudrait que @Loic intègre une commande spécifique avec un menu déroulant et les 3 valeurs possibles
NB : par curiosité, comment as tu fait pour trouver l’attribut et les valeurs correspondantes ?
J’ai cherché sur internet et j’ai trouvé une discussion sur un forum ha zigbee ou ils avaient le même pb mais avec des ampoules et ici aussi sur ce forum je crois que c’était avec des ampoules hue.
Après j’ai extrapolé et testé.
Tiens c’était là :
https://forum.hacf.fr/t/zigbee-light-a-9-90/4173/6
Intéressant pour les ampoules.
Merci d’avoir retrouvé l’info. Cela m’a été très utile…
Je viens de retrouver le post
et celui-ci
Est-ce que quelqu’un sait sur quel paramètre jouer pour éteindre la led verte qui éclaire vraiment trop fort pour l’utilisation dans une chambre ?
A part la masquer mécaniquement :slight_smile:
Peut-être avec le 32769 (vu sur un post concernant une prise Tuya) ?
mais je n’y suis pas arrivé sur les Lexman.
Edit : par contre, je viens de me rendre compte que cela fonctionne avec les prises Lidl
mais pas avec les multiprises de la même marque ???
Merci pour l’inclusion de cette prise dans Jeedom.
Fonctionne parfaitement chez moi.
A ce jour, cela reste la moins chère des prises Zigbee 16A avec mesure de consommation.
