Mes 2 messages ne sont pas liés, ce sont 2 capteurs différents, de marques différents:
1er message: Capteur luminosité Xiaomi
2eme message: Capteur présence / température / mouvement Frient
Oupss. Trop rapide.
Corrigé
Prise Connectée Aqara Smart Plug
Marque: Aqara
Modèle: SP-EUC01
"ieee": "04:cf:8c:df:3c:89:d5:a0",
"nwk": 12490,
"status": 2,
"lqi": "255",
"rssi": "-54",
"last_seen": "1612532412.2050695",
"node_descriptor": "01:40:8e:5f:11:7f:64:00:00:2c:64:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "LUMI",
"model": "lumi.plug.maeu01",
"output_clusters": [
"id": 10,
"name": "Time",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 22
"id": 2,
"name": "stack_version",
"value": 2
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "LUMI"
"id": 5,
"name": "model",
"value": "lumi.plug.maeu01"
"id": 6,
"name": "date_code",
"value": "09-10-2019"
"id": 7,
"name": "power_source",
"value": 1
"id": 2,
"name": "Device Temperature",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 1
"id": 9,
"name": "Alarms",
"attributes": []
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"name": "current_summ_delivered",
"value": 181
"id": 2820,
"name": "Electrical Measurement",
"attributes": [
"id": 1291,
"name": "active_power",
"value": 0
"id": 242,
"status": 1,
"device_type": 97,
"profile_id": 41440,
"manufacturer": null,
"model": null,
"id": 33,
"name": "GreenPowerProxy",
"attributes": []
"input_clusters": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"mac_capability_flags": 142,
"manufacturer_code": 4447,
"maximum_buffer_size": 127,
"maximum_incoming_transfer_size": 100,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 100,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
2,
3,
4,
5,
6,
9,
1794,
2820
10,
25
"242": {
"device_type": 97,
"input_clusters": [],
33
"class": "zigpy.device"
P.S: J’ai essayé d’utiliser le profils d’une des prises connecté Xiaomi de la liste, les commandes ON / OFF et Etat fonctionnent, mais le suivie de conso sort des chiffres incohérents comparé au relevé sur d’autre prises ayant le suivie conso.
Je viens d’ajouter une prise connectée Frient.
Elle est présente dans la liste, mais n’a pas était associée automatiquement.
Après ajout manuel, aucun soucis avec les commandes.
Marque: Frient
Modèle: SPLZB-132
Nom Equipement dans la liste: [SPLZB-132] Wallplug
"ieee": "00:15:bc:00:2f:00:22:eb",
"nwk": 17282,
"status": 2,
"lqi": "191",
"rssi": "-70",
"last_seen": "1612533414.7704673",
"node_descriptor": "01:40:8e:15:10:48:18:06:00:00:18:06:00",
"endpoints": [
"id": 2,
"status": 1,
"device_type": 81,
"profile_id": 260,
"manufacturer": "frient A\/S",
"model": "SPLZB-132",
"id": 0,
"name": "Basic",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 1030,
"name": "Occupancy Sensing",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"value": 1
"id": 4,
"value": "frient A\/S"
"id": 5,
"name": "model",
"value": "SPLZB-132"
"id": 6,
"value": "2016-10-28 00:58"
"id": 7,
"value": 1
"id": 1794,
"name": "Metering",
"attributes": [
"id": 0,
"value": 0
"id": 1024,
"name": "instantaneous_demand",
"value": 0
"id": 3,
"name": "Identify",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 2820,
"attributes": [
"id": 1291,
"value": 0
"id": 6,
"name": "On\/Off",
"attributes": [
"id": 0,
"name": "on_off",
"value": 0
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 2,
"attributes": []
"id": 1,
"status": 1,
"device_type": 1,
"profile_id": 49353,
"model": null,
"output_clusters": [],
"input_clusters": [
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"signature": {
"node_desc": {
"byte1": 1,
"byte2": 64,
"manufacturer_code": 4117,
"maximum_buffer_size": 72,
"maximum_incoming_transfer_size": 1560,
"server_mask": 0,
"maximum_outgoing_transfer_size": 1560,
"endpoints": {
"2": {
"profile_id": 260,
"device_type": 81,
"input_clusters": [
0,
1794,
3,
9,
2820,
6,
4,
5,
2
0,
25,
10,
3,
1030
"1": {
"device_type": 1,
"input_clusters": [
5,
6
Ben écoute désolé…le seul log que j ai, je l ai mis…
Je le remets…
Error: No module named ‹ tornado › error
T’as forcement les logs des dépendances même si ça foire, sélectionne le mode debug, sauvegarde, et relance les dépendances puis actualise la page
Ok merci pour tes indications, je fais ça dès que je peux
Merci ca sera dans la beta de demain
Merci ca sera dans la beta de demain. Par contre pour l’incoherence de mesure sans en dire plus je ne peux rien faire.
Ca sera dans la beta de demain (il renomme leur gamme c’est compliqué…)
D’accord merci pour les MAJ.
Pour l’incohérence de mesure, avec une TV allumée, ma prise Frient relève 37w alors que la prise Aqara (en sélectionnant une prise Xiaomi dans la liste) me dit entre 388 et 505w.
Sur une vrai prise Xiaomi reconnue, la conso est de 38.69w.
Après, ça semble être environ 10x plus sur l’Aqara, donc peut être un problème d’unité.
Vu que ce n’est pas la configuration de base de la prise Aqara, c’est peut être pas la bonne commande. Peut être qu’avec la version MAJ les données seront bonnes, ça peut attendre de voir si tu veux.
J’ai fouillé un peu le forum et j’ai constaté que d’autres rencontrent le même souci en utilisant le plugin Deconz.
comment on fait pour repasser l’ampoule en mode blanc, car en mode couleur la luminosité est faiblarde mais même en choisissant la couleur blanche, ca reste faible même avec le luminosité à fond.
Ce n’est donc pas un problème de plugin mais plutôt de produit (ou de paramétrage du produit).
ce qui est bizarre c’est qu’après l’installation, avant de faire un choix de couleur, l’ampoule était bien en blanc pétant
Curieusement j’ai fait exactement le même constat.
La raison semble se trouver ICI
« Alors Deconz en fait la supporte très bien de base (NB l’ampoule), et d’ailleurs arrive à la faire fonctionner à 100% de ses capacité. le problème est plutôt coté Jeedom. Pour basculer du mode couleur au mode lumière, celle ci doit recevoir UNIQUEMENT une partie du json (et non l’intégralité) car si l’ampoule détecte un JSON « couleur » elle bascule automatiquement l’ampoule en mode couleur ! »
et la solution peut-être par ICI (détail et copie écran)
J’ai trouvé la solution pour éviter de devoir passer par un curseur pour passer de la couleur au blanc et aussi régler la luminosité sans passer par un curseur.
J’ai rajouté des commandes dans la configuration de l’ampoule:
Le concept semble duplicable à d’autres marques d’ampoules RGB (Leroy Merlin par exemple).
Qu’en penses-tu ?
alors un log « zigbee »
[2021-02-05 21:09:11][INFO] : Début d'activation du plugin [2021-02-05 21:09:20][INFO] : Info sur le démon : {"log":"zigbee","state":"nok","launchable":"nok","launchable_message":"Gestion automatique d\u00e9sactiv\u00e9e","auto":"0","last_launch":"Inconnue"} [2021-02-05 21:09:20][DEBUG] : Lancement de : /var/www/html/core/class/../../core/php/jeePlugin.php plugin_id=zigbee function=update callInstallFunction=1 [2021-02-05 21:09:39][INFO] : Lancement de l'installation des packages, pour le suivre veuillez lire regarder le logs packages [2021-02-05 21:10:13][INFO] : Lancement de l'installation des packages, pour le suivre veuillez lire regarder le logs packages
et un autre : Zigbeed_1
Tu n’as pas lancé les dépendances du plugin
Ben si c’est justement là le problème…
Bonjour @Loic
Est il possible de faire cohabiter 2 clés conbee chacune sur une box dans un même espace. En claire une sur la prod et l’autre en test?
Tu auras quoi qu’il arrive deux réseaux zigbee séparés. Chaque Conbee2 sera coordinateur de son réseau. Sinon pour le reste à part une potentielle limitation radio électrique si les Conbee2 sont sur le même canal Zigbee c’est possible si le plug sait gérer deux clefd en simultané. Un conseil: éloigne les deux Conbee2 l’une de l’autre d au moins 1m.
Super, merci pour la réponse
@olive @anon39781406 @olivr2s
Bonjour, pour faire suite, avec ma nouvelle antenne 12Dbi (35cm), mes valeur ont sensiblement augmenté nouvelles valeur a gauche. et l’ancienne antenne a droite (8cm)
Pour rappel chez Texas Instrument le LQI max est de 110, donc 2 perfect
Pour ceux que ca intéresse :
https://www.amazon.fr/gp/product/B00OUO9EZY/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
En revanche j’ai enlevé la rallonge, les valeurs était moins bonne avec…
d ailleurs quand je relance j ai le droit à ce message
Installation de package impossible car il y a déjà une installation en cours
