Module QS-Zigbee-C01
Je viens d’inclure 2 modules QS-Zigbee-C01 et tout marche parfaitement.
Comme beaucoup, je rencontre le problème avec le temps de calibration. En regardant dans community j’ai trouvé plusieurs sujet mais sans résultat. Dans un de tes message tu demandais le json et j’ai l’impression que tu ne l’a pas eu, par conséquent le voici.
    "ieee": "0c:43:14:ff:fe:6a:95:9a",
    "nwk": 27065,
    "status": 2,
    "lqi": "168",
    "rssi": "-58",
    "last_seen": "1627390388.0540433",
    "node_descriptor": "01:40:8e:02:10:52:52:00:00:2c:52:00:00",
    "endpoints": [
            "id": 1,
            "status": 1,
            "device_type": 514,
            "profile_id": 260,
            "manufacturer": "_TZ3000_vd43bbfq",
            "model": "TS130F",
            "output_clusters": [
                    "id": 10,
                    "name": "Time",
                    "attributes": []
                    "id": 25,
                    "name": "Ota",
                    "attributes": []
            "input_clusters": [
                    "id": 0,
                    "name": "Basic",
                    "attributes": [
                            "id": 0,
                            "name": "zcl_version",
                            "value": 3
                            "id": 1,
                            "name": "app_version",
                            "value": 64
                            "id": 2,
                            "name": "stack_version",
                            "value": 0
                            "id": 3,
                            "name": "hw_version",
                            "value": 1
                            "id": 4,
                            "name": "manufacturer",
                            "value": "_TZ3000_vd43bbfq"
                            "id": 5,
                            "name": "model",
                            "value": "TS130F"
                            "id": 6,
                            "name": "date_code",
                            "value": ""
                            "id": 7,
                            "name": "power_source",
                            "value": 1
                    "id": 4,
                    "name": "Groups",
                    "attributes": [
                            "id": 0,
                            "name": "name_support",
                            "value": 0
                    "id": 5,
                    "name": "Scenes",
                    "attributes": [
                            "id": 0,
                            "name": "count",
                            "value": 0
                    "id": 258,
                    "name": "Window Covering",
                    "attributes": [
                            "id": 8,
                            "name": "current_position_lift_percentage",
                            "value": 89
                            "id": 61440,
                            "name": "tuya_moving_state",
                            "value": 1
                            "id": 61441,
                            "name": "calibration",
                            "value": 1
                            "id": 61442,
                            "name": "motor_reversal",
                            "value": 0
    "signature": {
        "model": "TS130F",
        "node_desc": {
            "logical_type": 1,
            "reserved": 0,
            "aps_flags": 0,
            "frequency_band": 8,
            "mac_capability_flags": 142,
            "manufacturer_code": 4098,
            "maximum_buffer_size": 82,
            "maximum_incoming_transfer_size": 82,
            "server_mask": 11264,
            "maximum_outgoing_transfer_size": 82,
        "endpoints": {
            "1": {
                "profile_id": 260,
                "device_type": 514,
                "input_clusters": [
                    0,
                    4,
                    5,
                    258
                    10,
                    25
    "class": "zhaquirks.tuya.ts130f"
Tu pourras remarquer que endpoint 1 cluster 258 attribut 61441 est présente car j’ai fais quelques test sinon de base celui-ci n’apparait pas.
Autre info, si l’on tape endpoint 1 cluster 258 attribut 61443 le retour est 10 sans possibilité de le modifier.
Est ce que cela peut aider pour ajouter la calibration pour ces modules ?
As-tu besoin d’autre choses ?
Veuillez ne pas tag un développeur en direct pour une question.
Rappel des règles, point 16: Comment nous aider à vous aider - ou Comment poser une bonne question?
Bonjour désolé
Je viens de faire un test si d’autre personne peuvent essayer et faire un retour.
Procédure de calibration :
Mettre le volet complètement fermer
Vérifier la valeur de l’attribut 61443 (endpoint 1 cluster 258 attribut 61443) le retour doit-être 10
Vérifier la valeur de l’attribut 61441 (endpoint 1 cluster 258 attribut 61441) le retour doit-être 1
Mettre l’attribut 61441 à 0 (endpoint 1 cluster 258 attribut 61441) dans configuration du module
Monter le volet avec la commande Monter et attendre l’ouverture complète du volet
Appuyer sur la commande stop
Descendre le volet avec la commande Descendre et attendre la fermeture complète du volet
Mettre l’attribut 61441 à 1 (endpoint 1 cluster 258 attribut 61441) dans configuration du module
Vérifier la valeur de l’attribut 61443 (endpoint 1 cluster 258 attribut 61443) le retour doit-être différent de 10
@raulrd2019 et @Yves19 est-il possible de faire un essai ?
Je souhaiterai effectuer le test mais l’onglet « Action » n’apparait pas dans la fenêtre de configuration du nœud correspondant au module TS130F.
As-tu bien cliqué sur le bouton ci-dessous ?
si oui je suis en version béta c’est peut-être la différence
Désolé, Je viens de me rendre compte que le topic était pour le plugin Zigbee. Il est donc normal de ne pas être en phase car j’utilise le plugin Deconz.
Je viens de faire le test et c’est nickel.
J’étais en galère avec ce module.
Merci beaucoup.
Et bien de rien c’est fait pour le community
