Soucis chez moi avec la nouvelle version sur tous mes tel et tablette
« Problème de connexion à jeedom »
Je pense avoir tout tenté :
- suppression et réinstall de JC
- Avec et sans wifi
- effacement du cache et des données
Je suis en dns jeedom pour l’extérieur, wifi pour l’interieur
Le log au moment de la tentative de connexion :
0000|[2021-07-22 20:17:20][DEBUG] : HTTP API received {"method":"GET_CONFIG","jsonrpc":"2.0","id":1626977839491,"params":{"apiKey":"5e39ca8c38e27b504b6a80a595c935d5"}}
0001|[2021-07-22 20:17:20][DEBUG] : HTTP API received {"method":"GET_INFO","jsonrpc":"2.0","id":1626977839491,"params":{"apiKey":"5e39ca8c38e27b504b6a80a595c935d5"}}
0002|[2021-07-22 20:17:20][INFO] : Send info {"type":"SET_INFO","payload":{"cmds":[{"id":"3860","value":27.1,"modified":1626977143},{"id":"4436","value":0,"modified":1626953347},{"id":"4648","value":0,"modified":1626250594},{"id":"5201","value":0,"modified":1626245191},{"id":"5411","value":2,"modified":1626961959},{"id":"5496","value":2,"modified":1626977837},{"id":"6276","value":0,"modified":1626960667},{"id":"6648","value":0,"modified":1626240885},{"id":"6680","value":1,"modified":1626977409},{"id":"6693","value":1,"modified":1626977038},{"id":"6916","value":0,"modified":1626927161},{"id":"6917","value":23.4,"modified":1626977733},{"id":"7265","value":0,"modified":1626897903},{"id":"7289","value":"*** 20 h 17 mn ***<br>Info Piscine Ensu\u00e8se : Le Phi est trop bas, veuillez ajouter du Phi pluse ! , La temp\u00e9rature de l'eau est de 27.1 \u00b0C.<br>","modified":1626977822},{"id":"7711","value":99,"modified":1626245115},{"id":"7893","value":80,"modified":1626977335},{"id":"7912","value":0,"modified":1626897902},{"id":"9136","value":0,"modified":1626196021},{"id":"9137","value":25.4,"modified":1626974807},{"id":"9138","value":"<font color='Yellow'>Mode Confort (18 \u00b0)<\/font><br><br>Confort :","modified":1626953403},{"id":"9152","value":0,"modified":1626189601},{"id":"9153","value":25.9,"modified":1626976902},{"id":"9154","value":"<font color='Yellow'>Mode Confort (21 \u00b0)<\/font><br><br>Confort :","modified":1626953403},{"id":"9186","value":28,"modified":1626976373},{"id":"9214","value":99,"modified":1626244222},{"id":"9253","value":27.8,"modified":1626976899},{"id":"9264","value":28.3,"modified":1626973335},{"id":"9287","value":0,"modified":1626259628},{"id":"9681","value":1,"modified":1626977629},{"id":"9792","value":0,"modified":1626897903},{"id":"9910","value":1,"modified":1626977336},{"id":"10108","value":1,"modified":1626976430},{"id":"10189","value":99,"modified":1626240925},{"id":"10275","value":99,"modified":1626252544},{"id":"10279","value":99,"modified":1626240963},{"id":"10280","value":99,"modified":1626241208},{"id":"10281","value":99,"modified":1626962434},{"id":"10282","value":99,"modified":1626240976},{"id":"10284","value":199,"modified":1626953938},{"id":"10285","value":99,"modified":1626244222},{"id":"10286","value":99,"modified":1626253109},{"id":"10287","value":99,"modified":1626253096},{"id":"10551","value":0,"modified":1626953643},{"id":"12107","value":25.9,"modified":1626976902},{"id":"12109","value":24.4,"modified":1626977648},{"id":"12111","value":23.4,"modified":1626977733},{"id":"14286","value":68.6,"modified":1626977387},{"id":"14287","value":51,"modified":1626977733},{"id":"14451","value":99,"modified":1626250556},{"id":"14455","value":99,"modified":1626240976},{"id":"14457","value":99,"modified":1626253096},{"id":"14458","value":99,"modified":1626253109},{"id":"14461","value":99,"modified":1626240963},{"id":"16117","value":0,"modified":1626213608},{"id":"18853","value":99,"modified":1626240939},{"id":"18947","value":70.9,"modified":1626976651},{"id":"21359","value":0,"modified":1626897787},{"id":"21805","value":0,"modified":1626897926},{"id":"24227","value":23,"modified":1622220689},{"id":"24229","value":18,"modified":1613415902},{"id":"24231","value":21,"modified":1613415222},{"id":"24498","value":"43.3507038,5.2083872,195","modified":1626962903},{"id":"24579","value":"43.3507078,5.2083644,193.8","modified":1626974373},{"id":"25480","value":1,"modified":1626977335},{"id":"25492","value":1,"modified":1626977335},{"id":"25988","value":0,"modified":1626976203},{"id":"25991","value":254,"modified":1626244498},{"id":"26053","value":0,"modified":1626956764},{"id":"26091","value":1,"modified":1626977335},{"id":"26094","value":205,"modified":1626977335},{"id":"26341","value":-16.82,"modified":1626975223},{"id":"26380","value":10.44,"modified":1626977490},{"id":"26463","value":1,"modified":1626976097},{"id":"26580","value":0,"modified":1626976022},{"id":"28412","value":0,"modified":1626897926},{"id":"28417","value":0.5,"modified":1626897933},{"id":"28611","value":0,"modified":1626975994},{"id":"28614","value":27,"modified":1626977684},{"id":"29415","value":0.7,"modified":1626897907},{"id":"29508","value":0.7,"modified":1626897907},{"id":"29672","value":0,"modified":1626976875},{"id":"29676","value":0.7,"modified":1626976909},{"id":"30847","value":1,"modified":1626977335},{"id":"30855","value":1,"modified":1626977335},{"id":"32079","value":10.4,"modified":1626977341},{"id":"32151","value":10.4,"modified":1626977341},{"id":"32155","value":5.2,"modified":1626977341},{"id":"32361","value":1,"modified":1626977336},{"id":"32364","value":205,"modified":1626977336},{"id":"32367","value":26,"modified":1626977341},{"id":"32428","value":1,"modified":1626977335},{"id":"32938","value":0,"modified":1626976203},{"id":"32941","value":0,"modified":1626976203},{"id":"32944","value":0,"modified":1626976262}],"scenarios":[],"objects":[{"object_id":"4","keys":[{"fenetre":{"value":0,"cmds":[{"enable":"1","cmd":"#26463#","invert":"1"}]}},{"shutter":{"value":2,"cmds":[{"enable":"1","cmd":"#13288#","invert":"0"},{"enable":"1","cmd":"#14477#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#4628#","invert":"0"},{"enable":"1","cmd":"#4630# ","invert":"0"},{"enable":"1","cmd":"#4631#","invert":"0"},{"enable":"1","cmd":"#7700#","invert":"0"},{"enable":"1","cmd":"#16104#","invert":"0"}]}},{"temperature":{"value":23.4,"cmds":[{"enable":"1","cmd":"#28971#","invert":"0"},{"enable":"1","cmd":"#45#","invert":"0"},{"enable":"1","cmd":"#29098#","invert":"0"},{"enable":"1","cmd":"#25011#","invert":"0"}]}},{"light":{"value":0,"cmds":[{"enable":"1","cmd":"#21805#","invert":"0"},{"enable":"1","cmd":"#21359#","invert":"0"},{"enable":"1","cmd":"#9792#","invert":"0"},{"enable":"1","cmd":"#7265#","invert":"0"},{"enable":"1","cmd":"#21359#","invert":"0"}]}},{"humidity":{"value":85,"cmds":[{"enable":"1","cmd":"#13257#","invert":"0"},{"enable":"1","cmd":"#25014#","invert":"0"}]}},{"luminosity":{"value":431.5,"cmds":[{"enable":"1","cmd":"#29099#","invert":"0"},{"enable":"1","cmd":"#28972#","invert":"0"}]}},{"power":{"value":34.9,"cmds":[{"enable":"1","cmd":"#30659#","invert":"0"},{"enable":"1","cmd":"#29225#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"9","keys":[{"fenetre":{"value":4,"cmds":[{"enable":"1","cmd":"#26531#","invert":"0"},{"enable":"1","cmd":"#26528#","invert":"0"},{"enable":"1","cmd":"#26604#","invert":"0"},{"enable":"1","cmd":"#26610#","invert":"0"}]}},{"shutter":{"value":2,"cmds":[{"enable":"1","cmd":"#14457#","invert":"0"},{"enable":"1","cmd":"#14458#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#5213#","invert":"0"},{"enable":"1","cmd":"#5214#","invert":"0"},{"enable":"1","cmd":"#5215#","invert":"0"},{"enable":"1","cmd":"#5216#","invert":"0"}]}},{"temperature":{"value":28,"cmds":[{"enable":"1","cmd":"#9253#","invert":"0"},{"enable":"1","cmd":"#9264#","invert":"0"},{"enable":"1","cmd":"#9186#","invert":"0"}]}},{"light":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"1","keys":[{"fenetre":{"value":0,"cmds":[{"enable":"1","cmd":"#26354#","invert":"1"},{"enable":"1","cmd":"#26366#","invert":"1"},{"enable":"1","cmd":"#26360#","invert":"1"},{"enable":"1","cmd":"#26289#","invert":"1"},{"enable":"1","cmd":"#26351#","invert":"1"},{"enable":"1","cmd":"#26363#","invert":"1"}]}},{"shutter":{"value":5,"cmds":[{"enable":"1","cmd":"#14455#","invert":"0"},{"enable":"1","cmd":"#14461#","invert":"0"},{"enable":"1","cmd":"#18853#","invert":"0"},{"enable":"1","cmd":"#10189#","invert":"0"},{"enable":"1","cmd":"#14451#","invert":"0"}]}},{"motion":{"value":2,"cmds":[{"enable":"1","cmd":"#21325#","invert":"0"},{"enable":"1","cmd":"#4499#","invert":"0"},{"enable":"1","cmd":"#24177#","invert":"0"},{"enable":"1","cmd":"#5558#","invert":"0"},{"enable":"1","cmd":"#5488#","invert":"0"},{"enable":"1","cmd":"#4495#","invert":"0"},{"enable":"1","cmd":"#4493#","invert":"0"},{"enable":"1","cmd":"#5495#","invert":"0"}]}},{"temperature":{"value":24.4,"cmds":[{"enable":1,"cmd":"#2711#","invert":"0"},{"enable":1,"cmd":"#23796#","invert":"0"},{"enable":0,"cmd":"#27273#","invert":"0"},{"enable":1,"cmd":"#28653#","invert":"0"},{"enable":1,"cmd":"#28632#","invert":"0"},{"enable":0,"cmd":"#25006#","invert":"0"}]}},{"light":{"value":5,"cmds":[{"enable":"1","cmd":"#29672#","invert":"0"},{"enable":"1","cmd":"#32172#","invert":"0"},{"enable":"1","cmd":"#26091#","invert":"0"},{"enable":"1","cmd":"#25492#","invert":"0"},{"enable":"1","cmd":"#32361#","invert":"0"},{"enable":"1","cmd":"#32428#","invert":"0"},{"enable":"1","cmd":"#30847#","invert":"0"}]}},{"humidity":{"value":51,"cmds":[{"enable":"1","cmd":"#13449#","invert":"0"},{"enable":"1","cmd":"#25009#","invert":"0"}]}},{"luminosity":{"value":85.7,"cmds":[{"enable":"1","cmd":"#27274#","invert":"0"},{"enable":"1","cmd":"#28654#","invert":"0"},{"enable":"1","cmd":"#28633#","invert":"0"}]}},{"power":{"value":659.3,"cmds":[{"enable":"1","cmd":"#27701#","invert":"0"},{"enable":"1","cmd":"#30428#","invert":"0"},{"enable":"1","cmd":"#29297#","invert":"0"},{"enable":"1","cmd":"#29339#","invert":"0"},{"enable":"1","cmd":"#28443#","invert":"0"},{"enable":"1","cmd":"#29339#","invert":"0"},{"enable":"1","cmd":"#28453#","invert":"0"},{"enable":"1","cmd":"#29232#","invert":"0"},{"enable":"1","cmd":"#29346#","invert":"0"},{"enable":"1","cmd":"#32079#","invert":"0"},{"enable":"1","cmd":"#32367#","invert":"0"},{"enable":"1","cmd":"#32434#","invert":"0"},{"enable":"1","cmd":"#32151#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"21","keys":[{"fenetre":{"value":1,"cmds":[{"enable":"1","cmd":"#26204#","invert":"1"}]}},{"shutter":{"value":1,"cmds":[{"enable":"1","cmd":"#7711#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#26580#","invert":"0"}]}},{"temperature":{"value":25.3,"cmds":[{"enable":"1","cmd":"#3899#","invert":"0"},{"enable":0,"cmd":"#26333#","invert":"0"}]}},{"light":{"value":null,"cmds":[]}},{"humidity":{"value":70.9,"cmds":[{"enable":"1","cmd":"#13456#","invert":"0"},{"enable":"1","cmd":"#26334#","invert":"0"}]}},{"luminosity":{"value":222,"cmds":[{"enable":"1","cmd":"#26582#","invert":"0"}]}},{"power":{"value":0,"cmds":[{"enable":"1","cmd":"#30523#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"23","keys":[{"fenetre":{"value":2,"cmds":[{"enable":"1","cmd":"#26348#","invert":"1"},{"enable":"1","cmd":"#26357#","invert":"1"}]}},{"shutter":{"value":1,"cmds":[{"enable":"1","cmd":"#9214#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#28611#","invert":"0"}]}},{"temperature":{"value":25.9,"cmds":[{"enable":1,"cmd":"#26337#","invert":"0"},{"enable":1,"cmd":"#28613#","invert":"0"},{"enable":1,"cmd":"#2720#","invert":"0"}]}},{"light":{"value":0,"cmds":[{"enable":"1","cmd":"#25988#","invert":"0"}]}},{"humidity":{"value":68.6,"cmds":[{"enable":"1","cmd":"#13385#","invert":"0"},{"enable":"1","cmd":"#26338#","invert":"0"}]}},{"luminosity":{"value":27,"cmds":[{"enable":"1","cmd":"#28614#","invert":"0"}]}},{"power":{"value":1.7,"cmds":[{"enable":"1","cmd":"#28426#","invert":"0"},{"enable":"1","cmd":"#29232#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"fenetre":{"value":7}},{"shutter":{"value":9}},{"motion":{"value":2}},{"temperature":{"value":24.4}},{"light":{"value":5}},{"humidity":{"value":51}},{"luminosity":{"value":85.7}},{"power":{"value":694.3}},{"portecomm":{"value":null}},{"security":{"value":null}}]}]}}
0003|[2021-07-22 20:17:21][DEBUG] : HTTP API received {"method":"CONNECT","params":{"deviceId":"037f4971437433e8","deviceName":"HUAWEI P30 Pro","appVersion":"0.21.3","pluginRequire":"0.21.3","token":"edXMi9eDQFa1NwZLyCYzQW:APA91bFWAuDL8N7TPXTS897Gw6Cf1tYTPPXk4MUwTnIu4no38cMRvTiVkmF1xkVeuz03h9U17nMqrScgT2BhE8nfM6kRjZVbXZt5J47_n5fU8rkDoXqL-COZL0qmxad6aWlaMfuI0xnX","platformOs":"android","apiKey":"5e39ca8c38e27b504b6a80a595c935d5"},"jsonrpc":"2.0","id":1626977841032}
0004|[2021-07-22 20:17:21][DEBUG] : send {"type":"WELCOME","payload":{"pluginVersion":"0.21.3","useWs":"0","userHash":"8aQXJDp2SygkQBQ8PPZcvYFPds25TqTj","userId":"1","userProfil":"admin","configVersion":1138,"scenariosEnabled":true,"webviewEnabled":true,"editEnabled":true,"pluginConfig":{"httpUrl":"https:\/\/georgein.dns2.jeedom.com\/","internalHttpUrl":"http:\/\/192.168.2.196","wsAddress":"ws:\/\/192.168.2.196","internalWsAddress":"ws:\/\/192.168.2.196","pluginJeedomVersion":"2021-07-22 18:37:50"},"cmdInfo":[{"id":"3860","value":27.1,"modified":1626977143},{"id":"4436","value":0,"modified":1626953347},{"id":"4648","value":0,"modified":1626250594},{"id":"5201","value":0,"modified":1626245191},{"id":"5411","value":2,"modified":1626961959},{"id":"5496","value":2,"modified":1626977837},{"id":"6276","value":0,"modified":1626960667},{"id":"6648","value":0,"modified":1626240885},{"id":"6680","value":1,"modified":1626977409},{"id":"6693","value":1,"modified":1626977038},{"id":"6916","value":0,"modified":1626927161},{"id":"6917","value":23.4,"modified":1626977733},{"id":"7265","value":0,"modified":1626897903},{"id":"7289","value":"*** 20 h 17 mn ***<br>Info Piscine Ensu\u00e8se : Le Phi est trop bas, veuillez ajouter du Phi pluse ! , La temp\u00e9rature de l'eau est de 27.1 \u00b0C.<br>","modified":1626977822},{"id":"7711","value":99,"modified":1626245115},{"id":"7893","value":80,"modified":1626977335},{"id":"7912","value":0,"modified":1626897902},{"id":"9136","value":0,"modified":1626196021},{"id":"9137","value":25.4,"modified":1626974807},{"id":"9138","value":"<font color='Yellow'>Mode Confort (18 \u00b0)<\/font><br><br>Confort :","modified":1626953403},{"id":"9152","value":0,"modified":1626189601},{"id":"9153","value":25.9,"modified":1626976902},{"id":"9154","value":"<font color='Yellow'>Mode Confort (21 \u00b0)<\/font><br><br>Confort :","modified":1626953403},{"id":"9186","value":28,"modified":1626976373},{"id":"9214","value":99,"modified":1626244222},{"id":"9253","value":27.8,"modified":1626976899},{"id":"9264","value":28.3,"modified":1626973335},{"id":"9287","value":0,"modified":1626259628},{"id":"9681","value":1,"modified":1626977629},{"id":"9792","value":0,"modified":1626897903},{"id":"9910","value":1,"modified":1626977336},{"id":"10108","value":1,"modified":1626976430},{"id":"10189","value":99,"modified":1626240925},{"id":"10275","value":99,"modified":1626252544},{"id":"10279","value":99,"modified":1626240963},{"id":"10280","value":99,"modified":1626241208},{"id":"10281","value":99,"modified":1626962434},{"id":"10282","value":99,"modified":1626240976},{"id":"10284","value":199,"modified":1626953938},{"id":"10285","value":99,"modified":1626244222},{"id":"10286","value":99,"modified":1626253109},{"id":"10287","value":99,"modified":1626253096},{"id":"10551","value":0,"modified":1626953643},{"id":"12107","value":25.9,"modified":1626976902},{"id":"12109","value":24.4,"modified":1626977648},{"id":"12111","value":23.4,"modified":1626977733},{"id":"14286","value":68.6,"modified":1626977387},{"id":"14287","value":51,"modified":1626977733},{"id":"14451","value":99,"modified":1626250556},{"id":"14455","value":99,"modified":1626240976},{"id":"14457","value":99,"modified":1626253096},{"id":"14458","value":99,"modified":1626253109},{"id":"14461","value":99,"modified":1626240963},{"id":"16117","value":0,"modified":1626213608},{"id":"18853","value":99,"modified":1626240939},{"id":"18947","value":70.9,"modified":1626976651},{"id":"21359","value":0,"modified":1626897787},{"id":"21805","value":0,"modified":1626897926},{"id":"24227","value":23,"modified":1622220689},{"id":"24229","value":18,"modified":1613415902},{"id":"24231","value":21,"modified":1613415222},{"id":"24498","value":"43.3507038,5.2083872,195","modified":1626962903},{"id":"24579","value":"43.3507078,5.2083644,193.8","modified":1626974373},{"id":"25480","value":1,"modified":1626977335},{"id":"25492","value":1,"modified":1626977335},{"id":"25988","value":0,"modified":1626976203},{"id":"25991","value":254,"modified":1626244498},{"id":"26053","value":0,"modified":1626956764},{"id":"26091","value":1,"modified":1626977335},{"id":"26094","value":205,"modified":1626977335},{"id":"26341","value":-16.82,"modified":1626975223},{"id":"26380","value":10.44,"modified":1626977490},{"id":"26463","value":1,"modified":1626976097},{"id":"26580","value":0,"modified":1626976022},{"id":"28412","value":0,"modified":1626897926},{"id":"28417","value":0.5,"modified":1626897933},{"id":"28611","value":0,"modified":1626975994},{"id":"28614","value":27,"modified":1626977684},{"id":"29415","value":0.7,"modified":1626897907},{"id":"29508","value":0.7,"modified":1626897907},{"id":"29672","value":0,"modified":1626976875},{"id":"29676","value":0.7,"modified":1626976909},{"id":"30847","value":1,"modified":1626977335},{"id":"30855","value":1,"modified":1626977335},{"id":"32079","value":10.4,"modified":1626977341},{"id":"32151","value":10.4,"modified":1626977341},{"id":"32155","value":5.2,"modified":1626977341},{"id":"32361","value":1,"modified":1626977336},{"id":"32364","value":205,"modified":1626977336},{"id":"32367","value":26,"modified":1626977341},{"id":"32428","value":1,"modified":1626977335},{"id":"32938","value":0,"modified":1626976203},{"id":"32941","value":0,"modified":1626976203},{"id":"32944","value":0,"modified":1626976262}],"scInfo":[],"objInfo":[{"object_id":"4","keys":[{"fenetre":{"value":0,"cmds":[{"enable":"1","cmd":"#26463#","invert":"1"}]}},{"shutter":{"value":2,"cmds":[{"enable":"1","cmd":"#13288#","invert":"0"},{"enable":"1","cmd":"#14477#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#4628#","invert":"0"},{"enable":"1","cmd":"#4630# ","invert":"0"},{"enable":"1","cmd":"#4631#","invert":"0"},{"enable":"1","cmd":"#7700#","invert":"0"},{"enable":"1","cmd":"#16104#","invert":"0"}]}},{"temperature":{"value":23.4,"cmds":[{"enable":"1","cmd":"#28971#","invert":"0"},{"enable":"1","cmd":"#45#","invert":"0"},{"enable":"1","cmd":"#29098#","invert":"0"},{"enable":"1","cmd":"#25011#","invert":"0"}]}},{"light":{"value":0,"cmds":[{"enable":"1","cmd":"#21805#","invert":"0"},{"enable":"1","cmd":"#21359#","invert":"0"},{"enable":"1","cmd":"#9792#","invert":"0"},{"enable":"1","cmd":"#7265#","invert":"0"},{"enable":"1","cmd":"#21359#","invert":"0"}]}},{"humidity":{"value":85,"cmds":[{"enable":"1","cmd":"#13257#","invert":"0"},{"enable":"1","cmd":"#25014#","invert":"0"}]}},{"luminosity":{"value":431.5,"cmds":[{"enable":"1","cmd":"#29099#","invert":"0"},{"enable":"1","cmd":"#28972#","invert":"0"}]}},{"power":{"value":34.9,"cmds":[{"enable":"1","cmd":"#30659#","invert":"0"},{"enable":"1","cmd":"#29225#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"9","keys":[{"fenetre":{"value":4,"cmds":[{"enable":"1","cmd":"#26531#","invert":"0"},{"enable":"1","cmd":"#26528#","invert":"0"},{"enable":"1","cmd":"#26604#","invert":"0"},{"enable":"1","cmd":"#26610#","invert":"0"}]}},{"shutter":{"value":2,"cmds":[{"enable":"1","cmd":"#14457#","invert":"0"},{"enable":"1","cmd":"#14458#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#5213#","invert":"0"},{"enable":"1","cmd":"#5214#","invert":"0"},{"enable":"1","cmd":"#5215#","invert":"0"},{"enable":"1","cmd":"#5216#","invert":"0"}]}},{"temperature":{"value":28,"cmds":[{"enable":"1","cmd":"#9253#","invert":"0"},{"enable":"1","cmd":"#9264#","invert":"0"},{"enable":"1","cmd":"#9186#","invert":"0"}]}},{"light":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"1","keys":[{"fenetre":{"value":0,"cmds":[{"enable":"1","cmd":"#26354#","invert":"1"},{"enable":"1","cmd":"#26366#","invert":"1"},{"enable":"1","cmd":"#26360#","invert":"1"},{"enable":"1","cmd":"#26289#","invert":"1"},{"enable":"1","cmd":"#26351#","invert":"1"},{"enable":"1","cmd":"#26363#","invert":"1"}]}},{"shutter":{"value":5,"cmds":[{"enable":"1","cmd":"#14455#","invert":"0"},{"enable":"1","cmd":"#14461#","invert":"0"},{"enable":"1","cmd":"#18853#","invert":"0"},{"enable":"1","cmd":"#10189#","invert":"0"},{"enable":"1","cmd":"#14451#","invert":"0"}]}},{"motion":{"value":2,"cmds":[{"enable":"1","cmd":"#21325#","invert":"0"},{"enable":"1","cmd":"#4499#","invert":"0"},{"enable":"1","cmd":"#24177#","invert":"0"},{"enable":"1","cmd":"#5558#","invert":"0"},{"enable":"1","cmd":"#5488#","invert":"0"},{"enable":"1","cmd":"#4495#","invert":"0"},{"enable":"1","cmd":"#4493#","invert":"0"},{"enable":"1","cmd":"#5495#","invert":"0"}]}},{"temperature":{"value":24.4,"cmds":[{"enable":1,"cmd":"#2711#","invert":"0"},{"enable":1,"cmd":"#23796#","invert":"0"},{"enable":0,"cmd":"#27273#","invert":"0"},{"enable":1,"cmd":"#28653#","invert":"0"},{"enable":1,"cmd":"#28632#","invert":"0"},{"enable":0,"cmd":"#25006#","invert":"0"}]}},{"light":{"value":5,"cmds":[{"enable":"1","cmd":"#29672#","invert":"0"},{"enable":"1","cmd":"#32172#","invert":"0"},{"enable":"1","cmd":"#26091#","invert":"0"},{"enable":"1","cmd":"#25492#","invert":"0"},{"enable":"1","cmd":"#32361#","invert":"0"},{"enable":"1","cmd":"#32428#","invert":"0"},{"enable":"1","cmd":"#30847#","invert":"0"}]}},{"humidity":{"value":51,"cmds":[{"enable":"1","cmd":"#13449#","invert":"0"},{"enable":"1","cmd":"#25009#","invert":"0"}]}},{"luminosity":{"value":85.7,"cmds":[{"enable":"1","cmd":"#27274#","invert":"0"},{"enable":"1","cmd":"#28654#","invert":"0"},{"enable":"1","cmd":"#28633#","invert":"0"}]}},{"power":{"value":659.3,"cmds":[{"enable":"1","cmd":"#27701#","invert":"0"},{"enable":"1","cmd":"#30428#","invert":"0"},{"enable":"1","cmd":"#29297#","invert":"0"},{"enable":"1","cmd":"#29339#","invert":"0"},{"enable":"1","cmd":"#28443#","invert":"0"},{"enable":"1","cmd":"#29339#","invert":"0"},{"enable":"1","cmd":"#28453#","invert":"0"},{"enable":"1","cmd":"#29232#","invert":"0"},{"enable":"1","cmd":"#29346#","invert":"0"},{"enable":"1","cmd":"#32079#","invert":"0"},{"enable":"1","cmd":"#32367#","invert":"0"},{"enable":"1","cmd":"#32434#","invert":"0"},{"enable":"1","cmd":"#32151#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"21","keys":[{"fenetre":{"value":1,"cmds":[{"enable":"1","cmd":"#26204#","invert":"1"}]}},{"shutter":{"value":1,"cmds":[{"enable":"1","cmd":"#7711#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#26580#","invert":"0"}]}},{"temperature":{"value":25.3,"cmds":[{"enable":"1","cmd":"#3899#","invert":"0"},{"enable":0,"cmd":"#26333#","invert":"0"}]}},{"light":{"value":null,"cmds":[]}},{"humidity":{"value":70.9,"cmds":[{"enable":"1","cmd":"#13456#","invert":"0"},{"enable":"1","cmd":"#26334#","invert":"0"}]}},{"luminosity":{"value":222,"cmds":[{"enable":"1","cmd":"#26582#","invert":"0"}]}},{"power":{"value":0,"cmds":[{"enable":"1","cmd":"#30523#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"23","keys":[{"fenetre":{"value":2,"cmds":[{"enable":"1","cmd":"#26348#","invert":"1"},{"enable":"1","cmd":"#26357#","invert":"1"}]}},{"shutter":{"value":1,"cmds":[{"enable":"1","cmd":"#9214#","invert":"0"}]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#28611#","invert":"0"}]}},{"temperature":{"value":25.9,"cmds":[{"enable":1,"cmd":"#26337#","invert":"0"},{"enable":1,"cmd":"#28613#","invert":"0"},{"enable":1,"cmd":"#2720#","invert":"0"}]}},{"light":{"value":0,"cmds":[{"enable":"1","cmd":"#25988#","invert":"0"}]}},{"humidity":{"value":68.6,"cmds":[{"enable":"1","cmd":"#13385#","invert":"0"},{"enable":"1","cmd":"#26338#","invert":"0"}]}},{"luminosity":{"value":27,"cmds":[{"enable":"1","cmd":"#28614#","invert":"0"}]}},{"power":{"value":1.7,"cmds":[{"enable":"1","cmd":"#28426#","invert":"0"},{"enable":"1","cmd":"#29232#","invert":"0"}]}},{"portecomm":{"value":null,"cmds":[]}},{"security":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"fenetre":{"value":7}},{"shutter":{"value":9}},{"motion":{"value":2}},{"temperature":{"value":24.4}},{"light":{"value":5}},{"humidity":{"value":51}},{"luminosity":{"value":85.7}},{"power":{"value":694.3}},{"portecomm":{"value":null}},{"security":{"value":null}}]}]}}
0005|[2021-07-22 20:17:21][DEBUG] : eventServer init client #616
0006|[2021-07-22 20:17:21][DEBUG] : value of listValue "0|Max;1|Light;2|Bureau;3|Cin\u00e9ma;4|Tamis\u00e9"
0007|[2021-07-22 20:17:21][DEBUG] : final choices list => [{"id":"0","value":"Max"},{"id":"1","value":"Light"},{"id":"2","value":"Bureau"},{"id":"3","value":"Cin\u00e9ma"},{"id":"4","value":"Tamis\u00e9"}]
0008|[2021-07-22 20:17:37][DEBUG] : eventServer connexion closed for client #616
Sans JC on se sent orphelin
