[Jeedom Connect] Version 0.21.3 Beta
Bonjour, après une mise à jour ce matin dans Jeedom et donc mis à jour de l’appli 0.21.3, plus de connexion aussi bien QR code que connexion classique avec identifiant.
Avec le QR code j,ai tout de suite connexion impossible …
Avec les identifiants le symbole se connecter tourne sans arrêt …
Doit-on faire une manip une manip spéciale à faire ??
2021-07-23 10:14:14][DEBUG] : eventServer init client #65
[2021-07-23 10:14:14][DEBUG] : HTTP API received {"method":"GET_JEEDOM_DATA","jsonrpc":"2.0","id":1627028054053,"params":{"apiKey":"b22109ee942892bc7e9c7f62197927ab"}}
[2021-07-23 10:14:28][DEBUG] : HTTP API received {"method":"GET_INFO","jsonrpc":"2.0","id":1627028068833,"params":{"apiKey":"b22109ee942892bc7e9c7f62197927ab"}}
[2021-07-23 10:14:28][DEBUG] : HTTP API received {"method":"GET_CONFIG","jsonrpc":"2.0","id":1627028068832,"params":{"apiKey":"b22109ee942892bc7e9c7f62197927ab"}}
[2021-07-23 10:14:28][INFO] : Send info {"type":"SET_INFO","payload":{"cmds":[{"id":"335","value":"Brigitte","modified":1626997503},{"id":"622","value":"","modified":false},{"id":"965","value":0,"modified":1626975476},{"id":"1276","value":23,"modified":1627027159},{"id":"1561","value":29.6,"modified":1627027648},{"id":"1729","value":24.2,"modified":1627026964},{"id":"1737","value":-21,"modified":1627027428},{"id":"1748","value":23.9,"modified":1627023018},{"id":"1905","value":0,"modified":1627026375},{"id":"1992","value":1,"modified":1616948990},{"id":"1996","value":0,"modified":1622731729},{"id":"1997","value":0,"modified":1622731687},{"id":"2045","value":1,"modified":1616949010},{"id":"2049","value":0,"modified":1623945255},{"id":"2050","value":0,"modified":1623945255},{"id":"2059","value":0,"modified":1627026375},{"id":"2889","value":24.3,"modified":1627028003},{"id":"3191","value":0,"modified":1619634048},{"id":"3202","value":0,"modified":1627020062},{"id":"5281","value":1,"modified":1624723530},{"id":"5396","value":"","modified":false},{"id":"5589","value":24,"modified":1627026877},{"id":"5593","value":23.5,"modified":1627027694},{"id":"5607","value":21.9,"modified":1627025958},{"id":"5612","value":0,"modified":1625130451},{"id":"5792","value":22.7,"modified":1627018406},{"id":"6088","value":0,"modified":1626987134},{"id":"6688","value":20.8,"modified":1627027307},{"id":"6733","value":22.4,"modified":1627022072},{"id":"6741","value":24.3,"modified":1627024873},{"id":"7321","value":0,"modified":1626969809},{"id":"8085","value":2211,"modified":1627028039},{"id":"8086","value":7807,"modified":1627028065},{"id":"8267","value":"6h01","modified":1627002009},{"id":"8268","value":"21h40","modified":1627002009},{"id":"10602","value":1,"modified":1626982923},{"id":"10749","value":250,"modified":1626982924},{"id":"10750","value":1,"modified":1626982923},{"id":"11435","value":0,"modified":1622096606},{"id":"11436","value":22.4,"modified":1627028039},{"id":"11445","value":20,"modified":1627012802},{"id":"11461","value":20.8,"modified":1627027307},{"id":"11692","value":22.7,"modified":1627028050},{"id":"11960","value":"NORMAL","modified":1627012802},{"id":"12141","value":100,"modified":1627012134},{"id":"12142","value":100,"modified":1627020363},{"id":"12143","value":0,"modified":1626978654},{"id":"12144","value":100,"modified":1627020363},{"id":"12145","value":100,"modified":1627012135},{"id":"12146","value":0,"modified":1626991382},{"id":"12147","value":8,"modified":1627022803},{"id":"12209","value":"50.1751202,3.8262044,183","modified":1626982237},{"id":"12285","value":0,"modified":1627022853},{"id":"12286","value":14,"modified":1621025750},{"id":"12287","value":"#7400ff","modified":1625424296},{"id":"12288","value":3377,"modified":1625424298},{"id":"12291","value":21.1,"modified":1627025856},{"id":"12332","value":"Verrouill\u00e9e","modified":1626790645},{"id":"12359","value":0,"modified":1625067793},{"id":"12594","value":1,"modified":1623738989},{"id":"12660","value":0,"modified":1626954707},{"id":"12839","value":0,"modified":1626966905},{"id":"13034","value":"jour","modified":1627013044},{"id":"13256","value":21.9,"modified":1627027301},{"id":"13419","value":0,"modified":1622721403},{"id":"13423","value":0,"modified":1621531267},{"id":"13424","value":0,"modified":1621531267},{"id":"13474","value":0,"modified":1626541185},{"id":"13475","value":"Aucune erreur","modified":1626541185},{"id":"13477","value":"Sur la base","modified":1626971345},{"id":"13766","value":10.8,"modified":1627026001},{"id":"13801","value":7,"modified":1627028064},{"id":"13950","value":0,"modified":1626472862},{"id":"14038","value":0,"modified":1626645661},{"id":"14039","value":106.1,"modified":1626400086},{"id":"14040","value":223.8,"modified":1626400086},{"id":"14042","value":19,"modified":1627027238},{"id":"14047","value":"2140","modified":1626982921},{"id":"14048","value":601,"modified":1627012741},{"id":"14049","value":16,"modified":1627025426},{"id":"14050","value":23.4,"modified":1627025426},{"id":"14051","value":"Partiellement nuageux","modified":1627025426},{"id":"14052","value":802,"modified":1627025426},{"id":"14522","value":0,"modified":1627027444},{"id":"14556","value":0,"modified":1627027563},{"id":"14708","value":0,"modified":1626978003},{"id":"15089","value":1,"modified":1626887703},{"id":"15090","value":1,"modified":1626959403},{"id":"15091","value":0,"modified":1626985803},{"id":"15099","value":1,"modified":1627020603},{"id":"15100","value":1,"modified":1626972603},{"id":"15103","value":0,"modified":1626901503}],"scenarios":[],"objects":[{"object_id":"1","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"2","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"3","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#46#","invert":"0"}]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"5","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"21","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"15","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"security":{"value":null}},{"motion":{"value":0}},{"door":{"value":null}},{"windows":{"value":null}},{"shutter":{"value":null}},{"light":{"value":null}},{"outlet":{"value":null}},{"temperature":{"value":null}},{"humidity":{"value":null}},{"luminosity":{"value":null}},{"power":{"value":null}},{"presence":{"value":2}}]}]}}
[2021-07-23 10:14:31][DEBUG] : eventServer connexion closed for client #65
[2021-07-23 10:14:40][DEBUG] : HTTP API received {"method":"SET_BATTERY","params":{"level":44,"apiKey":"b22109ee942892bc7e9c7f62197927ab"},"jsonrpc":"2.0","id":1627028080541}
[2021-07-23 10:14:45][DEBUG] : HTTP API received {"method":"CONNECT","params":{"deviceId":"e6afca87817e2c6a","deviceName":"Redmi Note 7","appVersion":"0.21.3","pluginRequire":"0.21.3","token":"dnCJXk3LSHmRHxiUejiWfs:APA91bF1Dyuf0NQWqr39UXzpYSKW9zapq4lvoPY0hwxW34hwqIefvyYGmyU5WuR4Gn4l1Pb39lqtmelQkKH18IdQRGJvL-WK9ANLlpoAmX2iWbNcPmupiUGvap4lGBsttn92atHw3ouE","platformOs":"android","apiKey":"b22109ee942892bc7e9c7f62197927ab"},"jsonrpc":"2.0","id":1627028085247}
[2021-07-23 10:14:45][DEBUG] : send {"type":"WELCOME","payload":{"pluginVersion":"0.21.3","useWs":"0","userHash":"EZSKiPtB7nwrsTrRiXIAjSHKXmlQNYuj","userId":"1","userProfil":"admin","configVersion":377,"scenariosEnabled":true,"webviewEnabled":true,"editEnabled":true,"pluginConfig":{"httpUrl":"https:\/\/6c8a1e3a.dns2.jeedom.com","internalHttpUrl":"http:\/\/192.168.0.27","wsAddress":"ws:\/\/:8090","internalWsAddress":"ws:\/\/192.168.0.27:8090","pluginJeedomVersion":"2021-07-22 18:37:50"},"cmdInfo":[{"id":"335","value":"Brigitte","modified":1626997503},{"id":"622","value":"","modified":false},{"id":"965","value":0,"modified":1626975476},{"id":"1276","value":23,"modified":1627027159},{"id":"1561","value":29.6,"modified":1627027648},{"id":"1729","value":24.2,"modified":1627026964},{"id":"1737","value":-21,"modified":1627027428},{"id":"1748","value":23.9,"modified":1627023018},{"id":"1905","value":1,"modified":1627028076},{"id":"1992","value":1,"modified":1616948990},{"id":"1996","value":0,"modified":1622731729},{"id":"1997","value":0,"modified":1622731687},{"id":"2045","value":1,"modified":1616949010},{"id":"2049","value":0,"modified":1623945255},{"id":"2050","value":0,"modified":1623945255},{"id":"2059","value":1,"modified":1627028076},{"id":"2889","value":24.3,"modified":1627028003},{"id":"3191","value":0,"modified":1619634048},{"id":"3202","value":0,"modified":1627020062},{"id":"5281","value":1,"modified":1624723530},{"id":"5396","value":"","modified":false},{"id":"5589","value":24,"modified":1627026877},{"id":"5593","value":23.5,"modified":1627027694},{"id":"5607","value":21.9,"modified":1627025958},{"id":"5612","value":0,"modified":1625130451},{"id":"5792","value":22.7,"modified":1627018406},{"id":"6088","value":0,"modified":1626987134},{"id":"6688","value":20.8,"modified":1627027307},{"id":"6733","value":22.4,"modified":1627022072},{"id":"6741","value":24.3,"modified":1627024873},{"id":"7321","value":0,"modified":1626969809},{"id":"8085","value":2213,"modified":1627028069},{"id":"8086","value":7807,"modified":1627028065},{"id":"8267","value":"6h01","modified":1627002009},{"id":"8268","value":"21h40","modified":1627002009},{"id":"10602","value":1,"modified":1626982923},{"id":"10749","value":250,"modified":1626982924},{"id":"10750","value":1,"modified":1626982923},{"id":"11435","value":0,"modified":1622096606},{"id":"11436","value":22.4,"modified":1627028039},{"id":"11445","value":20,"modified":1627012802},{"id":"11461","value":20.8,"modified":1627027307},{"id":"11692","value":22.7,"modified":1627028050},{"id":"11960","value":"NORMAL","modified":1627012802},{"id":"12141","value":100,"modified":1627012134},{"id":"12142","value":100,"modified":1627020363},{"id":"12143","value":0,"modified":1626978654},{"id":"12144","value":100,"modified":1627020363},{"id":"12145","value":100,"modified":1627012135},{"id":"12146","value":0,"modified":1626991382},{"id":"12147","value":8,"modified":1627022803},{"id":"12209","value":"50.1751202,3.8262044,183","modified":1626982237},{"id":"12285","value":0,"modified":1627022853},{"id":"12286","value":14,"modified":1621025750},{"id":"12287","value":"#7400ff","modified":1625424296},{"id":"12288","value":3377,"modified":1625424298},{"id":"12291","value":21.1,"modified":1627025856},{"id":"12332","value":"Verrouill\u00e9e","modified":1626790645},{"id":"12359","value":0,"modified":1625067793},{"id":"12594","value":1,"modified":1623738989},{"id":"12660","value":0,"modified":1626954707},{"id":"12839","value":0,"modified":1626966905},{"id":"13034","value":"jour","modified":1627013044},{"id":"13256","value":21.9,"modified":1627027301},{"id":"13419","value":0,"modified":1622721403},{"id":"13423","value":0,"modified":1621531267},{"id":"13424","value":0,"modified":1621531267},{"id":"13474","value":0,"modified":1626541185},{"id":"13475","value":"Aucune erreur","modified":1626541185},{"id":"13477","value":"Sur la base","modified":1626971345},{"id":"13766","value":10.8,"modified":1627026001},{"id":"13801","value":6,"modified":1627028074},{"id":"13950","value":0,"modified":1626472862},{"id":"14038","value":0,"modified":1626645661},{"id":"14039","value":106.1,"modified":1626400086},{"id":"14040","value":223.8,"modified":1626400086},{"id":"14042","value":19,"modified":1627027238},{"id":"14047","value":"2140","modified":1626982921},{"id":"14048","value":601,"modified":1627012741},{"id":"14049","value":16,"modified":1627025426},{"id":"14050","value":23.4,"modified":1627025426},{"id":"14051","value":"Partiellement nuageux","modified":1627025426},{"id":"14052","value":802,"modified":1627025426},{"id":"14522","value":0,"modified":1627027444},{"id":"14556","value":0,"modified":1627027563},{"id":"14708","value":0,"modified":1626978003},{"id":"15089","value":1,"modified":1626887703},{"id":"15090","value":1,"modified":1626959403},{"id":"15091","value":0,"modified":1626985803},{"id":"15099","value":1,"modified":1627020603},{"id":"15100","value":1,"modified":1626972603},{"id":"15103","value":0,"modified":1626901503}],"scInfo":[],"objInfo":[{"object_id":"1","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"2","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"3","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#46#","invert":"0"}]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"5","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"21","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"15","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"security":{"value":null}},{"motion":{"value":0}},{"door":{"value":null}},{"windows":{"value":null}},{"shutter":{"value":null}},{"light":{"value":null}},{"outlet":{"value":null}},{"temperature":{"value":null}},{"humidity":{"value":null}},{"luminosity":{"value":null}},{"power":{"value":null}},{"presence":{"value":2}}]}]}}
[2021-07-23 10:14:45][DEBUG] : eventServer init client #281
[2021-07-23 10:14:46][DEBUG] : HTTP API received {"method":"GET_JEEDOM_DATA","jsonrpc":"2.0","id":1627028085709,"params":{"apiKey":"b22109ee942892bc7e9c7f62197927ab"}}
[2021-07-23 10:14:53][DEBUG] : ¤¤¤¤¤ only send the config file without enrichment for apikey b22109ee942892bc7e9c7f62197927ab
[2021-07-23 10:15:00][DEBUG] : eventServer connexion closed for client #281
J’ai le même soucis, je n’arrive plus aà me connecter .
[2021-07-23 10:25:28][DEBUG] : HTTP API received {"method":"CONNECT","params":{"deviceId":"e6afca87817e2c6a","deviceName":"Redmi Note 7","appVersion":"0.21.3","pluginRequire":"0.21.3","token":"dnCJXk3LSHmRHxiUejiWfs:APA91bF1Dyuf0NQWqr39UXzpYSKW9zapq4lvoPY0hwxW34hwqIefvyYGmyU5WuR4Gn4l1Pb39lqtmelQkKH18IdQRGJvL-WK9ANLlpoAmX2iWbNcPmupiUGvap4lGBsttn92atHw3ouE","platformOs":"android","apiKey":"b22109ee942892bc7e9c7f62197927ab"},"jsonrpc":"2.0","id":1627028728698}
[2021-07-23 10:25:28][DEBUG] : send {"type":"WELCOME","payload":{"pluginVersion":"0.21.3","useWs":"0","userHash":"EZSKiPtB7nwrsTrRiXIAjSHKXmlQNYuj","userId":"1","userProfil":"admin","configVersion":379,"scenariosEnabled":true,"webviewEnabled":true,"editEnabled":true,"pluginConfig":{"httpUrl":"https:\/\/6c8a1e3a.dns2.jeedom.com","internalHttpUrl":"http:\/\/192.168.0.27","wsAddress":"ws:\/\/:8090","internalWsAddress":"ws:\/\/192.168.0.27:8090","pluginJeedomVersion":"2021-07-22 18:37:50"},"cmdInfo":[{"id":"335","value":"Brigitte","modified":1626997503},{"id":"622","value":"","modified":false},{"id":"965","value":0,"modified":1626975476},{"id":"1276","value":22.9,"modified":1627028185},{"id":"1561","value":29.1,"modified":1627028723},{"id":"1729","value":24.3,"modified":1627028446},{"id":"1737","value":-20,"modified":1627028341},{"id":"1748","value":23.9,"modified":1627023018},{"id":"1905","value":0,"modified":1627028226},{"id":"1992","value":1,"modified":1616948990},{"id":"1996","value":0,"modified":1622731729},{"id":"1997","value":0,"modified":1622731687},{"id":"2045","value":1,"modified":1616949010},{"id":"2049","value":0,"modified":1623945255},{"id":"2050","value":0,"modified":1623945255},{"id":"2059","value":0,"modified":1627028226},{"id":"2889","value":24.5,"modified":1627028714},{"id":"3191","value":0,"modified":1619634048},{"id":"3202","value":0,"modified":1627020062},{"id":"5281","value":1,"modified":1624723530},{"id":"5396","value":"","modified":false},{"id":"5589","value":24,"modified":1627026877},{"id":"5593","value":23.5,"modified":1627027694},{"id":"5607","value":22.1,"modified":1627028658},{"id":"5612","value":0,"modified":1625130451},{"id":"5792","value":22.7,"modified":1627018406},{"id":"6088","value":0,"modified":1627028124},{"id":"6688","value":21.8,"modified":1627028698},{"id":"6733","value":22.4,"modified":1627022072},{"id":"6741","value":24.4,"modified":1627028678},{"id":"7321","value":1,"modified":1627028322},{"id":"8085","value":2252,"modified":1627028707},{"id":"8086","value":7889,"modified":1627028722},{"id":"8267","value":"6h01","modified":1627002009},{"id":"8268","value":"21h40","modified":1627002009},{"id":"10602","value":1,"modified":1626982923},{"id":"10749","value":250,"modified":1626982924},{"id":"10750","value":1,"modified":1626982923},{"id":"11435","value":0,"modified":1622096606},{"id":"11436","value":22.3,"modified":1627028719},{"id":"11445","value":20,"modified":1627012802},{"id":"11461","value":21.8,"modified":1627028698},{"id":"11692","value":22.7,"modified":1627028050},{"id":"11960","value":"NORMAL","modified":1627012802},{"id":"12141","value":100,"modified":1627012134},{"id":"12142","value":100,"modified":1627020363},{"id":"12143","value":0,"modified":1626978654},{"id":"12144","value":100,"modified":1627020363},{"id":"12145","value":100,"modified":1627012135},{"id":"12146","value":0,"modified":1626991382},{"id":"12147","value":8,"modified":1627022803},{"id":"12209","value":"50.1751202,3.8262044,183","modified":1626982237},{"id":"12285","value":0,"modified":1627022853},{"id":"12286","value":14,"modified":1621025750},{"id":"12287","value":"#7400ff","modified":1625424296},{"id":"12288","value":3377,"modified":1625424298},{"id":"12291","value":21,"modified":1627028350},{"id":"12332","value":"Verrouill\u00e9e","modified":1626790645},{"id":"12359","value":0,"modified":1625067793},{"id":"12594","value":1,"modified":1623738989},{"id":"12660","value":0,"modified":1626954707},{"id":"12839","value":0,"modified":1626966905},{"id":"13034","value":"jour","modified":1627013044},{"id":"13256","value":21.9,"modified":1627027301},{"id":"13419","value":0,"modified":1622721403},{"id":"13423","value":0,"modified":1621531267},{"id":"13424","value":0,"modified":1621531267},{"id":"13474","value":0,"modified":1626541185},{"id":"13475","value":"Aucune erreur","modified":1626541185},{"id":"13477","value":"Sur la base","modified":1626971345},{"id":"13766","value":10.8,"modified":1627026001},{"id":"13801","value":9,"modified":1627028727},{"id":"13950","value":0,"modified":1626472862},{"id":"14038","value":0,"modified":1626645661},{"id":"14039","value":106.1,"modified":1626400086},{"id":"14040","value":223.8,"modified":1626400086},{"id":"14042","value":19,"modified":1627027238},{"id":"14047","value":"2140","modified":1626982921},{"id":"14048","value":601,"modified":1627012741},{"id":"14049","value":16,"modified":1627025426},{"id":"14050","value":23.4,"modified":1627025426},{"id":"14051","value":"Partiellement nuageux","modified":1627025426},{"id":"14052","value":802,"modified":1627025426},{"id":"14522","value":0,"modified":1627028523},{"id":"14556","value":1,"modified":1627028704},{"id":"14708","value":0,"modified":1626978003},{"id":"15089","value":1,"modified":1626887703},{"id":"15090","value":1,"modified":1626959403},{"id":"15091","value":0,"modified":1626985803},{"id":"15099","value":1,"modified":1627020603},{"id":"15100","value":1,"modified":1626972603},{"id":"15103","value":0,"modified":1626901503}],"scInfo":[],"objInfo":[{"object_id":"1","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"2","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"3","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":0,"cmds":[{"enable":"1","cmd":"#46#","invert":"0"}]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"5","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"21","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"15","keys":[{"security":{"value":null,"cmds":[]}},{"motion":{"value":null,"cmds":[]}},{"door":{"value":null,"cmds":[]}},{"windows":{"value":null,"cmds":[]}},{"shutter":{"value":null,"cmds":[]}},{"light":{"value":null,"cmds":[]}},{"outlet":{"value":null,"cmds":[]}},{"temperature":{"value":null,"cmds":[]}},{"humidity":{"value":null,"cmds":[]}},{"luminosity":{"value":null,"cmds":[]}},{"power":{"value":null,"cmds":[]}}]},{"object_id":"global","keys":[{"security":{"value":null}},{"motion":{"value":0}},{"door":{"value":null}},{"windows":{"value":null}},{"shutter":{"value":null}},{"light":{"value":null}},{"outlet":{"value":null}},{"temperature":{"value":null}},{"humidity":{"value":null}},{"luminosity":{"value":null}},{"power":{"value":null}},{"presence":{"value":2}}]}]}}
[2021-07-23 10:25:29][DEBUG] : eventServer init client #191
[2021-07-23 10:25:44][DEBUG] : eventServer connexion closed for client #191
bonjour @delaportedom
as-tu bien supprimé la liaison entre ton téléphone et JC avant de re-scanner le QRCode ?
Norbert
non je ne l’avais pas fait. Je viens de le faire, refait une sauvegarde, relancer le démon, effacer les donner de l’appli téléphone et toujours « problème de connexion à Jeedom »
Comme indiqué plus haut, on a bien noté qu’il y avait un soucis chez certains utilisateurs (visiblement ça dépend des machines sur laquelle tourne Jeedom).
On essaie de faire une correction rapidement pour que les accès soient rétablis au plus vite pour tout le monde !
Bonjour, merci de votre réponse.
pas de pb de lenteur de mon côté. pas de pb de connexion.
meme pb d’affichage en mode carte
et par contre les menus « vides » que j’avais créé pour faire des sauts à la ligne s’affiche alors que invisible avant , et quand j’essaie d’éditer pour les rendre invisible ça ne prends pas en compte.
Pour les saut de ligne il faut normalement mettre un groupe actif et sans nom
Pour les autres problèmes remontés ça devrait être fixé rapidement :wink:
on est obligé de mettre un nom. le nom est un champ obligatoire.
ba … met un espace !? :slight_smile:
Autre bug, je ne sais pas si je suis la seule concernée : la page batterie me fait une fatale erreur de la mort qui tue avec la tête de mort et la phrase « cannot read property widgetid of undefined »
+1 !
tu as raison
Ca ne change rien.
+1 pour moi aussi … J’en ai lâché le téléphone !
la page batterie fonctionne chez moi
moi j’aime bien cette tete de mort :slight_smile: on sait tout de suite que ya un truc qui va pas au moins :slight_smile: :slight_smile:
3 « J'aime »
all good, fixé !
C’est propre à chaque équipement.
Chacun sa sauvegarde :wink:
ça ne marche pas .
Dans l’interface de l’apk cela fonctionne sans soucis (champ vide ou espace)
