C’est comme s’il y avait saturation…
[2021-10-30 09:48:05][DEBUG] : Closed serial connection
[2021-10-30 09:48:09][INFO] : [DeviceHandler.prepare] Json arg : {'ieee': '5c:02:72:ff:fe:92:29:dc', 'cmd': [{'endpoint': 1, 'cluster': 'on_off', 'command': 'on', 'await': 1}], 'allowQueue': False}
[2021-10-30 09:48:09][ERROR] : [5c:02:72:ff:fe:92:29:dc][zdevices.command] Command failed retry in 1s : ApplicationController is not running
[2021-10-30 09:48:09][DEBUG] : Using selector: EpollSelector
[2021-10-30 09:48:09][DEBUG] : Resetting EZSP
[2021-10-30 09:48:09][DEBUG] : Resetting ASH
[2021-10-30 09:48:09][DEBUG] : Sending: b'1ac038bc7e'
[2021-10-30 09:48:10][INFO] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 83, in command
await command()
File "/usr/local/lib/python3.7/dist-packages/zigpy/device.py", line 274, in request
use_ieee=use_ieee,
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 501, in request
raise ControllerError("ApplicationController is not running")
bellows.exception.ControllerError: ApplicationController is not running
During handling of the above exception, another exception occurred:
File "/var/www/html/plugins/zigbee/resources/zigbeed/restServer.py", line 253, in put
await zdevices.command(self.json_args)
File "/var/www/html/plugins/zigbee/resources/zigbeed/zdevices.py", line 88, in command
await command()
use_ieee=use_ieee,
[2021-10-30 09:48:10][INFO] : 200 PUT /device/command (127.0.0.1) 1018.05ms
[2021-10-30 09:48:10][DEBUG] : RSTACK Version: 2 Reason: RESET_SOFTWARE frame: b'c1020b0a527e'
[2021-10-30 09:48:10][DEBUG] : Send command version: (4,)
[2021-10-30 09:48:10][DEBUG] : Sending: b'004221a850ed2c7e'
[2021-10-30 09:48:10][DEBUG] : Data frame: b'0142a1a85c2805dbd7ae7e'
[2021-10-30 09:48:10][DEBUG] : Sending: b'8160597e'
[2021-10-30 09:48:10][DEBUG] : Application frame 0 (version) received: b'08021069'
[2021-10-30 09:48:11][DEBUG] : Switching to EZSP protocol version 8
[2021-10-30 09:48:11][DEBUG] : Send command version: (8,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'7d314221a9542a1d8cdf7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'1242a1a9542a1db049fd70757e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'82503a7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 0 (version) received: b'08021069'
[2021-10-30 09:48:11][DEBUG] : EZSP Stack Type: 2, Stack Version: 6910, Protocol version: 8
[2021-10-30 09:48:11][DEBUG] : Send command getValue: (<EzspValueId.VALUE_FREE_BUFFERS: 3>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'224321a9fe2a1683467e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'2343a1a9fe2a15b3a081f77e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'83401b7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 170 (getValue) received: b'0001f9'
[2021-10-30 09:48:11][DEBUG] : Send command getConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'334021a9062a14a80d7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'3440a1a9062a15485927a17e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'8430fc7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 82 (getConfigurationValue) received: b'00fa00'
[2021-10-30 09:48:11][DEBUG] : Free/configured buffers before any configurations: 249/250
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS: 42>, <EmberZdoConfigurationFlags.APP_HANDLES_UNSUPPORTED_ZDO_REQUESTS|APP_RECEIVES_SUPPORTED_ZDO_REQUESTS: 3>)
[2021-10-30 09:48:11][DEBUG] : Sending: b'444121a9072a3fb159225f7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'4541a1a9072a15cd287e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'8520dd7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 83 (setConfigurationValue) received: b'00'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_STACK_PROFILE: 12>, 2)
[2021-10-30 09:48:11][DEBUG] : Sending: b'554621a9072a19b0595acd7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'5646a1a9072a15ea907e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'8610be7e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_ADDRESS_TABLE_SIZE: 5>, 16)
[2021-10-30 09:48:11][DEBUG] : Sending: b'664721a9072a10a2593fd87e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'6747a1a9072a154edc7e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'87009f7e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SECURITY_LEVEL: 13>, 5)
[2021-10-30 09:48:11][DEBUG] : Sending: b'774421a9072a7d38b7597d3a577e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'7044a1a9072a15ae037e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'8070787e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SUPPORTED_NETWORKS: 45>, 1)
[2021-10-30 09:48:11][DEBUG] : Sending: b'004521a9072a38b3590df67e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'0145a1a9072a15d7a37e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'8160597e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE: 25>, 2)
[2021-10-30 09:48:11][DEBUG] : Sending: b'7d314a21a9072a0cb05920df7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'124aa1a9072a15fd597e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD: 34>, 2)
[2021-10-30 09:48:11][DEBUG] : Sending: b'224b21a9072a37b0598b1e7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'234ba1a9072a1559157e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S: 56>, 90)
[2021-10-30 09:48:11][DEBUG] : Sending: b'334821a9072a2de859f8027e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'3448a1a9072a15b9ca7e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SOURCE_ROUTE_TABLE_SIZE: 26>, 16)
[2021-10-30 09:48:11][DEBUG] : Sending: b'444921a9072a0fa259af007e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'4549a1a9072a15c06a7e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT: 18>, 7680)
[2021-10-30 09:48:11][DEBUG] : Sending: b'554e21a9072a07b24789e87e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'564ea1a9072a15e7d27e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT: 19>, 8)
[2021-10-30 09:48:11][DEBUG] : Sending: b'664f21a9072a06ba595a1b7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'674fa1a9072a15439e7e'
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_MULTICAST_TABLE_SIZE: 6>, 16)
[2021-10-30 09:48:11][DEBUG] : Sending: b'774c21a9072a7d33a25908fa7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'704ca1a9072a15a3417e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'004d21a9fe2a160df07e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'014da1a9fe2a15b3a07e7d7e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'7d315221a9062a1437dc7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'1252a1a9062a15485968c77e'
[2021-10-30 09:48:11][DEBUG] : Free/configured buffers before all memory allocation: 249/250
[2021-10-30 09:48:11][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>, 255)
[2021-10-30 09:48:11][DEBUG] : Sending: b'225321a9072a144d59127b7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'2353a1a9072a154ed37e'
[2021-10-30 09:48:11][DEBUG] : Sending: b'335021a9fe2a16d8387e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'3450a1a9fe2a15b3a5c6c67e'
[2021-10-30 09:48:11][DEBUG] : Application frame 170 (getValue) received: b'0001fc'
[2021-10-30 09:48:11][DEBUG] : Sending: b'445121a9062a146a0c7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'4551a1a9062a154f5984a97e'
[2021-10-30 09:48:11][DEBUG] : Application frame 82 (getConfigurationValue) received: b'00fd00'
[2021-10-30 09:48:11][DEBUG] : Free/configured buffers after all memory allocation: 252/253
[2021-10-30 09:48:11][DEBUG] : Send command getConfigurationValue: (<EzspConfigId.CONFIG_APS_UNICAST_MESSAGE_COUNT: 3>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'555621a9062a160d157e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'5656a1a9062a15b859b75d7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 82 (getConfigurationValue) received: b'000a00'
[2021-10-30 09:48:11][DEBUG] : APS_UNICAST_MESSAGE_COUNT is set to 10
[2021-10-30 09:48:11][DEBUG] : Send command addEndpoint: (1, 260, 48879, 0, 0, 1, [], [1280])
[2021-10-30 09:48:11][DEBUG] : Sending: b'665721a9562a14b6587bf425aa54924c7c287e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'6757a1a9562a153da67e'
[2021-10-30 09:48:11][DEBUG] : Application frame 2 (addEndpoint) received: b'00'
[2021-10-30 09:48:11][DEBUG] : Ezsp adding endpoint: [<EzspStatus.SUCCESS: 0>]
[2021-10-30 09:48:11][DEBUG] : getting MFG_STRING token
[2021-10-30 09:48:11][DEBUG] : Send command getMfgToken: (<EzspMfgTokenId.MFG_STRING: 1>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'775421a95f2a14685d7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'7054a1a95f2a05f735f12644c8266db663b1d854123198016d7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 11 (getMfgToken) received: b'10456c656c616273ffffffffffffffffff'
[2021-10-30 09:48:11][DEBUG] : getting MFG_BOARD_NAME token
[2021-10-30 09:48:11][DEBUG] : Send command getMfgToken: (<EzspMfgTokenId.MFG_BOARD_NAME: 2>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'005521a95f2a1780bb7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'0155a1a95f2a05f715c67a1799aa6db663b1d85412319849217e'
[2021-10-30 09:48:11][DEBUG] : Application frame 11 (getMfgToken) received: b'10454c52303233ffffffffffffffffffff'
[2021-10-30 09:48:11][DEBUG] : Send command getValue: (<EzspValueId.VALUE_VERSION_INFO: 17>,)
[2021-10-30 09:48:11][DEBUG] : Sending: b'7d315a21a9fe2a04625c7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'125aa1a9fe2a15b58f944c2cab5538a70f7e'
[2021-10-30 09:48:11][DEBUG] : Application frame 170 (getValue) received: b'0007d60006090100aa'
[2021-10-30 09:48:11][INFO] : EZSP Radio manufacturer: Elelabs
[2021-10-30 09:48:11][INFO] : EZSP Radio board name: ELR023
[2021-10-30 09:48:11][INFO] : EmberZNet version: 6.9.1.0 build 214
[2021-10-30 09:48:11][DEBUG] : Send command networkInit: ()
[2021-10-30 09:48:11][DEBUG] : Sending: b'225b21a9432af6d57e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'235ba5a9432a150bfa7e'
[2021-10-30 09:48:11][DEBUG] : Data frame: b'335bb1a94d2a8529657e'
[2021-10-30 09:48:11][DEBUG] : Application frame 23 (networkInit) received: b'00'
[2021-10-30 09:48:11][DEBUG] : Application frame 25 (stackStatusHandler) received: b'90'
[2021-10-30 09:48:11][DEBUG] : Send command getNetworkParameters: ()
[2021-10-30 09:48:11][DEBUG] : Sending: b'345821a97c2a9ac97e'
[2021-10-30 09:48:16][DEBUG] : ControllerApplication reset unsuccessful:
[2021-10-30 09:48:17][DEBUG] : Data frame: b'4458a1a97c2a15b3e76a1a3ea984639615bb2fa4edce678bfd3e9c8e03d67e'
[2021-10-30 09:48:17][DEBUG] : Sending: b'8520dd7e'
[2021-10-30 09:48:17][DEBUG] : Data frame: b'4c58a1a97c2a15b3e76a1a3ea984639615bb2fa4edce678bfd3e9c8e37577e'
[2021-10-30 09:48:17][DEBUG] : Application frame 40 (getNetworkParameters) received: b'0001befe501b03d1f1df89f5080f0000000000f8ff07'
[2021-10-30 09:48:17][DEBUG] : Error processing 26 response. getNetworkParameters command timed out?
[2021-10-30 09:48:17][DEBUG] : Error code: ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT, Version: 2, frame: b'c20251a8bd7e'
[2021-10-30 09:48:17][ERROR] : NCP entered failed state. Requesting APP controller restart
[2021-10-30 09:48:17][DEBUG] : Closed serial connection
[2021-10-30 09:48:21][DEBUG] : Using selector: EpollSelector
[2021-10-30 09:48:21][DEBUG] : Resetting EZSP
[2021-10-30 09:48:21][DEBUG] : Resetting ASH
[2021-10-30 09:48:21][DEBUG] : Sending: b'1ac038bc7e'
[2021-10-30 09:48:22][DEBUG] : RSTACK Version: 2 Reason: RESET_SOFTWARE frame: b'c1020b0a527e'
[2021-10-30 09:48:22][DEBUG] : Send command version: (4,)
[2021-10-30 09:48:22][DEBUG] : Sending: b'004221a850ed2c7e'
[2021-10-30 09:48:22][DEBUG] : Data frame: b'0142a1a85c2805dbd7ae7e'
[2021-10-30 09:48:22][DEBUG] : Sending: b'8160597e'
[2021-10-30 09:48:22][DEBUG] : Application frame 0 (version) received: b'08021069'
[2021-10-30 09:48:22][DEBUG] : Switching to EZSP protocol version 8
[2021-10-30 09:48:22][DEBUG] : Send command version: (8,)
[2021-10-30 09:48:22][DEBUG] : Sending: b'7d314221a9542a1d8cdf7e'
[2021-10-30 09:48:22][DEBUG] : Data frame: b'1242a1a9542a1db049fd70757e'
[2021-10-30 09:48:22][DEBUG] : Sending: b'82503a7e'
[2021-10-30 09:48:23][DEBUG] : EZSP Stack Type: 2, Stack Version: 6910, Protocol version: 8
[2021-10-30 09:48:23][DEBUG] : Send command getValue: (<EzspValueId.VALUE_FREE_BUFFERS: 3>,)
[2021-10-30 09:48:23][DEBUG] : Sending: b'224321a9fe2a1683467e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'2343a1a9fe2a15b3a081f77e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'83401b7e'
[2021-10-30 09:48:23][DEBUG] : Application frame 170 (getValue) received: b'0001f9'
[2021-10-30 09:48:23][DEBUG] : Send command getConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>,)
[2021-10-30 09:48:23][DEBUG] : Sending: b'334021a9062a14a80d7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'3440a1a9062a15485927a17e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'8430fc7e'
[2021-10-30 09:48:23][DEBUG] : Application frame 82 (getConfigurationValue) received: b'00fa00'
[2021-10-30 09:48:23][DEBUG] : Free/configured buffers before any configurations: 249/250
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_APPLICATION_ZDO_FLAGS: 42>, <EmberZdoConfigurationFlags.APP_HANDLES_UNSUPPORTED_ZDO_REQUESTS|APP_RECEIVES_SUPPORTED_ZDO_REQUESTS: 3>)
[2021-10-30 09:48:23][DEBUG] : Sending: b'444121a9072a3fb159225f7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'4541a1a9072a15cd287e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'8520dd7e'
[2021-10-30 09:48:23][DEBUG] : Application frame 83 (setConfigurationValue) received: b'00'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_STACK_PROFILE: 12>, 2)
[2021-10-30 09:48:23][DEBUG] : Sending: b'554621a9072a19b0595acd7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'5646a1a9072a15ea907e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'8610be7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_ADDRESS_TABLE_SIZE: 5>, 16)
[2021-10-30 09:48:23][DEBUG] : Sending: b'664721a9072a10a2593fd87e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'6747a1a9072a154edc7e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'87009f7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SECURITY_LEVEL: 13>, 5)
[2021-10-30 09:48:23][DEBUG] : Sending: b'774421a9072a7d38b7597d3a577e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'7044a1a9072a15ae037e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'8070787e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SUPPORTED_NETWORKS: 45>, 1)
[2021-10-30 09:48:23][DEBUG] : Sending: b'004521a9072a38b3590df67e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'0145a1a9072a15d7a37e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'8160597e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_TRUST_CENTER_ADDRESS_CACHE_SIZE: 25>, 2)
[2021-10-30 09:48:23][DEBUG] : Sending: b'7d314a21a9072a0cb05920df7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'124aa1a9072a15fd597e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'82503a7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_PAN_ID_CONFLICT_REPORT_THRESHOLD: 34>, 2)
[2021-10-30 09:48:23][DEBUG] : Sending: b'224b21a9072a37b0598b1e7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'234ba1a9072a1559157e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_TC_REJOINS_USING_WELL_KNOWN_KEY_TIMEOUT_S: 56>, 90)
[2021-10-30 09:48:23][DEBUG] : Sending: b'334821a9072a2de859f8027e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'3448a1a9072a15b9ca7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_SOURCE_ROUTE_TABLE_SIZE: 26>, 16)
[2021-10-30 09:48:23][DEBUG] : Sending: b'444921a9072a0fa259af007e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'4549a1a9072a15c06a7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_INDIRECT_TRANSMISSION_TIMEOUT: 18>, 7680)
[2021-10-30 09:48:23][DEBUG] : Sending: b'554e21a9072a07b24789e87e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'564ea1a9072a15e7d27e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_END_DEVICE_POLL_TIMEOUT: 19>, 8)
[2021-10-30 09:48:23][DEBUG] : Sending: b'664f21a9072a06ba595a1b7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'674fa1a9072a15439e7e'
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_MULTICAST_TABLE_SIZE: 6>, 16)
[2021-10-30 09:48:23][DEBUG] : Sending: b'774c21a9072a7d33a25908fa7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'704ca1a9072a15a3417e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'004d21a9fe2a160df07e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'014da1a9fe2a15b3a07e7d7e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'7d315221a9062a1437dc7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'1252a1a9062a15485968c77e'
[2021-10-30 09:48:23][DEBUG] : Free/configured buffers before all memory allocation: 249/250
[2021-10-30 09:48:23][DEBUG] : Send command setConfigurationValue: (<EzspConfigId.CONFIG_PACKET_BUFFER_COUNT: 1>, 255)
[2021-10-30 09:48:23][DEBUG] : Sending: b'225321a9072a144d59127b7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'2353a1a9072a154ed37e'
[2021-10-30 09:48:23][DEBUG] : Sending: b'335021a9fe2a16d8387e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'3450a1a9fe2a15b3a5c6c67e'
[2021-10-30 09:48:23][DEBUG] : Application frame 170 (getValue) received: b'0001fc'
[2021-10-30 09:48:23][DEBUG] : Sending: b'445121a9062a146a0c7e'
[2021-10-30 09:48:23][DEBUG] : Data frame: b'4551a1a9062a154f5984a97e'
[2021-10-30 09:48:23][DEBUG] : Application frame 82 (getConfigurationValue) received: b'00fd00'
[2021-10-30 09:48:23][DEBUG] : Free/configured buffers after all memory allocation: 252/253
[2021-10-30 09:48:23][DEBUG] : Send command getConfigurationValue: (<EzspConfigId.CONFIG_APS_UNICAST_MESSAGE_COUNT: 3>,)
[2021-10-30 09:48:35][DEBUG] : Send command networkInit: ()
[2021-10-30 09:48:35][DEBUG] : Sending: b'225b21a9432af6d57e'
[2021-10-30 09:48:35][DEBUG] : Data frame: b'235ba5a9432a150bfa7e'
[2021-10-30 09:48:35][DEBUG] : Sending: b'83401b7e'
[2021-10-30 09:48:35][DEBUG] : Application frame 23 (networkInit) received: b'00'
[2021-10-30 09:48:35][DEBUG] : Data frame: b'335bb1a94d2a8529657e'
[2021-10-30 09:48:35][DEBUG] : Sending: b'8430fc7e'
[2021-10-30 09:48:35][DEBUG] : Send command getNetworkParameters: ()
[2021-10-30 09:48:35][DEBUG] : Application frame 25 (stackStatusHandler) received: b'90'
[2021-10-30 09:48:35][DEBUG] : Sending: b'345821a97c2a9ac97e'
J’arrive à alumer ma lampe mais lorsque je demande l’état pour rafraichir le widget ça plante…
