Juste avec les infos :
[2021-10-30 10:30:52][INFO] : Start zigbeed
[2021-10-30 10:30:52][INFO] : Log level : info
[2021-10-30 10:30:52][INFO] : PID file : /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-30 10:30:52][INFO] : Device : auto
[2021-10-30 10:30:52][INFO] : Apikey : xxxxx
[2021-10-30 10:30:52][INFO] : Callback : http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php
[2021-10-30 10:30:52][INFO] : Cycle : 0.3
[2021-10-30 10:30:52][INFO] : Controller : ezsp
[2021-10-30 10:30:52][INFO] : Channel : 15
[2021-10-30 10:30:52][INFO] : Data folder : /var/www/html/plugins/zigbee/data/1
[2021-10-30 10:30:52][INFO] : Device folder : /var/www/html/plugins/zigbee/data/device
[2021-10-30 10:30:52][INFO] : Folder OTA : /var/www/html/plugins/zigbee/data/ota
[2021-10-30 10:30:52][INFO] : Zigpy advance configuration file : None
[2021-10-30 10:30:54][INFO] : Find device : /dev/ttyUSB2
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.danfoss
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.danfoss.details
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.develco
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.develco.details
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.frient
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.frient.details
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.schneider
[2021-10-30 10:30:54][INFO] : LOADER------Import de la configuration specifics.schneider.details
[2021-10-30 10:30:54][INFO] : Writing PID 19035 to /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-30 10:30:54][INFO] : Init request module v2.25.1
[2021-10-30 10:30:54][INFO] : [start_zigbee] Init zigbee network with config : {'database_path': '/var/www/html/plugins/zigbee/data/1/network_ezsp.db', 'device': {'path': '/dev/ttyUSB2', 'baudrate': 115200}, 'network': {'channel': 15}, 'ota': {'otau_directory': '/var/www/html/plugins/zigbee/data/ota', 'ikea_provider': True, 'ikea_update_url': 'http://fw.ota.homesmart.ikea.net/feed/version_info.json', 'ledvance_provider': True}, 'ezsp': {'CONFIG_APS_UNICAST_MESSAGE_COUNT': 12, 'CONFIG_SOURCE_ROUTE_TABLE_SIZE': 16, 'CONFIG_ADDRESS_TABLE_SIZE': 8}}
[2021-10-30 10:30:55][INFO] : Trådfri: OTA provider enabled
[2021-10-30 10:30:55][INFO] : Ledvance: OTA provider enabled
[2021-10-30 10:30:58][ERROR] : NCP entered failed state. Requesting APP controller restart
[2021-10-30 10:30:59][INFO] : EZSP Radio manufacturer: Elelabs
[2021-10-30 10:30:59][INFO] : EZSP Radio board name: ELR023
[2021-10-30 10:30:59][INFO] : EmberZNet version: 6.9.1.0 build 214
[2021-10-30 10:31:04][ERROR] : Couldn't start application
[2021-10-30 10:31:04][INFO] : Shutting down ControllerApplication
[2021-10-30 10:31:04][ERROR] : [start_zigbee] Fatal error :
[2021-10-30 10:31:04][INFO] : Traceback (most recent call last):
File "/var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py", line 102, in start_zigbee
start_radio=True,
File "/usr/local/lib/python3.7/dist-packages/zigpy/application.py", line 69, in new
await app.startup(auto_form)
File "/usr/local/lib/python3.7/dist-packages/bellows/zigbee/application.py", line 151, in startup
status, node_type, nwk_params = await ezsp.getNetworkParameters()
File "/usr/lib/python3.7/asyncio/tasks.py", line 423, in wait_for
raise futures.TimeoutError()
concurrent.futures._base.TimeoutError
[2021-10-30 10:31:04][INFO] : Shutdown
[2021-10-30 10:31:04][INFO] : Removing PID file /tmp/jeedom/zigbee/deamon_1.pid
[2021-10-30 10:31:04][INFO] : Exit 0
J’ai même changé le port USB au cas où…
Le jour où j’ai constaté l’instabilité j’ai aussi fait un apt upgrade :
Start-Date: 2021-10-25 10:05:29
Commandline: apt upgrade
Install: zip:arm64 (3.0-11+b1, automatic)
Upgrade: debconf:arm64 (1.5.71, 1.5.71+deb10u1), linux-image-current-meson64:arm64 (21.05.4, 21.08.1), libkrb5-3:arm64 (1.17-3+deb10u1, 1.17-3+deb10u3), libavformat58:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), libgssapi-krb5-2:arm64 (1.17-3+deb10u1, 1.17-3+deb10u3), libavfilter7:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), ffmpeg:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), linux-libc-dev:arm64 (4.19.194-2, 21.08.2), openssl:arm64 (1.1.1d-0+deb10u6, 1.1.1d-0+deb10u7), libswresample3:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), ntfs-3g:arm64 (1:2017.3.23AR.3-3, 1:2017.3.23AR.3-3+deb10u1), libsystemd0:arm64 (241-7~deb10u7, 241-7~deb10u8), debconf-utils:arm64 (1.5.71, 1.5.71+deb10u1), mariadb-common:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), mariadb-server-core-10.3:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), libk5crypto3:arm64 (1.17-3+deb10u1, 1.17-3+deb10u3), linux-dtb-current-meson64:arm64 (21.05.4, 21.08.1), udev:arm64 (241-7~deb10u7, 241-7~deb10u8), libntfs-3g883:arm64 (1:2017.3.23AR.3-3, 1:2017.3.23AR.3-3+deb10u1), apache2-data:arm64 (2.4.38-3+deb10u5, 2.4.38-3+deb10u6), libpostproc55:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), libudev1:arm64 (241-7~deb10u7, 241-7~deb10u8), mariadb-server-10.3:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), telegraf:arm64 (1.19.1-1, 1.20.2-1), armbian-firmware:arm64 (21.05.6, 21.08.3), libudev-dev:arm64 (241-7~deb10u7, 241-7~deb10u8), psmisc:arm64 (23.2-1, 23.2-1+deb10u1), libkrb5support0:arm64 (1.17-3+deb10u1, 1.17-3+deb10u3), libnss-myhostname:arm64 (241-7~deb10u7, 241-7~deb10u8), systemd-sysv:arm64 (241-7~deb10u7, 241-7~deb10u8), libavcodec58:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), libpam-systemd:arm64 (241-7~deb10u7, 241-7~deb10u8), libavutil56:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), distro-info-data:arm64 (0.41+deb10u3, 0.41+deb10u4), libsndfile1:arm64 (1.0.28-6, 1.0.28-6+deb10u1), armbian-config:arm64 (21.02.4, 21.08.3), systemd:arm64 (241-7~deb10u7, 241-7~deb10u8), libavdevice58:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), linux-u-boot-odroidc2-current:arm64 (21.05.4, 21.08.1), libswscale5:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), mariadb-client-10.3:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), mariadb-server:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), mariadb-client-core-10.3:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), mariadb-client:arm64 (1:10.3.29-0+deb10u1, 1:10.3.31-0+deb10u1), apache2-bin:arm64 (2.4.38-3+deb10u5, 2.4.38-3+deb10u6), apache2:arm64 (2.4.38-3+deb10u5, 2.4.38-3+deb10u6), apache2-utils:arm64 (2.4.38-3+deb10u5, 2.4.38-3+deb10u6), libavresample4:arm64 (7:4.1.6-1~deb10u1, 7:4.1.8-0+deb10u1), base-files:arm64 (10.3+deb10u10, 10.3+deb10u11), tzdata:arm64 (2021a-0+deb10u1, 2021a-0+deb10u2)
End-Date: 2021-10-25 10:12:01
