Suite à la mise à jour de mon code du widget « Décompte à la seconde » / « tps_restant », voici la dernière version (conforme Jeedom v4.3) :
<!-- CUSTOM WIDGET "tps_restant_v4.3"
Community link: https://community.jeedom.com/t/widget-decompte-a-la-seconde-tps-restant/99012
Updated on: 2023-01-08
Versions supported: Jeedom v4.3
Last Modification: use v4.3 js (jeeFrontEnd, jeedom.cmd.addUpdateFunction, jeedom.cmd.refreshValue)
<div class="tooltips cmd cmd-widget" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="title #hide_name#">
<span class="cmdName">#name_display#</span>
</div>
<div class="content-sm">
<div class="state"></div>
</div>
<script>
jeedom.cmd.addUpdateFunction('#id#', function(_options) {
$('.cmd[data-cmd_id=#id#]').attr('title', '{{Date de valeur :}} '+_options.valueDate+'<br/>{{Date de collecte :}} '+_options.collectDate);
$('.cmd[data-cmd_id=#id#]').attr('interval', );
if ($('.cmd[data-cmd_id=#id#]').attr('interval')) {
clearInterval($('.cmd[data-cmd_id=#id#]').attr('interval'));
$('.cmd[data-cmd_id=#id#]').removeAttr('interval');
var timestamp = parseFloat(_options.display_value);
if (timestamp > 0) {
$('.cmd[data-cmd_id=#id#]').attr('interval', setInterval(function () {
var dateLoc = new Date;
var time_left = timestamp * 1000 - (dateLoc.getTime() + (dateLoc.getTimezoneOffset() + jeeFrontEnd.serverTZoffsetMin) * 60000 + jeeFrontEnd.clientServerDiffDatetime);
if (!$('.cmd[data-cmd_id=#id#] .state').length || timestamp < 0 || time_left < 0) {
$('.cmd[data-cmd_id=#id#] .state').empty();
} else {
//============ CONVERSIONS
var s_left = time_left / 1000;
var i_left = s_left / 60;
var H_left = i_left / 60;
s_left = Math.floor(s_left % 60);
i_left = Math.floor(i_left % 60);
H_left = Math.floor(H_left);
//============ FORMATTING
s_left = s_left < 10 ? "0"+ s_left : s_left;
i_left = i_left < 10 ? "0"+ i_left : i_left;
H_left = H_left < 10 ? "0"+ H_left : H_left;
//============ DISPLAY
if (H_left > 0) {
$('.cmd[data-cmd_id=#id#] .state').empty().append(H_left + ":" + i_left + ":" +s_left);
} else {
$('.cmd[data-cmd_id=#id#] .state').empty().append(i_left + ":" +s_left);
}, 1000));
} else {
jeedom.cmd.refreshValue([{cmd_id :'#id#',display_value: '#state#', valueDate: '#valueDate#', collectDate: '#collectDate#', alertLevel: '#alertLevel#', unit: '#unite#'}]);
</script>
</div>
L’utilisation se fait toujours de la façon suivante :
Une fois le widget créé :
Il suffit de l’associer à une info (virtuel ou non), comme un widget standard…
A l’aide du bouton « roue crantée » :
Puis dans l’onglet affichage, selectionner le widget :
Et sauvegarder.
Le code de mon vitruel de test est le suivant :
7068 : info : "Compteur"
7075 : action : "-60s" : (#timestamp# >= #[Compteur]# - 60) ? 0 : (#[Compteur]# - 60)
7074 : action : "-10s" : (#timestamp# >= #[Compteur]# - 10) ? 0 : (#[Compteur]# - 10)
7070 : action : "Reset" : 0
7071 : action : "+10s" : (#timestamp# <= #[Compteur]#) ? (#[Compteur]# + 10) : (#timestamp# + 10)
7072 : action : "+60s" : (#timestamp# <= #[Compteur]#) ? (#[Compteur]# + 60) : (#timestamp# + 60)
Etat initial ou Reset :
+60s, le décompte commence :
Les boutons -60s, -10s et +10s décalent l’heure de fin du compteur.
Une fois le compteur arrivé à 0, son contenu disparait.
La valeur manipulée par le « compteur » dans Jeedom est #timestamp#, également appelé EPOCH. La valeur stockée dans le compteur peut-être utilisée dans un scenario (ou autre) et comparée à #timestamp# pour savoir « où on en est ».
Pour ce qui est de l’utilité, perso je l’utilise dans mes temporisations Salon, Cuisine, Entrée, etc pour avoir un retour visuel du temps restant sur la tempo.
Vous trouverez ici les différentes version (que j’ai pu retrouver) du code de ce widget :
- Mise à jour en 2021 par Bad (conforme jeedom v4.1 & v4.2)
Code
<!-- WIDGET SPECIFIQUE widget "tps_restant"
Refs : https://community.jeedom.com/t/decompte-a-la-seconde-widgets-v4/10658
https://community.jeedom.com/t/plugin-compte-a-rebours/6659/
Update : 2021/01/10
Modification : Clean error on clearInterval()
</div>
<div id="countdown_#id#_decompte" data-cmd_id="#id#"></div>
</div>
<script>
$('.cmd[data-cmd_id=#id#]').attr('title','Date de valeur : '+_options.valueDate+'<br/>Date de collecte : '+_options.collectDate)
if (interval#uid#) {
clearInterval(interval#uid#);
interval#uid# = false;
interval#uid# = setInterval(function () {
var tps_restant=timestamp*1000 - (dateLoc.getTime()+(dateLoc.getTimezoneOffset()+serverTZoffsetMin)*60000 + clientServerDiffDatetime);
// console.log("interval("+intervalId+")");
if (!$('#countdown_#id#_decompte').length || timestamp < 0 || tps_restant < 0) {
// console.log("clearInterval("+intervalId+")");
$('#countdown_#id#_decompte').text(' ');
} else {
var s_restantes = tps_restant / 1000; // Secondes restantes
var i_restantes = s_restantes / 60; // Minutes restantes
var H_restantes = i_restantes / 60; // Heures restantes
s_restantes = Math.floor(s_restantes % 60); // Secondes restantes
i_restantes = Math.floor(i_restantes % 60); // Minutes restantes
H_restantes = Math.floor(H_restantes); // Heures restantes
//============ FORMATTAGE
s_restantes = s_restantes < 10 ? "0"+ s_restantes : s_restantes;
i_restantes = i_restantes < 10 ? "0"+ i_restantes : i_restantes;
H_restantes = H_restantes < 10 ? "0"+ H_restantes : H_restantes;
if (H_restantes > 0) {
$('#countdown_#id#_decompte').text(H_restantes + ":" + i_restantes + ":" +s_restantes);
} else {
$('#countdown_#id#_decompte').text(i_restantes + ":" +s_restantes);
}, 1000);
} else {
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#',alertLevel:'#alertLevel#'});
</script>
</div>
- Mise à jour en 2020 par ajja17orange (conforme jeedom v4.0.40)
Code
Modifications :
_options.display_value > javascript_timestamp (ligne 33
Mise à jour :
- Le 2020/2/20 : conforme jeedom v4.0.40
<div class="cmd cmd-widget" style="min-width:90px;min-height:50px;margin-right: 5px;margin-left: 5px;padding:0px !important;" data-type="info" data-subtype="numeric" data-cmd_id="#id#" title="Valeur du #valueDate#, collectée le #collectDate#">
<center>
<div class="cmdName">#name_display#</div>
</div>
<div>
<span style="line-height: 32px;font-size: 2.5em;font-weight: bold;" id="countdown_#id#_decompte">--</span>
</div>
</center>
<script>
//var now = null;
// console.log($('#countdown_#id#_decompte').text);
var thisdate = new Date();
var actualdate = (thisdate.getTime());
var timestamps = actualdate / 1000;
var javascript_timestamp = Math.round(timestamps);
// console.log("temp_reel "+javascript_timestamp);
// console.log("temp_valeur "+_options.display_value);
$(function (e) {
if (timestamp > javascript_timestamp) {
// var tps_restant == null;
interval#id# = setInterval(function () {
var now = (new Date()).getTime(); // On déclare la date d'aujourd'hui.
var tps_restant =timestamp*1000 - now; // Temps restant en millisecondes
if (!$('#countdown_#id#_decompte').length || timestamp < javascript_timestamp || tps_restant < 0) {
clearInterval(interval#id#);
$('#countdown_#id#_decompte').text('--');
} else {
} else {
}, 1000);
}else {
e.stopPropagation();
</script>
</div>
- Mise à jour en 2019 par windex encore sur l’ancien forum (conforme jeedom v3.3.20)
Code
Modifications :
- update, _options.display_value, et stop fonction
Mise à jour :
- Le 2019/4/16 : conforme jeedom v3.3.20
<div style="min-width:90px;min-height:62px;margin-right: 5px;margin-left: 5px;padding:0px !important;" class="tooltips cmd cmd-widget" data-type="info" data-subtype="numeric" data-cmd_id="#id#" title="Valeur du #valueDate#, collectée le #collectDate#">
<center>
<span style="font-weight: bold;font-size : 12px;" class="cmdName">#name_display#</span><br/>
<span style="font-size: 1.5em;font-weight: bold;" id="countdown_#id#_decompte">--</span>
</center>
<script>
$(function (e) {
} else {
} else {
}, 1000);
}else {
</script>
</div>
Code
<!-- WIDGET SPECIFIQUE adapté du widget standard "countdown"
Modifications :
- Remplacement de style="display: block;" par style="min-width:90px;min-height:62px;margin-right: 5px;margin-left: 5px;padding:0px !important;"
- Remplacement de title="#collectDate#" par title="Valeur du #valueDate#, collectée le #collectDate#"
- Mutualisation de #countdown_#id#_#state#_h, #countdown_#id#_#state#_m, et #countdown_#id#_#state#_s en #countdown_#id#_#state#_decompte
- Suppression de class='label label-default'
- Ajout calcul de #countdown_#id#_#state#_decompte affichant si nécessaire les heures
- Remplacement de la valeur par défaut par --
Mise à jour :
- Le 2016/11/19 : Correction d'une erreur d'écriture
- Le 2016/04/11 : Création
<center>
<span style="font-size: 2em;font-weight: bold;" id="countdown_#id#_#state#_decompte">--</span>
</center>
<script>
if ('#background-color#' !== '#'+'background-color'+'#') {
$('#cmd#id# .label').css({'background-color':'#background-color#'});
$(function () {
if ('#state#' > 0) {
var intervalId = setInterval(function () {
var tps_restant = '#state#'*1000 - now; // Temps restant en millisecondes
if (!$('#countdown_#id#_#state#_decompte').length || '#state#' < 0 || tps_restant < 0) {
clearInterval(intervalId);
$('#countdown_#id#_#state#_decompte').text('--');
} else {
$('#countdown_#id#_#state#_decompte').text(H_restantes + ":" + i_restantes + ":" +s_restantes);
} else {
$('#countdown_#id#_#state#_decompte').text(i_restantes + ":" +s_restantes);
}, 1000);
</script>
</div>
Enjoy ![]()
