Bonjour @jpty
Merci pour les liens
Je me suis concentré sur le 1er lien dont la methodo m’a l’air plus simple
Le fichier Json se créé, j’arrive à communiquer avec la chaudiere ( ex MAJ de la température de consigne)
Par contre je n’arrive pas à lire les informations du fichier Json
exemple: Nom: Temp_Exterieur
type Script: JSON
Type: info et Numérique
Requête: 5373>Wert
Options: https://AdresseJeedom/plugins/script/core/ressources/viessmann.json
Unité: °
J’obtiens le message suivant
Je n’arrive pas à savoir si c’est un probleme d’accès ou si la requête n’est pas bonne (j’ai lu la doc sur le format JSON
Le fichier json ressemble à ca:
{"77":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"82":{"Wert":"20","Zeitstempel":"2020-11-19 12:05:56","Name":"konf_raumsolltemp_rw","iswriteable":true},"89":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"94":{"Wert":"2","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"104":{"Wert":"5482.94","Zeitstempel":"2020-11-19 12:05:56","Name":"anzahl_brennerstunden_r","iswriteable":false},"111":{"Wert":"123512","Zeitstempel":"2020-11-19 12:05:56","Name":"anzahl_brennerstart_r","iswriteable":true},"245":{"Wert":"1","Zeitstempel":"2020-11-19 12:05:56","Name":"zustand_interne_pumpe_r","iswriteable":false},"709":{"Wert":"3","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"718":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"730":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5272":{"Wert":"3276.7","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5273":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5274":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5276":{"Wert":"3276.7","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5277":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5279":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":null,"iswriteable":null},"5280":{"Wert":"0","Zeitstempel":"2020-11-19 12:05:56","Name":"zustand_speicherladepumpe_r","iswriteable":false},"5372":{"Wert":"29","Zeitstempel":"2020-11-19 12:05:56","Name":"temp_agt_r","iswriteable":false},"5373":{"Wert":"10.3","Zeitstempel":"2020-11-19 12:05:56","Name":"temp_ats_r","iswriteable":false},"5374":{"Wert":"25","Zeitstempel":"2020-11-19 12:05:56","Name":"temp_kts_r","iswriteable":false},"5376":{"Wert":"20","Zeitstempel":"2020-11-19
Merci pour votre aide
