@TheWalkingDad
Si tu possède une box tahoma et que ton portail est pilotable par celle-ci, alors oui, le plugin doit fonctionner
Stéphane
ok merci donc ca devrait marcher…
je me permets de remettre dans le nouveau forum le log du problème rencontré et déjà remonté il y a plus d’un an.
Erreur sur tahoma::pull() : [Aucun][radiateur salle à ma][core:TimeProgramState] Le sous-type de la commande ne peut pas être vide :tahomaCmd Object ( [id:protected] => [logicalId:protected] => core:TimeProgramState [generic_type:protected] => [eqType:protected] => [name:protected] => core:TimeProgramState [order:protected] => [type:protected] => info [subType:protected] => [eqLogic_id:protected] => 103 [isHistorized:protected] => 0 [unite:protected] => [configuration:protected] => Array ( [type] => core:TimeProgramState ) [template:protected] => [display:protected] => [value:protected] => [isVisible:protected] => 0 [alert:protected] => [_collectDate:protected] => [_valueDate:protected] => [_eqLogic:protected] => tahoma Object ( [id:protected] => 103 [name:protected] => radiateur salle à ma [logicalId:protected] => [generic_type:protected] => [object_id:protected] => [eqType_name:protected] => tahoma [eqReal_id:protected] => [isVisible:protected] => 1 [isEnable:protected] => 1 [configuration:protected] => {"type":"io:AtlanticElectricalHeaterWithAdjustableTemperatureSetpointIOComponent","deviceURL":"io:\/\/1205-1930-1525\/7058953#1","createtime":"2019-10-10 15:34:03"} [timeout:protected] => [category:protected] => [] [display:protected] => {"showObjectNameOnview":1,"showObjectNameOndview":1,"showObjectNameOnmview":1,"height":"auto","width":"auto","layout::dashboard::table::parameters":{"center":1,"styletd":"padding:3px;"},"layout::mobile::table::parameters":{"center":1,"styletd":"padding:3px;"}} [order:protected] => 9999 [comment:protected] => [tags:protected] => [_debug:protected] => [_object:protected] => [_needRefreshWidget:protected] => [_timeoutUpdated:protected] => [_batteryUpdated:protected] => [_changed:protected] => ) [_needRefreshWidget:protected] => 1 [_needRefreshAlert:protected] => [_changed:protected] => 1 )
je sais que @gcherel a le même problème. Plusieurs personnes ce sont intéressées au sujet mais aucune solution n’a été trouvé si je ne me trompe pas.
Les équipements de la tahoma s’ajoutes bien. Ici le radiateur s’ajoute mais avec cette erreur, il est possible de voir les infos mais impossible d’utiliser les commandes (modifier la température de consigne, le mode, éteindre, allumer,…).
Si @redbug ou quelqu’un sait nous aider ?
D’avance merci
Bonne journée
Bonjour la communauté
Je rencontre un problème que me remonte le plugin et sature fichier de log; J’utilise le plugin avec une connexoon Windows pour mes volets roulant somfy
Erreur sur tahoma::pull() : [MySQL] Error code : 23000 (1062). Duplicate entry ‹ 403-Window - ABSENT - 2biche › for key ‹ unique › : INSERT INTO cmd SET id = :id, logicalId = :logicalId, generic_type = :generic_type, eqType = :eqType, name = :name, order = :order, type = :type, subType = :subType, eqLogic_id = :eqLogic_id, isHistorized = :isHistorized, unite = :unite, configuration = :configuration, template = :template, display = :display, value = :value, isVisible = :isVisible, alert = :alert
Quelqu’un à une idée ? Merci pour votre aide
le plugin Tahoma est-il compatible Jeedom V4 ?
Je suis en V3 et projète de passer en V4 sauf si le plugin n’est pas compatible…
Merci !
Bonjour.
je m’en suis servi sur une v4 pour mes volets Somfy sans problème. J’avais une tahoma. On a plus de souci avec les évolutions Somfy que jeedom
Au départ j’avais utilisé le plugin sur une v3
En cours de construction, je me pose la question des volets roulants motorisés Somfy (VRM).
De base, on me les propose en filaire : il me faudrait ajouter un micromodule dans ce cas ?
(exemple : FIBARO Roller Shutter 3) pour synchronisation avec la box Jeedom.
Mais ça me fait peur, je ne m’y connais pas et me vois pas installer ces modules…
J’ai demandé les VRM en techno IO-homecontrol, pour me passer de l’installation de ces micromodules : la box Jeedom permet-elle de piloter cette techno ?
J’ai vu que oui, finalement ça plante, qu’en est-il à ce jour ?
Merci d’avance
Bonjour et bienvenue !
Globalement avec de l’IO Homecontrol et des ouvrants, on tournera sur 2 solutions si on ne veut pas de micro modules dans ce que je connais ou lis sur les différents forum :
box Somfy (Tahoma / connexoon) + plugin Tahoma : selon moi cela fonctionne.Ca fonctionne chez moi en tout cas en Jeedom v3 et v4.
– avantages : ca fonctionne / rien à installer au niveau des ouvrants / possibilité le cas échéant de gérer aussi du RTS / utilisation en backup de l’appli Somfy Tahoma
– inconvénients : Cloud Somfy obligatoire (donc pas de commande en local / Coud HS = volets non pilotables) / prix box / dépendance totale aux évols des API Somfy ou de la Tahoma (pas trop possible de refuser les maj FW) ou choix Somfy de limiter les appels serveurs / retour état à 15mn par limitation des appels Cloud Somfy (choix chez Somfy a priori) -
box Velux KLF200 + plugin KLF : fonctionne chez moi en v3/v4
– avantages : tout est en local via API du KLF / retour d’état à 1mn / possibilités de mettre Velux et VRM Somfy sur une seule box (pt etre faisable sur Tahoma, pas testé…) / la box ne se met pas à jour obligatoirement (? à vérifier ?)
– inconvénients : prix de la KLF / pas forcément très facile de coupler Somfy sur KLF (selon l’équipement Somfy mis à dispo)
Voila mon retour d’expérience
Si c’est filaire, il faut rester en filaire jusqu’au bout, avec par exemple un IPX800 V4 - Extension X4VR.
Je cherche simplement a rafraichir l’état d’un volet pour le refermer ensuite mais le cron de 15 min me handicape, je n’ai aucune base en programmation comme vous pouvez le constater.
Bien évidemment le bloc code n’a aucun effet … Quelqu’un peut il m’aiguiller ?
J’espere au moins avoir fait sourire les programmateurs avertis
As tu trouvé une solution ? je rencontre exactement le même problème. Je me demande si ce n’est pas lié à l’ajout de l’application connexoon sur un nouveau tel…
J’ai un problème avec la remonté d’informations de deux volets (IO) du plugin tahoma.
La box tahoma les vois bien ouvert (via le web ou l’application android) mais le plugin les vois constamment fermé… (l’état reste à 0).
l’action « synchronisation » change l’état des autres si ils ont bouger mais pas les 2 concernés…
Comment faire ?
Mercii
bonjour
non toujours pas sniiff
Encore en panne ce soir. Soit tous les 2 mois depuis presque 1 an.
Je passe au klf200
J’en ai assez
Bonjour, oui j’ai moi aussi un problème quasiment tous les soirs depuis un peu plus d’une semaine : Visiblement perte de connexion avec les serveurs Somfy
Comme ça survient systématiquement sur le créneau du coucher du soleil, l’ordre de fermeture de mes volets ne passe pas.
D’autres ont aussi des problèmes ?
PS: sur le forum SOMFY plusieurs personnes ont le même problème, donc c’est bien encore les serveurs Somfy qui sont en vrac - ca devient effectivement pénible
J’ai bien envie de passer à la klf200 mais je ne sais pas si c’est compatible avec les moteurs de volets roulants IO somfy.
Hello
@xavax59 tu peux regarder ici : IO-Homecontrol et Jeedom
Pour ma part j’ai éteint ma Tahoma depuis plusieurs mois et désomais ma KLF gère mes 8 ouvrants Velux et mes volets roulants Somfy IO. Donc oui cela fonctionne et je ne suis pas le seul à utiliser le produit Velux pour les Somfy. Attention que IO pas de RTS avec la KLF
Reste que selon ton installation, la maitrise de la clé IO d’origine en cas de remplacement de moteur ou ajout d’un ouvrant SOmfy (avec envoi de clé) peut obliger à conserver la Tahoma. Dans mon cas ma clé maitre a été créé sur ma télécommande murale Somfy Impresario Chronis donc je dois pouvoir m’en sortir sans garder la Tahoma.
Merci ! Bonne nouvelle !
On ne peut pas envoyer la clé directement depuis les télécommandes des appareils ?
Je sais qu’une Smoove IO (télécommande murale que j’ai) permet d’ajouter un autre point de commande / télécommande sur un même moteur. En revanche la notion d’envoi de clé je ne l’ai pas vu sur ce type de point de commande (je n’ai pas trop cherché et je n’aime pas trop les commandes avec appui long et court ou on ne sait plus trop ou on est car aucun retour sur l’état télécommande et moteur).
Le KLF ne parvenant pas directement dans mon cas à se coupler au moteur IO Somfy, je suis passé par ma commande tactile centrale Velux KLR200 (que j’avais pris avec les Velux) : j’ai du envoyer la clé Tahoma sur ma commande centrale tactile Velux KLR200 ce qui a mis la clé Somfy partout (dans ma compréhension) et ajouté tous les Somfy dans la commande tactile Velux (bien pratique) et ensuite j’ai synchronisé le KLF200 avec la KLR200 (recopie) ce qui m’a mis tous les ouvrants Somfy + Velux sur le KLF.
J’ai expliqué cela dans l’autre fil. D’autres ont aussi indiqué ce qu’ils faisaient. Il faut bien lire ces échanges je pense et comparer avec son propre matériel avant d’investir dans le KLF qui coute quand mm un peu, surtout quand on a dépensé pareil sur une Tahoma
Après c’est sur que c’est le jour et le nuit (c’est le cas de le dire) avec les ouvrants commandés en local sans Cloud et avec un retour d’état à la minute.
Pour info, message venant de SOMFY sur le forum suite à quelques messages postés hier :
« Bonjour à tous,
Je vous confirme que nous avons identifié depuis plusieurs jours des ralentissements ou non fonctionnement des box TaHoma en début de soirée (entre 19h00 et 22h00).
Nos équipes sont mobilisées pour identifier la source de ce défaut, je reviendrais vers vous lorsque nous aurons plus d’informations à vous fournir.
Je vous prie de nous excuser pour la gêne occasionnée et vous souhaite une bonne journée »
