Tout d’abord, le paramétrage de « hasspresence » de bt/entree est bien resté à true : merci pour le « RETAIN » !
Ci-après, les remontées d’un NUT FIND 3 dans le topic bt/Entree/BTtoMQTT :
05/08/2023 18:11:22(-38.62 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-69,"distance":3.119501,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:12:01(-39.66 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-67,"distance":2.509097,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:12:40(-6.82 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-78,"distance":7.85288,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:12:47(-119.85 seconds)
Mise du NUT au micro-ondes … et après 2 minutes de cuisson
05/08/2023 18:14:47
{"id":"D5:A5:AE:08:51:BF","state":"offline"}
Après retrait du NUT :
05/08/2023 18:32:05(-4 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-66,"distance":2.246586,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:32:28(-27.04 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-55,"distance":0.495572,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:32:56
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-60,"distance":1.135236,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
Le NUT est tout proche de l’ESP32, mais je constate une perte de remontée d’info > 2 minutes :
05/08/2023 18:34:55(-3.3 seconds)
05/08/2023 18:35:26(-23.38 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-76,"distance":6.44788,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
05/08/2023 18:35:49(-27.05 seconds)
{"id":"D5:A5:AE:08:51:BF","name":"nut","rssi":-57,"distance":0.708318,"brand":"nut","model":"Smart Tracker","model_id":"NUT","type":"TRACK","device":"nut Tracker"}
J’ai surveillé une dizaine de minutes et pas de délai de remontée > 2 minutes
NB :
J’ai découvert que ma montre HUAWEI WATCH GT 2 était détectée par l’ESP32 et les remontées d’infos sont de l’ordre de la seconde.
Par contre pas de « state »:« offline » après 2 minutes de micro-ondes
Type d’infos remontées :
{"id":"34:B2:0A:XX:XX:XX","name":"HUAWEI WATCH GT 2e-091","rssi":-88,"txpower":0,"distance":19.7325}
Merci pour ton aide
