Je tente l’installation du plugin WEB OS TV pour une smart TV LG 55E9OLED sur une Box Jeedom Atlas zigbee.
Après que la barre de progression ait atteint 40% le statut des dépendances indique NOK.
Les logs debug me disent pourtant :
* Installation des dépendances *
10
***** Commande: sudo apt-get update **********
Hit:2 http://security.debian.org buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster InRelease
Hit:4 http://deb.debian.org/debian buster-updates InRelease
Hit:5 https://deb.nodesource.com/node_14.x buster InRelease
Hit:6 http://deb.debian.org/debian buster-backports InRelease
Hit:1 https://armbian.site-meganet.com/apt buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
net-tools is already the newest version (1.60+git20180626.aebd88e-1).
0 upgraded, 0 newly installed, 0 to remove and 114 not upgraded.
/var/www/html/plugins/webosTv/3rdparty/LGWebOSRemote/setup.py found.
running install
running bdist_egg
running egg_info
writing requirements to LGTV.egg-info/requires.txt
writing LGTV.egg-info/PKG-INFO
writing top-level names to LGTV.egg-info/top_level.txt
writing dependency_links to LGTV.egg-info/dependency_links.txt
reading manifest file 'LGTV.egg-info/SOURCES.txt'
writing manifest file 'LGTV.egg-info/SOURCES.txt'
installing library code to build/bdist.linux-aarch64/egg
running install_lib
running build_py
creating build/bdist.linux-aarch64/egg
creating build/bdist.linux-aarch64/egg/LGTV
copying build/lib.linux-aarch64-2.7/LGTV/__init__.py -> build/bdist.linux-aarch64/egg/LGTV
byte-compiling build/bdist.linux-aarch64/egg/LGTV/__init__.py to __init__.pyc
creating build/bdist.linux-aarch64/egg/EGG-INFO
copying LGTV.egg-info/PKG-INFO -> build/bdist.linux-aarch64/egg/EGG-INFO
copying LGTV.egg-info/SOURCES.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying LGTV.egg-info/dependency_links.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying LGTV.egg-info/requires.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
copying LGTV.egg-info/top_level.txt -> build/bdist.linux-aarch64/egg/EGG-INFO
zip_safe flag not set; analyzing archive contents...
LGTV.__init__: module references __file__
creating 'dist/LGTV-0.1.2-py2.7.egg' and adding 'build/bdist.linux-aarch64/egg' to it
removing 'build/bdist.linux-aarch64/egg' (and everything under it)
Processing LGTV-0.1.2-py2.7.egg
removing '/usr/local/lib/python2.7/dist-packages/LGTV-0.1.2-py2.7.egg' (and everything under it)
creating /usr/local/lib/python2.7/dist-packages/LGTV-0.1.2-py2.7.egg
Extracting LGTV-0.1.2-py2.7.egg to /usr/local/lib/python2.7/dist-packages
LGTV 0.1.2 is already the active version in easy-install.pth
Installed /usr/local/lib/python2.7/dist-packages/LGTV-0.1.2-py2.7.egg
Processing dependencies for LGTV==0.1.2
Searching for wakeonlan==0.2.2
Best match: wakeonlan 0.2.2
Processing wakeonlan-0.2.2-py2.7.egg
wakeonlan 0.2.2 is already the active version in easy-install.pth
Installing wol script to /usr/local/bin
Using /usr/local/lib/python2.7/dist-packages/wakeonlan-0.2.2-py2.7.egg
Searching for ws4py==0.5.1
Best match: ws4py 0.5.1
Processing ws4py-0.5.1-py2.7.egg
ws4py 0.5.1 is already the active version in easy-install.pth
Using /usr/local/lib/python2.7/dist-packages/ws4py-0.5.1-py2.7.egg
Finished processing dependencies for LGTV==0.1.2
Collecting wakeonlan==0.2.2
Using cached wakeonlan-0.2.2-py3-none-any.whl
Installing collected packages: wakeonlan
Attempting uninstall: wakeonlan
Found existing installation: wakeonlan 0.2.2
Uninstalling wakeonlan-0.2.2:
Successfully uninstalled wakeonlan-0.2.2
Successfully installed wakeonlan-0.2.2
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
* Installation terminée *
Le deamon reste déspérément NOK.
Les dépendances de WEBOS TV tentent régulièrement de s’installer.
Le centre de message dit en boucle : webosTv Attention : installation des dépendances lancée
Au final, ça ne s’installe pas.
Selon vous cela peut venir d’où ?
