salut tous le monde il m’est impossible d’installer les dépendance sur le le plug in lgthinq cela s’arrête à 90%
voici le retour en debug si vous avez une idée bien cordialement CARI
PI j’ai essayé la méthode dépendance bloquée à 40% mais cela n’a pas fonctionné
[2023-05-21 15:06:05]INFO : missing pip dependancies (1 )
[2023-05-21 15:06:06]INFO : missing pip dependancies (1 )
[2023-05-21 15:06:06]DEBUG : python3 alias detected
[2023-05-21 15:06:06]DEBUG : etat server wideq KO:[]
[2023-05-21 15:06:08]DEBUG : python3 alias detected
[2023-05-21 15:06:08]INFO : missing pip dependancies (1 )
[2023-05-21 15:06:09]INFO : missing pip dependancies (1 )
[2023-05-21 15:06:10]DEBUG : python3 alias detected
[2023-05-21 15:06:11]DEBUG : python3 alias detected
et dans install voici le retour
[2023-05-21 15:04:45] Start install dependancies
[2023-05-21 15:04:45] Valid Python version 37
[2023-05-21 15:04:45] upgrade pip3
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.1.2)
[2023-05-21 15:04:48] install python dependencies in /var/www/html/plugins/lgthinq/resources
[2023-05-21 15:04:49] clone wideq lib from github in /var/www/html/plugins/lgthinq/resources
[2023-05-21 15:04:50] Everything is successfully installed!
et dans update
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
ERROR: Ignored the following versions that require a different python version: 2.3.0 Requires-Python >=3.8; 2.3.1 Requires-Python >=3.8; 2.3.2 Requires-Python >=3.8
ERROR: Could not find a version that satisfies the requirement Flask==2.3.2 (from versions: 0.1, 0.2, 0.3, 0.3.1, 0.4, 0.5, 0.5.1, 0.5.2, 0.6, 0.6.1, 0.7, 0.7.1, 0.7.2, 0.8, 0.8.1, 0.9, 0.10, 0.10.1, 0.11, 0.11.1, 0.12, 0.12.1, 0.12.2, 0.12.3, 0.12.4, 0.12.5, 1.0, 1.0.1, 1.0.2, 1.0.3, 1.0.4, 1.1.0, 1.1.1, 1.1.2, 1.1.3, 1.1.4, 2.0.0rc1, 2.0.0rc2, 2.0.0, 2.0.1, 2.0.2, 2.0.3, 2.1.0, 2.1.1, 2.1.2, 2.1.3, 2.2.0, 2.2.1, 2.2.2, 2.2.3, 2.2.4, 2.2.5)
ERROR: No matching distribution found for Flask==2.3.2
Cloning into 'wideq'...
je pense que je vais virer ce bouton
