Bon, toujours rien…
Je pense à une autre piste, j’ai mis mon firmware à jour je suis en 6.9.1.0, la dernière. Possible cause?
Si ça peut aiguiller, voici le message du démon en debug:
[2021-11-19 19:36:29][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey uUsYsh4JNDHynt2iFlqwqIxhpj9k6AmU --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 11
[2021-11-19 19:36:32][DEBUG] : null
[2021-11-19 19:37:49][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2021-11-19 19:37:49][DEBUG] : {"with_attributes":0}
[2021-11-19 19:37:49][DEBUG] : http://127.0.0.1:8089/application/info type : GET
[2021-11-19 19:37:49][DEBUG] : null
[2021-11-19 19:37:49][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:6c","nwk":0,"status":2,"lqi":"None","rssi":"None","last_seen":"None","node_descriptor":"00:40:8f:cd:ab:52:80:00:41:2c:80:00:00","endpoints":[{"id":1,"status":1,"device_type":48879,"profile_id":260,"manufacturer":null,"model":null,"output_clusters":[],"input_clusters":[]}],"signature":{"manufacturer":"Silicon Labs","model":"EZSP","node_desc":{"logical_type":0,"complex_descriptor_available":0,"user_descriptor_available":0,"reserved":0,"aps_flags":0,"frequency_band":8,"mac_capability_flags":143,"manufacturer_code":43981,"maximum_buffer_size":82,"maximum_incoming_transfer_size":128,"server_mask":11329,"maximum_outgoing_transfer_size":128,"descriptor_capability_field":0},"endpoints":{"1":{"profile_id":260,"device_type":48879,"input_clusters":[],"output_clusters":[]}}},"class":"bellows.zigbee.application"}]
[2021-11-19 19:37:49][DEBUG] : http://127.0.0.1:8089/network/map type : GET
[2021-11-19 19:37:49][DEBUG] : [{"ieee":"84:fd:27:ff:fe:0e:46:6c","nwk":"0x0000","lqi":null,"rssi":null,"device_type":"Coordinator","manufacturer":"Silicon Labs","model":"EZSP","offline":false,"neighbours":[]}]
[2021-11-19 19:37:49][DEBUG] : {"ieee":"84:fd:27:ff:fe:0e:46:6c","version":"0.41.0","nwk":0,"config":{"database_path":"\/var\/www\/html\/plugins\/zigbee\/data\/1\/network_ezsp.db","device":{"path":"\/dev\/ttyUSB0","baudrate":115200,"flow_control":"software"},"network":{"channel":11,"tc_link_key":"5a:69:67:42:65:65:41:6c:6c:69:61:6e:63:65:30:39","extended_pan_id":null,"pan_id":null,"update_id":0,"key":null,"channels":34635776,"key_sequence_number":0,"tc_address":null},"ezsp":{"CONFIG_APS_UNICAST_MESSAGE_COUNT":12,"CONFIG_SOURCE_ROUTE_TABLE_SIZE":16,"CONFIG_ADDRESS_TABLE_SIZE":8},"handle_unknown_devices":false,"ota":{"ikea_provider":false,"otau_directory":null,"ledvance_provider":false},"topology_scan_skip_coordinator":false,"source_routing":false,"ezsp_policies":[],"topology_scan_period":240,"ezsp_config":[],"topology_scan_enabled":true},"ezsp":{"extendedPanId":"c7:b6:4a:8a:b2:6c:2b:ce","panId":"0x93f9","radioTxPower":8,"radioChannel":11,"nwkManagerId":"0x0","nwkUpdateId":"0x0","version":"6.9.1.0 build 214"}}
[2021-11-19 19:39:25][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2021-11-19 19:39:25][DEBUG] : {"duration":180}
[2021-11-19 19:39:27][DEBUG] : ""
[2021-11-19 19:41:41][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey uUsYsh4JNDHynt2iFlqwqIxhpj9k6AmU --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 11
[2021-11-19 19:41:44][DEBUG] : null
[2021-11-19 19:41:50][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey uUsYsh4JNDHynt2iFlqwqIxhpj9k6AmU --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15
[2021-11-19 19:41:52][DEBUG] : null
[2021-11-19 19:42:03][DEBUG] : http://127.0.0.1:8089/application/include type : PUT
[2021-11-19 19:42:03][DEBUG] : {"duration":180}
[2021-11-19 19:42:04][DEBUG] : ""
