merci pour ton aide @naboleo
en faite, j’ai l’impression que dans les logs ça va…
J’ai envoyé la même commande sur les deux boitiers pour voir la différence dans les logs, et je n’en vois pas…(toujours pas de réaction du RM3mini)
[2020-01-20 15:48:13][DEBUG] : Writing PID 29675 to /tmp/jeedom/broadlink/deamon.pid
[2020-01-20 15:48:13][DEBUG] : Init request module v2.12.4
[2020-01-20 15:48:13][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-01-20 15:48:13][DEBUG] : http://127.0.0.1:80 "GET /plugins/broadlink/core/php/jeeBroadlink.php?apikey=xxxxx n HTTP/1.1" 200 0
[2020-01-20 15:48:13][DEBUG] : Start listening...
[2020-01-20 15:48:13][DEBUG] : Socket interface started
[2020-01-20 15:48:13][DEBUG] : LoopNetServer Thread started
[2020-01-20 15:48:13][DEBUG] : Listening on: [127.0.0.1:55013]
[2020-01-20 15:48:15][DEBUG] : Client connected to [127.0.0.1:47712]
[2020-01-20 15:48:15][DEBUG] : Message read from socket: {"apikey":"xxxx","cmd":"add","device":{"mac":"321e7ba7df24","ip":"192.168.1.6","name":"321e7ba7df24","delay":"300","port":"80","type":"rm2"}}
[2020-01-20 15:48:15][DEBUG] : Client disconnected from [127.0.0.1:47712]
[2020-01-20 15:48:15][DEBUG] : Client connected to [127.0.0.1:47714]
[2020-01-20 15:48:15][DEBUG] : Message read from socket: {"apikey":"xxxx","cmd":"add","device":{"mac":"8b37fd770f78","ip":"192.168.1.21","name":"Broadlink","delay":"300","port":"80","type":"rm2"}}
[2020-01-20 15:48:15][DEBUG] : Client disconnected from [127.0.0.1:47714]
[2020-01-20 15:48:15][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-01-20 15:48:15][DEBUG] : Add device : {u'name': u'321e7ba7df24', u'ip': u'192.168.1.6', u'delay': u'300', u'mac': u'321e7ba7df24', u'type': u'rm2', u'port': u'80'}
[2020-01-20 15:48:15][DEBUG] : Handling RM2 for 321e7ba7df24
[2020-01-20 15:48:15][DEBUG] : Connecting to Broadlink device with name 321e7ba7df24....
[2020-01-20 15:48:15][DEBUG] : Connected to Broadlink device with name 321e7ba7df24....
[2020-01-20 15:48:15][DEBUG] : {'mac': u'321e7ba7df24', 'temperature': None}
[2020-01-20 15:48:15][DEBUG] : Send to jeedom : {u'devices': {u'321e7ba7df24': {'mac': u'321e7ba7df24', 'temperature': None}}}
[2020-01-20 15:48:15][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-01-20 15:48:15][DEBUG] : Add device : {u'name': u'Broadlink', u'ip': u'192.168.1.21', u'delay': u'300', u'mac': u'8b37fd770f78', u'type': u'rm2', u'port': u'80'}
[2020-01-20 15:48:15][DEBUG] : Handling RM2 for Broadlink
[2020-01-20 15:48:15][DEBUG] : Connecting to Broadlink device with name Broadlink....
[2020-01-20 15:48:15][DEBUG] : http://127.0.0.1:80 "POST /plugins/broadlink/core/php/jeeBroadlink.php?apikey=xxxx HTTP/1.1" 200 0
[2020-01-20 15:48:15][DEBUG] : Connected to Broadlink device with name Broadlink....
[2020-01-20 15:48:15][DEBUG] : {'mac': u'8b37fd770f78', 'temperature': 0.0}
[2020-01-20 15:48:16][DEBUG] : Send to jeedom : {u'devices': {u'8b37fd770f78': {'mac': u'8b37fd770f78', 'temperature': 0.0}}}
[2020-01-20 15:48:16][DEBUG] : Starting new HTTP connection (1): 127.0.0.1
[2020-01-20 15:48:16][DEBUG] : http://127.0.0.1:80 "POST /plugins/broadlink/core/php/jeeBroadlink.php?apikey=xxxx HTTP/1.1" 200 0
[2020-01-20 15:50:18][DEBUG] : Client connected to [127.0.0.1:48072]
[2020-01-20 15:50:18][DEBUG] : Message read from socket: {"apikey":"xxxx","cmd":"send","cmdType":"command","mac":"321e7ba7df24","device":{"hex2send":"260006016c360e0d0f0d0d290c0f0c2a0e0d0f0d0e0d0f270e28100b0f0d0d0e0c2a0e28100b0e0e0c0f0d0e0d0e0f0d0f0c0f0c0c100c0f0e0d0e0d0e0d0f270e0d0e0e0e0d0e0d0f0d0d0e0f0c0e280f0c0e0e0e0d0f0c0f270e2810270d290f270c2a0f2710260e0b110d0e280f0d0c0e0d0f0e0d0e0d0e0e0f0c0f0c0d290e28100b0e0e0c2a0e0d0f0c0f0e0b2a0e2810260d0e0d0f0e0b10280f0c0d0e0e0e0e0d0e0e0e0c0f0d0e280e0d0e0d0f0c0f0e0b0f0c0f0d0e0e0e0e0d0e0d0e0d0d0f0d0e0c0f0d0e0e0d0f0d0f0c0c0f0e0e0c0f0e0d0f0c0e0c100c0f0d0e0e0b100d0d0e0e0e0d0f0c0e0d0f0b0e2a0f0c100b0e280e290e280c0e0e290f270e0e0c0f0e000d050000","ip":"192.168.1.6","port":"80","type":"rm2","name":"321e7ba7df24","mac":"321e7ba7df24"}}
[2020-01-20 15:50:18][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-01-20 15:50:18][DEBUG] : Client disconnected from [127.0.0.1:48072]
[2020-01-20 15:50:18][DEBUG] : Send command
[2020-01-20 15:50:18][DEBUG] : Connecting to Broadlink device with name 321e7ba7df24....
[2020-01-20 15:50:18][DEBUG] : Connected to Broadlink device with name 321e7ba7df24....
[2020-01-20 15:50:18][DEBUG] : Code Sent....
[2020-01-20 15:50:37][DEBUG] : Client connected to [127.0.0.1:48086]
[2020-01-20 15:50:37][DEBUG] : Message read from socket: {"apikey":"xxx","cmd":"send","cmdType":"command","mac":"8b37fd770f78","device":{"hex2send":"260006016c360e0d0f0d0d290c0f0c2a0e0d0f0d0e0d0f270e28100b0f0d0d0e0c2a0e28100b0e0e0c0f0d0e0d0e0f0d0f0c0f0c0c100c0f0e0d0e0d0e0d0f270e0d0e0e0e0d0e0d0f0d0d0e0f0c0e280f0c0e0e0e0d0f0c0f270e2810270d290f270c2a0f2710260e0b110d0e280f0d0c0e0d0f0e0d0e0d0e0e0f0c0f0c0d290e28100b0e0e0c2a0e0d0f0c0f0e0b2a0e2810260d0e0d0f0e0b10280f0c0d0e0e0e0e0d0e0e0e0c0f0d0e280e0d0e0d0f0c0f0e0b0f0c0f0d0e0e0e0e0d0e0d0e0d0d0f0d0e0c0f0d0e0e0d0f0d0f0c0c0f0e0e0c0f0e0d0f0c0e0c100c0f0d0e0e0b100d0d0e0e0e0d0f0c0e0d0f0b0e2a0f0c100b0e280e290e280c0e0e290f270e0e0c0f0e000d050000","ip":"192.168.1.21","port":"80","type":"rm2","name":"Broadlink","mac":"8b37fd770f78"}}
[2020-01-20 15:50:37][DEBUG] : Client disconnected from [127.0.0.1:48086]
[2020-01-20 15:50:37][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2020-01-20 15:50:37][DEBUG] : Send command
[2020-01-20 15:50:37][DEBUG] : Connecting to Broadlink device with name Broadlink....
[2020-01-20 15:50:38][DEBUG] : Connected to Broadlink device with name Broadlink....
[2020-01-20 15:50:38][DEBUG] : Code Sent....
