zigbee2mqtt_z2m_debug :
> zigbee2mqtt@1.22.2 start /opt/zigbee2mqtt
> node index.js
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Loaded state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Logging to console and directory: '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-01-22.11-38-19' filename: log.txt
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2022-01-21.20-47-48'
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Starting Zigbee2MQTT version 1.22.2 (commit #1a0a9a6e)
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Starting zigbee-herdsman (0.13.188)
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","network":{"channelList":[11],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":6754},"serialPort":{"adapter":"deconz","path":"/dev/ttyACM0"}}'
2022-01-22T10:38:21.780Z zigbee-herdsman:adapter Path '/dev/ttyACM0' is valid for 'DeconzAdapter'
2022-01-22T10:38:21.782Z zigbee-herdsman:deconz:driver Set delay to 0
CREATED DECONZ ADAPTER
2022-01-22T10:38:21.784Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[1,3,5,7,9,11,13,15,0,2,4,6,8,10,12,13],"panID":6754,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[11]},"serialPort":{"path":"/dev/ttyACM0","adapter":"deconz"},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2022-01-22T10:38:21.784Z zigbee-herdsman:deconz:driver Opening with /dev/ttyACM0
2022-01-22T10:38:21.792Z zigbee-herdsman:deconz:driver Serialport opened
2022-01-22T10:38:21.793Z zigbee-herdsman:controller:log Started with result 'resumed'
2022-01-22T10:38:21.793Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2022-01-22T10:38:21.794Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2022-01-22T10:38:21.801Z zigbee-herdsman:deconz:frameParser MAC: 0x00212effff071d08
2022-01-22T10:38:21.804Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 2 paramId: 7
2022-01-22T10:38:21.807Z zigbee-herdsman:deconz:frameParser NWKADDR: 0
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: zigbee-herdsman started (resumed)
2022-01-22T10:38:21.815Z zigbee-herdsman:deconz:driver send read firmware version request from queue. seqNr: 3
2022-01-22T10:38:21.818Z zigbee-herdsman:deconz:frameParser read firmware version response - version: 0,7,104,38
e[32mZigbee2MQTT:info e[39m 2022-01-22 11:38:21: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":104,"product":0,"revision":"0x26680700","transportrev":0},"type":"ConBee2/RaspBee2"}'
2022-01-22T10:38:21.821Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 4 paramId: 5
2022-01-22T10:38:21.824Z zigbee-herdsman:deconz:frameParser PANID: 1a62
2022-01-22T10:38:21.827Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 5 paramId: 11
2022-01-22T10:38:21.830Z zigbee-herdsman:deconz:frameParser APS_EXT_PANID: 0xdddddddddddddddd
2022-01-22T10:38:21.832Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 6 paramId: 28
2022-01-22T10:38:21.834Z zigbee-herdsman:deconz:frameParser CHANNEL: 11
2022-01-22T10:38:21.837Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 7 paramId: 24
2022-01-22T10:38:21.839Z zigbee-herdsman:deconz:frameParser NETWORK_KEY: hidden
e[34mZigbee2MQTT:debuge[39m 2022-01-22 11:38:21: Zigbee network parameters: {"channel":11,"extendedPanID":"0xdddddddddddddddd","panID":6754}
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Failed to start zigbee
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: Exiting...
e[31mZigbee2MQTT:errore[39m 2022-01-22 11:38:21: TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received undefined
at new NodeError (internal/errors.js:322:7)
at validateString (internal/validators.js:124:11)
at Object.join (path.js:1148:7)
at Object.joinPath (/opt/zigbee2mqtt/lib/util/data.ts:17:17)
at writeDevicesOrGroups (/opt/zigbee2mqtt/lib/util/settings.ts:205:38)
at write (/opt/zigbee2mqtt/lib/util/settings.ts:211:5)
at Object.addDevice (/opt/zigbee2mqtt/lib/util/settings.ts:515:5)
at Device.ensureInSettings (/opt/zigbee2mqtt/lib/model/device.ts:37:22)
at Zigbee.resolveDevice (/opt/zigbee2mqtt/lib/zigbee.ts:230:20)
at /opt/zigbee2mqtt/lib/zigbee.ts:272:30
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.22.2 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.22.2 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-01-22T10_38_22_087Z-debug.log
zigbee2mqtt_dep :
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
Hit:4 http://deb.debian.org/debian buster-backports InRelease
Hit:5 https://deb.nodesource.com/node_16.x buster InRelease
Hit:6 http://mirrors.xtom.de/armbian buster InRelease
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
make is already the newest version (4.2.1-1.2).
git is already the newest version (1:2.20.1-2+deb10u4).
0 upgraded, 0 newly installed, 0 to remove and 189 not upgraded.
##### Install or update NodeJs
NodeJs 16 already installed : Nothing to do !
# INSTALLING : Mosquitto (server) #
mosquitto is already the newest version (1.5.7-1+deb10u1).
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
From https://github.com/Koenkk/zigbee2mqtt
ab126138..0e4ea6a3 dev -> origin/dev
##### Compiling for NodeJS version 16
##### Updating...
error: Your local changes to the following files would be overwritten by merge:
package-lock.json
Please commit your changes or stash them before you merge.
Aborting
Updating bc4ffc00..52e545f9
##### Compiling for production (Branch: master)
added 815 packages, and audited 816 packages in 36s
83 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
##### Force zigbee-herdsman-converters update
up to date, audited 816 packages in 6s
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
