ma mise à jour ne se fait plus lorsque je relance les dépendances .
# INSTALL : Zigbee2mqtt #
##### apt-get update in progress
Hit:1 http://deb.debian.org/debian buster InRelease
Get:2 http://deb.debian.org/debian buster-updates InRelease [56.6 kB]
Get:3 http://security.debian.org/debian-security buster/updates InRelease [34.8 kB]
Get:4 https://deb.nodesource.com/node_16.x buster InRelease [4584 B]
Get:5 http://security.debian.org/debian-security buster/updates/main Sources [274 kB]
Get:6 http://security.debian.org/debian-security buster/updates/main amd64 Packages [392 kB]
Get:7 http://security.debian.org/debian-security buster/updates/main Translation-en [209 kB]
Get:8 https://deb.nodesource.com/node_16.x buster/main amd64 Packages [774 B]
Fetched 972 kB in 1s (772 kB/s)
Reading package lists...
##### Install or update Git
Building dependency tree...
Reading state information...
g++ is already the newest version (4:8.3.0-1).
gcc is already the newest version (4:8.3.0-1).
make is already the newest version (4.2.1-1.2).
git is already the newest version (1:2.20.1-2+deb10u4).
The following package was automatically installed and is no longer required:
linux-image-4.19.0-20-amd64
Use 'sudo apt autoremove' to remove it.
0 upgraded, 0 newly installed, 0 to remove and 20 not upgraded.
##### Install or update NodeJs
NodeJs 16 already installed : Nothing to do !
# INSTALLING : Mosquitto for Php #
Mosquitto for Php is already installed, nothing to do
##### Install Socat
Socat is already installed, nothing to do
##### Install yaml php and restart apache
Yaml is already installed, nothing to do
##### Stopping Zigbee2mqtt deamon #
##### Update : Download update from Zigbee2mqtt git
From https://github.com/Koenkk/zigbee2mqtt
31f00229..e66fe853 master -> origin/master
9540b6c1..98a6a2df dev -> origin/dev
* [new tag] 1.28.2 -> 1.28.2
##### Compiling for NodeJS version 16
##### Updating...
package-lock.json
Please commit your changes or stash them before you merge.
Aborting
Updating 31f00229..e66fe853
##### Compiling for production (Branch: master)
added 813 packages, and audited 814 packages in 18s
81 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
##### Force zigbee-herdsman-converters update
up to date, audited 814 packages in 3s
##### Configure deamon and start it
Created symlink /etc/systemd/system/multi-user.target.wants/zigbee2mqtt.service -> /etc/systemd/system/zigbee2mqtt.service.
# END #
Merci de votre aide.
