Version Jeedom 4.1.27, VM sur Synology
Plugin en version stable : 2021-12-10 07:30:57
Version de l’application ANDROID : 1.0.0
Je peux créer un équipement mais impossible d’aller plus loin. On dirait une icompatibilité avec un autre plugin …
Log sur le plugin. Entre « étoiles » ce que j’ai anonymisé (au cas où)
[2021-11-26 12:45:28][INFO] : No token defined. Please connect your device first
[2021-11-26 12:46:03][INFO] : Stopping daemon
[2021-12-10 10:23:15][INFO] : Début d'activation du plugin
[2021-12-10 10:23:16][INFO] : Info sur le démon : {"launchable_message":"","launchable":"nok","state":"nok","log":"nok","auto":0}
[2021-12-10 10:23:33][ERROR] : Error with 'SET_APPSTATE' method - Can't find eqLogic
[2021-12-10 10:24:01][INFO] : Stopping daemon
[2021-12-10 10:24:01][INFO] : Starting daemon
[2021-12-10 10:24:01][INFO] : Listenning on port 8090
[2021-12-10 10:24:18][DEBUG] : user session:07Qp5ri2jYLOXYihCTRKadu4Rm7tBqf0
[2021-12-10 10:24:18][DEBUG] : getWidgets for all widgets with full config
[2021-12-10 10:24:23][DEBUG] : Generate qrcode with data {"useWs":0,"httpUrl":"https:\/\/**NDD**","internalHttpUrl":"http:\/\/**IPLOCALE**","wsAddress":"ws:\/\/NDD:8090","internalWsAddress":"ws:\/\/**IPLOCALE**:8090","apiKey":"**7xxxxxxxxxxxxxxxxxxxx80**","userHash":"07Qp5ri2jYLOXYihCTRKadu4Rm7tBqf0","eqName":"Oneplus"}
[2021-12-10 10:24:23][DEBUG] : Saving conf in file : /var/www/html/plugins/JeedomConnect/core/class/../../data/configs/7d0cbcc165d7ab62bd3c8bbc8bfaad80.json
[2021-12-10 10:24:23][INFO] : No token defined. Please connect your device first
[2021-12-10 10:24:23][DEBUG] : add new cmd Notification
[2021-12-10 10:24:24][DEBUG] : user session:07Qp5ri2jYLOXYihCTRKadu4Rm7tBqf0
[2021-12-10 10:24:24][DEBUG] : getWidgets for all widgets with full config
[2021-12-10 10:26:11][DEBUG] : ¤¤¤¤¤ only send the config file without enrichment for apikey **7xxxxxxxxxxxxxxxxx80**
[2021-12-10 10:26:11][DEBUG] : user session:07Qp5ri2jYLOXYihCTRKadu4Rm7tBqf0
[2021-12-10 10:28:35][DEBUG] : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"active","apiKey":"27bf61c9a35bcc9f44605dbadf32af26"},"jsonrpc":"2.0","id":1639128515008}
[2021-12-10 10:28:35][ERROR] : Error with 'SET_APPSTATE' method - Can't find eqLogic
[2021-12-10 10:28:42][DEBUG] : [API] HTTP Received {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"27bf61c9a35bcc9f44605dbadf32af26"},"jsonrpc":"2.0","id":1639128522782}
[2021-12-10 10:28:42][ERROR] : Error with 'SET_APPSTATE' method - Can't find eqLogic
[2021-12-10 10:36:12][DEBUG] : ¤¤¤¤¤ only send the config file without enrichment for apikey **7xxxxxxxxxxxxxxxxxxxxxxxx80**
[2021-12-10 10:36:12][DEBUG] : user session:07Qp5ri2jYLOXYihCTRKadu4Rm7tBqf0
Coté Jeedom j’ai une erreur Info (orange)
2021-12-10 10:28:42 JeedomConnect Error with ‹ SET_APPSTATE › method - Can’t find eqLogic
Le QRcode ne se génére pas, si je le force avec le bouton régénérer j’ai une info /!\ dans Jeedom
https://**NDD**/core/php/getResource.php?file=plugins/JeedomConnect/desktop/js/JeedomConnect.js&md5=9c2d093f6867c3243820e6bf05081fce&lang=fr_FR
757 Uncaught SyntaxError: Unexpected token ?
Le bouton ‹ configurer l’appareil › me retourne lui aussi
https://**NDD**/index.php?v=d&m=JeedomConnect&p=JeedomConnect
par contre EFFECTIVEMENT je n’ai pas la modification pour le websocket (mais comme tu le dis, en HTTP ca devrait déjà fonctionner).
je vais regarder si je peux de nouveau reproduire mais sans garantie. Si ce forum pouvait notifier par email ca serait tellement plus ‹ social ›
