Bonjour. Exemple la vanne de la chambre d’ami. La commande VanneGet retourne la valeur 65 sous Jeedom et 0 (ce qui me parrait plus normal) sous SmartLife
[2021-10-20 09:03:05][DEBUG] : >>>>Daemon Started
[2021-10-20 09:03:05][DEBUG] : Memory used :1889 ko 568 o
[2021-10-20 09:03:05][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices - V1.80 stable <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:03:05][DEBUG] : ** Bureau - TuyaCustom2_V2 @192.168.1.173 - c:4 **
[2021-10-20 09:03:05][DEBUG] : Key not set New device: created @192.168.1.173 ADD New device @192.168.1.173 channel:4 key:0 @192.168.1.173 c:4 d:0
[2021-10-20 09:03:05][DEBUG] : ** Ch. Parents - TuyaCustom2_V2 @192.168.1.173 - c:8 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:8 key:0 @192.168.1.173 c:8 d:0
[2021-10-20 09:03:05][DEBUG] : ** Ch.Amis - TuyaCustom2_V2 @192.168.1.173 - c:1 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:1 key:0 @192.168.1.173 c:1 d:0
[2021-10-20 09:03:05][DEBUG] : ** Cuisine - TuyaCustom2_V2 @192.168.1.173 - c:5 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:5 key:0 @192.168.1.173 c:5 d:0
[2021-10-20 09:03:05][DEBUG] : ** Gateway ZigBee - TuyaCustom2_Hub_V2 @192.168.1.173 - c:10 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:10 key:0 @192.168.1.173 c:10 d:0
[2021-10-20 09:03:05][DEBUG] : ** Home Cinéma - TuyaCustom2_V2 @192.168.1.173 - c:2 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:2 key:0 @192.168.1.173 c:2 d:0
[2021-10-20 09:03:05][DEBUG] : ** Salon - TuyaCustom2_V2 @192.168.1.173 - c:6 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:6 key:0 @192.168.1.173 c:6 d:0
[2021-10-20 09:03:05][DEBUG] : ** DectectMvt1 - TuyaCustom2_V2 @192.168.1.173 - c:3 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:3 key:0 @192.168.1.173 c:3 d:0
[2021-10-20 09:03:05][DEBUG] : ** Inter Entrée - TuyaCustom2_V2 @192.168.1.173 - c:7 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:7 key:0 @192.168.1.173 c:7 d:0
[2021-10-20 09:03:05][DEBUG] : ** Boutton Salon - TuyaCustom2_V2 @192.168.1.173 - c:9 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:9 key:0 @192.168.1.173 c:9 d:0
[2021-10-20 09:03:05][DEBUG] : ** Prise 1 - TuyaCustom2_V2 @192.168.1.173 - c:13 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:13 key:0 @192.168.1.173 c:13 d:0
[2021-10-20 09:03:05][DEBUG] : ** Prise 2 - TuyaCustom2_V2 @192.168.1.173 - c:14 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:14 key:0 @192.168.1.173 c:14 d:0
[2021-10-20 09:03:05][DEBUG] : ** Prise 3 - TuyaCustom2_V2 @192.168.1.173 - c:12 **
[2021-10-20 09:03:05][DEBUG] : Key:0 Diff:0 Socket already created @192.168.1.173 ADD New device @192.168.1.173 channel:12 key:0 @192.168.1.173 c:12 d:0
[2021-10-20 09:03:05][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Memory used :2035 ko <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:03:05][DEBUG] : << Update state of: Bureau @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"bc33acfffe458937","cid":"bc33acfffe458937"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : No dps states to update
[2021-10-20 09:03:05][DEBUG] : No other states to update
[2021-10-20 09:03:05][DEBUG] : << Update state of: Ch. Parents @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"5c0272fffedabe27","cid":"5c0272fffedabe27"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: Ch.Amis @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"5c0272fffedc37c2","cid":"5c0272fffedc37c2"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: Cuisine @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"5c0272fffedabe2f","cid":"5c0272fffedabe2f"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: Gateway ZigBee @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"bfca9bfdc3bb1d999cfmcq","cid":"bfca9bfdc3bb1d999cfmcq"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: Home Cinéma @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"847127fffe9f3247","cid":"847127fffe9f3247"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: Salon @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"5c0272fffedc3762","cid":"5c0272fffedc3762"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:05][DEBUG] : << Update state of: DectectMvt1 @192.168.1.173
[2021-10-20 09:03:05][DEBUG] : Cmd to 192.168.1.173: {"gwId":"847127fffe0d0f40","cid":"847127fffe0d0f40"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : No other states to update
[2021-10-20 09:03:06][DEBUG] : << Update state of: Inter Entrée @192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Cmd to 192.168.1.173: {"gwId":"bc33acfffed85171","cid":"bc33acfffed85171"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : No dps states to update
[2021-10-20 09:03:06][DEBUG] : << Update state of: Boutton Salon @192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Cmd to 192.168.1.173: {"gwId":"847127fffe0d1c08","cid":"847127fffe0d1c08"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : << Update state of: Prise 1 @192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Cmd to 192.168.1.173: {"gwId":"d88e1ac6950f46ed","cid":"d88e1ac6950f46ed"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : << Update state of: Prise 2 @192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Cmd to 192.168.1.173: {"gwId":"a8bf56d0086cc706","cid":"a8bf56d0086cc706"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : << Update state of: Prise 3 @192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Cmd to 192.168.1.173: {"gwId":"bf5fc85640e7146080arul","cid":"bf5fc85640e7146080arul"} - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:06][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:03:06][DEBUG] : Mess: {"dps":{"2":190,"3":200,"4":"auto","7":true,"13":0,"44":-20,"105":300,"106":"normal","108":15,"109":75,"110":false,"111":"0","114":15,"115":false,"116":false,"117":1},"cid":"bc33acfffe458937"} - Read Json OK
[2021-10-20 09:03:06][DEBUG] : found Zigbee:Bureau
[2021-10-20 09:03:06][DEBUG] : Dps2|ConsTempGetZ formula:#value#/10 #value#:190 After:19 Dps3|ValTempGetZ formula:#value#/10 #value#:200 After:20 Dps4|EcoGetZ:auto Dps7|ManLockedGetZ:1 Dps105|TimerBoostGetZ formula:#value#/100 #value#:300 After:3 Dps106|ModeForcedGetZ:normal Dps108|ConsTempEcoGetZ formula:#value# #value#:15 After:15 Dps109|VanneGetZ formula:#value# #value#:75 After:75 Dps114|ConsTempVacGetZ formula:#value# #value#:15 After:15 Dps117|TimerGetZ formula:#value# #value#:1 After:1
[2021-10-20 09:03:06][DEBUG] : Mess: {"dps":{"2":180,"3":195,"4":"auto","7":true,"13":0,"44":-10,"105":300,"106":"normal","107":20,"108":15,"109":0,"110":false,"111":"2","114":15,"115":false,"116":false,"117":1},"cid":"5c0272fffedabe27"} - Read Json OK
[2021-10-20 09:03:06][DEBUG] : found Zigbee:Ch. Parents
[2021-10-20 09:03:06][DEBUG] : Dps2|ConsTempGetZ formula:#value#/10 #value#:180 After:18 Dps3|ValTempGetZ formula:#value#/10 #value#:195 After:19.5 Dps4|EcoGetZ:auto Dps7|ManLockedGetZ:1 Dps105|TimerBoostGetZ formula:#value#/100 #value#:300 After:3 Dps106|ModeForcedGetZ:normal Dps108|ConsTempEcoGetZ formula:#value# #value#:15 After:15 Dps109|VanneGetZ formula:#value# #value#:0 After:0 Dps114|ConsTempVacGetZ formula:#value# #value#:15 After:15 Dps117|TimerGetZ formula:#value# #value#:1 After:1 Dps107|ConsTempConfGetZ formula:#value# #value#:20 After:20
[2021-10-20 09:03:06][DEBUG] : Mess: json obj data unvalid - Bad JSON or Hub Response
[2021-10-20 09:03:06][DEBUG] : Mess: {"dps":{"1":"none","4":100},"cid":"847127fffe0d0f40"} - Read Json OK
[2021-10-20 09:03:06][DEBUG] : found Zigbee:DectectMvt1
[2021-10-20 09:03:06][DEBUG] : Dps1|PresenceGet:none
[2021-10-20 09:03:06][DEBUG] : Mess: {"dps":{"1":false,"2":false,"7":0,"8":0},"cid":"bc33acfffed85171"} - Read Json OK
[2021-10-20 09:03:06][DEBUG] : found Zigbee:Inter Entrée
[2021-10-20 09:03:06][DEBUG] : Dps2|SwOnOffGet_2:0 Dps1|SwOnOffGet_1:0
[2021-10-20 09:03:06][DEBUG] : Mess: devid not found - Bad JSON or Hub Response
[2021-10-20 09:03:22][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:03:22][DEBUG] : Bad local key
[2021-10-20 09:03:38][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:03:38][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:38][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:03:38][DEBUG] : Bad local key
[2021-10-20 09:03:54][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:03:54][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:03:54][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:03:54][DEBUG] : Bad local key
[2021-10-20 09:04:06][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices - V1.80 stable <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:04:06][DEBUG] : ** Bureau - TuyaCustom2_V2 @192.168.1.173 - c:4 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:4 d:12
[2021-10-20 09:04:06][DEBUG] : ** Ch. Parents - TuyaCustom2_V2 @192.168.1.173 - c:8 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:8 d:12
[2021-10-20 09:04:06][DEBUG] : ** Ch.Amis - TuyaCustom2_V2 @192.168.1.173 - c:1 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:1 d:12
[2021-10-20 09:04:06][DEBUG] : ** Cuisine - TuyaCustom2_V2 @192.168.1.173 - c:5 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:5 d:12
[2021-10-20 09:04:06][DEBUG] : ** Gateway ZigBee - TuyaCustom2_Hub_V2 @192.168.1.173 - c:10 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:10 d:12
[2021-10-20 09:04:06][DEBUG] : ** Home Cinéma - TuyaCustom2_V2 @192.168.1.173 - c:2 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:2 d:12
[2021-10-20 09:04:06][DEBUG] : ** Salon - TuyaCustom2_V2 @192.168.1.173 - c:6 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:6 d:12
[2021-10-20 09:04:06][DEBUG] : ** DectectMvt1 - TuyaCustom2_V2 @192.168.1.173 - c:3 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:3 d:12
[2021-10-20 09:04:06][DEBUG] : ** Inter Entrée - TuyaCustom2_V2 @192.168.1.173 - c:7 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:7 d:12
[2021-10-20 09:04:06][DEBUG] : ** Boutton Salon - TuyaCustom2_V2 @192.168.1.173 - c:9 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:9 d:12
[2021-10-20 09:04:06][DEBUG] : ** Prise 1 - TuyaCustom2_V2 @192.168.1.173 - c:13 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:13 d:12
[2021-10-20 09:04:06][DEBUG] : ** Prise 2 - TuyaCustom2_V2 @192.168.1.173 - c:14 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:14 d:12
[2021-10-20 09:04:06][DEBUG] : ** Prise 3 - TuyaCustom2_V2 @192.168.1.173 - c:12 **
[2021-10-20 09:04:06][DEBUG] : key:0 @192.168.1.173 c:12 d:12
[2021-10-20 09:04:06][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Memory used :2174 ko <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:04:10][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:04:10][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:04:10][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:04:10][DEBUG] : Bad local key
[2021-10-20 09:04:26][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:04:26][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:04:26][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:04:26][DEBUG] : Bad local key
[2021-10-20 09:04:42][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:04:42][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:04:42][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:04:42][DEBUG] : Bad local key
[2021-10-20 09:04:58][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:04:58][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:05:07][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Search for devices - V1.80 stable <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:05:07][DEBUG] : ** Bureau - TuyaCustom2_V2 @192.168.1.173 - c:4 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:4 d:9
[2021-10-20 09:05:07][DEBUG] : ** Ch. Parents - TuyaCustom2_V2 @192.168.1.173 - c:8 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:8 d:9
[2021-10-20 09:05:07][DEBUG] : ** Ch.Amis - TuyaCustom2_V2 @192.168.1.173 - c:1 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:1 d:9
[2021-10-20 09:05:07][DEBUG] : ** Cuisine - TuyaCustom2_V2 @192.168.1.173 - c:5 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:5 d:9
[2021-10-20 09:05:07][DEBUG] : ** Gateway ZigBee - TuyaCustom2_Hub_V2 @192.168.1.173 - c:10 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:10 d:9
[2021-10-20 09:05:07][DEBUG] : ** Home Cinéma - TuyaCustom2_V2 @192.168.1.173 - c:2 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:2 d:9
[2021-10-20 09:05:07][DEBUG] : ** Salon - TuyaCustom2_V2 @192.168.1.173 - c:6 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:6 d:9
[2021-10-20 09:05:07][DEBUG] : ** DectectMvt1 - TuyaCustom2_V2 @192.168.1.173 - c:3 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:3 d:9
[2021-10-20 09:05:07][DEBUG] : ** Inter Entrée - TuyaCustom2_V2 @192.168.1.173 - c:7 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:7 d:9
[2021-10-20 09:05:07][DEBUG] : ** Boutton Salon - TuyaCustom2_V2 @192.168.1.173 - c:9 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:9 d:9
[2021-10-20 09:05:07][DEBUG] : ** Prise 1 - TuyaCustom2_V2 @192.168.1.173 - c:13 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:13 d:9
[2021-10-20 09:05:07][DEBUG] : ** Prise 2 - TuyaCustom2_V2 @192.168.1.173 - c:14 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:14 d:9
[2021-10-20 09:05:07][DEBUG] : ** Prise 3 - TuyaCustom2_V2 @192.168.1.173 - c:12 **
[2021-10-20 09:05:07][DEBUG] : key:0 @192.168.1.173 c:12 d:9
[2021-10-20 09:05:07][DEBUG] : >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> Memory used :2174 ko <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
[2021-10-20 09:05:14][DEBUG] : << Ping of: Bureau @192.168.1.173 diff:16
[2021-10-20 09:05:14][DEBUG] : Cmd to 192.168.1.173: - Try:192.168.1.173 6668 - Connect OK!
[2021-10-20 09:05:14][DEBUG] : Receive from:192.168.1.173
[2021-10-20 09:05:14][DEBUG] : Bad local key
