Soucis démarrage service Zigbee2MQTT
Après avoir tenté un appairage sur un routeur uniquement le pluin zogbee2MQTT ne fonctionne plus, je suis sous Rasp3 avec la clé Conbee2
J’ai relancé l’installation des dépendances et redémarré Zigbee2MQTT en débug.
Voici le Log :
> zigbee2mqtt@1.22.1 start /opt/zigbee2mqtt
> node index.js
e[34mZigbee2MQTT:debuge[39m 2021-12-15 11:49:30: Loaded state from file /var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/state.json
e[32mZigbee2MQTT:info e[39m 2021-12-15 11:49:30: Logging to console and directory: '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2021-12-15.11-49-24' filename: log.txt
e[34mZigbee2MQTT:debuge[39m 2021-12-15 11:49:30: Removing old log directory '/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/log/2021-11-18.05-41-49'
e[32mZigbee2MQTT:info e[39m 2021-12-15 11:49:30: Starting Zigbee2MQTT version 1.22.1 (commit #c2b5229f)
e[32mZigbee2MQTT:info e[39m 2021-12-15 11:49:30: Starting zigbee-herdsman (0.13.176)
e[34mZigbee2MQTT:debuge[39m 2021-12-15 11:49:30: Using zigbee-herdsman with settings: '{"adapter":{"concurrent":null,"delay":null,"disableLED":false},"backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","network":{"channelList":[20],"extendedPanID":[221,221,221,221,221,221,221,221],"networkKey":"HIDDEN","panID":63567},"serialPort":{"adapter":"deconz"}}'
2021-12-15T11:49:31.349Z zigbee-herdsman:adapter No path provided, auto detecting path
2021-12-15T11:49:31.962Z zigbee-herdsman:adapter Auto detected path '/dev/ttyACM1' from adapter 'DeconzAdapter'
2021-12-15T11:49:31.966Z zigbee-herdsman:deconz:driver Set delay to 0
CREATED DECONZ ADAPTER
2021-12-15T11:49:31.969Z zigbee-herdsman:controller:log Starting with options '{"network":{"networkKeyDistribute":false,"networkKey":[175,85,95,241,38,45,250,104,254,197,206,76,27,172,193,224],"panID":63567,"extendedPanID":[221,221,221,221,221,221,221,221],"channelList":[20]},"serialPort":{"path":"/dev/ttyACM1","adapter":"deconz"},"databasePath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db","databaseBackupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/database.db.backup","backupPath":"/var/www/html/plugins/zigbee2mqtt/data/zigbee2mqtt/coordinator_backup.json","adapter":{"disableLED":false,"concurrent":null,"delay":null}}'
2021-12-15T11:49:31.970Z zigbee-herdsman:deconz:driver Opening with /dev/ttyACM1
2021-12-15T11:49:31.985Z zigbee-herdsman:deconz:driver Serialport opened
2021-12-15T11:49:31.987Z zigbee-herdsman:controller:log Started with result 'resumed'
2021-12-15T11:49:31.988Z zigbee-herdsman:controller:log Injected database: true, adapter: true
2021-12-15T11:49:31.990Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 1 paramId: 1
2021-12-15T11:49:32.009Z zigbee-herdsman:deconz:frameParser MAC: 0x00212effff05d0d2
2021-12-15T11:49:32.012Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 2 paramId: 7
2021-12-15T11:49:32.016Z zigbee-herdsman:deconz:frameParser NWKADDR: 0
e[32mZigbee2MQTT:info e[39m 2021-12-15 11:49:32: zigbee-herdsman started (resumed)
2021-12-15T11:49:32.037Z zigbee-herdsman:deconz:driver send read firmware version request from queue. seqNr: 3
2021-12-15T11:49:32.043Z zigbee-herdsman:deconz:frameParser read firmware version response - version: 0,7,114,38
e[32mZigbee2MQTT:info e[39m 2021-12-15 11:49:32: Coordinator firmware version: '{"meta":{"maintrel":0,"majorrel":38,"minorrel":114,"product":0,"revision":"0x26720700","transportrev":0},"type":"ConBee2/RaspBee2"}'
2021-12-15T11:49:32.055Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 4 paramId: 5
2021-12-15T11:49:32.060Z zigbee-herdsman:deconz:frameParser PANID: f84f
2021-12-15T11:49:32.062Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 5 paramId: 11
2021-12-15T11:49:32.066Z zigbee-herdsman:deconz:frameParser APS_EXT_PANID: 0xdddddddddddddddd
2021-12-15T11:49:32.068Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 6 paramId: 28
2021-12-15T11:49:32.072Z zigbee-herdsman:deconz:frameParser CHANNEL: 20
2021-12-15T11:49:32.075Z zigbee-herdsman:deconz:driver send read parameter request from queue. seqNr: 7 paramId: 24
2021-12-15T11:49:32.079Z zigbee-herdsman:deconz:frameParser NETWORK_KEY: hidden
e[34mZigbee2MQTT:debuge[39m 2021-12-15 11:49:32: Zigbee network parameters: {"channel":20,"extendedPanID":"0xdddddddddddddddd","panID":63567}
e[31mZigbee2MQTT:errore[39m 2021-12-15 11:49:32: Failed to start zigbee
e[31mZigbee2MQTT:errore[39m 2021-12-15 11:49:32: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
e[31mZigbee2MQTT:errore[39m 2021-12-15 11:49:32: Exiting...
e[31mZigbee2MQTT:errore[39m 2021-12-15 11:49:32: TypeError [ERR_INVALID_ARG_TYPE]: The "path" argument must be of type string. Received undefined
    at new NodeError (internal/errors.js:322:7)
    at validateString (internal/validators.js:124:11)
    at Object.join (path.js:1148:7)
    at Object.joinPath (/opt/zigbee2mqtt/lib/util/data.ts:17:17)
    at writeDevicesOrGroups (/opt/zigbee2mqtt/lib/util/settings.ts:205:38)
    at write (/opt/zigbee2mqtt/lib/util/settings.ts:211:5)
    at Object.addDevice (/opt/zigbee2mqtt/lib/util/settings.ts:512:5)
    at Device.ensureInSettings (/opt/zigbee2mqtt/lib/model/device.ts:28:22)
    at Zigbee.resolveDevice (/opt/zigbee2mqtt/lib/zigbee.ts:228:20)
    at /opt/zigbee2mqtt/lib/zigbee.ts:270:30
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! zigbee2mqtt@1.22.1 start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the zigbee2mqtt@1.22.1 start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2021-12-15T11_49_33_178Z-debug.log
Si vous identifiez quelques choses.
Page Santé sans erreur car le démon ne passe pas en arrêt.
Version de Jeedom 4.1.27
Raspbian 10 Buster
Version Zigbee2MQTT 1.22.1
Installation complète de Zigbeelinker tout sur la raspberry
La clé n’est pas sur un HUB mais bien avec une rallonge USB et tout fonctionnait sans soucis depuis plus d’1 mois.
A +
Salut, regarde si tu n’as rien de bizarre dans ton fichier de configuration z2mqtt
J’ai ça dans le fichier de configuration :
homeassistant: false
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: mqtt://192.168.1.35:1883
  reject_unauthorized: true
  include_device_information: true
  keepalive: 60
serial:
  adapter: deconz
advanced:
  channel: 20
  network_key:
  - 175
  - 85
  - 95
  - 241
  - 38
  - 45
  - 250
  - 104
  - 254
  - 197
  - 206
  - 76
  - 27
  - 172
  - 193
  - 224
  pan_id: 63567
  log_level: debug
frontend:
  host: 192.168.1.35
  port: 8080
devices:
  "0xa4c138b19ec0f168":
    friendly_name: VR Bureau
    invert_cover: true
  "0x60a423fffe7bf1ab":
    friendly_name: LED TV
  "0x000d6ffffeb01a42":
    friendly_name: VR SàM
    invert_cover: true
  "0xa4c1382f2bdadca7":
    friendly_name: VR Cellier
    invert_cover: true
  "0x000d6ffffebf0c89":
    friendly_name: VRCuisineSud
    invert_cover: true
  "0x086bd7fffe01a749":
    friendly_name: VRCuisineEst
    invert_cover: true
  "0x00158d0005222f64":
    friendly_name: PorteEntrée
  "0x00158d00052dd252":
    friendly_name: PorteCellier
    temperature_calibration: -5
  "0xa4c13886b77ab69e":
    friendly_name: VRChambreSud
    invert_cover: true
  "0xa4c138fe7b8d5c24":
    friendly_name: VRChambreOuest
    invert_cover: true
  "0x804b50fffeb71bd3":
    friendly_name: "0x804b50fffeb71bd3"
  "0xa4c138e2c4ab7ec8":
    friendly_name: VRSalon
    invert_cover: true
  "0xa4c1382baada0a55":
    friendly_name: VRStoreNord
    invert_cover: true
groups: []
external_converters: []
Je ne vois rien d’étrange. :frowning:
Essaye en effaçant
groups: [ ]
external_converters: [ ]
SUPER !
Merci, c’était bien çà. :slight_smile:
Impec !
Bonne soirée :slight_smile:
