Bonsoir
Je suis en jeedom 3.3.60
openvpn stable 2023 11 07
page santé ci dessous
log openvpn ci dessous
|[2023-12-16 00:01:21][ERROR] : Erreur sur la fonction cron5 du plugin : [MySQL] Error code : 42S02 (1146). Table ‹ jeedom.object › doesn’t exist : SELECT el.id, el.name, el.logicalId, el.generic_type, el.object_id, el.eqType_name, el.eqReal_id, el.isVisible, el.isEnable, el.configuration, el.timeout, el.category, el.display, el.order, el.comment, el.tags ||FROM eqLogic el ||LEFT JOIN object ob ON el.object_id=ob.id ||WHERE eqType_name=:eqType_name ORDER BY ob.name,el.name|
LOG OPENVPN_DNS_JEEDOM_1
Sat Dec 16 16:21:45 2023 OpenVPN 2.3.4 arm-unknown-linux-gnueabihf [SSL (OpenSSL)] [LZO] [EPOLL] [PKCS11] [MH] [IPv6] built on Jun 26 2017
Sat Dec 16 16:21:45 2023 library versions: OpenSSL 1.0.1k 8 Jan 2015, LZO 2.08
Sat Dec 16 16:21:45 2023 WARNING: file '/tmp/jeedom/openvpn/openvpn_auth_39ijPd40ef1hfvQ14dcHah6PSvnnKD.conf' is group or others accessible
Sat Dec 16 16:21:45 2023 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Sat Dec 16 16:21:45 2023 UDPv4 link local: [undef]
Sat Dec 16 16:21:45 2023 UDPv4 link remote: [AF_INET]51.159.136.63:1197
Sat Dec 16 16:21:45 2023 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Sat Dec 16 16:21:45 2023 VERIFY OK: depth=1, C=FR, ST=IDF, L=Paris, O=jeedom.com, OU=jeedom.com, CN=jeedom.com CA, name=jeedom, emailAddress=postmaster@jeedom.com
Sat Dec 16 16:21:45 2023 VERIFY OK: depth=0, C=FR, ST=IDF, L=Paris, O=jeedom.com, OU=jeedom.com, CN=server, name=jeedom, emailAddress=postmaster@jeedom.com
Sat Dec 16 16:21:45 2023 WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1542', remote='link-mtu 1342'
Sat Dec 16 16:21:45 2023 WARNING: 'tun-mtu' is used inconsistently, local='tun-mtu 1500', remote='tun-mtu 1300'
Sat Dec 16 16:21:45 2023 Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Dec 16 16:21:45 2023 Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Dec 16 16:21:45 2023 Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Sat Dec 16 16:21:45 2023 Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Sat Dec 16 16:21:45 2023 Control Channel: TLSv1, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-SHA, 1024 bit RSA
Sat Dec 16 16:21:45 2023 [server] Peer Connection Initiated with [AF_INET]51.159.136.63:1197
Sat Dec 16 16:21:47 2023 TUN/TAP device tun0 opened
Sat Dec 16 16:21:47 2023 do_ifconfig, tt->ipv6=0, tt->did_ifconfig_ipv6_setup=0
Sat Dec 16 16:21:47 2023 /sbin/ip link set dev tun0 up mtu 1500
Sat Dec 16 16:21:47 2023 /sbin/ip addr add dev tun0 local 10.12.0.26 peer 10.12.0.25
Sat Dec 16 16:21:47 2023 Initialization Sequence Completed
merci de votre aide
