En complément, ce log RFXCOM en mode debug après relance du démon : il y a des informations au sujet des sondes que je ne sais évidemment pas interpréter
[2019-10-18 11:46:13][DEBUG] : Decode data : {'temperature': '19.6', 'raw': '0A520D62970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:46:13][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.6', 'raw': '0A520D62970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:46:13][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:46:13][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:46:25][DEBUG] : Message: 0A 52 0D 63 6C 01 00 E0 36 01 79
[2019-10-18 11:46:25][DEBUG] : Decode : 0A 52 0D 63 6C 01 00 E0 36 01 79
[2019-10-18 11:46:25][DEBUG] : Test message: 0A 52 0D 63 6C 01 00 E0 36 01 79
[2019-10-18 11:46:25][DEBUG] : PacketType: 52
[2019-10-18 11:46:25][DEBUG] : SubType: 0D
[2019-10-18 11:46:25][DEBUG] : SeqNbr: 63
[2019-10-18 11:46:25][DEBUG] : Id1: 6C
[2019-10-18 11:46:25][DEBUG] : Id2: 01
[2019-10-18 11:46:25][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D636C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:46:25][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D636C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:46:25][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:46:25][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:46:48][DEBUG] : Message: 0A 52 0D 64 97 01 00 C4 45 01 79
[2019-10-18 11:46:48][DEBUG] : Decode : 0A 52 0D 64 97 01 00 C4 45 01 79
[2019-10-18 11:46:48][DEBUG] : Test message: 0A 52 0D 64 97 01 00 C4 45 01 79
[2019-10-18 11:46:48][DEBUG] : PacketType: 52
[2019-10-18 11:46:48][DEBUG] : SubType: 0D
[2019-10-18 11:46:48][DEBUG] : SeqNbr: 64
[2019-10-18 11:46:48][DEBUG] : Id1: 97
[2019-10-18 11:46:48][DEBUG] : Id2: 01
[2019-10-18 11:46:48][DEBUG] : Decode data : {'temperature': '19.6', 'raw': '0A520D64970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:46:48][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.6', 'raw': '0A520D64970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:46:48][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:46:48][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:47:00][DEBUG] : Message: 0A 52 0D 65 6C 01 00 E0 36 01 79
[2019-10-18 11:47:00][DEBUG] : Decode : 0A 52 0D 65 6C 01 00 E0 36 01 79
[2019-10-18 11:47:00][DEBUG] : Test message: 0A 52 0D 65 6C 01 00 E0 36 01 79
[2019-10-18 11:47:00][DEBUG] : PacketType: 52
[2019-10-18 11:47:00][DEBUG] : SubType: 0D
[2019-10-18 11:47:00][DEBUG] : SeqNbr: 65
[2019-10-18 11:47:00][DEBUG] : Id1: 6C
[2019-10-18 11:47:00][DEBUG] : Id2: 01
[2019-10-18 11:47:00][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D656C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:47:00][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D656C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:47:00][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:47:00][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:47:34][INFO] : Lancement démon rfxcomd : /usr/bin/python /var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py --device /dev/ttyUSB0 --loglevel debug --socketport 55000 --serialrate 38400 --protocol 6,12,13,18,20,21,22,23 --callback http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php --apikey UA9w2gbqunNpAcQelRAuyJniykOSViw4WMH1wprjVvSv1PpB --cycle 0.3 --pid /tmp/jeedom/rfxcom/deamon.pid
[2019-10-18 11:47:34][INFO] : Start rfxcomd
[2019-10-18 11:47:34][INFO] : Log level : debug
[2019-10-18 11:47:34][INFO] : Socket port : 55000
[2019-10-18 11:47:34][INFO] : Socket host : 127.0.0.1
[2019-10-18 11:47:34][INFO] : PID file : /tmp/jeedom/rfxcom/deamon.pid
[2019-10-18 11:47:34][INFO] : Device : /dev/ttyUSB0
[2019-10-18 11:47:34][INFO] : Apikey : xxxxxxxxxxxx
[2019-10-18 11:47:34][INFO] : Callback : http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php
[2019-10-18 11:47:34][INFO] : Cycle : 0.3
[2019-10-18 11:47:34][INFO] : Serial rate : 38400
[2019-10-18 11:47:34][INFO] : Serial timeout : 9
[2019-10-18 11:47:34][INFO] : Protocol : 6,12,13,18,20,21,22,23
[2019-10-18 11:47:34][INFO] : Find device : /dev/ttyUSB0
[2019-10-18 11:47:34][DEBUG] : Writing PID 20094 to /tmp/jeedom/rfxcom/deamon.pid
[2019-10-18 11:47:34][DEBUG] : Init request module v2.20.0
[2019-10-18 11:47:34][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:47:34][DEBUG] : http://127.0.0.1:80 "GET /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:47:34][DEBUG] : Init serial module v3.4
[2019-10-18 11:47:34][DEBUG] : Start listening...
[2019-10-18 11:47:34][DEBUG] : Socket interface started
[2019-10-18 11:47:34][DEBUG] : Open serial port on device: /dev/ttyUSB0, rate 38400, timeout : 9
[2019-10-18 11:47:34][DEBUG] : Open Serialport
[2019-10-18 11:47:34][DEBUG] : LoopNetServer Thread started
[2019-10-18 11:47:34][DEBUG] : Listening on: [127.0.0.1:55000]
[2019-10-18 11:47:34][DEBUG] : flushOutput serial port
[2019-10-18 11:47:34][DEBUG] : flushInput serial port
[2019-10-18 11:47:34][DEBUG] : Read Socket Thread Launched
[2019-10-18 11:47:34][DEBUG] : Read Device Thread Launched
[2019-10-18 11:47:35][DEBUG] : Message: 0A 52 0D 67 6C 01 00 E0 36 01 79
[2019-10-18 11:47:35][DEBUG] : Decode : 0A 52 0D 67 6C 01 00 E0 36 01 79
[2019-10-18 11:47:35][DEBUG] : Test message: 0A 52 0D 67 6C 01 00 E0 36 01 79
[2019-10-18 11:47:35][DEBUG] : PacketType: 52
[2019-10-18 11:47:35][DEBUG] : SubType: 0D
[2019-10-18 11:47:35][DEBUG] : SeqNbr: 67
[2019-10-18 11:47:35][DEBUG] : Id1: 6C
[2019-10-18 11:47:35][DEBUG] : Id2: 01
[2019-10-18 11:47:35][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D676C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:47:35][DEBUG] : Send rfxcomd_reset
[2019-10-18 11:47:35][DEBUG] : Write data to serial port : 0D 00 00 00 00 00 00 00 00 00 00 00 00 00
[2019-10-18 11:47:35][DEBUG] : Sleep 1 sec
[2019-10-18 11:47:36][DEBUG] : flushInput serial port
[2019-10-18 11:47:36][DEBUG] : Send get status test
[2019-10-18 11:47:36][DEBUG] : Write data to serial port : 0D 00 00 01 02 00 00 00 00 00 00 00 00 00
[2019-10-18 11:47:36][DEBUG] : Message: 14 01 00 01 02 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:36][DEBUG] : Decode : 14 01 00 01 02 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:36][DEBUG] : Test message: 14 01 00 01 02 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:36][DEBUG] : PacketType: 01
[2019-10-18 11:47:36][DEBUG] : SubType: 00
[2019-10-18 11:47:36][DEBUG] : SeqNbr: 01
[2019-10-18 11:47:36][DEBUG] : Id1: 02
[2019-10-18 11:47:36][DEBUG] : Id2: 53
[2019-10-18 11:47:36][DEBUG] : Subtype = Interface response
[2019-10-18 11:47:36][DEBUG] : Sequence nbr = 01
[2019-10-18 11:47:36][DEBUG] : Response on cmnd = Get Status, return firmware versions and configuration of the interface.
[2019-10-18 11:47:36][DEBUG] : Transceiver type = 433.92MHz
[2019-10-18 11:47:36][DEBUG] : Firmware version = 1
[2019-10-18 11:47:36][DEBUG] : Protocols:
[2019-10-18 11:47:36][DEBUG] : Undecoded Disabled
[2019-10-18 11:47:36][DEBUG] : Imagintronix,Opus Disabled
[2019-10-18 11:47:36][DEBUG] : Byron SX,SelectPlus Disabled
[2019-10-18 11:47:36][DEBUG] : RSL,Revolt Disabled
[2019-10-18 11:47:36][DEBUG] : Lightning4 Disabled
[2019-10-18 11:47:36][DEBUG] : FineOffset / Viking Disabled
[2019-10-18 11:47:36][DEBUG] : Rubicson,Alecto,Banggood Enabled
[2019-10-18 11:47:36][DEBUG] : AE Blyss Disabled
[2019-10-18 11:47:36][DEBUG] : Blinds T1/T2/T3/T4 Disabled
[2019-10-18 11:47:36][DEBUG] : Blinds T0 Disabled
[2019-10-18 11:47:36][DEBUG] : Disabled
[2019-10-18 11:47:36][DEBUG] : Legrand CAD Disabled
[2019-10-18 11:47:36][DEBUG] : La Crosse Enabled
[2019-10-18 11:47:36][DEBUG] : Hideki,TFA,Cresta,UPM Enabled
[2019-10-18 11:47:36][DEBUG] : AD Lightwave RF Disabled
[2019-10-18 11:47:36][DEBUG] : Mertik Disabled
[2019-10-18 11:47:36][DEBUG] : Visonic Disabled
[2019-10-18 11:47:36][DEBUG] : ATI/cartelectronic Disabled
[2019-10-18 11:47:36][DEBUG] : Oregon Scientific Enabled
[2019-10-18 11:47:36][DEBUG] : Meiantech,Atlantic Disabled
[2019-10-18 11:47:36][DEBUG] : HomeEasy EU Enabled
[2019-10-18 11:47:36][DEBUG] : AC Enabled
[2019-10-18 11:47:36][DEBUG] : ARC Enabled
[2019-10-18 11:47:36][DEBUG] : X10 Enabled
[2019-10-18 11:47:36][DEBUG] : FunkBus Disabled
[2019-10-18 11:47:36][DEBUG] : Decode data : {'subtype': '00', 'packettype': '01', 'raw': '14010001025301020C2F0001031C03524658434F4D'}
[2019-10-18 11:47:37][DEBUG] : Client connected to [127.0.0.1:51872]
[2019-10-18 11:47:37][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxx","cmd":"add","device":{"id":"E501"}}
[2019-10-18 11:47:37][DEBUG] : Client disconnected from [127.0.0.1:51872]
[2019-10-18 11:47:37][DEBUG] : Message received in socket JEEDOM_SOCKET_MESSAGE
[2019-10-18 11:47:37][DEBUG] : Add device : {u'id': u'E501'}
[2019-10-18 11:47:37][DEBUG] : Client connected to [127.0.0.1:51874]
[2019-10-18 11:47:37][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxx","cmd":"add","device":{"id":"6C01"}}
[2019-10-18 11:47:37][DEBUG] : Client disconnected from [127.0.0.1:51874]
[2019-10-18 11:47:37][DEBUG] : Client connected to [127.0.0.1:51876]
[2019-10-18 11:47:37][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxx","cmd":"add","device":{"id":"4601"}}
[2019-10-18 11:47:37][DEBUG] : Client disconnected from [127.0.0.1:51876]
[2019-10-18 11:47:37][DEBUG] : Client connected to [127.0.0.1:51878]
[2019-10-18 11:47:37][DEBUG] : Message read from socket: {"apikey":"xxxxxxxxxx","cmd":"add","device":{"id":"9701"}}
[2019-10-18 11:47:37][DEBUG] : Client disconnected from [127.0.0.1:51878]
[2019-10-18 11:47:37][INFO] : Démon RFXcom lancé
[2019-10-18 11:47:37][DEBUG] : Add device : {u'id': u'6C01'}
[2019-10-18 11:47:37][DEBUG] : Add device : {u'id': u'4601'}
[2019-10-18 11:47:37][DEBUG] : Add device : {u'id': u'9701'}
[2019-10-18 11:47:37][DEBUG] : Firmware is 1
[2019-10-18 11:47:37][DEBUG] : Type is 3
[2019-10-18 11:47:37][DEBUG] : Disable protocol 0
[2019-10-18 11:47:37][DEBUG] : Disable protocol 1
[2019-10-18 11:47:37][DEBUG] : Disable protocol 2
[2019-10-18 11:47:37][DEBUG] : Disable protocol 3
[2019-10-18 11:47:37][DEBUG] : Disable protocol 4
[2019-10-18 11:47:37][DEBUG] : Disable protocol 5
[2019-10-18 11:47:37][DEBUG] : Enable protocol 6
[2019-10-18 11:47:37][DEBUG] : Disable protocol 7
[2019-10-18 11:47:37][DEBUG] : Disable protocol 8
[2019-10-18 11:47:37][DEBUG] : Disable protocol 9
[2019-10-18 11:47:37][DEBUG] : Disable protocol 10
[2019-10-18 11:47:37][DEBUG] : Disable protocol 11
[2019-10-18 11:47:37][DEBUG] : Enable protocol 12
[2019-10-18 11:47:37][DEBUG] : Enable protocol 13
[2019-10-18 11:47:37][DEBUG] : Disable protocol 14
[2019-10-18 11:47:37][DEBUG] : Disable protocol 15
[2019-10-18 11:47:37][DEBUG] : Disable protocol 16
[2019-10-18 11:47:37][DEBUG] : Disable protocol 17
[2019-10-18 11:47:37][DEBUG] : Enable protocol 18
[2019-10-18 11:47:37][DEBUG] : Disable protocol 19
[2019-10-18 11:47:37][DEBUG] : Enable protocol 20
[2019-10-18 11:47:37][DEBUG] : Enable protocol 21
[2019-10-18 11:47:37][DEBUG] : Enable protocol 22
[2019-10-18 11:47:37][DEBUG] : Enable protocol 23
[2019-10-18 11:47:37][DEBUG] : Disable protocol 24
[2019-10-18 11:47:37][DEBUG] : Disable protocol 25
[2019-10-18 11:47:37][DEBUG] : Disable protocol 26
[2019-10-18 11:47:37][DEBUG] : Disable protocol 27
[2019-10-18 11:47:37][DEBUG] : Disable protocol 28
[2019-10-18 11:47:37][DEBUG] : Disable protocol 29
[2019-10-18 11:47:37][DEBUG] : Disable protocol 30
[2019-10-18 11:47:37][DEBUG] : Disable protocol 31
[2019-10-18 11:47:37][DEBUG] : Disable protocol 32
[2019-10-18 11:47:37][DEBUG] : msg3: [0, 0, 0, 0, 0, 0, 1, 0] / 02
[2019-10-18 11:47:37][DEBUG] : msg4: [0, 0, 0, 0, 1, 1, 0, 0] / 0c
[2019-10-18 11:47:37][DEBUG] : msg5: [0, 0, 1, 0, 1, 1, 1, 1] / 2f
[2019-10-18 11:47:37][DEBUG] : msg6: [0, 0, 0, 0, 0, 0, 0, 0] / 00
[2019-10-18 11:47:37][DEBUG] : Command: 0d000002035300020c2f00000000
[2019-10-18 11:47:37][DEBUG] : Write data to serial port : 0D 00 00 02 03 53 00 02 0C 2F 00 00 00 00
[2019-10-18 11:47:37][DEBUG] : Message: 14 01 00 02 03 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:37][DEBUG] : Decode : 14 01 00 02 03 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:37][DEBUG] : Test message: 14 01 00 02 03 53 01 02 0C 2F 00 01 03 1C 03 52 46 58 43 4F 4D
[2019-10-18 11:47:37][DEBUG] : PacketType: 01
[2019-10-18 11:47:37][DEBUG] : SubType: 00
[2019-10-18 11:47:37][DEBUG] : SeqNbr: 02
[2019-10-18 11:47:37][DEBUG] : Id1: 03
[2019-10-18 11:47:37][DEBUG] : Id2: 53
[2019-10-18 11:47:37][DEBUG] : Subtype = Interface response
[2019-10-18 11:47:37][DEBUG] : Sequence nbr = 02
[2019-10-18 11:47:37][DEBUG] : Response on cmnd = Set mode msg1-msg5, return firmware versions and configuration of the interface.
[2019-10-18 11:47:37][DEBUG] : Transceiver type = 433.92MHz
[2019-10-18 11:47:37][DEBUG] : Firmware version = 1
[2019-10-18 11:47:37][DEBUG] : Protocols:
[2019-10-18 11:47:37][DEBUG] : Undecoded Disabled
[2019-10-18 11:47:37][DEBUG] : Imagintronix,Opus Disabled
[2019-10-18 11:47:37][DEBUG] : Byron SX,SelectPlus Disabled
[2019-10-18 11:47:37][DEBUG] : RSL,Revolt Disabled
[2019-10-18 11:47:37][DEBUG] : Lightning4 Disabled
[2019-10-18 11:47:37][DEBUG] : FineOffset / Viking Disabled
[2019-10-18 11:47:37][DEBUG] : Rubicson,Alecto,Banggood Enabled
[2019-10-18 11:47:37][DEBUG] : AE Blyss Disabled
[2019-10-18 11:47:37][DEBUG] : Blinds T1/T2/T3/T4 Disabled
[2019-10-18 11:47:37][DEBUG] : Blinds T0 Disabled
[2019-10-18 11:47:37][DEBUG] : Disabled
[2019-10-18 11:47:37][DEBUG] : Legrand CAD Disabled
[2019-10-18 11:47:37][DEBUG] : La Crosse Enabled
[2019-10-18 11:47:37][DEBUG] : Hideki,TFA,Cresta,UPM Enabled
[2019-10-18 11:47:37][DEBUG] : AD Lightwave RF Disabled
[2019-10-18 11:47:37][DEBUG] : Mertik Disabled
[2019-10-18 11:47:37][DEBUG] : Visonic Disabled
[2019-10-18 11:47:37][DEBUG] : ATI/cartelectronic Disabled
[2019-10-18 11:47:37][DEBUG] : Oregon Scientific Enabled
[2019-10-18 11:47:37][DEBUG] : Meiantech,Atlantic Disabled
[2019-10-18 11:47:37][DEBUG] : HomeEasy EU Enabled
[2019-10-18 11:47:37][DEBUG] : AC Enabled
[2019-10-18 11:47:37][DEBUG] : ARC Enabled
[2019-10-18 11:47:37][DEBUG] : X10 Enabled
[2019-10-18 11:47:37][DEBUG] : FunkBus Disabled
[2019-10-18 11:47:37][DEBUG] : Decode data : {'subtype': '00', 'packettype': '01', 'raw': '14010002035301020C2F0001031C03524658434F4D'}
[2019-10-18 11:47:38][DEBUG] : All is ok, sending start
[2019-10-18 11:47:38][DEBUG] : Write data to serial port : 0D 00 00 02 07 00 00 00 00 00 00 00 00 00
[2019-10-18 11:47:38][DEBUG] : Message: 14 01 07 02 07 43 6F 70 79 72 69 67 68 74 20 52 46 58 43 4F 4D
[2019-10-18 11:47:38][DEBUG] : Decode : 14 01 07 02 07 43 6F 70 79 72 69 67 68 74 20 52 46 58 43 4F 4D
[2019-10-18 11:47:38][DEBUG] : Test message: 14 01 07 02 07 43 6F 70 79 72 69 67 68 74 20 52 46 58 43 4F 4D
[2019-10-18 11:47:38][DEBUG] : PacketType: 01
[2019-10-18 11:47:38][DEBUG] : SubType: 07
[2019-10-18 11:47:38][DEBUG] : SeqNbr: 02
[2019-10-18 11:47:38][DEBUG] : Id1: 07
[2019-10-18 11:47:38][DEBUG] : Id2: 43
[2019-10-18 11:47:38][DEBUG] : Subtype = Interface response
[2019-10-18 11:47:38][DEBUG] : Response is Copyright RFXCOM
[2019-10-18 11:47:39][DEBUG] : All is ok, Ready for operation
[2019-10-18 11:47:58][DEBUG] : Message: 0A 52 0D 00 97 01 00 C4 45 01 79
[2019-10-18 11:47:58][DEBUG] : Decode : 0A 52 0D 00 97 01 00 C4 45 01 79
[2019-10-18 11:47:58][DEBUG] : Test message: 0A 52 0D 00 97 01 00 C4 45 01 79
[2019-10-18 11:47:58][DEBUG] : PacketType: 52
[2019-10-18 11:47:58][DEBUG] : SubType: 0D
[2019-10-18 11:47:58][DEBUG] : SeqNbr: 00
[2019-10-18 11:47:58][DEBUG] : Id1: 97
[2019-10-18 11:47:58][DEBUG] : Id2: 01
[2019-10-18 11:47:58][DEBUG] : Decode data : {'temperature': '19.6', 'raw': '0A520D00970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:47:58][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.6', 'raw': '0A520D00970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:47:58][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:47:58][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:48:10][DEBUG] : Message: 0A 52 0D 01 6C 01 00 E0 36 01 79
[2019-10-18 11:48:10][DEBUG] : Decode : 0A 52 0D 01 6C 01 00 E0 36 01 79
[2019-10-18 11:48:10][DEBUG] : Test message: 0A 52 0D 01 6C 01 00 E0 36 01 79
[2019-10-18 11:48:10][DEBUG] : PacketType: 52
[2019-10-18 11:48:10][DEBUG] : SubType: 0D
[2019-10-18 11:48:10][DEBUG] : SeqNbr: 01
[2019-10-18 11:48:10][DEBUG] : Id1: 6C
[2019-10-18 11:48:10][DEBUG] : Id2: 01
[2019-10-18 11:48:10][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D016C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:48:10][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D016C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:48:10][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:48:10][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:48:33][DEBUG] : Message: 0A 52 0D 02 97 01 00 C4 45 01 79
[2019-10-18 11:48:33][DEBUG] : Decode : 0A 52 0D 02 97 01 00 C4 45 01 79
[2019-10-18 11:48:33][DEBUG] : Test message: 0A 52 0D 02 97 01 00 C4 45 01 79
[2019-10-18 11:48:33][DEBUG] : PacketType: 52
[2019-10-18 11:48:33][DEBUG] : SubType: 0D
[2019-10-18 11:48:33][DEBUG] : SeqNbr: 02
[2019-10-18 11:48:33][DEBUG] : Id1: 97
[2019-10-18 11:48:33][DEBUG] : Id2: 01
[2019-10-18 11:48:33][DEBUG] : Decode data : {'temperature': '19.6', 'raw': '0A520D02970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:48:33][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.6', 'raw': '0A520D02970100C4450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:48:33][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:48:33][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:48:45][DEBUG] : Message: 0A 52 0D 03 6C 01 00 E0 36 01 79
[2019-10-18 11:48:45][DEBUG] : Decode : 0A 52 0D 03 6C 01 00 E0 36 01 79
[2019-10-18 11:48:45][DEBUG] : Test message: 0A 52 0D 03 6C 01 00 E0 36 01 79
[2019-10-18 11:48:45][DEBUG] : PacketType: 52
[2019-10-18 11:48:45][DEBUG] : SubType: 0D
[2019-10-18 11:48:45][DEBUG] : SeqNbr: 03
[2019-10-18 11:48:45][DEBUG] : Id1: 6C
[2019-10-18 11:48:45][DEBUG] : Id2: 01
[2019-10-18 11:48:45][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D036C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:48:45][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D036C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:48:45][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:48:45][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:49:08][DEBUG] : Message: 0A 52 0D 04 97 01 00 C5 45 01 79
[2019-10-18 11:49:08][DEBUG] : Decode : 0A 52 0D 04 97 01 00 C5 45 01 79
[2019-10-18 11:49:08][DEBUG] : Test message: 0A 52 0D 04 97 01 00 C5 45 01 79
[2019-10-18 11:49:08][DEBUG] : PacketType: 52
[2019-10-18 11:49:08][DEBUG] : SubType: 0D
[2019-10-18 11:49:08][DEBUG] : SeqNbr: 04
[2019-10-18 11:49:08][DEBUG] : Id1: 97
[2019-10-18 11:49:08][DEBUG] : Id2: 01
[2019-10-18 11:49:08][DEBUG] : Decode data : {'temperature': '19.7', 'raw': '0A520D04970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:49:08][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.7', 'raw': '0A520D04970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:49:08][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:49:08][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:49:20][DEBUG] : Message: 0A 52 0D 05 6C 01 00 E0 36 01 79
[2019-10-18 11:49:20][DEBUG] : Decode : 0A 52 0D 05 6C 01 00 E0 36 01 79
[2019-10-18 11:49:20][DEBUG] : Test message: 0A 52 0D 05 6C 01 00 E0 36 01 79
[2019-10-18 11:49:20][DEBUG] : PacketType: 52
[2019-10-18 11:49:20][DEBUG] : SubType: 0D
[2019-10-18 11:49:20][DEBUG] : SeqNbr: 05
[2019-10-18 11:49:20][DEBUG] : Id1: 6C
[2019-10-18 11:49:20][DEBUG] : Id2: 01
[2019-10-18 11:49:20][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D056C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:49:20][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D056C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:49:20][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:49:20][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:49:43][DEBUG] : Message: 0A 52 0D 06 97 01 00 C5 45 01 79
[2019-10-18 11:49:43][DEBUG] : Decode : 0A 52 0D 06 97 01 00 C5 45 01 79
[2019-10-18 11:49:43][DEBUG] : Test message: 0A 52 0D 06 97 01 00 C5 45 01 79
[2019-10-18 11:49:43][DEBUG] : PacketType: 52
[2019-10-18 11:49:43][DEBUG] : SubType: 0D
[2019-10-18 11:49:43][DEBUG] : SeqNbr: 06
[2019-10-18 11:49:43][DEBUG] : Id1: 97
[2019-10-18 11:49:43][DEBUG] : Id2: 01
[2019-10-18 11:49:43][DEBUG] : Decode data : {'temperature': '19.7', 'raw': '0A520D06970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:49:43][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.7', 'raw': '0A520D06970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:49:43][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:49:43][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:49:55][DEBUG] : Message: 0A 52 0D 07 6C 01 00 E0 36 01 79
[2019-10-18 11:49:55][DEBUG] : Decode : 0A 52 0D 07 6C 01 00 E0 36 01 79
[2019-10-18 11:49:55][DEBUG] : Test message: 0A 52 0D 07 6C 01 00 E0 36 01 79
[2019-10-18 11:49:55][DEBUG] : PacketType: 52
[2019-10-18 11:49:55][DEBUG] : SubType: 0D
[2019-10-18 11:49:55][DEBUG] : SeqNbr: 07
[2019-10-18 11:49:55][DEBUG] : Id1: 6C
[2019-10-18 11:49:55][DEBUG] : Id2: 01
[2019-10-18 11:49:55][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D076C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:49:55][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D076C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:49:55][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:49:55][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:50:18][DEBUG] : Message: 0A 52 0D 08 97 01 00 C5 45 01 79
[2019-10-18 11:50:18][DEBUG] : Decode : 0A 52 0D 08 97 01 00 C5 45 01 79
[2019-10-18 11:50:18][DEBUG] : Test message: 0A 52 0D 08 97 01 00 C5 45 01 79
[2019-10-18 11:50:18][DEBUG] : PacketType: 52
[2019-10-18 11:50:18][DEBUG] : SubType: 0D
[2019-10-18 11:50:18][DEBUG] : SeqNbr: 08
[2019-10-18 11:50:18][DEBUG] : Id1: 97
[2019-10-18 11:50:18][DEBUG] : Id2: 01
[2019-10-18 11:50:18][DEBUG] : Decode data : {'temperature': '19.7', 'raw': '0A520D08970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}
[2019-10-18 11:50:18][DEBUG] : Send to jeedom : {'devices': {'970152': {'temperature': '19.7', 'raw': '0A520D08970100C5450179', 'battery': '9', 'signal': '7', 'humidity': '69', 'subtype': '0D', 'packettype': '52', 'id': '9701'}}}
[2019-10-18 11:50:18][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:50:18][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:50:30][DEBUG] : Message: 0A 52 0D 09 6C 01 00 E0 36 01 79
[2019-10-18 11:50:30][DEBUG] : Decode : 0A 52 0D 09 6C 01 00 E0 36 01 79
[2019-10-18 11:50:30][DEBUG] : Test message: 0A 52 0D 09 6C 01 00 E0 36 01 79
[2019-10-18 11:50:30][DEBUG] : PacketType: 52
[2019-10-18 11:50:30][DEBUG] : SubType: 0D
[2019-10-18 11:50:30][DEBUG] : SeqNbr: 09
[2019-10-18 11:50:30][DEBUG] : Id1: 6C
[2019-10-18 11:50:30][DEBUG] : Id2: 01
[2019-10-18 11:50:30][DEBUG] : Decode data : {'temperature': '22.4', 'raw': '0A520D096C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}
[2019-10-18 11:50:30][DEBUG] : Send to jeedom : {'devices': {'6C0152': {'temperature': '22.4', 'raw': '0A520D096C0100E0360179', 'battery': '9', 'signal': '7', 'humidity': '54', 'subtype': '0D', 'packettype': '52', 'id': '6C01'}}}
[2019-10-18 11:50:30][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2019-10-18 11:50:30][DEBUG] : http://127.0.0.1:80 "POST /plugins/rfxcom/core/php/jeeRfxcom.php?apikey=xxxxxxxxxxxxxxxx HTTP/1.1" 200 0
[2019-10-18 11:50:53][DEBUG] : Message: 0A 52 0D 0A 97 01 00 C5 44 01 79
[2019-10-18 11:50:53][DEBUG] : Decode : 0A 52 0D 0A 97 01 00 C5 44 01 79
[2019-10-18 11:50:53][DEBUG] : Test message: 0A 52 0D 0A 97 01 00 C5 44 01 79
[2019-10-18 11:50:53][DEBUG] : PacketType: 52
[2019-10-18 11:50:53][DEBUG] : SubType: 0D
[2019-10-18 11:50:53][DEBUG] : SeqNbr: 0A
[2019-10-18 11:50:53][DEBUG] : Id1: 97
[2019-10-18 11:50:53][DEBUG] : Id2: 01
Je voulais ouvrir un ticket, mais impossible ayant le plugin Sonos en béta (nécessaire pour la correction du bug de reprise de la lecture enc ours après un TTS)
