J’ai redémarré le démon avec les logs en débug, voilà une copie.
log openzwave
[2020-05-01 17:21:35][INFO] : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device /dev/ttyACM0 --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey 0wnhNkMcUeYCX4XNL86un6JeND8Cfb3N --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2020-05-01 17:21:36][INFO] : Start openzwaved
[2020-05-01 17:21:36][INFO] : Log level : debug
[2020-05-01 17:21:36][DEBUG] : PID file : /tmp/jeedom/openzwave/deamon.pid
[2020-05-01 17:21:36][INFO] : Device : /dev/ttyACM0
[2020-05-01 17:21:36][DEBUG] : Apikey : xxx
[2020-05-01 17:21:36][INFO] : Callback : http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php
[2020-05-01 17:21:36][INFO] : Cycle : 0.3
[2020-05-01 17:21:36][DEBUG] : Initial disabled nodes list: []
[2020-05-01 17:21:36][DEBUG] : Init request module v2.23.0
[2020-05-01 17:21:36][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-05-01 17:21:36][DEBUG] : http://127.0.0.1:80 "GET /plugins/openzwave/core/php/jeeZwave.php?apikey=xxxHTTP/1.1" 200 0
[2020-05-01 17:21:36][INFO] : Check if the port REST server available
[2020-05-01 17:21:36][INFO] : --> pass
[2020-05-01 17:21:36][INFO] : Check OpenZWave Devices Database
[2020-05-01 17:21:36][INFO] : Validate zwcfg configuration file(s)
[2020-05-01 17:21:36][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xe1bc20dc.xml
[2020-05-01 17:21:36][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xfb330894.xml
[2020-05-01 17:21:36][INFO] : ... check: /var/www/html/plugins/openzwave/core/class/../../data/zwcfg_0xfcb7dcf7.xml
[2020-05-01 17:21:36][DEBUG] : Create network object.
[2020-05-01 17:21:36][DEBUG] : Use sqlite version : (u'3.27.2',)
[2020-05-01 17:21:36][DEBUG] : connect to the louie dispatcher
[2020-05-01 17:21:36][INFO] : ******** The ZWave network is being started ********
[2020-05-01 17:21:36][INFO] : Start Openzwave network.
[2020-05-01 17:21:36][INFO] : OpenZwave Library Version 1.4.0
[2020-05-01 17:21:36][INFO] : Python-OpenZwave Wrapper Version 0.3.1
[2020-05-01 17:21:36][INFO] : Waiting for network to become ready
[2020-05-01 17:21:36][DEBUG] : Writing PID 25241 to /tmp/jeedom/openzwave/deamon.pid
[2020-05-01 17:21:36][DEBUG] : notif_callback : new notification
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 18, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : notif_callback : call callback context
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'DriverReady', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification DriverReady : {'homeId': 4239908087, 'notificationType': 'DriverReady', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : Create object node (node_id:1)
[2020-05-01 17:21:36][INFO] : Driver ready using library Static Controller version Z-Wave 4.54
[2020-05-01 17:21:36][INFO] : home_id 0xfcb7dcf7, controller node id is 1
[2020-05-01 17:21:36][DEBUG] : Network home_id: [0xfcb7dcf7] controller: [home_id: [0xfcb7dcf7] id: [1] name: [1Z-Stick Gen5 (ZW090)] product: [ZW090 Z-Stick Gen5 EU] capabilities: set(['primaryController']) library: [Static Controller version Z-Wave 4.54]]
[2020-05-01 17:21:36][INFO] : Openzwave network are started with homeId fcb7dcf7.
[2020-05-01 17:21:36][DEBUG] : notif_callback : end
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 6, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'NodeAdded', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification NodeAdded : {'homeId': 4239908087, 'notificationType': 'NodeAdded', 'nodeId': 1}
[2020-05-01 17:21:36][INFO] : A node has been added to OpenZWave list id:[1] model:[ZW090 Z-Stick Gen5 EU].
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification Node : home_id: [0xfcb7dcf7] id: [1] name: [1Z-Stick Gen5 (ZW090)] model: [ZW090 Z-Stick Gen5 EU]
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 8, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'NodeProtocolInfo', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification NodeProtocolInfo : {'homeId': 4239908087, 'notificationType': 'NodeProtocolInfo', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 21, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'EssentialNodeQueriesComplete', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification EssentialNodeQueriesComplete : {'homeId': 4239908087, 'notificationType': 'EssentialNodeQueriesComplete', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 0, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : addValueId : ValueID : 72057594055229441
[2020-05-01 17:21:36][DEBUG] : addValueId : GetCommandClassId : 32, GetType : 1
[2020-05-01 17:21:36][INFO] : Démon openzwave lancé
[2020-05-01 17:21:36][DEBUG] : addValueId : Notification : {'homeId': 4239908087, 'valueId': {'commandClass': 'COMMAND_CLASS_BASIC', 'homeId': 4239908087, 'readOnly': False, 'genre': '', 'id': 72057594055229441L, 'index': 0, 'nodeId': 1, 'value': None, 'label': None, 'instance': 1, 'units': None, 'type': 'Byte'}, 'notificationType': 'ValueAdded', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'valueId': {'commandClass': 'COMMAND_CLASS_BASIC', 'homeId': 4239908087, 'readOnly': False, 'genre': '', 'id': 72057594055229441L, 'index': 0, 'nodeId': 1, 'value': None, 'label': None, 'instance': 1, 'units': None, 'type': 'Byte'}, 'notificationType': 'ValueAdded', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification ValueAdded : {'homeId': 4239908087, 'valueId': {'commandClass': 'COMMAND_CLASS_BASIC', 'homeId': 4239908087, 'readOnly': False, 'genre': '', 'id': 72057594055229441L, 'index': 0, 'nodeId': 1, 'value': None, 'label': None, 'instance': 1, 'units': None, 'type': 'Byte'}, 'notificationType': 'ValueAdded', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : Create object value (valueId:72057594055229441)
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 9, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'NodeNaming', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification NodeNaming : {'homeId': 4239908087, 'notificationType': 'NodeNaming', 'nodeId': 1}
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 22, nodeId : 1
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'NodeQueriesComplete', 'nodeId': 1}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification NodeQueriesComplete : {'homeId': 4239908087, 'notificationType': 'NodeQueriesComplete', 'nodeId': 1}
[2020-05-01 17:21:36][INFO] : All the initialisation queries on a node have been completed. id:[1] model:[ZW090 Z-Stick Gen5 EU].
[2020-05-01 17:21:36][DEBUG] : notif_callback : Notification type : 25, nodeId : 255
[2020-05-01 17:21:36][DEBUG] : zwcallback args=[{'homeId': 4239908087, 'notificationType': 'AllNodesQueried', 'nodeId': 255}]
[2020-05-01 17:21:36][DEBUG] : Z-Wave Notification AllNodesQueried : {'homeId': 4239908087, 'notificationType': 'AllNodesQueried', 'nodeId': 255}
[2020-05-01 17:21:36][INFO] : Openzwave network is ready with 1 nodes (0 are sleeping). All nodes are queried, the network is fully functional.
[2020-05-01 17:21:36][INFO] : ZWave configuration written to user directory.
[2020-05-01 17:21:36][INFO] : write configuration file
[2020-05-01 17:21:36][DEBUG] : Send to jeedom : {'network': {'state': {'value': 5}}}
[2020-05-01 17:21:36][DEBUG] : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=xxx HTTP/1.1" 200 0
[2020-05-01 17:21:37][DEBUG] : notif_callback : end
[2020-05-01 17:21:37][DEBUG] : Send to jeedom : {'network': {'state': {'value': 10}}}
[2020-05-01 17:21:37][DEBUG] : Starting new HTTP connection (1): 127.0.0.1:80
[2020-05-01 17:21:37][DEBUG] : http://127.0.0.1:80 "POST /plugins/openzwave/core/php/jeeZwave.php?apikey=xxxHTTP/1.1" 200 0
log openzwaved
2020-05-01 17:21:36.119 Always, OpenZwave Version 1.4.0 Starting Up
2020-05-01 17:21:36.123 Info, Setting Up Provided Network Key for Secure Communications
2020-05-01 17:21:36.123 Info, mgr, Added driver for controller /dev/ttyACM0
2020-05-01 17:21:36.123 Info, Opening controller /dev/ttyACM0
2020-05-01 17:21:36.123 Info, Trying to open serial port /dev/ttyACM0 (attempt 1)
2020-05-01 17:21:36.127 Info, Serial port /dev/ttyACM0 opened (attempt 1)
2020-05-01 17:21:36.128 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-01 17:21:36.128 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-01 17:21:36.128 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-01 17:21:36.128 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-01 17:21:36.128 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-01 17:21:36.128 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x15) - FUNC_ID_ZW_GET_VERSION: 0x01, 0x03, 0x00, 0x15, 0xe9
2020-05-01 17:21:36.132 Detail, contrlr, Received: 0x01, 0x10, 0x01, 0x15, 0x5a, 0x2d, 0x57, 0x61, 0x76, 0x65, 0x20, 0x34, 0x2e, 0x35, 0x34, 0x00, 0x01, 0x93
2020-05-01 17:21:36.132 Info, contrlr, Received reply to FUNC_ID_ZW_GET_VERSION:
2020-05-01 17:21:36.132 Info, contrlr, Static Controller library, version Z-Wave 4.54
2020-05-01 17:21:36.132 Detail, Node045, Expected reply was received
2020-05-01 17:21:36.133 Detail, Node045, Message transaction complete
2020-05-01 17:21:36.133 Detail, contrlr, Removing current message
2020-05-01 17:21:36.133 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x20) - FUNC_ID_ZW_MEMORY_GET_ID: 0x01, 0x03, 0x00, 0x20, 0xdc
2020-05-01 17:21:36.136 Detail, contrlr, Received: 0x01, 0x08, 0x01, 0x20, 0xfc, 0xb7, 0xdc, 0xf7, 0x01, 0xb7
2020-05-01 17:21:36.136 Info, contrlr, Received reply to FUNC_ID_ZW_MEMORY_GET_ID. Home ID = 0xfcb7dcf7. Our node ID = 1
2020-05-01 17:21:36.136 Detail, Node183, Expected reply was received
2020-05-01 17:21:36.136 Detail, Node183, Message transaction complete
2020-05-01 17:21:36.136 Detail, contrlr, Removing current message
2020-05-01 17:21:36.136 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x05) - FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES: 0x01, 0x03, 0x00, 0x05, 0xf9
2020-05-01 17:21:36.139 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x05, 0x28, 0xd7
2020-05-01 17:21:36.139 Info, contrlr, Received reply to FUNC_ID_ZW_GET_CONTROLLER_CAPABILITIES:
2020-05-01 17:21:36.139 Info, contrlr, There is no SUC ID Server (SIS) in this network.
2020-05-01 17:21:36.139 Info, contrlr, The PC controller is a primary controller.
2020-05-01 17:21:36.139 Detail, Node215, Expected reply was received
2020-05-01 17:21:36.139 Detail, Node215, Message transaction complete
2020-05-01 17:21:36.139 Detail, contrlr, Removing current message
2020-05-01 17:21:36.140 Detail,
2020-05-01 17:21:36.140 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x07) - FUNC_ID_SERIAL_API_GET_CAPABILITIES: 0x01, 0x03, 0x00, 0x07, 0xfb
2020-05-01 17:21:36.145 Detail, contrlr, Received: 0x01, 0x2b, 0x01, 0x07, 0x01, 0x01, 0x00, 0x86, 0x00, 0x01, 0x00, 0x5a, 0xfe, 0x81, 0xff, 0x88, 0x4f, 0x1f, 0x00, 0x00, 0xfb, 0x9f, 0x7d, 0xa0, 0x67, 0x00, 0x00, 0x80, 0x00, 0x80, 0x86, 0x00, 0x00, 0x00, 0xe8, 0x73, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x60, 0x00, 0x00, 0xfa
2020-05-01 17:21:36.145 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_CAPABILITIES
2020-05-01 17:21:36.145 Info, contrlr, Serial API Version: 1.1
2020-05-01 17:21:36.145 Info, contrlr, Manufacturer ID: 0x0086
2020-05-01 17:21:36.145 Info, contrlr, Product Type: 0x0001
2020-05-01 17:21:36.145 Info, contrlr, Product ID: 0x005a
2020-05-01 17:21:36.145 Detail, contrlr, Queuing (Command) FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-05-01 17:21:36.145 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-05-01 17:21:36.145 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-05-01 17:21:36.145 Detail, contrlr, Queuing (Command) FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-05-01 17:21:36.145 Detail, Node001, Expected reply was received
2020-05-01 17:21:36.145 Detail, Node001, Message transaction complete
2020-05-01 17:21:36.145 Detail, contrlr, Removing current message
2020-05-01 17:21:36.145 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x56) - FUNC_ID_ZW_GET_SUC_NODE_ID: 0x01, 0x03, 0x00, 0x56, 0xaa
2020-05-01 17:21:36.150 Detail, contrlr, Received: 0x01, 0x04, 0x01, 0x56, 0x00, 0xac
2020-05-01 17:21:36.151 Detail,
2020-05-01 17:21:36.151 Info, contrlr, Received reply to GET_SUC_NODE_ID. Node ID = 0
2020-05-01 17:21:36.151 Info, Controller Does not Support SUC - Cannot Setup Controller as SUC Node
2020-05-01 17:21:36.151 Detail, Node172, Expected reply was received
2020-05-01 17:21:36.151 Detail, Node172, Message transaction complete
2020-05-01 17:21:36.151 Detail, contrlr, Removing current message
2020-05-01 17:21:36.151 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x1c) - FUNC_ID_ZW_GET_RANDOM: 0x01, 0x04, 0x00, 0x1c, 0x20, 0xc7
2020-05-01 17:21:36.208 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x1c, 0x01, 0x20, 0xbc, 0x0a, 0xf6, 0x4d, 0x40, 0x1b, 0xbb, 0x5e, 0xde, 0xe9, 0x6b, 0x18, 0x55, 0xe6, 0xc2, 0x01, 0xaf, 0x09, 0x86, 0x2a, 0xa8, 0x99, 0x4e, 0x04, 0xde, 0xb7, 0x2e, 0x6b, 0x68, 0x71, 0x81, 0xcc, 0x68
2020-05-01 17:21:36.209 Detail,
2020-05-01 17:21:36.209 Info, contrlr, Received reply to FUNC_ID_ZW_GET_RANDOM: true
2020-05-01 17:21:36.209 Detail, Node032, Expected reply was received
2020-05-01 17:21:36.209 Detail, Node032, Message transaction complete
2020-05-01 17:21:36.209 Detail, contrlr, Removing current message
2020-05-01 17:21:36.209 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x02) - FUNC_ID_SERIAL_API_GET_INIT_DATA: 0x01, 0x03, 0x00, 0x02, 0xfe
2020-05-01 17:21:36.315 Detail, contrlr, Received: 0x01, 0x25, 0x01, 0x02, 0x05, 0x00, 0x1d, 0x01, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x00, 0xc5
2020-05-01 17:21:36.315 Info, mgr, Driver with Home ID of 0xfcb7dcf7 is now ready.
2020-05-01 17:21:36.315 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_GET_INIT_DATA:
2020-05-01 17:21:36.315 Info, contrlr, Node 001 - Known
2020-05-01 17:21:36.315 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=CacheLoad live=1
2020-05-01 17:21:36.315 Detail, Node001, QueryStage_CacheLoad
2020-05-01 17:21:36.315 Info, Node001, Node Identity Codes: 0086:0001:005a
2020-05-01 17:21:36.315 Detail, Node001, QueryStage_Associations
2020-05-01 17:21:36.315 Detail, Node001, QueryStage_Neighbors
2020-05-01 17:21:36.315 Detail, contrlr, Requesting routing info (neighbor list) for Node 1
2020-05-01 17:21:36.315 Detail, Node001, Queuing (Command) Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-05-01 17:21:36.315 Detail, Node001, Queuing (Query) Query Stage Complete (Neighbors)
2020-05-01 17:21:36.315 Detail, Expected reply was received
2020-05-01 17:21:36.316 Detail, Message transaction complete
2020-05-01 17:21:36.316 Detail, contrlr, Removing current message
2020-05-01 17:21:36.316 Detail, Node001, Notification: DriverReady
2020-05-01 17:21:36.320 Detail, Node001, Notification: NodeAdded
2020-05-01 17:21:36.325 Detail, Node001, Notification: NodeProtocolInfo
2020-05-01 17:21:36.326 Detail, Node001, Notification: EssentialNodeQueriesComplete
2020-05-01 17:21:36.329 Detail, Node001, Notification: ValueAdded
2020-05-01 17:21:36.336 Detail, Node001, Notification: NodeNaming
2020-05-01 17:21:36.337 Detail,
2020-05-01 17:21:36.337 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x06) - FUNC_ID_SERIAL_API_SET_TIMEOUTS: 0x01, 0x05, 0x00, 0x06, 0x64, 0x0f, 0x97
2020-05-01 17:21:36.341 Detail, contrlr, Received: 0x01, 0x05, 0x01, 0x06, 0x64, 0x0f, 0x96
2020-05-01 17:21:36.341 Info, contrlr, Received reply to FUNC_ID_SERIAL_API_SET_TIMEOUTS
2020-05-01 17:21:36.341 Detail, Node015, Expected reply was received
2020-05-01 17:21:36.341 Detail, Node015, Message transaction complete
2020-05-01 17:21:36.341 Detail, contrlr, Removing current message
2020-05-01 17:21:36.341 Info, contrlr, Sending (Command) message (Callback ID=0x00, Expected Reply=0x00) - FUNC_ID_SERIAL_API_APPL_NODE_INFORMATION: 0x01, 0x07, 0x00, 0x03, 0x01, 0x02, 0x01, 0x00, 0xf9
2020-05-01 17:21:36.344 Detail, contrlr, Removing current message
2020-05-01 17:21:36.344 Info, Node001, Sending (Command) message (Callback ID=0x00, Expected Reply=0x80) - Get Routing Info (Node=1): 0x01, 0x07, 0x00, 0x80, 0x01, 0x00, 0x00, 0x03, 0x7a
2020-05-01 17:21:36.350 Detail, Node001, Received: 0x01, 0x20, 0x01, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5e
2020-05-01 17:21:36.350 Info, Node001, Received reply to FUNC_ID_ZW_GET_ROUTING_INFO
2020-05-01 17:21:36.350 Info, Node001, Neighbors of this node are:
2020-05-01 17:21:36.350 Info, Node001, (none reported)
2020-05-01 17:21:36.350 Detail, Expected reply was received
2020-05-01 17:21:36.350 Detail, Message transaction complete
2020-05-01 17:21:36.350 Detail, Node001, Removing current message
2020-05-01 17:21:36.350 Detail, Node001, Query Stage Complete (Neighbors)
2020-05-01 17:21:36.350 Detail, Node001, AdvanceQueries queryPending=0 queryRetries=0 queryStage=Session live=1
2020-05-01 17:21:36.350 Detail, Node001, QueryStage_Session
2020-05-01 17:21:36.350 Detail, Node001, QueryStage_Dynamic
2020-05-01 17:21:36.350 Detail, Node001, QueryStage_Configuration
2020-05-01 17:21:36.350 Detail, Node001, QueryStage_Complete
2020-05-01 17:21:36.350 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2020-05-01 17:21:36.350 Warning, CheckCompletedNodeQueries all=1, deadFound=0 sleepingOnly=1
2020-05-01 17:21:36.350 Info, Node query processing complete.
2020-05-01 17:21:36.351 Detail, Node001, Notification: NodeQueriesComplete
2020-05-01 17:21:36.353 Detail, contrlr, Notification: AllNodesQueried
2020-05-01 17:21:36.354 Info, mgr, Manager::WriteConfig completed for driver with home ID of 0xfcb7dcf7
Je vois pas d’erreur, j’ai raté un truc ?
