Bonjour. Depuis quelques jours je n’arrive plus à me connecter à mon Atlas via Internet. Le réseau externe est en NOK. Dans le log de la vérification générale, il y a effectivement un problème, mais c’est pour moi du chinois. Le voici:
[START CONSISTENCY]
[START CHECK AND FIX DB]
[END CHECK AND FIX DB]
Check jeedom package...
OK
Check jeedom database...OK
Check crons...
Check filesystem right...
OK
Flush cache widget...
Check jeedom object...OK
Check jeedom cmd...OK
Set cache hour...OK
Check nodejs...
W: Failed to fetch http://deb.debian.org/debian/dists/buster/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/buster-updates/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://deb.debian.org/debian/dists/buster-backports/InRelease Could not resolve 'deb.debian.org'
W: Failed to fetch http://security.debian.org/dists/buster/updates/InRelease Could not resolve 'security.debian.org'
W: Failed to fetch http://apt.armbian.com/dists/buster/InRelease Could not resolve 'apt.armbian.com'
W: Failed to fetch https://deb.nodesource.com/node_18.x/dists/nodistro/InRelease Could not resolve 'deb.nodesource.com'
W: Failed to fetch https://dl.yarnpkg.com/debian/dists/stable/InRelease Could not resolve 'dl.yarnpkg.com'
W: Some index files failed to download. They have been ignored, or old ones used instead.
Err:1 http://deb.debian.org/debian buster InRelease
Err:2 https://dl.yarnpkg.com/debian stable InRelease
Err:3 http://deb.debian.org/debian buster-updates InRelease
Err:4 http://deb.debian.org/debian buster-backports InRelease
Err:5 http://security.debian.org buster/updates InRelease
Err:6 http://apt.armbian.com buster InRelease
Err:7 https://deb.nodesource.com/node_18.x nodistro InRelease
Reading package lists...
Building dependency tree...
Reading state information...
apt-utils is already the newest version (1.8.2.3).
build-essential is already the newest version (12.6).
lsb-release is already the newest version (10.2019051400).
git is already the newest version (1:2.20.1-2+deb10u8).
0 upgraded, 0 newly installed, 0 to remove and 247 not upgraded.
[Check Version NodeJS actuelle : v18.19.0 : [ OK ]
[Check Prefix : /usr and sudo prefix : /usr and www-data prefix : /usr : [ OK ]
OK
[END CONSISTENCY]
Je n’ai rien fait de particulier, sauf les mises à jour qui m’ont été proposées. Avez-vous une idée du problème, et surtout de sa résolution?
Merci beaucoup.
dans jeedom , menu Réglages => système => configuration => onglet >_OS/DB => Administration Système
clique sur ip addr sur le côté gauche et dit nous le résultat
Ce n’est pas une IP typique des réseaux internes fournis par les FAI français ça.
As-tu un réseau particulier chez toi ?
Parce que :
est synonyme de « Je n’arrive pas à joindre le serveur distant », donc d’un problème de configuration réseau. En gros, pas d’accès à Internet pour cette machine (peut-être un problème de DNS).
Je suis connecté sur un routeur 4G, jusqu’à maintenant ça ne posait pas de problème. Je l’ai redémarré mais ça n’a rien changé, et les autres appareils connectés dessus n’ont pas de problème.
Le log d’origine semble être extrait de Jeedom. Si c’est le cas, il est probable que Jeedom s’appuie sur la configuration réseau renseignée dans Réglages → Configuration → onglet Réseaux
Vérifie que l’IP renseignée à cet endroit est bien la même que celle renvoyée par ip addr. Il n’est pas impossible qu’en cas de dissonance cela pose problème (je ne sais pas comment Jeedom gère les configurations réseaux, mais s’il demande à l’utilisateur de renseigner une IP, autant qu’elle soit cohérente avec celle assignée par le serveur DHCP du routeur).
Si ton routeur 4G le permet, vérifie que tu peux assigner une IP fixe à ton serveur Jeedom via un bail DHCP fixe.
J’ai bien une adresse réservée pour jeedom, en l’occurence 192.168.137.9
C’est bien celle que l’on retrouve dans ip addr dans la rubrique eth0, et dans l’onglet réseau de jeedom.
Le log d’origine est bien celui de jeedom.
Je viens de restaurer mon routeur à une date qui fonctionnait, ça ne marche toujours pas.
J’ai fait un traceroute en passant par Putty, c’est bien ce qu’il fallait faire?
Il me dit qu’il ne trouve pas la commande et me suggère « atraceroute ». C’est la même réponse.
J’ai essayé, mais apparemment ça ne va pas. Voici ce qu’il répond:
jeedom@JeedomAtlas:~$ sudo apt install traceroute -y
[sudo] Mot de passe de jeedom :
Lecture des listes de paquets... Fait
Construction de l'arbre des dépendances
Lecture des informations d'état... Fait
Les NOUVEAUX paquets suivants seront installés :
traceroute
0 mis à jour, 1 nouvellement installés, 0 à enlever et 247 non mis à jour.
Il est nécessaire de prendre 51,6 ko dans les archives.
Après cette opération, 152 ko d'espace disque supplémentaires seront utilisés.
Err :1 http://deb.debian.org/debian buster/main arm64 traceroute arm64 1:2.1.0-2
Ne parvient pas à résoudre « deb.debian.org »
E: Impossible de récupérer http://deb.debian.org/debian/pool/main/t/traceroute/t raceroute_2.1.0-2_arm64.deb Ne parvient pas à résoudre « deb.debian.org »
E: Impossible de récupérer certaines archives, peut-être devrez-vous lancer apt- get update ou essayer avec --fix-missing ?
jeedom@JeedomAtlas:~$ traceroute 8.8.8.8
Command 'traceroute' not found, did you mean:
command 'atraceroute' from deb ripe-atlas-tools
Try: sudo apt install <deb name>
