Version (Beta) installée du plugin: 2023-09-17 01:10:14
Et voici les logs de l’installation des dependances:
Get:5 http://www.deb-multimedia.org buster InRelease [18.1 kB]
Hit:6 https://oph.mdrjr.net/meveric all InRelease
Hit:7 https://oph.mdrjr.net/meveric buster InRelease
Reading package lists...
E: Repository 'http://security.debian.org/debian-security buster/updates InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
E: Repository 'http://ftp.uk.debian.org/debian buster-updates InRelease' changed its 'Suite' value from 'oldstable-updates' to 'oldoldstable-updates'
E: Repository 'http://www.deb-multimedia.org buster InRelease' changed its 'Suite' value from 'oldstable' to 'oldoldstable'
Building dependency tree...
Reading state information...
Package 'python3-serial' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 225 not upgraded.
The following additional packages will be installed:
icu-devtools libicu-dev libicu63 libxml2 libxslt1.1 pkg-config
Suggested packages:
icu-doc
icu-devtools libicu-dev libxml2-dev libxslt1-dev pkg-config
The following packages will be upgraded:
3 upgraded, 5 newly installed, 0 to remove and 222 not upgraded.
Need to get 19.6 MB of archives.
After this operation, 49.4 MB of additional disk space will be used.
Err:1 http://security.debian.org/debian-security buster/updates/main arm64 libxml2 arm64 2.9.4+dfsg1-7+deb10u5
404 Not Found [IP: 2a04:4e42:6a::644 80]
Err:2 http://security.debian.org/debian-security buster/updates/main arm64 libxml2-dev arm64 2.9.4+dfsg1-7+deb10u5
Get:3 http://security.debian.org/debian-security buster/updates/main arm64 libxslt1.1 arm64 1.1.32-2.2~deb10u2 [225 kB]
Get:4 http://ftp.uk.debian.org/debian buster/main arm64 libicu63 arm64 63.1-6+deb10u3 [8,154 kB]
Get:5 http://security.debian.org/debian-security buster/updates/main arm64 libxslt1-dev arm64 1.1.32-2.2~deb10u2 [518 kB]
Get:6 http://ftp.uk.debian.org/debian buster/main arm64 pkg-config arm64 0.29-6 [62.2 kB]
Get:7 http://ftp.uk.debian.org/debian buster/main arm64 icu-devtools arm64 63.1-6+deb10u3 [179 kB]
Get:8 http://ftp.uk.debian.org/debian buster/main arm64 libicu-dev arm64 63.1-6+deb10u3 [9,064 kB]
Fetched 18.2 MB in 18s (1,033 kB/s)
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/libx/libxml2/libxml2_2.9.4+dfsg1-7+deb10u5_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/libx/libxml2/libxml2-dev_2.9.4+dfsg1-7+deb10u5_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
python3 is already the newest version (3.7.3-1).
python3-pip is already the newest version (18.1-5).
python3-dev is already the newest version (3.7.3-1).
python3.7-venv
python3-venv python3.7-venv
0 upgraded, 2 newly installed, 0 to remove and 225 not upgraded.
Need to get 7,320 B of archives.
After this operation, 44.0 kB of additional disk space will be used.
Err:1 http://security.debian.org/debian-security buster/updates/main arm64 python3.7-venv arm64 3.7.3-2+deb10u4
Get:2 http://ftp.uk.debian.org/debian buster/main arm64 python3-venv arm64 3.7.3-1 [1,180 B]
Fetched 1,180 B in 0s (2,783 B/s)
E: Failed to fetch http://security.debian.org/debian-security/pool/updates/main/p/python3.7/python3.7-venv_3.7.3-2+deb10u4_arm64.deb 404 Not Found [IP: 2a04:4e42:6a::644 80]
The virtual environment was not created successfully because ensurepip is not
available. On Debian/Ubuntu systems, you need to install the python3-venv
package using the following command.
apt-get install python3-venv
You may need to use sudo with that command. After installing the python3-venv
package, recreate your virtual environment.
Failing command: ['/var/www/html/plugins/enphasesecur/resources/venv/bin/python3', '-Im', 'ensurepip', '--upgrade', '--default-pip']
sudo: /var/www/html/plugins/enphasesecur/resources/venv/bin/pip3: command not found
* Installation des dépendances OK *
