J’ai un souci après l’installation du plugin, les dépendances restent à un status NOK même lorsque je relance l’installation. Jeedom m’indique « Attention : l’installation des dépendances a dépassé le temps maximum autorisé : 0min »
Dans les logs d’update, j’ai ceci:
* Installation des dépendances *
Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
Hit:3 https://deb.nodesource.com/node_14.x bullseye InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3 is already the newest version (3.9.2-3).
The following packages were automatically installed and are no longer required:
chromium-codecs-ffmpeg-extra docutils-common libfuse2 libmbim-glib4
libmbim-proxy libqmi-glib5 libqmi-proxy mypy pylint python3-astroid
python3-asttokens python3-docutils python3-isort python3-jedi
python3-lazy-object-proxy python3-logilab-common python3-mccabe python3-mypy
python3-mypy-extensions python3-parso python3-pygments python3-roman
python3-send2trash python3-toml python3-typed-ast python3-typing-extensions
python3-wrapt sgml-base xml-core xsel
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 204 not upgraded.
python3-pip is already the newest version (20.3.4-4+rpt1+deb11u1).
File "/usr/bin/pip3", line 33, in <module>
sys.exit(load_entry_point('pip==20.3.4', 'console_scripts', 'pip3')())
File "/usr/bin/pip3", line 25, in importlib_load_entry_point
return next(matches).load()
File "/usr/lib/python3.9/importlib/metadata.py", line 77, in load
module = import_module(match.group('module'))
File "/usr/lib/python3.9/importlib/__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1030, in _gcd_import
File "<frozen importlib._bootstrap>", line 1007, in _find_and_load
File "<frozen importlib._bootstrap>", line 986, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 680, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 790, in exec_module
File "<frozen importlib._bootstrap>", line 228, in _call_with_frames_removed
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main.py", line 10, in <module>
from pip._internal.cli.autocompletion import autocomplete
File "/usr/lib/python3/dist-packages/pip/_internal/cli/autocompletion.py", line 9, in <module>
from pip._internal.cli.main_parser import create_main_parser
File "/usr/lib/python3/dist-packages/pip/_internal/cli/main_parser.py", line 7, in <module>
from pip._internal.cli import cmdoptions
File "/usr/lib/python3/dist-packages/pip/_internal/cli/cmdoptions.py", line 23, in <module>
from pip._vendor.packaging.utils import canonicalize_name
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 94, in <module>
vendored("requests.packages.urllib3.contrib.pyopenssl")
File "/usr/lib/python3/dist-packages/pip/_vendor/__init__.py", line 36, in vendored
__import__(modulename, globals(), locals(), level=0)
File "<frozen importlib._bootstrap>", line 664, in _load_unlocked
File "<frozen importlib._bootstrap>", line 627, in _load_backward_compatible
File "<frozen zipimport>", line 259, in load_module
File "/usr/share/python-wheels/urllib3-1.26.5-py2.py3-none-any.whl/urllib3/contrib/pyopenssl.py", line 50, in <module>
File "/usr/lib/python3/dist-packages/OpenSSL/__init__.py", line 8, in <module>
from OpenSSL import crypto, SSL
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1556, in <module>
class X509StoreFlags(object):
File "/usr/lib/python3/dist-packages/OpenSSL/crypto.py", line 1577, in X509StoreFlags
CB_ISSUER_CHECK = _lib.X509_V_FLAG_CB_ISSUER_CHECK
AttributeError: module 'lib' has no attribute 'X509_V_FLAG_CB_ISSUER_CHECK'
Package 'python3-serial' is not installed, so not removed
python3-setuptools is already the newest version (52.0.0-4).
python3-pyudev is already the newest version (0.22.0-2).
python3-requests is already the newest version (2.25.1+dfsg-2).
* Installation des dépendances OK *
Pouvez vous m’aider ?
Merci beaucoup
Nico
