essai d’installer ces 2 package mentionné, mais je vois pas pk toi tu en aurais besoin…
sudo apt-get install libxml2-dev libxslt-dev python-dev
et relance les dépandances
Pas mieux…
* Installation des dépendances *
Hit:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
Hit:2 http://archive.raspberrypi.org/debian buster InRelease
Hit:3 https://deb.nodesource.com/node_12.x buster InRelease
Reading package lists...
Building dependency tree...
Reading state information...
python3 is already the newest version (3.7.3-1).
0 upgraded, 0 newly installed, 0 to remove and 315 not upgraded.
python3-pip is already the newest version (18.1-5+rpt1).
Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.1.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
WARNING: Skipping serial as it is not installed.
Package 'python3-serial' is not installed, so not removed
python3-setuptools is already the newest version (40.8.0-1).
python3-pyudev is already the newest version (0.21.0-1).
python3-requests is already the newest version (2.21.0-1+deb10u1).
Collecting pyjwt
Using cached PyJWT-2.7.0-py3-none-any.whl (22 kB)
Collecting html5lib
Using cached html5lib-1.1-py2.py3-none-any.whl (112 kB)
Collecting asyncio
Using cached asyncio-3.4.3-py3-none-any.whl (101 kB)
Collecting httpx
Using cached httpx-0.24.1-py3-none-any.whl (75 kB)
Collecting lxml
Using cached lxml-4.9.2.tar.gz (3.7 MB)
Preparing metadata (setup.py): started
Preparing metadata (setup.py): finished with status 'done'
Collecting html.parser
Using cached html-parser-0.2.tar.gz (904 bytes)
Collecting typing-extensions (from pyjwt)
Using cached typing_extensions-4.6.3-py3-none-any.whl (31 kB)
Requirement already satisfied: six>=1.9 in /usr/local/lib/python3.7/dist-packages (from html5lib) (1.16.0)
Collecting webencodings (from html5lib)
Using cached webencodings-0.5.1-py2.py3-none-any.whl (11 kB)
Requirement already satisfied: certifi in /usr/lib/python3/dist-packages (from httpx) (2018.8.24)
Collecting httpcore<0.18.0,>=0.15.0 (from httpx)
Using cached httpcore-0.17.2-py3-none-any.whl (72 kB)
Requirement already satisfied: idna in /usr/lib/python3/dist-packages (from httpx) (2.6)
Collecting sniffio (from httpx)
Using cached sniffio-1.3.0-py3-none-any.whl (10 kB)
Collecting ply (from html.parser)
Using cached ply-3.11-py2.py3-none-any.whl (49 kB)
Collecting h11<0.15,>=0.13 (from httpcore<0.18.0,>=0.15.0->httpx)
Using cached h11-0.14.0-py3-none-any.whl (58 kB)
Collecting anyio<5.0,>=3.0 (from httpcore<0.18.0,>=0.15.0->httpx)
Using cached anyio-3.7.0-py3-none-any.whl (80 kB)
Collecting idna (from httpx)
Using cached idna-3.4-py3-none-any.whl (61 kB)
Collecting exceptiongroup (from anyio<5.0,>=3.0->httpcore<0.18.0,>=0.15.0->httpx)
Using cached exceptiongroup-1.1.1-py3-none-any.whl (14 kB)
Building wheels for collected packages: lxml, html.parser
Building wheel for lxml (setup.py): started
Si justement c’est beaucoup mieux. Faut attendre et relancer
Bonjour @cddu33,
Merci pour l’évol.
Par contre, j’ai un pb lors du lancement du démon avec le message : « Une commande portant ce nom (varhLagLifetime1) existe déjà pour cet équipement »
[2023-06-26 22:55:29]ERROR : [MySQL] Error code : 23000 (1062). Duplicate entry '486-varhLagLifetime1' for key 'unique' : INSERT INTO `cmd` SET `id` = :id, `logicalId` = :logicalId, `generic_type` = :generic_type, `eqType` = :eqType, `name` = :name, `order` = :order, `type` = :type, `subType` = :subType, `eqLogic_id` = :eqLogic_id, `isHistorized` = :isHistorized, `unite` = :unite, `configuration` = :configuration, `template` = :template, `display` = :display, `value` = :value, `isVisible` = :isVisible, `alert` = :alert
[2023-06-26 22:56:05]ERROR : Erreur sur la fonction deamon_start du plugin : Using $this when not in object context
Encore un truc pour ceux en triphasé
ça te parle?
Cordialement,
Effectivement ça s’est installé après avoir attendu très longtemps mais ma charge est désormais à 9 au lieu de 1,5
Et jeedom rame
Alors,
@Menfin , la charge c’est que si tu es en triphasé ya plus de 20 commandes nouvelles à créer
@Silkarion , comme d’hab c’est corrigé mais il faudra surement supprimer les nouvelles commandes puis sauvegarder l’équipement
C’est bon maintenant.
Il faut faire un autre post pour les constats?
Sur « Conso courant net 1 2 et 3 » la data est vide.
Je me questionne quand même sur la surcharge générée à traiter toutes ces données…
Dès que l’on va commencer à parler de puissance active et réactive, on commence à toucher des initiés… avoir toutes ces datas surcharge l’équipement (et jeedom?) pour des utilisateurs non initiés. En triphasé, ça commence a faire pas mal de data😳
Il n’est pas possible d’avoir une sélection des infos à remonter sur l’équipement?
Ou bien un autre équipement complémentaire de type « expertise »
…pour réflexion.
Mais dans tous les cas : merci encore
Je vais regarde pour le courant.
Je ni pas activé l’historique de base pour ces commandes
Si quelqu’un est en tri et avec un pi, pour voir la charge
edit: corrigé
Merci à toi en tout cas !
Les dépendances sont installées et le plugin fonctionne
J’ai effectivement autant d’équipement que de PV + passerelle, ça fait au moins 60 commandes
C’est vrai que je n’aurai pas forcément nécessité de toutes ces informations mais je vais déjà les confronter dans un premier temps à l’appli enphase
Je vais aussi limiter le rafraichissement pour soulager le cpu
tu vois un impacte sur le CPU une fois que les commandes ont été créée?
Apparemment la charge CPU est redevenue dans des valeurs « normales » mais j’ai juste laissé la passerelle et désactivé tous les équipements onduleurs. La page santé jeedom reste cependant en rouge pour la mémoire, j’ai l’impression qu’elle ne s’est pas actualisée depuis hier
Concernant les informations prod et conso, je retrouve des valeurs cohérentes avec l’appli enphase pour la prod jour et la conso jour mais pour l’import reseau jour et l’export réseau jour, ça n’a rien à voir
J’ai un export de 21 kwh et le plugin affiche 37 wh, et un import de 3,6 kwh avec un affichage de - 17 kwh
Regarde les valeurs sur ton compte enedis plutôt , les valeurs de l’appli sont un peu pourris
Mon installation est récente et je n’ai pas le retour enedis pour la production mais je connais bien ma conso et il n’est pas possible que j’exporte 37 wh alors que je produis 40 kwh dans la journée !
J’ai vérifié la commande Export Reseau ne s’actualise pas
Je ne la vois pas apparaitre dans le temps réel donc ça parait logique que Export Reseau Jour soit aussi faible.
Forunis tes 2 logs en debug ça sert a rien de parler dans le vent ^^
J’avais déplacé cette question dans un autre post plus approprié https://community.jeedom.com/t/cumul-journalier-import-export-enphasesecure/106822/161 considérant que tu avais répondu à mon problème d’installation de dépendances
Mes logs ont été fournis et le problème du cumul d’export fixé à 37 Wh demeure…
j’avoue que je m’y perd avec ses sujets ^^ dsl
D’abords, merci pour le boulot effectué pour ce plugin
J’ai, a mon tour un soucis d’installation des dépendances.
J’ai essayé diverses choses mentionné dans ce fil et forum, j’ai même supprimé et réinstallé le plugin, « rétablis les droits » dans … mais rien n’y fait.
Le plugin reste désespérément NOK pour les dépendances.
Cela s’est produit pour ma part, lors d’une réinstallation de JEEDOM sur un nouveau disque SSD et réinstallation via une sauvegarde.
Voici le log de enphasesecur_update :
0000|**********************************
0001|* Installation des dépendances *
0002|**********************************
0003|Hit:1 http://security.debian.org/debian-security buster/updates InRelease
0004|Hit:2 http://deb.debian.org/debian buster InRelease
0005|Hit:3 https://packagecloud.io/ookla/speedtest-cli/debian buster InRelease
0006|Reading package lists...
0007|Reading package lists...
0008|Building dependency tree...
0009|Reading state information...
0010|python3 is already the newest version (3.7.3-1).
0011|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0012|Reading package lists...
0013|Building dependency tree...
0014|Reading state information...
0015|python3-pip is already the newest version (18.1-5).
0016|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0017|Requirement already satisfied: pip in /usr/local/lib/python3.7/dist-packages (23.1.2)
0018|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0019|WARNING: Skipping serial as it is not installed.
0020|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0021|WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
0022|Reading package lists...
0023|Building dependency tree...
0024|Reading state information...
0025|Package 'python3-serial' is not installed, so not removed
0026|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0027|Reading package lists...
0028|Building dependency tree...
0029|Reading state information...
0030|python3-setuptools is already the newest version (40.8.0-1).
0031|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0032|Reading package lists...
0033|Building dependency tree...
0034|Reading state information...
0035|python3-pyudev is already the newest version (0.21.0-1).
0036|python3-requests is already the newest version (2.21.0-1+deb10u1).
0037|0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
0038|Requirement already satisfied: pyjwt in /usr/local/lib/python3.7/dist-packages (2.7.0)
0039|Requirement already satisfied: html5lib in /usr/local/lib/python3.7/dist-packages (1.1)
0040|Requirement already satisfied: asyncio in /usr/local/lib/python3.7/dist-packages (3.4.3)
0041|Requirement already satisfied: httpx in /usr/local/lib/python3.7/dist-packages (0.24.1)
0042|Requirement already satisfied: lxml in /usr/local/lib/python3.7/dist-packages (4.9.3)
0043|Requirement already satisfied: html.parser in /usr/local/lib/python3.7/dist-packages (0.2)
0044|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0045|Collecting pyserial
0046|Using cached pyserial-3.5-py2.py3-none-any.whl (90 kB)
0047|Installing collected packages: pyserial
0048|Successfully installed pyserial-3.5
0049|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0050|Requirement already satisfied: six in /usr/local/lib/python3.7/dist-packages (1.16.0)
0051|WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager. It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv
0052|**********************************
0053|* Installation des dépendances OK *
0054|**********************************
Si quelqu’un a une idée ?
