[Plugin Tiers] Plugin VMWARE
Après quelques mois sans soucis, le plugin est en rideau (pas de snapshot d’effectué) depuis ce matin, le message :
‹ DateTime::__construct(): Failed to parse time string (@) at position 0 (@): Unexpected character ›
apparait en bandeau si on tente une synchro
Seule modification depuis hier une MàJ du core (alpha)
le log du cron se rempli avec :
 ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 183
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 184
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 185
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 192
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 193
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 194
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 201
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 202
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 203
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 209
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 210
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 211
PHP Warning:  ssh2_connect(): Unable to connect to 10.187.70.123 on port 22 in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 55
PHP Warning:  ssh2_connect(): Unable to connect to 10.187.70.123 in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 55
PHP Warning:  ssh2_auth_password() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 64
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 78
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 79
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 80
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 86
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 87
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 88
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 93
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 94
PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 95
PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 106
PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 107
PHP War
le log httperror avec :
[Sun Dec 08 09:39:48.187343 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1251, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187368 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1259, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187374 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1260, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187380 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1261, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187390 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1267, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187396 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1268, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187401 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1269, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187410 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1275, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187416 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1276, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187421 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_get_contents() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1277, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187435 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  ssh2_exec() expects parameter 1 to be resource, boolean given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1288, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
[Sun Dec 08 09:39:48.187441 2019] [:error] [pid 10494] [client 10.187.70.139:52042] PHP Warning:  stream_set_blocking() expects parameter 1 to be resource, null given in /var/www/html/plugins/vmware/core/class/vmware.class.php on line 1289, referer: http://10.187.70.106/index.php?v=d&m=vmware&p=vmware
le log vmware :
[2019-12-08 09:55:02][INFO] : ========================================================
[2019-12-08 09:55:02][INFO] : ================ Début du log - Cron 5 =================
[2019-12-08 09:55:02][ERROR] : ESXi injoignable
[2019-12-08 09:55:02][ERROR] : Connexion KO à l'ESXi
[2019-12-08 09:55:02][INFO] : Fin de la fonction Cron 5
Tous le reste est ok, la comm via putty avec esxi ne pose aucun soucis, tous les scénarios de surveillance qui communique avec esxi fonctionnent sans soucis
