Oui c’est bon
@Ynats je viens de voir que mon http.error se rempli de ces lignes régulièrement :
[Wed Jul 01 12:04:08.940629 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 874, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.941220 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 880, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.941687 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 886, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.942660 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 898, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.943102 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 904, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.943543 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 910, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.944032 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 916, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.944553 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 922, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.945010 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 928, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.945419 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 934, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.945816 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 940, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.946277 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 946, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.946776 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 952, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.947203 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 958, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
[Wed Jul 01 12:04:08.947709 2020] [:error] [pid 31954] [client 10.10.0.1:47578] PHP Warning: number_format() expects parameter 1 to be float, string given in /var/www/html/plugins/previsy/core/class/previsy.class.php on line 964, referer: https://monip/index.php?v=d&p=dashboard&object_id=1
Oui bizarre … je vais regarder.
Done …
En effet c’est partis sauf la 964.
Bonjour Ynats,
Super plugin que j’ai découvert hier soir et qui est bien intéressant !
J’ai un bug sur l’affichage du texte prédictif qui annonce l’heure de début de l’alerte à la fin du phénomène cité en condensé. la photo jointe sera plus explicite.
Merci pour le job déjà effectué !
salut très bon plugin depuis le temps que je cherche un plugin avec meteo et précipitation en mm.
comment tu fait pour avoir en ce moment et dans Xh? moi j’ai que Xh
Merci pour le retour et bien vu, j’ai corrigé le problème. Ce sera sur la prochaine version stable.
L’idée de ce plugin est d’afficher uniquement les alertes en prévisions.
Ce n’est pas un plugin de météo à proprement parlé.
Pour avoir cette information il y a « Prevision meteo » qui s’appuie sur les mêmes données que moi et qui pourra t’aider je pense.
ah ok j’avais pas tilté merci
Est-il possible d’utilisé des commandes ou des variables dans la localisation pour les coordonnées géographiques ?
Je ne suis pas certain de comprendre la question ?
Chaque commande et variable est associée à une localisation donc … je ne comprends pas la question?
Hello !
D’abord merci pour ce plugin, que je commence à apprivoiser.
Par contre y’a un truc (simple probablement) que j’arrive pas à comprendre : Sur quel(s) facteur(s)/condition(s) le plugin considère qu’il y a une alerte à annoncer ?
Dans la page de config, on voit que pour le vent, un seuil est donné (en fonction de la force du vent), et que donc les conditions actuelles seront considérées comme étant en alerte si le vent dépasse le seuil réglé dans la page de config. Mais quid pour les autres conditions ? Peut-configurer notre propre seuil d’alerte pour chaque paramètre ? (température max pour canicule ? Quantité d’eau pour pluie ? etc…)
Mon idée finale étant de ne faire remonter que les alertes qui m’intéresse (comme les tempêtes et les températures extrêmes). Les alertes liées à la pluie par exemple ne m’intéressent, et je voudrais pouvoir les ignorer.
Merci d’avance pour les éclaircissements !
Bonbour et merci pour le retour. Effectivement, les seuils ne sont gerables que sur le vent. Et pas sur les autres indicateurs. Toutefois m, pour le pluie et autre il suffit d’avoir le quelques goutes pour depéclancher une alerte. Effectivement je pourrai dans une prochaine version étendre cela sur l’ensemble des données. A voir avec le temps que j’aurai.
En fait j’aimerais utiliser la localisation de mon portable (dynamique donc) dans l’appli. Or pour qu’il fonctionne il faut inscrire la latitude et longitude en dur. D’où ma question est ce qu’on peu mettre dans la case une commande ou une variable pour faire de la localisation dynamique
Je ne sais pas du tout comment marche la gestion des coordonnées dynamiques ?
C’est donc en lien avec la version de Jeedom mobile ou un plugin particulier ?
En tout cas à ce jour, le plugin n’est pas conçu pour ça et par ailleurs cela risque de mettre la grouille au niveau des appels météo et le cache … Donc je pense que cela risque de poser des problèmes …
Super idée ce plugin, merci
Si j’ai bien compris si pas d’alerte = widget « aucune alerte à déclarer » et apparaîtra des données comme plus haut qu’en cas d’alerte, right ?
Puni
Edit : c’est bien ca, je viens d’avoir une alerte
Sympa ce plugin, je connaissais pas
Un petit soucis dans la phrase:
Dans 25 heures, soit demain à partir de 14 heures, un orage est prévu durant 3 heures. Il y aura un total de 3.1 millimètres de précipitation soit une moyenne de 0.8 millimètre au m² et par heure. Au plus bas, , avec 0.0 millimètre de précipitation. Au plus haut, le ciel sera faiblement orageux, avec 2.5 millimètres de précipitation. Le taux d’humidité sera en moyenne à 65.3% allant d’une amplitude de 58.0% à 74.0%. La température moyenne sera de 18.4°C allant d’une amplitude de 17.5°C à 19.1°C. Le vent soufflera en moyenne à 19.5 KM/H avec des rafales pouvant aller jusqu’à 38.0 KM/H.
Petite remarque de detail sur widget, j’ai l’unité du vent (vitesse et rafales) qui se met sur 2 lignes pour les min et Max (le H est sur une ligne seul). Je ne vois pas ça sur les captures au dessus alors c’est peut-être un soucis chez moi…
edit: je ne sais pas si la partie de phrase vide vient du code ou des infos meteo, alors dans le dout j’ai recupéré je json dans le dossier du plugin226.json.txt (51,8 Ko)
C’est bien ça
