Alors là par exemple je viens de me reconnecter à mon Jeedom et directe j’ai eu le message.
Deprecated: Non-static method horoscope::templateWidget() should not be called statically in /var/www/html/core/class/cmd.class.php on line 1183
Notice: Undefined index: poaceae in /var/www/html/plugins/airquality/3rdparty/class.IconesAqi.php on line 129
Warning: Invalid argument supplied for foreach() in /var/www/html/plugins/airquality/3rdparty/class.IconesAqi.php on line 129
Notice: Undefined index: poaceae in /var/www/html/plugins/airquality/3rdparty/class.IconesAqi.php on line 142
Notice: Undefined index: nettle in /var/www/html/plugins/airquality/3rdparty/class.IconesAqi.php on line 129
Notice: Undefined index: nettle in /var/www/html/plugins/airquality/3rdparty/class.IconesAqi.php on line 142
J’ai mis le plugin en Debug et j’ai cela dans les log:
[2021-07-01 12:00:42][DEBUG] : Curl Info http != 200 : {"url":"http:\/\/api.openweathermap.org\/data\/2.5\/air_pollution?lat=48.912073&lon=2.4366605","content_type":null,"http_code":0,"header_size":0,"request_size":219,"filetime":-1,"ssl_verify_result":0,"redirect_count":0,"total_time":30.001357,"namelookup_time":0.040572,"connect_time":0.066105,"pretransfer_time":0.066544,"size_upload":0,"size_download":0,"speed_download":0,"speed_upload":0,"download_content_length":-1,"upload_content_length":-1,"starttransfer_time":0,"redirect_time":0,"redirect_url":"","primary_ip":"37.139.20.5","certinfo":[],"primary_port":80,"local_ip":"192.168.1.54","local_port":56060,"http_version":0,"protocol":1,"ssl_verifyresult":0,"scheme":"HTTP","appconnect_time_us":0,"connect_time_us":66105,"namelookup_time_us":40572,"pretransfer_time_us":66544,"redirect_time_us":0,"starttransfer_time_us":0,"total_time_us":30001357} - Url : "http:\/\/api.openweathermap.org\/data\/2.5\/air_pollution?lat=48.912073&lon=2.4366605"
[2021-07-01 12:00:42][DEBUG] : Problème API : "Operation timed out after 30001 milliseconds with 0 bytes received"
[2021-07-01 12:00:42][ERROR] : Erreur sur la fonction cron30 du plugin : Pas de données de pollution pour l'instant : Operation timed out after 30001 milliseconds with 0 bytes received
Voici le fichier log en question
errors.log (1,2 Mo)
