Plantage demon Jeezigbee
Bonjour, j’ai toujours cette erreur qui persiste et je n’arrive pas a corriger le problème.
A ce que j’ai pu chercher il s’agirait peut être d’un problème de communication entre la clef sonoff et jeedom.
Je ne sais pas comment résoudre ce problème.
Merci de votre aide.
 zigbee2mqtt@1.42.0 start
> node index.js
Starting Zigbee2MQTT without watchdog.
[2025-01-24 12:35:54] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ERROR_WRONG_DIRECTION. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=219 Len=26].
[2025-01-24 12:35:57] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ERROR_WRONG_DIRECTION. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=219 Len=26].
[2025-01-24 12:36:47] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=219 Len=26].
[2025-01-24 12:36:48] e[31merrore[39m: 	zh:ember: Adapter fatal error: ASH_ERROR_TIMEOUTS
[2025-01-24 12:36:56] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
[2025-01-24 12:45:51] e[31merrore[39m: 	zh:ember:uart:ash: Received ERROR from adapter, with code=ERROR_EXCEEDED_MAXIMUM_ACK_TIMEOUT_COUNT.
[2025-01-24 12:45:52] e[31merrore[39m: 	zh:ember:uart:ash: ASH disconnected | Adapter status: ASH_NCP_FATAL_ERROR
[2025-01-24 12:45:54] e[31merrore[39m: 	zh:ember:uart:ash: Error while parsing received frame, status=ASH_NCP_FATAL_ERROR.
[2025-01-24 12:45:56] e[31merrore[39m: 	zh:ember: Adapter fatal error: HOST_FATAL_ERROR
[2025-01-24 12:45:56] e[31merrore[39m: 	zh:ember:uart:ash: Error while parsing received frame, status=ASH_NCP_FATAL_ERROR.
[2025-01-24 12:45:59] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ASH_ERROR_TIMEOUTS. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=74 Len=7].
[2025-01-24 12:45:59] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=74 Len=7].
[2025-01-24 12:46:00] e[31merrore[39m: 	zh:ember:ezsp: ERROR Transaction failure; status=ASH_NCP_FATAL_ERROR. Last Frame: [FRAME: ID=52:"SEND_UNICAST" Seq=74 Len=7].
[2025-01-24 12:46:45] e[31merrore[39m: 	z2m: Adapter disconnected, stopping
> node index.js
Informations Jeedom
Core : 4.4.19 (master)
DNS Jeedom : oui
Plugin : JeeZigbee
Version : 2025-01-15 01:01:47 (stable)
Statut Démon : Démarré - (2025-01-24 12:50:14)
Les liens des images ont été collés dans la partie log. Il faudrait le fichier de configuration.yaml
La version firmware de votre clé est compatible ember?
pour info avant j’utilisais Zigbeelinker et je suis passé a jeezigbee, j’ai donc un dossier zigbeemqtt2 dans les plugin
version firmware de la clef ZBDongle-E : Zigbee (EZSP) 7.4.4.0 build 0
pour le fichier configuration.yaml
permit_join: false
mqtt:
  server: mqtt://127.0.0.1:1883
  user: jeedom
  password: khKUt3jRAbVyZH0bFGcDj6JA9AgE84KPRFjCHGOJ82YqZQ7SgM6rrbEyy4wDebv6
  base_topic: zigbee2mqtt
  include_device_information: true
serial:
  port: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231121165355-if00
  adapter: ember
frontend:
  port: 8080
  host: 0.0.0.0
  auth_token: vrPuzjiO5i7R0Af7EZPR14A6An8QUqUQ
advanced:
  last_seen: ISO_8601
  network_key:
  - 207
  - 207
  - 195
  - 140
  - 220
  - 231
  - 24
  - 162
  - 52
  - 41
  - 108
  - 180
  - 36
  - 58
  - 54
  - 237
  pan_id: 21761
  ext_pan_id:
  - 220
  - 61
  - 151
  - 176
  - 22
  - 152
  - 152
  - 71
  log_level: error
  homeassistant_legacy_entity_attributes: false
  legacy_api: false
  legacy_availability_payload: false
external_converters:
- /var/www/html/plugins/z2m/core/class/../config/converters/Danfoss/icon.js
device_options:
  legacy: false
devices:
  "0xa4c13860e46034c7":
    friendly_name: "0xa4c13860e46034c7"
  "0x70b3d52b600783f4":
    friendly_name: "0x70b3d52b600783f4"
  "0xa4c1381748645366":
    friendly_name: "0xa4c1381748645366"
  "0xa4c13844caff5f2b":
    friendly_name: "0xa4c13844caff5f2b"
  "0xa4c13800ab501e91":
    friendly_name: "0xa4c13800ab501e91"
  "0xa4c1383394ccab75":
    friendly_name: "0xa4c1383394ccab75"
  "0xccccccfffed8414e":
    friendly_name: "0xccccccfffed8414e"
  "0xa4c13854bdc201c0":
    friendly_name: "0xa4c13854bdc201c0"
  "0xa4c138dd4f218935":
    friendly_name: "0xa4c138dd4f218935"
  "0xa4c1382ca05642be":
    friendly_name: "0xa4c1382ca05642be"
  "0x385b44fffed69caf":
    friendly_name: "0x385b44fffed69caf"
  "0x881a14fffeee2953":
    friendly_name: "0x881a14fffeee2953"
  "0x70b3d52b60047615":
    friendly_name: "0x70b3d52b60047615"
  "0xa4c138d6fd17bb5b":
    friendly_name: "0xa4c138d6fd17bb5b"
  "0x70b3d52b600782c4":
    friendly_name: "0x70b3d52b600782c4"
  "0xa4c138bd9726c6f8":
    friendly_name: "0xa4c138bd9726c6f8"
  "0xa4c13891311862b8":
    friendly_name: "0xa4c13891311862b8"
  "0xa4c138931d36c9f0":
    friendly_name: "0xa4c138931d36c9f0"
  "0xa4c138b47113356a":
    friendly_name: "0xa4c138b47113356a"
  "0xa4c138667974c512":
    friendly_name: "0xa4c138667974c512"
  "0xa4c138a269f1f792":
    friendly_name: "0xa4c138a269f1f792"
  "0xa4c1380d11fdaf2c":
    friendly_name: "0xa4c1380d11fdaf2c"
  "0xa4c138cbfddb7b62":
    friendly_name: "0xa4c138cbfddb7b62"
  "0x000d6ffffedb1104":
    friendly_name: "0x000d6ffffedb1104"
  "0x94deb8fffea4086e":
    friendly_name: "0x94deb8fffea4086e"
  "0xa4c138d4aeb90ac9":
    friendly_name: "0xa4c138d4aeb90ac9"
  "0xa4c138ce87fabb3b":
    friendly_name: "0xa4c138ce87fabb3b"
  "0xa4c138ce71ff6a13":
    friendly_name: "0xa4c138ce71ff6a13"
  "0xa4c138860fee5f5f":
    friendly_name: "0xa4c138860fee5f5f"
  "0xa4c13889c966e8eb":
    friendly_name: "0xa4c13889c966e8eb"
  "0xa4c13813c544cfa6":
    friendly_name: "0xa4c13813c544cfa6"
  "0xa4c138807ed8ad1b":
    friendly_name: "0xa4c138807ed8ad1b"
  "0xa4c138a741af3a28":
    friendly_name: "0xa4c138a741af3a28"
  "0xa4c13821cf9608ed":
    friendly_name: "0xa4c13821cf9608ed"
Et zigbeelinker est-il désactivé ?
Le firmware est bien pour ember.
oui zigbeelinker est desactivé
Dans Type de contrôleur a tu essayé de mettre ZNP/ZI.
bonjour,
tu as migré de Zigbeelinker vers Jeezigbee (z2m) pour récupérer l’ensemble des devices sans avoir à ré-appareiller ?
Si oui as tu suivis une procédure ? et surtout à la fin lorsque tu as désactivé Zigbeelinker as tu redémarré ta boite pour « libérer » les ports ?
Je te dis cela car hier j’ai voulu faire l’inverse (Z2m->Zigbeelinker) en appliquant la méthode proposé sur ce forum… et j’ai buté quelques heures sur un problème ou le demon ne se lançait pas à cause de l’Eszp…(sans compter les lignes du fichier configuration.yaml) Et je me suis souvenu d’un post ou il était dis que l’accès à un port se libérait en redémarrant.
Et comme par hasard il a démarré ensuite !! j’ai eu plus de mal avec les devices car je ne suis aps arrivé à les faire revenir par synchronisation sur Zigbeelinker…donc restauration de la sauvegarder et retour sur Z2m
voici le lien [RTEX] migration ZigbeeLinker vers JeeZigbee - Plugins / Protocole domotique - Communauté Jeedom
J’ai re inclus mes périphériques un par un. et oui je redémarre souvent ma box, le problème n’est pas récent.
Non, j’ai essayer ember et EZSP, je vais essayer de suite ^^
avec ZNP/ZI le demon ne démarre pas
[2025-01-24 17:53:14] e[31merrore[39m: 	z2m: Error while starting zigbee-herdsman
[2025-01-24 17:53:14] e[31merrore[39m: 	z2m: Failed to start zigbee
[2025-01-24 17:53:14] e[31merrore[39m: 	z2m: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
[2025-01-24 17:53:14] e[31merrore[39m: 	z2m: Exiting...
[2025-01-24 17:53:14] e[31merrore[39m: 	z2m: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
at ZStackAdapter.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/adapter/z-stack/adapter/zStackAdapter.ts:113:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/node_modules/zigbee-herdsman/src/controller/controller.ts:137:29)
at Zigbee.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/zigbee.ts:69:27)
at Controller.start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/lib/controller.ts:161:27)
at start (/var/www/html/plugins/z2m/resources/zigbee2mqtt/index.js:154:5)
Du coup remet le sur ember.
Dsl j’ai pas de solution à te proposer.
Pas contre moi j’utilise une clé sonoff mais sans le v2 sur ZNP/ZI et tout fonctionne parfaitement.
d’accord. merci de l’info
Est ce que ca servirait a quelque chose de refaire mon installation à zero : réinstallation de jeedom etc…?
Avant de tout resintaller pourrais tu nous mettre le contenu de ton fichier configuration.yaml ?
oui je l’ai partager plus haut dans les conversations
permit_join: false
mqtt:
  user: jeedom
serial:
  adapter: ember
frontend:
  port: 8080
  host: 0.0.0.0
advanced:
  last_seen: ISO_8601
  network_key:
  - 207
  - 207
  - 195
  - 140
  - 220
  - 231
  - 24
  - 162
  - 52
  - 41
  - 108
  - 180
  - 36
  - 58
  - 54
  - 237
  pan_id: 21761
  ext_pan_id:
  - 220
  - 61
  - 151
  - 176
  - 22
  - 152
  - 152
  - 71
  log_level: error
  legacy_api: false
device_options:
  legacy: false
devices:
  "0xa4c13825d4268d84":
    friendly_name: "0xa4c13825d4268d84"
  "0xa4c1380577c880af":
    friendly_name: "0xa4c1380577c880af"
Bonsoir
Je te laisse lire en intégralité le post, mais j’ai rapidement lu qu’un utilisateur avait résolu son problème en passant sa clé avec un firwmare en 8.0.2
Peut être une piste à explorer.
je viens d essayer même erreur
JE vais peut etre essayer de changer de doogle. vous me conseillez le quel ?
désolé je n’avais pas vu
Fait une copie de ton fichier… je ne sais pas si cela changera quoique ce soit, mais par comparaison avec le mien j’enlèverais les lignes … et si cela ne fonctionne pas reinjecte ta copie de fichier
legacy_api: false
:device_options:
legacy: false
et j’ajouterais à la fin:
version: 4
permit_join: false
voici le mien (qui fonctionne) …
mqtt:
  user: jeedom
  password: TFBz8sL9lYE8lZKLqJ26u5XoIhzmqh63NLcbob5eAsyWHD
serial:
  port: /dev/ttyLuna-Zigbee
  adapter: ezsp
frontend:
  enabled: true
  port: 8080
  host: 0.0.0.0
  auth_token: LzVcrnBDnwDfsAPPRjUoj1AQ
advanced:
  last_seen: ISO_8601
  network_key:
  - 99
  - 2
  - 120
  - 93
  - 102
  - 223
  - 183
  - 2
  - 183
  - 128
  - 229
  - 59
  - 121
  - 14
  - 221
  - 237
  pan_id: 34378
  ext_pan_id:
  - 238
  - 192
  - 245
  - 111
  - 19
  - 212
  - 151
  - 10
  log_level: error
devices:
  "0xa4c1381c1d9b0279":
    friendly_name: "0xa4c1381c1d9b0279"
  "0xa4c138fd47ff7315":
    friendly_name: "0xa4c138fd47ff7315"
  "0xa4c13890f64b47e5":
    friendly_name: "0xa4c13890f64b47e5"
  "0xa4c13853fe5f95aa":
    friendly_name: "0xa4c13853fe5f95aa"
  "0xa4c13847f90de28c":
    friendly_name: "0xa4c13847f90de28c"
  "0x6cfd22fffe5b13b7":
    friendly_name: "0x6cfd22fffe5b13b7"
  "0xa4c138f13bfd400c":
    friendly_name: "0xa4c138f13bfd400c"
  "0x44e2f8fffe1a6e67":
    friendly_name: "0x44e2f8fffe1a6e67"
  "0x44e2f8fffe1a726f":
    friendly_name: "0x44e2f8fffe1a726f"
  "0xa4c138771e39dffb":
    friendly_name: "0xa4c138771e39dffb"
  "0x50325ffffe1d7141":
    friendly_name: "0x50325ffffe1d7141"
  "0xa4c138835ca30f0c":
    friendly_name: "0xa4c138835ca30f0c"
  "0x0c4314fffe5d073d":
    friendly_name: "0x0c4314fffe5d073d"
  "0xa4c1384a80fc7a38":
    friendly_name: "0xa4c1384a80fc7a38"
  "0x54ef44100068522c":
    friendly_name: "0x54ef44100068522c"
  "0xe0798dfffec2ed5f":
    friendly_name: "0xe0798dfffec2ed5f"
  "0x00124b0026b7f541":
    friendly_name: "0x00124b0026b7f541"
  "0x00124b0026b7cbd2":
    friendly_name: "0x00124b0026b7cbd2"
    state_action: false
  "0x00124b00287f03b7":
    friendly_name: "0x00124b00287f03b7"
  "0x0ceff6fffe5b5b64":
    friendly_name: "0x0ceff6fffe5b5b64"
  "0x0ceff6fffee3308e":
    friendly_name: "0x0ceff6fffee3308e"
  "0x08ddebfffeeedbfb":
    friendly_name: "0x08ddebfffeeedbfb"
  "0x842712fffe73b445":
    friendly_name: "0x842712fffe73b445"
  "0x842712fffe32f9f0":
    friendly_name: "0x842712fffe32f9f0"
groups:
  1:
    friendly_name: "T\xE8te Thermostatique"
version: 4
permit_join: false
