Au final je devais être sur une page pas rafraichie. Ce soir je suis bien avec ce firmware :
ZCL Version : 3 APP Version : 33 Stack Version : 98 HW Version : 1 Date code : 20210526 Software version : 2.3.075
Et impossible de refaire un binding avec la télécommande. J’ai bien un message comme quoi c’est réussi mais il ne se passe plus rien.
voila les logs : binding on/off, binding level control, appuis court sur 1 puis 0, appuis long sur 1 puis 0
{"devices":{"84:fd:27:ff:fe:8d:4b:bd":{"1":[{"1":{"value":"66","cluster_name":"Basic"}}]}}}
Search attribut for 84:fd:27:ff:fe:8d:4b:bd logicalId : 1::0::1 => 66
{"devices":{"00:15:8d:00:05:3a:3d:3c":{"1":{"768":{"7":{"value":"153","cluster_name":"Color Control"}}}}}}
Search attribut for 00:15:8d:00:05:3a:3d:3c logicalId : 1::768::7 => 153
http://127.0.0.1:8089/device/bind type : PUT
{"src":{"ieee":"cc:cc:cc:ff:fe:f2:3c:3f","endpoint":1,"cluster":6},"dest":{"type":"group","group_id":"1"}}
{"devices":{"cc:cc:cc:ff:fe:f2:3c:3f":{"1":{"6":{"cmd":[{"value":"1","cluster_name":"On\/Off"},{"value":"[]","cluster_name":"On\/Off"}]}}}}}
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::6::cmd::0 => 1
{"src":{"ieee":"cc:cc:cc:ff:fe:f2:3c:3f","endpoint":1,"cluster":8},"dest":{"type":"group","group_id":"1"}}
{"devices":{"cc:cc:cc:ff:fe:f2:3c:3f":{"1":{"6":{"cmd":[{"value":"0","cluster_name":"On\/Off"},{"value":"[]","cluster_name":"On\/Off"}]}}}}}
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::6::cmd::0 => 0
{"devices":{"cc:cc:cc:ff:fe:f2:3c:3f":{"1":{"8":{"cmd":{"0":{"value":"5","cluster_name":"Level control"},"1":{"value":"0","cluster_name":"Level control"},"1.1":{"value":"83","cluster_name":"Level control"}}}}}}}
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::0 => 5
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::1 => 0
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::1.1 => 83
{"devices":{"cc:cc:cc:ff:fe:f2:3c:3f":{"1":{"8":{"cmd":[{"value":"7","cluster_name":"Level control"},{"value":"[]","cluster_name":"Level control"}]}}}}}
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::0 => 7
{"devices":{"cc:cc:cc:ff:fe:f2:3c:3f":{"1":{"8":{"cmd":{"0":{"value":"1","cluster_name":"Level control"},"1":{"value":"1","cluster_name":"Level control"},"1.1":{"value":"83","cluster_name":"Level control"}}}}}}}
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::0 => 1
Search command for cc:cc:cc:ff:fe:f2:3c:3f logicalId : 1::8::cmd::1 => 1
Voici ce que j’ai comme infos, elles sont peut être différentes avec la MAJ ? :
"ieee": "cc:cc:cc:ff:fe:f2:3c:3f",
"nwk": 36237,
"status": 2,
"lqi": "136",
"rssi": "-66",
"last_seen": "1622911593.3623617",
"node_descriptor": "02:40:80:7c:11:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 2080,
"profile_id": 260,
"manufacturer": "IKEA of Sweden",
"model": "TRADFRI on\/off switch",
"output_clusters": [
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 25,
"name": "Ota",
"attributes": []
"id": 258,
"name": "Window Covering",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 33
"id": 2,
"name": "stack_version",
"value": 98
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "IKEA of Sweden"
"id": 5,
"name": "model",
"value": "TRADFRI on\/off switch"
"id": 6,
"name": "date_code",
"value": "20210526"
"id": 7,
"name": "power_source",
"value": 3
"id": 16384,
"name": "sw_build_id",
"value": "2.3.075"
"id": 1,
"name": "Power Configuration",
"attributes": [
"id": 32,
"name": "battery_voltage",
"value": 31
"id": 33,
"name": "battery_percentage_remaining",
"value": 174
"id": 3,
"name": "Identify",
"attributes": []
"id": 9,
"name": "Alarms",
"attributes": []
"id": 32,
"name": "Poll Control",
"attributes": []
"id": 4096,
"name": "LightLinkCluster",
"attributes": []
"id": 64636,
"name": "Manufacturer Specific",
"attributes": []
"signature": {
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4476,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"input_clusters": [
0,
1,
3,
9,
32,
4096,
64636
3,
4,
6,
8,
25,
258,
4096
"class": "zhaquirks.ikea.twobtnremote"
Juju
