Bonsoir @sim140680 et @Michel_F,
J’ai modifié la conf côté passerelle pour passer en « Transparent Mode », le reste des confs était déjà OK.
ça a l’air beaucoup mieux déjà !
J’ai (pour la première fois) des valeurs correctes (elles paraissent bizarres, mais parce qu’il faut les diviser par 10) :
Par contre, ça a récupéré les valeurs à 20h49
Et depuis, j’ai l’impression que ça ne bouge plus, et j’ai de nombreuses erreurs dans les logs
0091|[2025-02-14 20:56:37] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0092|[2025-02-14 20:56:42] ERROR : No response received after 3.0 retries, continue with next request
0093|[2025-02-14 20:56:42] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0094|[2025-02-14 20:56:50] ERROR : No response received after 3.0 retries, continue with next request
0095|[2025-02-14 20:56:50] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0096|[2025-02-14 20:56:55] ERROR : No response received after 3.0 retries, continue with next request
0097|[2025-02-14 20:56:55] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0098|[2025-02-14 20:57:03] ERROR : No response received after 3.0 retries, continue with next request
0099|[2025-02-14 20:57:03] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0100|[2025-02-14 20:57:08] ERROR : No response received after 3.0 retries, continue with next request
0101|[2025-02-14 20:57:08] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0102|[2025-02-14 20:57:17] ERROR : No response received after 3.0 retries, continue with next request
0103|[2025-02-14 20:57:17] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0104|[2025-02-14 20:57:22] ERROR : No response received after 3.0 retries, continue with next request
0105|[2025-02-14 20:57:22] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0106|[2025-02-14 20:57:30] ERROR : No response received after 3.0 retries, continue with next request
0107|[2025-02-14 20:57:30] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0108|[2025-02-14 20:57:35] ERROR : No response received after 3.0 retries, continue with next request
0109|[2025-02-14 20:57:35] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0110|[2025-02-14 20:57:44] ERROR : No response received after 3.0 retries, continue with next request
0111|[2025-02-14 20:57:44] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0112|[2025-02-14 20:57:49] ERROR : No response received after 3.0 retries, continue with next request
0113|[2025-02-14 20:57:49] ERROR : Chaudiere/608_Ionization_current: error during read request on slave id 100, address 608 -> Exception Response(131, 3, None)
0114|[2025-02-14 20:57:57] ERROR : No response received after 3.0 retries, continue with next request
0115|[2025-02-14 20:57:57] ERROR : Chaudiere/602_Temp_chaudiere: error during read request on slave id 100, address 602 -> Exception Response(131, 3, None)
0116|[2025-02-14 20:58:02] ERROR : No response received after 3.0 retries, continue with next request
Il ne doit plus manquer grand chose!
@sim140680
C’est étrange sur tes captures :
On voit Mode de rafraichissement = Cyclique, et en dessous une valeur de pooling.
J’ai mis Polling, je ne sais pas si c’est le bon choix.
