En choisissant une image perso depuis l’app ça marche ?
Je n’ai pas trop l’habitude d’éditer depuis l’application mais j’ai essayé « editer ce widget », clique sur image et là je n’ai pas accés à grand chose (juste le nom du fichier choisi sur le PC, pas d’image) :
Ok.
Peux tu activer les logs de l’appli.
Puis sélectionner une image perso ?
0:10:31 | INFO | Start logger
10:10:45 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"GET_FILES","params":{"folder":"/plugins/JeedomConnect/data/img/user_files","recursive":true,"apiKey":"xxx"},"jsonrpc":"2.0","id":1635235845330}
10:10:48 | INFO | Image pressed {"url":"http://192.168.2.37/core/php/downloadFile.php?apikey=xxxx&pathfile=/var/www/html/plugins/JeedomConnect/core/class/../../../../plugins/JeedomConnect/data/img/user_files/aeon_DSC24_US_off.png","filename":"aeon_DSC24_US_off","extension":"png","file":"aeon_DSC24_US_off.png","path":"aeon_DSC24_US_off.png"}
10:10:48 | INFO | userImgPath is plugins/JeedomConnect/data/img/user_files/
10:11:03 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"SET_WIDGET","params":{"widget":{"id":59,"name":"Branchée","subtitle":"elapsedTime","statusInfo":{"id":"8522","type":"info","subType":"binary","step":"1"},"image":{"source":"user","name":"aeon_DSC24_US_off.png"},"statusImages":[{"index":0,"image":{"source":"user","name":"aeon_DSC24_on.png","shadow":false},"condition":"#8522#"}],"display":"miniWidget","hideTitle":false,"hideSubTitle":false,"hideStatus":false,"hideIcon":false,"type":"generic-info-binary","blockDetail":false,"enable":true,"room":10},"apiKey":"xxxx"},"jsonrpc":"2.0","id":1635235863149}
10:11:03 | DEBUG | [http] CMD, SC, OBJ infos received
10:11:04 | DEBUG | [http] CMD, SC, OBJ infos received
10:11:05 | DEBUG | [http] CMD, SC, OBJ infos received
10:11:29 | INFO | App state changed to background
10:11:29 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"xxx"},"jsonrpc":"2.0","id":1635235889545}
10:12:38 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"SET_BATTERY","params":{"level":93,"apiKey":"xxx"},"jsonrpc":"2.0","id":1635235958552}
10:12:45 | INFO | App state changed to active
10:12:45 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"SET_APPSTATE","params":{"state":"active","apiKey":"xxx"},"jsonrpc":"2.0","id":1635235965616}
10:12:45 | DEBUG | [main] set secure session to false 76071
10:12:56 | INFO | App state changed to background
10:12:56 | DEBUG | sendToJcApi http://192.168.2.37/plugins/JeedomConnect/core/api/JeedomConnect.api.php {"method":"SET_APPSTATE","params":{"state":"background","apiKey":"xxx"},"jsonrpc":"2.0","id":1635235976889}
Tout semble normal.
Si tu copies l’URL (de la ligne 3) dans un navigateur, as tu l’image ?
j’ai « 401 - Accès non autorisé »
depuis un navigateur de mon mobile mais aussi depuis mon PC.
un problème de droit sur ce répertoire ?
Le user que l’équipement est un admin ?
oui je n’utilise qu’admin sur les 2 appareils mobiles
j’ai lu que jeedom avait renforcé la sécurité depuis cette version et que certains pluggin avaient du déplacer les images dans un répertoire autorisé par jeedom , une piste ?
la derniere version devait prendre en charge ces changements
mais on vient de découvrir une autre modif cote core (sur les beta & alpha 4.2.xx) qui foutent un peu la grouille et empêche du coup de récupère ce dont on a besoin.
Ce qui explique les soucis qu’il y a sur l’ensemble des nouvelles img perso (ie « nouvelles » dans le sens ‹ non déjà connues et présentes dans l’appli ›)
Ok compris, les joies de la béta , pas de soucis je vais patienter ou essayer de revenir à une version stable de jeedom.
non, heureusement qu’elle est finalement là
car devoir tout régler en derniere minute ca serait un peu galere !
mais c’est vrai que gérer tous les chgt n’est pas évident …
ou plus simple : utiliser la partie icone, ou seulement image standard de JC. pas la partie « img perso » (sauf si déjà utilisées ailleurs !)
OK je continue à tester cette béta et vous tenir au courant
Je peux me passer des images en attendant le texte est là
3 messages ont été scindés en un nouveau sujet : Souci sur la connexion manuelle (sans utiliser le qrcode)
3 messages ont été scindés en un nouveau sujet : Incohérence option sélecteur de zoom
4 messages ont été scindés en un nouveau sujet : Image sur condition sur un valeur de type chaine
