alors pour celui-ci j’ai un pavé que je ne saurai interpréter et je ne peux pas le copier ici, il est trop long
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.16.85+ (root@odroid-stretch64) (gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1) ) #1 SMP PREEMPT Mon Jul 13 14:40:04 UTC 2020
[ 0.000000] CPU: AArch64 Processor [410fd034] revision 4
[ 0.000000] secmon: share mem setup
[ 0.000000] Reserved memory: initialized node linux,secmon, compatible id aml _secmon_memory
[ 0.000000] __reserved_mem_alloc_size: linux,meson-fb
[ 0.000000] fb: Reserved memory: created fb at 0x0000000078000000, size 128 M iB
[ 0.000000] Reserved memory: initialized node linux,meson-fb, compatible id a mlogic, fb-memory
[ 0.000000] __reserved_mem_alloc_size: linux,di
[ 0.000000] DI reserved memory: created CMA memory pool at 0x0000000076200000 , size 30 MiB
[ 0.000000] Reserved memory: initialized node linux,di, compatible id amlogic , di-mem
[ 0.000000] __reserved_mem_alloc_size: linux,ion-dev
[ 0.000000] linux,ion-dev add multi user:ffffffc001d48000
[ 0.000000] ion_dev mem setup
[ 0.000000] Reserved memory: initialized node linux,ion-dev, compatible id am logic, idev-mem
[ 0.000000] ppmgr share mem setup
[ 0.000000] linux,ion-dev add multi user:ffffffc001d4d4a0
[ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_cma
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000067c00000, s ize 188 MiB
[ 0.000000] Reserved memory: initialized node linux,codec_mm_cma, compatible id shared-dma-pool
[ 0.000000] __reserved_mem_alloc_size: linux,picdec
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000064c00000, s ize 48 MiB
[ 0.000000] Reserved memory: initialized node linux,picdec, compatible id sha red-dma-pool
[ 0.000000] __reserved_mem_alloc_size: linux,codec_mm_reserved
[ 0.000000] codec_mm:vdec: reserved mem setup
[ 0.000000] Reserved memory: initialized node linux,codec_mm_reserved, compat ible id amlogic, codec-mm-reserved
[ 0.000000] __reserved_mem_alloc_size: linux,jpegenc_cma
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000005e400000, s ize 36 MiB
[ 0.000000] Reserved memory: initialized node linux,jpegenc_cma, compatible i d shared-dma-pool
[ 0.000000] cma: CMA: reserved 8 MiB at 5dc00000
[ 0.000000] On node 0 totalpages: 486912
[ 0.000000] Normal zone: 6664 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 486912 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] PERCPU: Embedded 12 pages/cpu s19712 r8192 d21248 u49152
[ 0.000000] pcpu-alloc: s19712 r8192 d21248 u49152 alloc=12*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pag es: 480248
[ 0.000000] Kernel command line: root=LABEL=emlinux rootwait ro console=ttyS0 ,115200n8 console=tty0 no_console_suspend hdmimode=1080p60hz m_bpp=32 vout=hdmi fsck.repair=yes net.ifnames=0 elevator=noop disablehpd=true
[ 0.000000] logo: get hdmimode: 1080p60hz
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[ 0.000000] Memory: 1476032K/1947648K available (8405K kernel code, 892K rwda ta, 3080K rodata, 919K init, 4116K bss, 471616K reserved)
[ 0.000000] Virtual kernel memory layout:
vmalloc : 0xffffff8000000000 - 0xffffffbbffff0000 (245759 M B)
vmemmap : 0xffffffbc00000000 - 0xffffffbc01a40000 ( 26 M B)
modules : 0xffffffbffc000000 - 0xffffffc000000000 ( 64 M B)
memory : 0xffffffc000000000 - 0xffffffc078000000 ( 1920 M B)
.init : 0xffffffc001bb9000 - 0xffffffc001c9ed00 ( 920 k B)
.text : 0xffffffc001080000 - 0xffffffc001bb8634 ( 11490 k B)
.data : 0xffffffc001c9f000 - 0xffffffc001d7e030 ( 893 k B)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000005] sched_clock: 32 bits at 1000kHz, resolution 1000ns, wraps every 2 147483648000ns
[ 0.000024] mclk->mux_reg =ffffff8000002990,mclk->reg =ffffff800000a994
[ 0.000071] local timer MESON TIMER-G mclk->mux_reg =ffffff8000002990,mclk->r eg =ffffff800000c998
[ 0.000092] local timer MESON TIMER-H mclk->mux_reg =ffffff8000002990,mclk->r eg =ffffff800000e99c
[ 0.000114] local timer MESON TIMER-I mclk->mux_reg =ffffff8000002990,mclk->r eg =ffffff80000109a0
[ 0.000125] Switching to timer-based delay loop
[ 0.000366] Console: colour dummy device 80x25
[ 0.000880] console [tty0] enabled
[ 0.003212] allocated 8388608 bytes of page_cgroup
[ 0.003221] please try 'cgroup_disable=memory' option if you don't want memor y cgroups
[ 0.003237] Calibrating delay loop (skipped), value calculated using timer fr equency.. 2.00 BogoMIPS (lpj=10000)
[ 0.003256] pid_max: default: 32768 minimum: 301
[ 0.003314] Security Framework initialized
[ 0.003341] AppArmor: AppArmor initialized
[ 0.003373] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.003386] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.003866] Initializing cgroup subsys memory
[ 0.003944] Initializing cgroup subsys devices
[ 0.003968] Initializing cgroup subsys freezer
[ 0.003984] Initializing cgroup subsys net_cls
[ 0.004000] Initializing cgroup subsys blkio
[ 0.004016] Initializing cgroup subsys perf_event
[ 0.004029] Initializing cgroup subsys net_prio
[ 0.004052] Initializing cgroup subsys hugetlb
[ 0.004063] Initializing cgroup subsys debug
[ 0.004115] ftrace: allocating 30254 entries in 119 pages
[ 0.030807] hw perfevents: enabled with arm/armv8-pmuv3 PMU driver, 7 counter s available
[ 0.071929] Meson chip version = RevC (1F:C - 0:0)
[ 0.090853] CPU1: Booted secondary processor
[ 0.110824] CPU2: Booted secondary processor
[ 0.130817] CPU3: Booted secondary processor
[ 0.130857] Brought up 4 CPUs
[ 0.130890] SMP: Total of 4 processors activated.
[ 0.131355] devtmpfs: initialized
[ 0.137028] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.139912] pinctrl core: initialized pinctrl subsystem
[ 0.140246] regulator-dummy: no parameters
[ 0.147018] device-tree: Duplicate name in efusekey, renamed to "key0#1"
[ 0.147066] device-tree: Duplicate name in efusekey, renamed to "key1#1"
[ 0.147100] device-tree: Duplicate name in efusekey, renamed to "key2#1"
[ 0.147132] device-tree: Duplicate name in efusekey, renamed to "key3#1"
[ 0.149603] NET: Registered protocol family 16
[ 0.150613] register canvas platform driver
[ 0.150633] codec:ignore bus ops for cpu=25
[ 0.150642] codec:ignore bus ops for cpu=29
[ 0.150651] codec:register amports ops for bus[0]
[ 0.150660] codec:register amports ops for bus[4]
[ 0.150668] codec:register amports ops for bus[3]
[ 0.150677] codec:register amports ops for bus[2]
[ 0.150685] codec:register amports ops for bus[1]
[ 0.150694] codec:register amports ops for bus[13]
[ 0.150704] codec:register amports ops for bus[2]
[ 0.150712] codec:register amports ops for bus[14]
[ 0.150743] register rdma platform driver
[ 0.151082] vdso: 2 pages (1 code, 1 data) at base ffffffc001ca6000
[ 0.151120] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.151730] DMA: preallocated 256 KiB pool for atomic allocations
[ 0.152916] software IO TLB: mapped [mem 0x5b000000-0x5b400000] (4MB)
[ 0.152930] Serial: AMBA PL011 UART driver
[ 0.153009] hdmitx: system: amhdmitx_init
[ 0.153018] hdmitx: system: Ver: 2014May6
[ 0.153057] tv_vout: tv_init_module
[ 0.153071] tv_vout: major number 254 for disp
[ 0.153080] vout_notify: vout_register_server
[ 0.153089] tv_vout: register tv module server ok
[ 0.153122] codec_mm:codec_mm_module_init
[ 0.153472] gxbb clk HIU base is 0xffffff8000058000
[ 0.153482] gxbb clk ao base is 0xffffff800005a000
[ 0.153529] register mpll_clk_out0 success done
[ 0.153541] register mpll_clk_out1 success done
[ 0.153553] register mpll_clk_out2 success done
[ 0.153743] register sys pll success done
[ 0.153790] clkrate [ xtal ] : 24000000Hz
[ 0.153800] clkrate [ 32Khz ] : 32000Hz
[ 0.153809] clkrate [ clk81 ] : 166666666Hz
[ 0.153818] clkrate [ fixed_pll ] : 2000000000Hz
[ 0.153827] clkrate [ fclk_div2 ] : 1000000000Hz
[ 0.153836] clkrate [ fclk_div3 ] : 666666000Hz
[ 0.153845] clkrate [ fclk_div4 ] : 500000000Hz
[ 0.153855] clkrate [ fclk_div5 ] : 400000000Hz
[ 0.153863] clkrate [ fclk_div7 ] : 285714000Hz
[ 0.153893] gxbb clock initialization complete
[ 0.153939] msr_clk_reg0=ffffff800005c75c,msr_clk_reg2=ffffff800005e764
[ 0.154786] amlogic iomap probe done
[ 0.155123] Init pinux probe!
[ 0.156133] pinmux-gxbb c1109880.pinmux: Probed amlogic pinctrl driver
[ 0.156464] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0 x0/0x148)
[ 0.156486] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0 x0/0x148)
[ 0.156566] genirq: Setting trigger mode 8 for irq 241 failed (gic_set_type+0 x0/0x148)
[ 0.156587] genirq: Setting trigger mode 8 for irq 242 failed (gic_set_type+0 x0/0x148)
[ 0.156791] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 0
[ 0.157344] codec:codec map io source 0x00000000c1100000,size=1048576 to 0xff ffff8000680000
[ 0.157369] codec:codec map io source 0x00000000c8820000,size=65536 to 0xffff ff80000a0000
[ 0.157390] codec:codec map io source 0x00000000c883c000,size=8192 to 0xfffff f8000094000
[ 0.157422] codec:codec map io source 0x00000000c8100000,size=1048576 to 0xff ffff8000800000
[ 0.157444] codec:codec map io source 0x00000000d0100000,size=262144 to 0xfff fff8000980000
[ 0.157464] codec:codec map io source 0x00000000c8838000,size=1024 to 0xfffff f800007e000
[ 0.157535] codec_mm has 2 memory regions
[ 0.157551] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_c ma ok
[ 0.157568] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c0000 0
[ 0.157582] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_r eserved ok
[ 0.157594] codec_mm:codec_mm_probe mem init done
[ 0.157605] codec_mm:add reserve memory 0000000060b00000(aligned 0000000060b0 0000) size=4100000(aligned 4100000)
[ 0.157635] codec_mm has 2 memory regions
[ 0.157648] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_c ma ok
[ 0.157662] codec_mm:codec_mm_reserved_init 0000000060b00000->0000000064c0000 0
[ 0.157675] codec_mm codec_mm: assigned reserved memory node linux,codec_mm_r eserved ok
[ 0.157687] codec_mm:codec_mm reserved memory probed done
[ 0.157696] codec_mm:codec_mm_probe ok
[ 0.158524] VPU driver version: v01
[ 0.158535] vpu driver detect cpu type: gxbaby
[ 0.158551] load vpu_clk in dts: 666667000Hz(7)
[ 0.158583] vpu_probe OK
[ 0.158831] hdmitx: system: amhdmitx_probe
[ 0.159096] hdmitx hpd irq = 89
[ 0.159305] hdmitx20: Mapped PHY: 0xc0800000
[ 0.159317] hdmitx20: Mapped PHY: 0xc1104400
[ 0.159339] hdmitx20: Mapped PHY: 0xc8100000
[ 0.159350] hdmitx20: Mapped PHY: 0xc8834000
[ 0.159360] hdmitx20: Mapped PHY: 0xc883a000
[ 0.159369] hdmitx20: Mapped PHY: 0xc883c000
[ 0.159384] hdmitx20: Mapped PHY: 0xd0100000
[ 0.159394] hdmitx20: Mapped PHY: 0xda83a000
[ 0.159409] hdmitx: alread display in uboot 0x10
[ 0.159436] avmute set to 1
[ 0.159837] canvas_probe reg=00000000c8838000,size=400
[ 0.159857] canvas maped reg_base =ffffff80000b2000
[ 0.164240] rdma_probe
[ 0.231127] SCSI subsystem initialized
[ 0.231325] usbcore: registered new interface driver usbfs
[ 0.231370] usbcore: registered new interface driver hub
[ 0.231432] usbcore: registered new device driver usb
[ 0.231536] media: Linux media interface: v0.10
[ 0.231577] Linux video capture interface: v2.00
[ 0.231648] pps_core: LinuxPPS API ver. 1 registered
[ 0.231658] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giome tti <giometti@linux.it>
[ 0.231684] PTP clock support registered
[ 0.231897] logo: logo_init
[ 0.231964] Advanced Linux Sound Architecture Driver Initialized.
[ 0.232338] Bluetooth: Core ver 2.19
[ 0.232368] NET: Registered protocol family 31
[ 0.232378] Bluetooth: HCI device and connection manager initialized
[ 0.232394] Bluetooth: HCI socket layer initialized
[ 0.232407] Bluetooth: L2CAP socket layer initialized
[ 0.232434] Bluetooth: SCO socket layer initialized
[ 0.232460] NetLabel: Initializing
[ 0.232468] NetLabel: domain hash size = 128
[ 0.232476] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.232518] NetLabel: unlabeled traffic allowed by default
[ 0.233058] Switched to clocksource Timer-E
[ 0.264516] AppArmor: AppArmor Filesystem Enabled
[ 0.269906] NET: Registered protocol family 2
[ 0.270431] TCP established hash table entries: 16384 (order: 5, 131072 bytes )
[ 0.270530] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[ 0.270722] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.270797] TCP: reno registered
[ 0.270809] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.270850] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[ 0.271010] NET: Registered protocol family 1
[ 0.271228] RPC: Registered named UNIX socket transport module.
[ 0.271239] RPC: Registered udp transport module.
[ 0.271247] RPC: Registered tcp transport module.
[ 0.271256] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.271433] Unpacking initramfs...
[ 0.444884] Freeing initrd memory: 5156K (ffffffc073a29000 - ffffffc073f32000 )
[ 0.448174] kvm [1]: interrupt-controller@c4304000 IRQ25
[ 0.448319] kvm [1]: kvm_arch_timer: can't find DT node
[ 0.448376] kvm [1]: error initializing Hyp mode: -19
[ 0.448950] audit: initializing netlink subsys (disabled)
[ 0.449011] audit: type=2000 audit(0.430:1): initialized
[ 0.449588] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.454948] VFS: Disk quotas dquot_6.5.2
[ 0.455088] Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.456924] NFS: Registering the id_resolver key type
[ 0.456965] Key type id_resolver registered
[ 0.456974] Key type id_legacy registered
[ 0.456994] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.457036] msgmni has been set to 3452
[ 0.458146] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2 47)
[ 0.458285] io scheduler noop registered (default)
[ 0.458301] io scheduler deadline registered
[ 0.458407] io scheduler cfq registered
[ 0.458990] meson-rng c8834000.rng: hwrng registered
[ 0.459315] enter cpufreq
[ 0.459346] probe cpufreq okay
[ 0.459478] dvfs [scpi_dvfs_get_opps] - new count 6, max_freq 0
[ 0.460576] aml-thermal aml-sensor@0: min state:500000 400 1 2
[ 0.460759] aml-thermal aml-sensor@0: gpu coef:437, pp:3
[ 0.465823] aml-thermal aml-sensor@0: cdev1 set upper to 3
[ 0.465835] aml-thermal aml-sensor@0: cdev2 set upper to 3
[ 0.465847] aml-thermal aml-sensor@0: cdev0 set upper to 3
[ 0.468440] [drm] Initialized drm 1.1.0 20060810
[ 0.468486] mali-utgard d00c0000.mali: max pp is 3
[ 0.468498] mali-utgard d00c0000.mali: min pp is 3
[ 0.468509] mali-utgard d00c0000.mali: min clk is 4
[ 0.468535] mali-utgard d00c0000.mali: hiu io source 0xffffff80000e4000
[ 0.468552] mali-utgard d00c0000.mali: hiu io source 0xffffff80000e6000
[ 0.468565] mali-utgard d00c0000.mali: num of pp used most of time 3
[ 0.468577] mali-utgard d00c0000.mali: clock dvfs table size is 6
[ 0.468589] mali-utgard d00c0000.mali: max clk set 4
[ 0.468599] mali-utgard d00c0000.mali: max clk is 4
[ 0.468610] mali-utgard d00c0000.mali: turbo clk set to 5
[ 0.468621] mali-utgard d00c0000.mali: turbo clk is 5
[ 0.468632] mali-utgard d00c0000.mali: default clk is 4
[ 0.468700] mali-utgard d00c0000.mali: ====================0================= ===
clk_freq= 125000000, clk_parent=fclk_div4, voltage=1150, keep_cou nt=5, threshod=<30 120>, clk_sample=125
[ 0.468727] mali-utgard d00c0000.mali: ====================1================= ===
clk_freq= 285000000, clk_parent=fclk_div7, voltage=1150, keep_cou nt=5, threshod=<100 190>, clk_sample=285
[ 0.468753] mali-utgard d00c0000.mali: ====================2================= ===
clk_freq= 400000000, clk_parent=fclk_div5, voltage=1150, keep_cou nt=5, threshod=<152 207>, clk_sample=400
[ 0.468779] mali-utgard d00c0000.mali: ====================3================= ===
clk_freq= 500000000, clk_parent=fclk_div4, voltage=1150, keep_cou nt=5, threshod=<180 220>, clk_sample=500
[ 0.468805] mali-utgard d00c0000.mali: ====================4================= ===
clk_freq= 666000000, clk_parent=fclk_div3, voltage=1150, keep_cou nt=5, threshod=<210 236>, clk_sample=666
[ 0.468831] mali-utgard d00c0000.mali: ====================5================= ===
clk_freq= 792000000, clk_parent= gp0_pll, voltage=1150, keep_cou nt=5, threshod=<230 255>, clk_sample=792
[ 0.470466] cdev3 set upper to 2
[ 0.470482] cdev4 set upper to 2
[ 0.470491] gpu cooling register okay with err=0
[ 0.470552] cdev5 set upper to 1
[ 0.470561] gpu core cooling register okay with err=0
[ 0.470731] Mali: Mali device driver loaded
[ 0.470891] UMP: UMP device driver -64c8062a loaded
[ 0.473319] loop: module loaded
[ 0.473628] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 0.474132] stmmac - user ID: 0x11, Synopsys ID: 0x37
[ 0.474143] Ring mode enabled
[ 0.474151] DMA HW capability register supported
[ 0.474160] Normal descriptors
[ 0.474170] RX Checksum Offload Engine supported (type 2)
[ 0.474179] TX Checksum insertion supported
[ 0.474187] Wake-Up On Lan supported
[ 0.474225] Enable RX Mitigation via HW Watchdog Timer
[ 0.480914] libphy: stmmac: probed
[ 0.480938] eth0: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[ 0.480950] eth0: PHY ID 001cc916 at 7 IRQ POLL (stmmac-0:07)
[ 0.481258] usbcore: registered new interface driver cdc_ether
[ 0.481330] usbcore: registered new interface driver cdc_ncm
[ 0.481464] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.481480] ehci-h20ahb: H20AHB-EHCI Host Controller driver
[ 0.481585] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.481650] usbcore: registered new interface driver cdc_acm
[ 0.481660] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
[ 0.481718] usbcore: registered new interface driver usb-storage
[ 0.481822] usbcore: registered new interface driver usbserial
[ 0.481855] usbcore: registered new interface driver usbserial_generic
[ 0.481886] usbserial: USB Serial support registered for generic
[ 0.482161] mousedev: PS/2 mouse device common for all mice
[ 0.482455] i2c /dev entries driver
[ 0.482892] IR Sharp protocol handler initialized
[ 0.483148] hdmitx: plugin
[ 0.483376] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.483453] hidraw: raw HID events driver (C) Jiri Kosina
[ 0.493201] usbcore: registered new interface driver usbhid
[ 0.493214] usbhid: USB HID core driver
[ 0.493446] ==uart0 reg addr = ffffff80002344c0
[ 0.493481] c81004c0.serial: ttyS0 at MMIO 0xc81004c0 (irq = 225, base_baud = 1500000) is a meson_uart
[ 0.547608] hdmitx: edid: raw data are all zeroes
[ 0.547612] EDID Parser:
[ 0.547658] EDID BlockCount=0
[ 0.547660] hdmitx: edid: HDMI: set default vic
[ 0.547671] hdmitx: video: get current mode: null
[ 0.547674] hdmtix: set audio
[ 0.547683] hdmitx tx_aud_src = 0
[ 0.547711] hdmitx aud_n_para = 24576
[ 0.547728] hdmitx set channel status
[ 2.253379] console [ttyS0] enabled
[ 2.257028] ==uart1 reg addr = ffffff80002364c0
[ 2.261306] c11084c0.serial: ttyS1 at MMIO 0xc11084c0 (irq = 58, base_baud = 1500000) is a meson_uart
[ 2.310789] dwc_otg: usb1: type: 1 speed: 0, config: 0, dma: 0, id: 1, phy: c 0000020, ctrl: 0
[ 2.316344] dwc_otg: Core Release: 3.10a
[ 2.317532] dwc_otg: Setting default values for core params
[ 2.323068] dwc_otg: curmode: 1, host_only: 1
[ 2.329580] dwc_otg: Using Buffer DMA mode
[ 2.331417] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[ 2.336514] dwc_otg: Working on port type = HOST
[ 2.341196] dwc_otg dwc2_b: DWC OTG Controller
[ 2.345496] dwc_otg dwc2_b: new USB bus registered, assigned bus number 1
[ 2.352217] dwc_otg dwc2_b: irq 63, io mem 0x00000000
[ 2.357214] dwc_otg: -------hcd->flags.d32 = 0
[ 2.361618] dwc_otg: Init: Port Power? op_state=1
[ 2.366268] dwc_otg: Init1: Power Port (0)
[ 2.370795] hub 1-0:1.0: USB hub found
[ 2.374059] hub 1-0:1.0: 1 port detected
[ 2.378110] dwc_otg: usb0: type: 0 speed: 0, config: 0, dma: 0, id: 0, phy: c 0000000, ctrl: 0
[ 2.397962] dwc_otg: Core Release: 3.10a
[ 2.397985] dwc_otg: Setting default values for core params
[ 2.401775] dwc_otg: curmode: 1, host_only: 0
[ 2.410302] dwc_otg: Using Buffer DMA mode
[ 2.410325] dwc_otg: OTG VER PARAM: 1, OTG VER FLAG: 1
[ 2.415235] dwc_otg: Working on port type = OTG
[ 2.419710] dwc_otg: Current port type: SLAVE
[ 2.424095] dwc_otg dwc2_a: DWC OTG Controller
[ 2.428432] dwc_otg dwc2_a: new USB bus registered, assigned bus number 2
[ 2.435170] dwc_otg dwc2_a: irq 62, io mem 0x00000000
[ 2.440529] hub 2-0:1.0: USB hub found
[ 2.443898] hub 2-0:1.0: 1 port detected
[ 2.447878] dwc_otg: Dedicated Tx FIFOs mode
[ 2.452151] dwc_otg: using timer detectid change, ffffffc05ad43800
[ 2.458258] fb: osd_init_module
[ 2.461282] fb: viu vsync irq: 35
[ 2.464536] meson-fb has 1 memory regions
[ 2.469617] meson-fb meson-fb: assigned reserved memory node linux,meson-fb o k
[ 2.475671] logo: get initial logo vmode: 1080p60hz
[ 2.480434] tv_vout: tv_set_current_vmode[707]fps_target_mode=12
[ 2.486393] tv_vout: mode is 12,sync_duration_den=1,sync_duration_num=60
[ 2.493027] switch_vpu_mem_pd: vencp ON
[ 2.496826] tv_vout: TV mode 1080p60hz selected.
[ 2.501393] tv_vout: new mode =1080p60hz set ok
[ 2.505882] vout_serve: vinfo mode is: 1080p60hz
[ 2.510447] switch_vpu_mem_pd: viu_osd1 ON
[ 2.514506] switch_vpu_mem_pd: viu_osd2 ON
[ 2.518553] switch_vpu_mem_pd: viu_osd_scale ON
[ 2.523141] osd_rdma: osd_rdma_init: rmda_table p=0x5dc49000,op=0x5dc49000 , v=0xffffff8000266000
[ 2.531854] hdmitx: video: get current mode: 1080p60hz
[ 2.536938] hdmitx: video: get current mode: 1080p60hz
[ 2.542015] hdmitx: system: [set_disp_mode_auto] ALREADY init VIC = 16
[ 2.548535] hdmitx: system: change to HDMI mode
[ 2.552966] fb: validating vinfo tables
[ 2.556783] hdmitx: warning: tvenc phy 27000 vid 54000 enc 27000 pix 27000 cl ocks not equal
[ 2.565057] fb: vinfo 0 480i60hz, hdmi 7 720x480i60hz, 720x480-60 4:3 27000
[ 2.571947] fb: warning: vinfo 1 480i_rpt, 720x480-60 4:3 27000, hdmi 11 no p ara
[ 2.579307] fb: warning: vinfo 2 480cvbs, 720x480-60 4:3 27000, no hdmi vic
[ 2.579351] dwc_otg: Indeed it is in host mode hprt0 = 00021501
[ 2.592052] fb: warning: vinfo 4 480p_rpt, 720x480-60 4:3 27000, hdmi 36 no p ara
[ 2.599384] hdmitx: warning: tvenc phy 27000 vid 54000 enc 27000 pix 27000 cl ocks not equal
[ 2.607658] fb: vinfo 5 576i50hz, hdmi 22 720x576i50hz, 720x576-50 4:3 27000
[ 2.614648] fb: warning: vinfo 6 576i_rpt, 720x576-50 4:3 27000, hdmi 26 no p ara
[ 2.621972] fb: warning: vinfo 7 576cvbs, 720x576-50 4:3 27000, no hdmi vic
[ 2.628882] fb: warning: vinfo 9 576p_rpt, 720x576-50 4:3 27000, hdmi 38 no p ara
[ 2.636227] fb: warning: vinfo 23 4k2k5g, 3840x2160-50 16:9 495000, no hdmi v ic
