Bonjour, suite à mon passage sur PI5, le plugin ne fonctionne plus.
J’ai essayé de supprimer/reinstaller, j’ai la même chose.
Quelqu’un a t’il eu le même souci ?
Dans la log j’ai ça :
merosync_update
Installation des dépendances
Hit:1 http://deb.debian.org/debian bookworm InRelease
Hit:2 https://download.docker.com/linux/debian bookworm InRelease
Hit:3 http://deb.debian.org/debian-security bookworm-security InRelease
Hit:4 http://deb.debian.org/debian bookworm-updates InRelease
Hit:5 https://deb.nodesource.com/node_18.x nodistro InRelease
Hit:6 http://archive.raspberrypi.com/debian bookworm InRelease
Reading package lists...
Installation libffi-dev
Building dependency tree...
Reading state information...
libffi-dev is already the newest version (3.4.4-1).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Installation python3
python3 is already the newest version (3.11.2-1+b1).
Installation python3-pip
python3-pip is already the newest version (23.0.1+dfsg-1+rpt1).
Installation python3-requests
python3-requests is already the newest version (2.28.1+dfsg-1).
Installation python3-setuptools
python3-setuptools is already the newest version (66.1.1-1).
Installation python3-dev
python3-dev is already the newest version (3.11.2-1+b1).
Empty cache
Files removed: 8
Installation upgrade pip
Looking in indexes: https://pypi.org/simple, https://www.piwheels.org/simple
Requirement already satisfied: pip in /usr/local/lib/python3.8/site-packages (24.2)
WARNING: Running pip as the 'root' user can result in broken permissions and conflicting behaviour with the system package manager, possibly rendering your system unusable.It is recommended to use a virtual environment instead: https://pip.pypa.io/warnings/venv. Use the --root-user-action option if you know what you are doing and want to suppress this warning.
Installation upgrade requests
Requirement already satisfied: requests in /usr/local/lib/python3.8/site-packages (2.32.3)
Requirement already satisfied: charset-normalizer<4,>=2 in /usr/local/lib/python3.8/site-packages (from requests) (3.3.2)
Requirement already satisfied: idna<4,>=2.5 in /usr/local/lib/python3.8/site-packages (from requests) (3.7)
Requirement already satisfied: urllib3<3,>=1.21.1 in /usr/local/lib/python3.8/site-packages (from requests) (2.2.2)
Requirement already satisfied: certifi>=2017.4.17 in /usr/local/lib/python3.8/site-packages (from requests) (2024.7.4)
Installation upgrade merossiot
error: externally-managed-environment
× This environment is externally managed
╰─> To install Python packages system-wide, try apt install
python3-xyz, where xyz is the package you are trying to
install.
If you wish to install a non-Debian-packaged Python package,
create a virtual environment using python3 -m venv path/to/venv.
Then use path/to/venv/bin/python and path/to/venv/bin/pip. Make
sure you have python3-full installed.
For more information visit http://rptl.io/venv
note: If you believe this is a mistake, please contact your Python installation or OS distribution provider. You can override this, at the risk of breaking your Python installation or OS, by passing --break-system-packages.
hint: See PEP 668 for the detailed specification.
Installation des dépendances terminée !
Informations Jeedom
Core : 4.4.8.1 (V4-stable)
DNS Jeedom : non
Plugin : MerosSync
Version : 2024-07-11 10:27:20 (stable)
Statut Démon : Stoppé - (2024-08-19 07:01:43)
