Merci @Yves19 j’avais peur de le démonter et de tout casser
Sinon il est bien inclus dans jeedom, mais je n’arrive pas à le piloter, ca me donne ca comme erreur.
[2022-02-22 11:39:17][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-22 11:39:17][DEBUG] : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"down_close","await":1}],"allowQueue":false}
[2022-02-22 11:39:28][ERROR] : Erreur exécution de la commande [salon][Legrand.Shutter_switch_with_neutral 00:04:74:00:00:9c:b5:c1][Descendre] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"down_close","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x6298:1:0x0102]: Message send failure","code":0}
[2022-02-22 11:39:34][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-22 11:39:34][DEBUG] : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"up_open","await":1}],"allowQueue":false}
[2022-02-22 11:39:45][ERROR] : Erreur exécution de la commande [salon][Legrand.Shutter_switch_with_neutral 00:04:74:00:00:9c:b5:c1][Monter] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"up_open","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x6298:1:0x0102]: Message send failure","code":0}
[2022-02-22 11:39:45][DEBUG] : http://127.0.0.1:8089/device/command type : PUT
[2022-02-22 11:39:45][DEBUG] : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"stop","await":1}],"allowQueue":false}
[2022-02-22 11:39:56][ERROR] : Erreur exécution de la commande [salon][Legrand.Shutter_switch_with_neutral 00:04:74:00:00:9c:b5:c1][Stop] : Erreur lors de la requete : http://127.0.0.1:8089/device/command(PUT), data : {"ieee":"00:04:74:00:00:9c:b5:c1","cmd":[{"endpoint":1,"cluster":"window_covering","command":"stop","await":1}],"allowQueue":false} erreur : {"state":"error","result":"[0x6298:1:0x0102]: Message send failure","code":0}
