Depuis la réinstallation de Jeddom sur raspberry pi4 et Raspbian buster, le deamon du plugin openzwave ne fonctionne plus.
Ci-dessous, ce que j’ai dans les log :
[2022-02-07 12:32:04]INFO : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device auto --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey Sa1YArwSUJujERDmRl9YVISWQUN7tlaqVVGmkrAiXksijRy4M2j9umSpk9RpKd2A --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
File "/var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py", line 18, in
from ozwave import globals,server_utils,rest_server
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/globals.py", line 1, in
import utils,network_utils,controller_utils,node_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/utils.py", line 6, in
import network_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/network_utils.py", line 5, in
import globals,utils,dispatcher_utils,serialization,node_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/dispatcher_utils.py", line 4, in
import network_utils,node_utils,value_utils,scene_utils,controller_utils
File "/var/www/html/plugins/openzwave/resources/openzwaved/ozwave/node_utils.py", line 5, in
from lxml import etree
ImportError: No module named lxml
[2022-02-07 12:32:34]ERROR : Impossible de lancer le démon openzwave, relancer le démon en debug et vérifiez la log
[2022-02-07 12:35:05]INFO : Lancement démon openzwave : /usr/bin/python /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/openzwaved.py --device auto --loglevel debug --port 8083 --config_folder /var/www/html/plugins/openzwave/core/class/../../resources/openzwaved/config --data_folder /var/www/html/plugins/openzwave/core/class/../../data --callback http://127.0.0.1:80/plugins/openzwave/core/php/jeeZwave.php --apikey Sa1YArwSUJujERDmRl9YVISWQUN7tlaqVVGmkrAiXksijRy4M2j9umSpk9RpKd2A --suppressRefresh 0 --cycle 0.3 --pid /tmp/jeedom/openzwave/deamon.pid
[2022-02-07 12:35:35]ERROR : Impossible de lancer le démon openzwave, relancer le démon en debug et vérifiez la log
Pouvez-vous m’aider sur le sujet
