Merci pour vos premiers retours. Le log du scénario est le suivant :
[2024-02-27 18:12:40][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709053934.081414-e4myz0", "camera": "garage", "frame_time": 1709053934.081414, "snapshot": null, "label": "person", "sub_label": null, "top_score": 0.0, "false_positive": true, "start_time": 1709053934.081414, "end_time": null, "score": 0.640625, "box": [0, 5, 202, 253], "area": 50096, "ratio": 0.8145161290322581, "region": [0, 0, 320, 320], "stationary": false, "motionless_count": 0, "position_changes": 0, "current_zones": [], "entered_zones": [], "has_clip": false, "has_snapshot": false, "attributes": {}, "current_attributes": []}, "after": {"id": "1709053934.081414-e4myz0", "camera": "garage", "frame_time": 1709053958.751112, "snapshot": {"frame_time": 1709053958.751112, "box": [18, 112, 297, 378], "area": 74214, "region": [0, 0, 644, 644], "score": 0.796875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.734375, "false_positive": false, "start_time": 1709053934.081414, "end_time": null, "score": 0.796875, "box": [18, 112, 297, 378], "area": 74214, "ratio": 1.0488721804511278, "region": [0, 0, 644, 644], "stationary": false, "motionless_count": 4, "position_changes": 2, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "new"}).
[2024-02-27 18:12:40][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:12:40][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:12:40][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:12:40][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:12:40][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:12:40][SCENARIO] | Evenement : 1709053934.081414-e4myz0
[2024-02-27 18:12:40][SCENARIO] | Lieu : garage
[2024-02-27 18:12:40][SCENARIO] | Date : 27/02 18:12:39
[2024-02-27 18:12:40][SCENARIO] | Label : person (73%) - Type : new
[2024-02-27 18:12:40][SCENARIO] | Fichier recupéré et redimensionné : /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:12:41][SCENARIO] | Envoi de la notification avec le fichier /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:12:41][SCENARIO] └───────────────────────────
[2024-02-27 18:12:41][SCENARIO] Fin correcte du scénario
[2024-02-27 18:12:53][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709053934.081414-e4myz0", "camera": "garage", "frame_time": 1709053958.751112, "snapshot": {"frame_time": 1709053958.751112, "box": [18, 112, 297, 378], "area": 74214, "region": [0, 0, 644, 644], "score": 0.796875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.734375, "false_positive": false, "start_time": 1709053934.081414, "end_time": null, "score": 0.796875, "box": [18, 112, 297, 378], "area": 74214, "ratio": 1.0488721804511278, "region": [0, 0, 644, 644], "stationary": false, "motionless_count": 4, "position_changes": 2, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "after": {"id": "1709053934.081414-e4myz0", "camera": "garage", "frame_time": 1709053966.548473, "snapshot": {"frame_time": 1709053958.751112, "box": [18, 112, 297, 378], "area": 74214, "region": [0, 0, 644, 644], "score": 0.796875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.8125, "false_positive": false, "start_time": 1709053934.081414, "end_time": 1709053972.116503, "score": 0.57421875, "box": [3, 24, 168, 259], "area": 38775, "ratio": 0.7021276595744681, "region": [0, 0, 320, 320], "stationary": false, "motionless_count": 2, "position_changes": 2, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "end"}).
[2024-02-27 18:12:53][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:12:53][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:12:53][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:12:53][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:12:53][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:12:53][SCENARIO] | Evenement : 1709053934.081414-e4myz0
[2024-02-27 18:12:53][SCENARIO] | Lieu : garage
[2024-02-27 18:12:53][SCENARIO] | Date : 27/02 18:12:47
[2024-02-27 18:12:53][SCENARIO] | Label : person (81%) - Type : end
[2024-02-27 18:12:53][SCENARIO] | Fichier recupéré et redimensionné : /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:12:53][SCENARIO] | Envoi de la notification avec le fichier /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:12:53][SCENARIO] └───────────────────────────
[2024-02-27 18:12:53][SCENARIO] Fin correcte du scénario
[2024-02-27 18:23:10][SCENARIO] Start : Scenario lance manuellement.
[2024-02-27 18:23:10][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:23:10][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:23:10][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:23:10][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:23:10][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:23:10][SCENARIO] | Evenement : 1709053934.081414-e4myz0
[2024-02-27 18:23:10][SCENARIO] | Lieu : garage
[2024-02-27 18:23:10][SCENARIO] | Date : 27/02 18:12:47
[2024-02-27 18:23:10][SCENARIO] | Label : person (81%) - Type : end
[2024-02-27 18:23:10][SCENARIO] | Fichier recupéré et redimensionné : /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:23:11][SCENARIO] | Envoi de la notification avec le fichier /var/www/html/data/events/1709053934.081414-e4myz0.png
[2024-02-27 18:23:11][SCENARIO] └───────────────────────────
[2024-02-27 18:23:11][SCENARIO] Fin correcte du scénario
[2024-02-27 18:37:11][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055428.066962, "snapshot": null, "label": "person", "sub_label": null, "top_score": 0.0, "false_positive": true, "start_time": 1709055428.066962, "end_time": null, "score": 0.8046875, "box": [0, 33, 224, 309], "area": 61824, "ratio": 0.8115942028985508, "region": [0, 0, 556, 556], "stationary": false, "motionless_count": 0, "position_changes": 0, "current_zones": [], "entered_zones": [], "has_clip": false, "has_snapshot": false, "attributes": {}, "current_attributes": []}, "after": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055428.470625, "snapshot": {"frame_time": 1709055428.470625, "box": [1, 44, 225, 299], "area": 57120, "region": [0, 0, 340, 340], "score": 0.76171875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.72265625, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.76171875, "box": [1, 44, 225, 299], "area": 57120, "ratio": 0.8784313725490196, "region": [0, 0, 340, 340], "stationary": false, "motionless_count": 0, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "new"}).
[2024-02-27 18:37:11][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:37:11][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:37:11][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:37:11][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:37:11][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:37:11][SCENARIO] | Evenement : 1709055428.066962-ghm1t5
[2024-02-27 18:37:11][SCENARIO] | Lieu : garage
[2024-02-27 18:37:11][SCENARIO] | Date : 27/02 18:37:08
[2024-02-27 18:37:11][SCENARIO] | Label : person (72%) - Type : new
[2024-02-27 18:37:11][SCENARIO] | Fichier recupéré et redimensionné : /var/www/html/data/events/1709055428.066962-ghm1t5.png
[2024-02-27 18:37:11][SCENARIO] | Envoi de la notification avec le fichier /var/www/html/data/events/1709055428.066962-ghm1t5.png
[2024-02-27 18:37:11][SCENARIO] └───────────────────────────
[2024-02-27 18:37:11][SCENARIO] Fin correcte du scénario
[2024-02-27 18:37:15][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055428.470625, "snapshot": {"frame_time": 1709055428.470625, "box": [1, 44, 225, 299], "area": 57120, "region": [0, 0, 340, 340], "score": 0.76171875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.72265625, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.76171875, "box": [1, 44, 225, 299], "area": 57120, "ratio": 0.8784313725490196, "region": [0, 0, 340, 340], "stationary": false, "motionless_count": 0, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "after": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055433.471015, "snapshot": {"frame_time": 1709055433.471015, "box": [11, 80, 328, 349], "area": 85273, "region": [0, 20, 332, 352], "score": 0.71484375, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.71484375, "box": [11, 80, 328, 349], "area": 85273, "ratio": 1.178438661710037, "region": [0, 20, 332, 352], "stationary": false, "motionless_count": 0, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "update"}).
[2024-02-27 18:37:15][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:37:15][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:37:15][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:37:15][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:37:15][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:37:15][SCENARIO] | Evenement : 1709055428.066962-ghm1t5
[2024-02-27 18:37:15][SCENARIO] | Lieu : garage
[2024-02-27 18:37:15][SCENARIO] | Date : 27/02 18:37:13
[2024-02-27 18:37:15][SCENARIO] | Label : person (76%) - Type : update
[2024-02-27 18:37:15][SCENARIO] └───────────────────────────
[2024-02-27 18:37:15][SCENARIO] Fin correcte du scénario
[2024-02-27 18:37:19][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055433.471015, "snapshot": {"frame_time": 1709055433.471015, "box": [11, 80, 328, 349], "area": 85273, "region": [0, 20, 332, 352], "score": 0.71484375, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.71484375, "box": [11, 80, 328, 349], "area": 85273, "ratio": 1.178438661710037, "region": [0, 20, 332, 352], "stationary": false, "motionless_count": 0, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "after": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055438.631687, "snapshot": {"frame_time": 1709055437.721585, "box": [18, 109, 395, 373], "area": 99528, "region": [0, 0, 516, 516], "score": 0.82421875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.65234375, "box": [10, 62, 203, 325], "area": 50759, "ratio": 0.7338403041825095, "region": [0, 46, 340, 386], "stationary": false, "motionless_count": 1, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "update"}).
[2024-02-27 18:37:19][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:37:19][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:37:19][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:37:19][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:37:19][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:37:19][SCENARIO] | Evenement : 1709055428.066962-ghm1t5
[2024-02-27 18:37:19][SCENARIO] | Lieu : garage
[2024-02-27 18:37:19][SCENARIO] | Date : 27/02 18:37:19
[2024-02-27 18:37:19][SCENARIO] | Label : person (76%) - Type : update
[2024-02-27 18:37:19][SCENARIO] └───────────────────────────
[2024-02-27 18:37:19][SCENARIO] Fin correcte du scénario
[2024-02-27 18:37:32][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055438.631687, "snapshot": {"frame_time": 1709055437.721585, "box": [18, 109, 395, 373], "area": 99528, "region": [0, 0, 516, 516], "score": 0.82421875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.65234375, "box": [10, 62, 203, 325], "area": 50759, "ratio": 0.7338403041825095, "region": [0, 46, 340, 386], "stationary": false, "motionless_count": 1, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "after": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055451.120353, "snapshot": {"frame_time": 1709055437.721585, "box": [18, 109, 395, 373], "area": 99528, "region": [0, 0, 516, 516], "score": 0.82421875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.734375, "box": [0, 6, 231, 309], "area": 69993, "ratio": 0.7623762376237624, "region": [0, 0, 364, 364], "stationary": true, "motionless_count": 51, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "type": "update"}).
[2024-02-27 18:37:32][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:37:32][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:37:32][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:37:32][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:37:32][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:37:32][SCENARIO] | Evenement : 1709055428.066962-ghm1t5
[2024-02-27 18:37:32][SCENARIO] | Lieu : garage
[2024-02-27 18:37:32][SCENARIO] | Date : 27/02 18:37:31
[2024-02-27 18:37:32][SCENARIO] | Label : person (76%) - Type : update
[2024-02-27 18:37:32][SCENARIO] └───────────────────────────
[2024-02-27 18:37:32][SCENARIO] Fin correcte du scénario
[2024-02-27 18:37:37][SCENARIO] Start : Scenario execute automatiquement sur evenement venant de : [Maison][events][events] ({"before": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055451.120353, "snapshot": {"frame_time": 1709055437.721585, "box": [18, 109, 395, 373], "area": 99528, "region": [0, 0, 516, 516], "score": 0.82421875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": null, "score": 0.734375, "box": [0, 6, 231, 309], "area": 69993, "ratio": 0.7623762376237624, "region": [0, 0, 364, 364], "stationary": true, "motionless_count": 51, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": true, "has_snapshot": true, "attributes": {}, "current_attributes": []}, "after": {"id": "1709055428.066962-ghm1t5", "camera": "garage", "frame_time": 1709055451.727219, "snapshot": {"frame_time": 1709055437.721585, "box": [18, 109, 395, 373], "area": 99528, "region": [0, 0, 516, 516], "score": 0.82421875, "attributes": []}, "label": "person", "sub_label": null, "top_score": 0.76171875, "false_positive": false, "start_time": 1709055428.066962, "end_time": 1709055456.921281, "score": 0.74609375, "box": [0, 13, 231, 308], "area": 68145, "ratio": 0.7830508474576271, "region": [0, 0, 364, 364], "stationary": true, "motionless_count": 53, "position_changes": 1, "current_zones": [], "entered_zones": [], "has_clip": false, "has_snapshot": false, "attributes": {}, "current_attributes": []}, "type": "end"}).
[2024-02-27 18:37:37][SCENARIO] - Exécution du sous-élément de type [action] : action
[2024-02-27 18:37:37][SCENARIO] Exécution d'un bloc élément : 2
[2024-02-27 18:37:37][SCENARIO] - Exécution du sous-élément de type [action] : code
[2024-02-27 18:37:37][SCENARIO] Exécution d'un bloc code
[2024-02-27 18:37:37][SCENARIO] ┌──────────── Logs bloc code - version du
[2024-02-27 18:37:37][SCENARIO] | Evenement : 1709055428.066962-ghm1t5
[2024-02-27 18:37:37][SCENARIO] | Lieu : garage
[2024-02-27 18:37:37][SCENARIO] | Date : 27/02 18:37:32
[2024-02-27 18:37:37][SCENARIO] | Label : person (76%) - Type : end
[2024-02-27 18:37:37][SCENARIO] | Fichier recupéré et redimensionné : /var/www/html/data/events/1709055428.066962-ghm1t5.png
[2024-02-27 18:37:37][SCENARIO] | Envoi de la notification avec le fichier /var/www/html/data/events/1709055428.066962-ghm1t5.png
[2024-02-27 18:37:37][SCENARIO] └───────────────────────────
[2024-02-27 18:37:37][SCENARIO] Fin correcte du scénario
Pour la partie jeedomconnect, c’est sous quel format que sont attendues les données ?
