Bonjour Lunarok,
Depuis la mise à jour du plugin-xiaomihome les commandes de l’anneau lumineux et les sons no fonctionne plus, sur le dashboard il y a bien une réaction mais il ne se passe rien sur la gateway
[2021-04-26 08:38:45][DEBUG] : execute : action aquara on
[2021-04-26 08:38:46][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"rgb","request":838860800,"vol":55}
[2021-04-26 08:38:46.298][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:38:48][DEBUG] : execute : action aquara off
[2021-04-26 08:38:48][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"rgb","request":0,"vol":55}
[2021-04-26 08:38:48.402][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:38:52][DEBUG] : execute : action aquara on
[2021-04-26 08:38:52][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"rgb","request":838860800,"vol":55}
[2021-04-26 08:38:52.909][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:38:57][DEBUG] : execute : action aquara vol-set
[2021-04-26 08:38:57][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"vol","request":"100","vol":100}
[2021-04-26 08:38:58.020][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:00][DEBUG] : execute : action aquara mid-list
[2021-04-26 08:39:00][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"1","vol":100}
[2021-04-26 08:39:00.725][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:01][DEBUG] : execute : action aquara mid-set
[2021-04-26 08:39:01][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"","vol":100}
[2021-04-26 08:39:01.928][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:03][DEBUG] : execute : action aquara mid-set
[2021-04-26 08:39:03][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"","vol":100}
[2021-04-26 08:39:03.739][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:05][DEBUG] : execute : action aquara mid-scenar
[2021-04-26 08:39:05][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"","vol":0}
[2021-04-26 08:39:05.243][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:07][DEBUG] : Rafraîchissement de Yeelight : ceiling10 0x00000000177dafe4
[2021-04-26 08:39:07][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"yeelight","cmd":"refresh","model":"ceiling10","dest":"192.168.1.88","token":"","devtype":"49","serial":"0x00000000177dafe4","id":"192.168.1.88"}
[2021-04-26 08:39:07][DEBUG] : Rafraîchissement de Yeelight : color 0x000000000371f531
[2021-04-26 08:39:07][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"yeelight","cmd":"refresh","model":"color","dest":"192.168.1.85","token":"","devtype":"76","serial":"0x000000000371f531","id":"192.168.1.85"}
[2021-04-26 08:39:07][DEBUG] : Rafraîchissement de Yeelight : color 0x0000000004cae3ee
[2021-04-26 08:39:07][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"yeelight","cmd":"refresh","model":"color","dest":"192.168.1.86","token":"","devtype":"76","serial":"0x0000000004cae3ee","id":"192.168.1.86"}
[2021-04-26 08:39:07][DEBUG] : Rafraîchissement de Yeelight : stripe 0x0000000004575dd2
[2021-04-26 08:39:07][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"yeelight","cmd":"refresh","model":"stripe","dest":"192.168.1.89","token":"","devtype":"50","serial":"0x0000000004575dd2","id":"192.168.1.89"}
[2021-04-26 08:39:13][DEBUG] : execute : action aquara mid-set
[2021-04-26 08:39:14][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"1","vol":100}
[2021-04-26 08:39:14.061][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:16][DEBUG] : execute : action aquara mid-set
[2021-04-26 08:39:17][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"1","vol":100}
[2021-04-26 08:39:17.067][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:18][DEBUG] : execute : action aquara mid-set
[2021-04-26 08:39:18][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"mid","request":"1","vol":100}
[2021-04-26 08:39:18.570][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:22][DEBUG] : execute : action aquara off
[2021-04-26 08:39:22][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"rgb","request":0,"vol":100}
[2021-04-26 08:39:22.778][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
[2021-04-26 08:39:27][DEBUG] : execute : action aquara on
[2021-04-26 08:39:28][DEBUG] : Envoi : {"apikey":"aypyWRsBb2OIXWgpj9W39ei4lGxxxxxx","type":"aquara","cmd":"send","dest":"192.168.1.80","password":"8DF5C31B581048AD","model":"gateway","sidG":"7811dcb35db6","sid":"7811dcb35db6","short_id":"0","switch":"rgb","request":838860800,"vol":100}
[2021-04-26 08:39:28.487][ERROR] : SOCKET-READ------Exception on socket : Object type <class 'str'> cannot be passed to C code
Jeedom 4.1.22
Rasbian buster 32bits sur pi3b+
plugin stable 2021-04-15 01:01:54
Si tu as besoin de d’autres choses n’hésite pas a faire signe
donc je suis chocolat pour le moment. Mais au moins je me sens moins seul
