Je commence à migrer sur le nouveau plugin zwave et j’ai pas mal de modules non reconnu après plusieurs heures. Je vais commencer avec un premier histoire d’être sur de fournir toutes les infos et ensuite je ferais les autres si l’équipe Jeedom est satisfaite des infos retournées.
Il y a un premier screenshot avec openzwave et les commandes retournées et ensuite zwavejs.
Je ne sais pas si vous avez besoin de l’arbe également:
"id": 7,
"name": "",
"loc": "",
"values": {
"37-0-currentValue": {
"id": "7-37-0-currentValue",
"nodeId": 7,
"toUpdate": false,
"commandClass": 37,
"commandClassName": "Binary Switch",
"endpoint": 0,
"property": "currentValue",
"propertyName": "currentValue",
"type": "boolean",
"readable": true,
"writeable": false,
"label": "Current value",
"stateless": false,
"commandClassVersion": 0,
"list": false,
"isCurrentValue": true,
"targetValue": "37-0-targetValue",
"lastUpdate": 1668839656943
"37-0-targetValue": {
"id": "7-37-0-targetValue",
"nodeId": 7,
"toUpdate": false,
"commandClass": 37,
"endpoint": 0,
"property": "targetValue",
"propertyName": "targetValue",
"type": "boolean",
"readable": true,
"writeable": true,
"label": "Target value",
"stateless": false,
"list": false,
"lastUpdate": 1668839656945
"37-0-duration": {
"id": "7-37-0-duration",
"nodeId": 7,
"toUpdate": false,
"commandClass": 37,
"endpoint": 0,
"property": "duration",
"propertyName": "duration",
"type": "duration",
"readable": true,
"writeable": false,
"label": "Remaining duration",
"stateless": false,
"list": false,
"value": {
"unit": "seconds"
"lastUpdate": 1668839656946
"49-0-Power": {
"id": "7-49-0-Power",
"nodeId": 7,
"toUpdate": false,
"commandClass": 49,
"commandClassName": "Multilevel Sensor",
"endpoint": 0,
"property": "Power",
"propertyName": "Power",
"type": "number",
"readable": true,
"writeable": false,
"label": "Power",
"ccSpecific": {
"sensorType": 4,
"scale": 0
"stateless": false,
"unit": "W",
"list": false,
"value": 0,
"lastUpdate": 1668842703879
"50-0-value-65537": {
"id": "7-50-0-value-65537",
"nodeId": 7,
"toUpdate": false,
"commandClass": 50,
"commandClassName": "Meter",
"endpoint": 0,
"property": "value",
"propertyName": "value",
"propertyKey": 65537,
"propertyKeyName": "Electric_kWh_Consumed",
"type": "number",
"readable": true,
"writeable": false,
"label": "Electric Consumption [kWh]",
"ccSpecific": {
"meterType": 1,
"rateType": 1,
"scale": 0
"stateless": false,
"unit": "kWh",
"list": false,
"value": 402.68,
"lastUpdate": 1668842596874
"50-0-value-66049": {
"id": "7-50-0-value-66049",
"nodeId": 7,
"toUpdate": false,
"commandClass": 50,
"endpoint": 0,
"propertyKey": 66049,
"propertyKeyName": "Electric_W_Consumed",
"type": "number",
"readable": true,
"writeable": false,
"label": "Electric Consumption [W]",
"ccSpecific": {
"meterType": 1,
"rateType": 1,
"scale": 2
"stateless": false,
"unit": "W",
"list": false,
"value": 0,
"lastUpdate": 1668839656949
"50-0-reset-1": {
"id": "7-50-0-reset-1",
"nodeId": 7,
"toUpdate": false,
"commandClass": 50,
"endpoint": 0,
"property": "reset",
"propertyName": "reset",
"propertyKey": 1,
"propertyKeyName": "Electric",
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Reset (Electric)",
"ccSpecific": {
"meterType": 1
"stateless": false,
"list": false,
"lastUpdate": 1668839656950
"50-0-reset": {
"id": "7-50-0-reset",
"nodeId": 7,
"toUpdate": false,
"commandClass": 50,
"endpoint": 0,
"type": "boolean",
"readable": false,
"writeable": true,
"label": "Reset accumulated values",
"stateless": false,
"list": false,
"lastUpdate": 1668839656952
"113-0-alarmType": {
"id": "7-113-0-alarmType",
"nodeId": 7,
"toUpdate": false,
"commandClass": 113,
"commandClassName": "Notification",
"endpoint": 0,
"property": "alarmType",
"propertyName": "alarmType",
"type": "number",
"readable": true,
"writeable": false,
"label": "Alarm Type",
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 0,
"lastUpdate": 1668839656953
"113-0-alarmLevel": {
"id": "7-113-0-alarmLevel",
"nodeId": 7,
"toUpdate": false,
"endpoint": 0,
"property": "alarmLevel",
"propertyName": "alarmLevel",
"type": "number",
"readable": true,
"writeable": false,
"label": "Alarm Level",
"stateless": false,
"min": 0,
"max": 255,
"list": false,
"value": 0,
"lastUpdate": 1668839656954
"113-0-Power Management-Over-current status": {
"id": "7-113-0-Power Management-Over-current status",
"nodeId": 7,
"toUpdate": false,
"endpoint": 0,
"property": "Power Management",
"propertyName": "Power Management",
"propertyKey": "Over-current status",
"propertyKeyName": "Over-current status",
"type": "number",
"readable": true,
"writeable": false,
"label": "Over-current status",
"ccSpecific": {
"notificationType": 8
"stateless": false,
"min": 0,
"max": 255,
"list": true,
"states": [
"text": "idle",
"value": 0
"text": "Over-current detected",
"value": 6
"113-0-Power Management-Over-load status": {
"id": "7-113-0-Power Management-Over-load status",
"nodeId": 7,
"toUpdate": false,
"endpoint": 0,
"propertyKey": "Over-load status",
"propertyKeyName": "Over-load status",
"type": "number",
"readable": true,
"writeable": false,
"label": "Over-load status",
"ccSpecific": {
"stateless": false,
"min": 0,
"max": 255,
"list": true,
"states": [
"text": "idle",
"value": 0
"text": "Over-load detected",
"value": 8
"lastUpdate": 1668839656955
"groups": [],
"neighbors": "",
"ready": true,
"available": true,
"hassDevices": [],
"failed": false,
"inited": true,
"eventsQueue": [
"time": "2022-11-19T06:34:16.908Z",
"event": "alive",
"args": [
0
"time": "2022-11-19T06:34:16.963Z",
"event": "ready",
"args": []
"time": "2022-11-19T07:23:16.876Z",
"event": "value updated",
"args": [
"commandClass": 50,
"endpoint": 0,
"newValue": 402.68,
"prevValue": 402.68,
"time": "2022-11-19T07:25:03.882Z",
"args": [
"commandClass": 49,
"endpoint": 0,
"newValue": 0,
"prevValue": 0,
"status": "Alive",
"interviewStage": "Complete",
"hexId": "0xXXXX-0xXXXX-0xXXXX",
"dbLink": "https://devices.zwave-js.io/?jumpTo=0xXXXX:0xXXXX:0xXXXX:0.0",
"productLabel": "Unknown product 0xXXXX",
"productDescription": "0xXXXX",
"manufacturer": "Unknown manufacturer 0xXXXX",
"protocolVersion": 3,
"zwavePlusVersion": 1,
"zwavePlusNodeType": 0,
"zwavePlusRoleType": 5,
"nodeType": 1,
"endpointsCount": 0,
"endpointIndizes": [],
"isSecure": true,
"security": "S0_Legacy",
"supportsSecurity": false,
"supportsBeaming": true,
"isControllerNode": false,
"isListening": true,
"isFrequentListening": false,
"isRouting": true,
"keepAwake": false,
"maxDataRate": 100000,
"deviceClass": {
"basic": 4,
"generic": 16,
"specific": 1
"firmwareCapabilities": {
"firmwareUpgradable": true,
"firmwareTargets": [
0,
1554
"continuesToFunction": "unknown",
"supportsActivation": "unknown"
"deviceId": "undefined-undefined-undefined",
"statistics": {
"commandsTX": 1,
"commandsRX": 2,
"commandsDroppedRX": 0,
"commandsDroppedTX": 0,
"timeoutResponse": 0,
"rtt": 105.4
"lastActive": 1668842703869,
"filename": "Aucun",
"numberGroups": 0,
"classBasic": 4,
"classGeneric": 16,
"classSpecific": 1,
"deviceIdNew": "--",
"confJeedom": "-",
"confType": "Configuration Jeedom <br>",
"lastWakeup": "N/A",
"nextWakeup": "N/A",
"configWakeup": "N/A"
Merci d’avance ![]()
