Salut @FredT ,
Donc sur le même principe que pour les widgets « line » avec le paramètre optionnel seuilCligno à renseigner pour indiquer la valeur à partir de laquelle elle doit clignoter (si rien c’est la valeur max):
Pour les widgets "Tile":
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-template="tile" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="title #hide_name#">
<div class="cmdName">#name_display#</div>
</div>
<div class="content-sm">
<span class="pull-right">#unite#</span>
<span class="pull-right state"></span>
</div>
<div class="value #hide_history#">
<div class="col-xs-12 center-block">
<span title='Min' class='tooltips'>#minHistoryValue#</span>|<span title='Moyenne' class='tooltips'>#averageHistoryValue#</span>|<span title='Max' class='tooltips'>#maxHistoryValue#</span> <i class="#tendance#"></i>
</div>
</div>
<style>
@keyframes cligno
0% {opacity:0;}
100% {opacity:1;}
.clignoValue {animation:cligno infinite 0.8s;}
</style>
<script>
var cmd = $('.cmd[data-cmd_id=#id#]')
cmd.attr('title','Date de valeur : '+_options.valueDate+'<br/>Date de collecte : '+_options.collectDate)
cmd.find('.state').empty().append(_options.display_value);
var clignoValue = is_numeric('#seuilCligno#') ? parseFloat('#seuilCligno#'):#maxValue#;
if (_options.display_value >= clignoValue) {
cmd.find('.state').addClass("clignoValue");}
else {
cmd.find('.state').removeClass("clignoValue");}
jeedom.cmd.update['#id#']({display_value:'#state#',valueDate:'#valueDate#',collectDate:'#collectDate#',alertLevel:'#alertLevel#'});
</script>
</div>
Pour les widgets "Badge":
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-template="badge" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
</div>
<div class="content-sm ">
<span class='label label-info state'></span>
</div>
<div class="cmdStats #hide_history#">
</div>
</div>
<style>
@keyframes cligno
0% {opacity:0;}
100% {opacity:1;}
</style>
<script>
cmd.find('.state').empty().append(_options.display_value +' #unite#');
else {
</script>
</div>
adejee
Décembre 12, 2019, 7:35
24
Lu ce midi, essayé ce soir GÉNIAL!
par contre j ai réussi à l appliquer que sur une commande virtuel, mais pas sur une commande info numeric du plugin vigilance, je comprend pas.
J’ai prévu de partager tout à l’heure un code qui inclut les 3 présentations en un seul widget !
Je vais tester vigilance pour voir
Ça peut fonctionner avec des valeurs en dessous d’une valeur mini ?
Ou encadré entre une valeur mini et une valeur maxi ?
adejee:
Super !!! on attend cela
Salut @ tous,
ci-dessous le code d’un seul widget englobant les 3 visuels (line, tile & badge) avec la possibilité de définir un seuil maximal et un seuil minimal au-dessus et au-dessous desquels la valeur va clignoter. Il est également possible de faire clignoter la valeur encadrée par les seuils mini et maxi:
<div class="cmd cmd-widget #history#" data-type="info" data-subtype="numeric" data-cmd_id="#id#" data-cmd_uid="#uid#" data-version="#version#" data-eqLogic_id="#eqLogic_id#">
<div class="content-xs">
<span class="cmdName #hide_name#">#name_display# </span> <strong class="state"></strong>
</div>
</div>
<div class="tile">
</div>
<div class="badge">
</div>
</div>
</div>
</div>
<style>
@keyframes cligno
0% {opacity:0;}
100% {opacity:1;}
</style>
<script>
var value = _options.display_value
if ('#disposition#' == 'tile'){
cmd.find('.content-xs').hide()
cmd.find('.badge').hide()
cmd.attr('data-template','tile')
cmd.find('.state').empty().append(value);}
else if ('#disposition#' == 'badge'){
cmd.find('.tile').hide()
cmd.attr('data-template','badge')
cmd.find('.state').empty().append(value +' #unite#');}
else { cmd.find('.title').hide()
cmd.find('.content-sm').hide()
cmd.attr('data-template','line')
var miniValue = is_numeric('#seuilMini#') ? parseFloat('#seuilMini#'):#minValue#;
var maxiValue = is_numeric('#seuilMaxi#') ? parseFloat('#seuilMaxi#'):#maxValue#;
if ('#cadre#' == '1'){
if (value > miniValue && value < maxiValue) {
else {
else if (value < miniValue | value > maxiValue) {
else {
if(_options.alertLevel){
if(_options.alertLevel == 'warning'){
cmd.find('.content-xs').addClass('label label-warning')
cmd.find('.content-sm').addClass('label label-warning')
cmd.attr('data-alertlevel','warning');
}else if(_options.alertLevel == 'danger'){
cmd.find('.content-xs').addClass('label label-danger')
cmd.find('.content-sm').addClass('label label-danger')
cmd.attr('data-alertlevel','danger');
}else{
cmd.find('.content-xs').removeClass('label label-warning label-danger')
cmd.find('.content-sm').removeClass('label label-warning label-danger')
cmd.attr('data-alertlevel','none');
</script>
</div>
Les paramètres optionnels
disposition = tile ou badge (line par défaut)
seuilMini = Valeur du seuil minimum (par défaut: valeur mini de la commande)
seuilMaxi = Valeur du seuil maximum (par défaut: valeur maxi de la commande)
cadre = mettre à 1 pour que la valeur clignote entre les bornes seuilMini & seuilMaxi
A peine testé donc n’hésitez pas à me faire vos remontées.
Have Fun
Tu casses la baraque.
Respect.
FredT
Décembre 13, 2019, 10:18
30
Salvialf:
#minHistoryValue# |#averageHistoryValue# |#maxHistoryValue#
@keyframes cligno { 0% {opacity:0;} 100% {opacity:1;} } .clignoValue {animation:cligno infinite 0.8s;}
Cela fonctionne, mais en mode badge, cela décale l’affichage par rapport à l’affichage normal (ici, l’info Salon est celle qui clignote)
adejee
Décembre 13, 2019, 10:22
31
Tu déchires!!!
comme mykerinos1 je suis jaloux;
on pourrait presque modifier la couleur de la valeur qui clignote !!!
Super !! Merci pour l’info, j’ai corrigé:
</div>
</div>
<div class="tile">
</div>
<div class="badge">
</div>
</div>
</div>
</div>
<style>
@keyframes cligno
0% {opacity:0;}
100% {opacity:1;}
</style>
<script>
else {
else {
}else{
</script>
</div>
Le code a été aussi remis à jour dans le post au-dessus et j’ai ajouté les niveaux d’alerte configurables dans Jeedom (warning & danger).
EDIT: Faut que j’affine le code des niveaux d’alerte
EDIT2: C’est tout bon - code mis à jour
Je veux bien que t’essayes et que tu me dises ce qu’il en est ? Penses bien à rafraichir la page avec ctrl+F5 après modification du code.
J’y passe beaucoup de temps mais ça commence à rentrer dans ma petite caboche… Merci Jeedom !
Oui on peut… C’est quoi l’idée ? t’as un exemple ?
Merci @Jeandhom j’avoues il est pas mal ce widget je suis étonné qu’il n’y en ai pas eu la demande avant.
Je t’invite à remplacer le code par celui que je viens de mettre à jour dans les 2 posts au-dessus qui est bien optimisé et inclut les niveaux d’alertes en + !
adejee
Décembre 13, 2019, 10:51
34
Admettons une valeur de température (dit normal…) police inchangé. Puis au dessus d un seuil: valeur clignotante avec un police rouge par exemple…
FredT
Décembre 13, 2019, 10:52
35
Merci beaucoup @Salvialf !!!
Fonctionne bien.
L’idée de pouvoir modifier la couleur est également une bonne idée
adejee
Décembre 13, 2019, 10:55
36
Oui l’impact au niveau visuel serait un +++ mais grâce @Salvialf je fais déjà un bond d idées.
Je confirme qu’il est bon @Salvialf . Je suis aussi intéressé par la couleur
Pour la couleur j’ai justement ajouté la prise en compte des niveaux d’alerte pour mettre la tuile en orange en warning et en rouge en danger:
Franchement à part la petite animation css c’est que des classes du core du coup il aurait peut-être sa place dans le core…
Il faut militer pour, @Alexandre , @Loic .
FredT
Décembre 13, 2019, 1:57
41
Pour ma part, je n’arrive pas à avoir l’info qui passe en couleur en gérant les seuils dans la partie « Alertes »
