Mick33
Décembre 22, 2023, 2:00
1
J’ai constaté avoir régulièrement ce type d’erreur quand je change de page de configuration ( accés à un plugin , autres…) avec erreur 500 internal server Error
En PJ un log http
0476|Stack trace:
0477|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b57097fc1a92200', Array)
0478|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0479|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0480|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0481|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0482|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0483|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0484|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0485|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0486|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/ in /var/www/html/core/class/DB.class.php on line 40
0487|[Fri Dec 22 14:51:37.326020 2023] [php7:error] [pid 27213] [client 127.0.0.1:41856] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [1040] Too many connections in /var/www/html/core/class/DB.class.php:40
0488|Stack trace:
0489|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b57097fc1a92200', Array)
0490|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0491|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0492|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0493|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0494|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0495|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0496|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0497|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0498|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/ in /var/www/html/core/class/DB.class.php on line 40
0499|[Fri Dec 22 14:51:45.741353 2023] [php7:error] [pid 27213] [client 127.0.0.1:41860] PHP Fatal error: Uncaught PDOException: SQLSTATE[HY000] [1040] Too many connections in /var/www/html/core/class/DB.class.php:40
0500|Stack trace:
0501|#0 /var/www/html/core/class/DB.class.php(40): PDO->__construct('mysql:host=loca...', 'jeedom', 'b57097fc1a92200', Array)
0502|#1 /var/www/html/core/class/DB.class.php(50): DB::initConnection()
0503|#2 /var/www/html/core/class/DB.class.php(82): DB::getConnection()
0504|#3 /var/www/html/core/class/config.class.php(192): DB::Prepare('SELECT `key`,`v...', Array, 1)
0505|#4 /var/www/html/core/class/translate.class.php(51): config::byKeys(Array)
0506|#5 /var/www/html/core/class/translate.class.php(207): translate::getConfig('language', 'fr_FR')
0507|#6 /var/www/html/core/class/translate.class.php(102): translate::getLanguage()
0508|#7 /var/www/html/core/class/translate.class.php(81): translate::exec('{{Chauffage}}', '/var/www/html/c...', false)
0509|#8 /var/www/html/core/class/translate.class.php(220): translate::sentence('Chauffage', '/var/www/html/c...', false)
0510|#9 /var/www/html/core/config/jeedom.config.php(23): __('Chauffage', '/ in /var/www/html/core/class/DB.class.php on line 40
Bad
Décembre 22, 2023, 3:30
2
Avec une petite recherche sur le forum , on tombe rapidement sur des sujets comme :
Il n’y a pas de solution unique, mais ça vient souvent du nombre d’enregistrement en base de donnée, ou du stockage qui est défaillant.
Bad
Mick33
Décembre 22, 2023, 3:40
3
J’ai fait un ON/OFF jeedom et c’est reparti trop de connexions,
Je ne sais pas pourquoi cela s’est accumulé, peut être parce que je fait des manips d’installations avec dépendances et demon?
Bad
Décembre 22, 2023, 3:43
4
Il va falloir que tu fasses plus de tests, cherche dans les sujets précédents, et comme dit :
Mick33
Décembre 22, 2023, 3:53
5
Mais comment puis je controler ces enregistrements en BD ou stockage défaillant, car je suis à 60% de libre en moyenne
iPapy
Décembre 22, 2023, 4:11
6
Tu es sur quoi comme type de support ?
Bad
Décembre 22, 2023, 4:13
7
Peux-tu m’en dire plus stp ? Il me faudrait :
la page santé de Jeedom (ou à nouveau, c’est un nouveau sujet),
une capture d’écran de la liste des plugins (page des mises à jours),
une capture d’écran du moteur de tâches,
si tu as le plugin Monitoring, les graphiques historiques de la charge et l’usage mémoire.
le résultat des commandes ps auxfw, top, netstat -anp,
et le résultat des requêtes SQL suivantes (à faire une par une) :
SHOW FULL PROCESSLIST;
SHOW VARIABLES LIKE "max_connections";
SHOW GLOBAL VARIABLES LIKE "%wait_t%";
SHOW SESSION VARIABLES LIKE "%wait_t%";
SELECT cmd_id, COUNT(value) AS nb, SUM(LENGTH(value)) AS taille FROM historyArch GROUP BY cmd_id ORDER BY taille DESC LIMIT 100
SELECT table_name AS `Table`, round(((data_length + index_length) / 1024 / 1024), 2) `MB`,table_rows as `Ligne` FROM information_schema.TABLES WHERE table_schema='jeedom' ORDER BY (data_length + index_length) DESC
Bad
iPapy
Décembre 22, 2023, 4:32
9
ok donc peu de chance que la eMMC soit HS ou alors c’est pas de chance
Mick33
Décembre 22, 2023, 4:44
10
Je péparerais le dossier complet demain
Mick33
Décembre 22, 2023, 5:54
11
Quel onglet? cron , listener ou demon
Ces commandes sont écrites dans le même champ « commande sql » que les suivantes
Bad
Décembre 22, 2023, 6:32
12
Les 3 si possible, mais le plus intéressant est le premier, et m’indiquer s’il y a beaucoup de choses (>20-30 lignes) dans le second et des erreurs dans le 3eme.
Non, toujours dans OS/DB le bouton " Administration système".
Mick33
Décembre 23, 2023, 8:52
13
1- Page de santé
2- ,Liste des plugin
3- Moteur de taches
4- Je n’ai pas de plugin monitoring
5- Résultats des commandes:
ps ax
PID TTY STAT TIME COMMAND
1 ? Ss 0:35 /sbin/init
2 ? S 0:00 [kthreadd]
3 ? I< 0:00 [rcu_gp]
4 ? I< 0:00 [rcu_par_gp]
8 ? I< 0:00 [mm_percpu_wq]
9 ? S 0:00 [rcu_tasks_kthre]
10 ? S 0:00 [rcu_tasks_rude_]
11 ? S 0:00 [rcu_tasks_trace]
12 ? S 0:01 [ksoftirqd/0]
13 ? I 3:55 [rcu_preempt]
14 ? S 0:00 [migration/0]
15 ? S 0:00 [cpuhp/0]
16 ? S 0:00 [cpuhp/1]
17 ? S 0:00 [migration/1]
18 ? S 0:01 [ksoftirqd/1]
21 ? S 0:00 [cpuhp/2]
22 ? S 0:00 [migration/2]
23 ? S 0:01 [ksoftirqd/2]
26 ? S 0:00 [cpuhp/3]
27 ? S 0:00 [migration/3]
28 ? S 0:01 [ksoftirqd/3]
31 ? S 0:00 [cpuhp/4]
32 ? S 0:00 [migration/4]
33 ? S 0:01 [ksoftirqd/4]
36 ? S 0:00 [cpuhp/5]
37 ? S 0:00 [migration/5]
38 ? S 0:01 [ksoftirqd/5]
41 ? S 0:00 [kdevtmpfs]
42 ? I< 0:00 [netns]
49 ? S 0:00 [kauditd]
50 ? S 0:00 [oom_reaper]
51 ? I< 0:00 [writeback]
52 ? S 0:05 [kcompactd0]
53 ? SN 0:00 [ksmd]
54 ? SN 0:00 [khugepaged]
86 ? I< 0:00 [cryptd]
147 ? I< 0:00 [kintegrityd]
148 ? I< 0:00 [kblockd]
149 ? I< 0:00 [blkcg_punt_bio]
161 ? I< 0:00 [ata_sff]
164 ? I< 0:00 [edac-poller]
165 ? I< 0:00 [devfreq_wq]
166 ? S 0:00 [watchdogd]
216 ? S 0:00 [kswapd0]
217 ? S 0:00 [ecryptfs-kthrea]
220 ? I< 0:00 [kthrotld]
222 ? S 0:00 [irq/74-rockchip]
223 ? S 0:00 [irq/75-rockchip]
225 ? I< 0:00 [nvme-wq]
226 ? I< 0:00 [nvme-reset-wq]
227 ? I< 0:00 [nvme-delete-wq]
228 ? I< 0:00 [vfio-irqfd-clea]
231 ? S 0:00 [irq/78-rk808]
239 ? S 0:00 [irq/48-rockchip]
240 ? I< 0:00 [bch_btree_io]
241 ? I< 0:00 [bcache]
242 ? I< 0:00 [bch_journal]
245 ? I< 0:00 [kworker/u13:0-hci0]
246 ? I< 0:00 [sdhci]
247 ? S 0:00 [irq/38-mmc2]
248 ? S 0:00 [irq/88-fe320000]
253 ? I< 0:00 [ipv6_addrconf]
260 ? I< 0:00 [mmc_complete]
264 ? I< 0:00 [kstrp]
267 ? I< 0:00 [zswap1]
268 ? I< 0:00 [zswap1]
269 ? I< 0:00 [zswap-shrink]
328 ? I< 0:00 [stmmac_wq]
357 ? S 0:23 [jbd2/mmcblk2p1-]
358 ? I< 0:00 [ext4-rsv-conver]
431 ? Ss 0:01 /lib/systemd/systemd-udevd
509 ? S 0:00 [irq/65-ff940000]
510 ? S 0:00 [card0-crtc0]
511 ? S 0:00 [card0-crtc1]
514 ? S 0:00 [irq/54-ff660000]
517 ? I< 0:00 [cfg80211]
518 ? S 0:00 [irq/67-panfrost]
519 ? S 0:00 [pan_js]
520 ? S 0:00 [pan_js]
521 ? S 0:00 [pan_js]
525 ? I< 0:00 [brcmf_wq/mmc0:0]
527 ? S 0:05 [brcmf_wdog/mmc0]
535 ? S 0:00 [cec-dw_hdmi]
536 ? S 0:00 [irq/65-dw-hdmi-]
546 ? I< 0:00 [kworker/u13:1-hci0]
618 ? Ss 0:00 /sbin/dhclient -4 -v -i -pf /run/dhclient.eth0.pid -lf /var/lib/dhcp/dhclient.eth0.leases -I -df /var/lib/dhcp/dhclient6.eth0.leases eth0
655 ? I< 0:00 [ext4-rsv-conver]
688 ? Ss 0:27 /lib/systemd/systemd-journald
693 ? Ss 0:00 /usr/sbin/haveged --Foreground --verbose=1 -w 1024
1069 ? I 0:00 [kworker/2:2-mm_percpu_wq]
1148 ? I< 0:00 [kworker/4:2H]
1230 ? I 0:00 [kworker/0:0-events]
1265 ? S 0:04 /usr/sbin/apache2 -k start
1266 ? S 0:02 /usr/sbin/apache2 -k start
1358 ? S 0:01 /usr/sbin/apache2 -k start
1366 ? S 0:01 /usr/sbin/apache2 -k start
1367 ? S 0:02 /usr/sbin/apache2 -k start
1499 ? S 4:25 /usr/sbin/apache2 -k start
1575 ? Ss 0:02 /usr/sbin/cron -f
1580 ? Ssl 0:06 /usr/sbin/rsyslogd -n -iNONE
1585 ? Ss 0:00 /usr/lib/bluetooth/bluetoothd
1590 ? SNs 0:00 /usr/sbin/alsactl -E HOME=/run/alsa -s -n 19 -c rdaemon
1599 ? SLsl 0:00 /usr/sbin/rngd -r /dev/urandom
1606 ? Ss 0:00 /usr/bin/python3 /usr/bin/networkd-dispatcher --run-startup-triggers
1608 ? Ss 0:01 /lib/systemd/systemd-logind
1615 ? Ss 0:17 /usr/bin/dbus-daemon --system --address=systemd: --nofork --nopidfile --systemd-activation --syslog-only
1622 ? Ss 0:09 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
1626 ? Ssl 0:57 /usr/sbin/NetworkManager --no-daemon
1632 ? Ss 0:00 /usr/sbin/atd -f
1755 ? Ss 0:09 /usr/sbin/vnstatd -n
1764 ? Ss 1:03 /usr/sbin/mosquitto -c /etc/mosquitto/mosquitto.conf
1765 ? Ss 0:29 avahi-daemon: running [JeedomAtlas.local]
1772 ? Ssl 0:00 /usr/bin/python3 /usr/share/unattended-upgrades/unattended-upgrade-shutdown --wait-for-signal
1775 ? Ssl 4:41 /usr/bin/python3 /usr/bin/fail2ban-server -xf start
1781 ? S 0:00 avahi-daemon: chroot helper
1791 tty1 Ss+ 0:00 /sbin/agetty -o -p -- \u --noclear tty1 linux
1792 ? Ss 0:00 /usr/sbin/sshd -D
1889 ? Ssl 15:15 /usr/sbin/mysqld
1890 ? Ssl 0:00 /usr/lib/policykit-1/polkitd --no-debug
1891 ? S 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-eth0.pid -lf /var/lib/NetworkManager/dhclient-2f57e76c-bfd2-4135-86df-716e46cc3cab-eth0.lease -cf /var/lib/NetworkManager/dhclient-eth0.conf eth0
1941 ? Ss 0:06 /usr/sbin/apache2 -k start
2009 ? S 6:13 /usr/sbin/apache2 -k start
2011 ? S 6:26 /usr/sbin/apache2 -k start
2063 ? I< 0:00 [dio/mmcblk2p1]
2224 ? S 0:00 /sbin/dhclient -d -q -sf /usr/lib/NetworkManager/nm-dhcp-helper -pf /run/dhclient-wlan0.pid -lf /var/lib/NetworkManager/dhclient-f0d73b1c-84dd-494e-9c38-656347fef21c-wlan0.lease -cf /var/lib/NetworkManager/dhclient-wlan0.conf wlan0
2340 ? Ssl 0:00 /usr/sbin/ntpd -p /var/run/ntpd.pid -g -c /run/ntp.conf.dhcp -u 110:119
2404 ? S 6:02 php /var/www/html/core/class/../php/jeeCron.php cron_id=837
2427 ? S 10:17 php /var/www/html/core/class/../php/jeeCron.php cron_id=32
2430 ? S 0:27 php /var/www/html/core/class/../php/jeeCron.php cron_id=27
2451 ? I 0:00 [kworker/u12:1-brcmf_wq/mmc0:0001:1]
2469 ? SNl 0:01 node /var/www/html/plugins/espeasy/resources/espeasy.js 192.168.1.71 http://127.0.0.1:80/plugins/espeasy/core/api/jeeEspeasy.php?apikey=5km3Ulp6tpEeSltN0D8nxp06DZ4nEGbW1lmBPCRP1pQVbs64SuguyQKLTL02FrIA 400
2507 ? Sl 11:06 /var/www/html/plugins/jMQTT/resources/jmqttd/venv/bin/python3 /var/www/html/plugins/jMQTT/resources/jmqttd/jmqttd.py
2538 ? S 0:00 sudo /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.1.71:1883 --username jeedom --password Michel553 --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey nJHFICsJsG8xiPNj3nZP0GG5VEEDgn2vaWViLcYO1sFY13D1havX6tmOnPDCDiyd --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
2539 ? Sl 5:02 /usr/bin/node /var/www/html/plugins/mqtt2/resources/mqtt2d/mqtt2d.js --loglevel debug --socketport 55035 --mqtt_server mqtt://192.168.1.71:1883 --username jeedom --password Michel553 --callback http://127.0.0.1:80/plugins/mqtt2/core/php/jeeMqtt2.php --apikey nJHFICsJsG8xiPNj3nZP0GG5VEEDgn2vaWViLcYO1sFY13D1havX6tmOnPDCDiyd --cycle 0.3 --pid /tmp/jeedom/mqtt2/deamon.pid
2599 ? S 6:15 /usr/sbin/apache2 -k start
2617 ? S 0:00 sudo openvpn --config /tmp/jeedom/openvpn/openvpn_2.ovpn
2624 ? S 0:03 openvpn --config /tmp/jeedom/openvpn/openvpn_2.ovpn
2803 ? Sl 16:23 /usr/bin/python3 /var/www/html/plugins/rfxcom/resources/rfxcomd/rfxcomd.py --device /dev/serial/by-id/usb-RFXCOM_RFXtrx433XL_DO738PPG-if00-port0 --loglevel debug --socketport 55000 --serialrate 38400 --protocol 6,18,21,22,23,31 --callback http://127.0.0.1:80/plugins/rfxcom/core/php/jeeRfxcom.php --apikey E1P1xdyU0n7rdauipInvYhY78i35DKRIxZwVP0Ryw8DAtSxjaYLlClnGqRThcF3h --cycle 0.3 --pid /tmp/jeedom/rfxcom/deamon.pid
2875 ? Sl 11:49 /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyS2 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey 1bhQrseZFJNMdsUBwUli9VOaSAalFnGFY4lCVSWddsiEdkhAp4f1X15L38h141KQ --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
3720 ? S 0:00 sudo ZIGBEE2MQTT_DATA=/var/www/html/plugins/z2m/core/class/../../data npm start --prefix /var/www/html/plugins/z2m/resources/zigbee2mqtt
3726 ? Sl 0:01 npm start
3747 ? S 0:00 sh -c node index.js
3749 ? Sl 4:32 node index.js
4177 ? I 0:00 [kworker/0:2-events]
4592 ? I< 0:00 [kworker/5:1H-kblockd]
5251 ? I 0:00 [kworker/u12:2]
5479 ? S 0:00 sh -c sudo ps ax 2>&1
5480 ? S 0:00 sudo ps ax
5482 ? R 0:00 ps ax
7422 ? S 6:05 /usr/sbin/apache2 -k start
7840 ? I 0:00 [kworker/5:1-events]
9944 ? I 0:00 [kworker/u12:0-events_unbound]
10041 ? I 0:00 [kworker/4:1-mm_percpu_wq]
16106 ? S 5:18 /usr/sbin/apache2 -k start
18862 ? I< 0:00 [kworker/1:2H]
23677 ? I 0:00 [kworker/5:0-events]
23738 ? I< 0:00 [kworker/4:1H-kblockd]
24519 ? I< 0:00 [kworker/2:0H-kblockd]
24520 ? I< 0:00 [kworker/5:0H-kblockd]
26138 ? I 0:00 [kworker/1:2-mm_percpu_wq]
27604 ? I< 0:00 [kworker/0:1H-kblockd]
27918 ? I 0:00 [kworker/3:1-mm_percpu_wq]
28285 ? I 0:00 [kworker/4:2-events]
28668 ? I< 0:00 [kworker/0:0H-kblockd]
29124 ? I< 0:00 [kworker/2:1H-kblockd]
29354 ? I< 0:00 [kworker/3:1H-kblockd]
29846 ? I< 0:00 [kworker/1:1H-kblockd]
29883 ? I< 0:00 [kworker/3:0H]
30042 ? I 0:00 [kworker/2:1-rcu_gp]
30254 ? I 0:00 [kworker/1:0-events]
30893 ? I 0:00 [kworker/0:1-mm_percpu_wq]
31889 ? I 0:00 [kworker/3:0-events]
netstat-tupin
(Not all processes could be identified, non-owned process info
will not be shown, you would have to be root to see it all.)
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:55000 0.0.0.0:* LISTEN 2803/python3
tcp 0 0 127.0.0.1:8089 0.0.0.0:* LISTEN 2875/python3
tcp 0 0 192.168.1.71:8121 0.0.0.0:* LISTEN 2469/node
tcp 0 0 127.0.0.1:55035 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:1883 0.0.0.0:* LISTEN -
tcp 0 0 127.0.0.1:40451 0.0.0.0:* LISTEN 2507/python3
tcp 0 0 127.0.0.1:3306 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN -
tcp 0 0 0.0.0.0:6900 0.0.0.0:* LISTEN 2427/php
tcp6 0 0 :::22 :::* LISTEN -
tcp6 0 0 :::1883 :::* LISTEN -
tcp6 0 0 :::80 :::* LISTEN -
udp 0 0 0.0.0.0:68 0.0.0.0:* -
udp 0 0 10.13.23.118:123 0.0.0.0:* -
udp 0 0 192.168.1.71:123 0.0.0.0:* -
udp 0 0 127.0.0.1:123 0.0.0.0:* -
udp 0 0 0.0.0.0:123 0.0.0.0:* -
udp 0 0 0.0.0.0:43514 0.0.0.0:* -
udp 0 0 0.0.0.0:56421 0.0.0.0:* -
udp 0 0 0.0.0.0:5353 0.0.0.0:* 2404/php
udp 0 0 0.0.0.0:5353 0.0.0.0:* -
udp6 0 0 fe80::2ca6:1464:eb8:123 :::* -
udp6 0 0 fe80::cfb:eaff:fedf:123 :::* -
udp6 0 0 ::1:123 :::* -
udp6 0 0 :::123 :::* -
udp6 0 0 :::41274 :::* -
udp6 0 0 :::5353 :::* -
Je n’ai pas trouvé les commandes top, -anp ?
Je fais un autre post pour la suite
Mick33
Décembre 23, 2023, 9:03
14
1- Show Processlist
2-Show variables like
3-SHOW GLOBAL
4-SHOW SESSION
5- SELECT cmd_id
cmd_id nb taille
1448 392325 3139357
1452 385059 3109801
1442 393545 2611884
1444 186038 1459955
18 11596 136829
1446 11017 123428
1523 9212 110544
1450 9680 108291
1524 8979 107748
1522 8850 106200
1521 8838 106056
20 4683 55077
1312 11899 52537
1471 1929 22906
1461 1921 22767
1491 1917 22748
1501 1919 22745
1481 1919 22726
1496 1916 22720
1466 1917 22713
1476 1918 22706
1486 1916 22663
1317 10860 21760
1447 697 12546
1451 697 11849
1311 719 9799
1316 719 9509
1310 719 9071
1449 672 8892
1315 719 8791
1309 719 8186
1314 720 7976
1735 393 5135
1736 427 5076
1443 262 4716
1746 391 4692
1743 383 4596
1667 1122 4412
1744 276 3609
1674 958 3496
1742 278 3249
1631 260 3030
1619 261 3029
1637 261 3029
1661 260 3018
1649 259 3017
1643 258 3010
1655 261 3009
1625 257 2971
1313 718 2774
720 225 2700
7108 176 2112
1445 144 1995
7261 165 1980
7262 164 1968
7107 154 1848
1663 1121 1801
1745 146 1752
6905 140 1680
1675 527 1634
1788 134 1608
1789 131 1572
6906 131 1572
1678 414 1198
1676 397 1114
10596 77 926
10595 77 859
1672 95 465
1482 31 377
1467 28 349
1492 28 340
1497 27 338
1477 27 337
1462 26 324
1502 26 324
1472 26 312
1487 25 311
1665 95 280
15305 19 247
11198 19 217
15302 17 204
1664 37 126
1679 37 95
1673 24 72
1510 5 60
1677 19 52
1632 5 49
1638 4 48
1662 4 48
1620 4 48
1644 4 48
1626 4 48
1656 4 48
1650 4 38
15300 3 33
705 32 32
1741 3 25
1666 5 23
10536 22 22
1793 9
6- SELECT table-name AS
J’espère avoir répondu correctement à toute ta demande, maintenant à toi de jouer.
Bonnes fêtes quand même
Michel
Bad
Décembre 23, 2023, 9:09
15
Merci pour ces traces, est-ce que tu rencontres encore le problème
SQLSTATE[HY000] [1040] Too many connections ?
Car tout à l’air parfaitement en ordre d’après ce que tu m’a envoyé.
La base de donnée fait 90 Mo, peut-être que les historiques des commandes prennent un peu de place en bdd, mais ce n’est pas vraiment exorbitant.
Peux-tu m’en dire plus sur les 5 commandes 1448, 1452, 1442 et 1444 stp ?
Bad
Mick33
Décembre 23, 2023, 9:16
16
Merci pour ton retour, pour l’instant je ne rencontre pas de problème, mais je ne manipe plus? Pour les 5 commandes que tu cites, comment puis je les trouver rapidement?
Bad
Décembre 23, 2023, 9:26
17
Dans le résumé domotique :
Mick33
Décembre 23, 2023, 9:34
18
Ce sont les commandes de mon Envoy
Par contre une chose importante que je viens de m’apercevoir, je travaille avec un imac et un macbook pro et parfois je suis connecté avec les 2 mac sur le server Jeedom.
Quand j’ai voulu accéder au résumé domotique avec mon mac book erreur d’accés à la page, par contre sans pb avec mon imac. Est ce que c’est peut être la cause initiale du pb? Trop de connexions, sachant que j’ai un iphone et une tablette connectés avec JC.
Bad
Décembre 23, 2023, 9:45
19
Ok, donc c’est logique qu’il y ait beaucoup de points de mesure.
Vérifie quand même que ces commandes sont bien de type info/ binaire ou numérique, et qu’il y a une purge et/ou du lissage des historiques.
Je pense que ça peut exacerber le problème mais ça ne devrait pas en être la cause.
Quand le problème se produit, peux-tu faire une capture sur un équipement fonctionnel de ta page santé stp ?
As-tu de nouveaux messages dans les logs ?
Bad
Mick33
Décembre 23, 2023, 10:31
20
Pas d’erreur particulière uniquement un pb de requête Envoy qui arrive de temps en temps:
D’accord, par contre pour ma culture personnelle, j’ai un pb d’inclusion avec un module Tuya Mesure de puissance qui est compatible Z2M. Comment peux t on observer la requête d’inclusion et savoir pourquoi cela ne se réalise pas? sur un log ou autre?
