Merci pour votre retour
Comme je disais à Bad, ce problème est apparu après avoir installé MQTT manager et JeeZigbee. JMQTT était déjà installé avec Mosquito, pour un couplage avec un ESP.
Je vous transmets en PJ les logs d’erreur relevé sur
JMQTT:
et JMQTTD
0000|[2023-12-26 16:10:08,436]INFO Main MainThread set_log_level() : New log level set to: ERROR
0001|[2023-12-26 16:10:11,452]ERROR JMsg.Snd MainThread send_test() : Callback test Exception (HTTPConnectionPool(host='127.0.0.1', port=80): Read timed out. (read timeout=3.0))
0002|[2023-12-26 16:10:11,453][CRITICAL] Main MainThread open_comm() : Open Comm : Failed to Open the communication channel to send informations back TO Jeedom
0003|[2023-12-26 16:10:11,945][CRITICAL] Main MainThread open_comm() : Open Comm : Closed the communication channel to get instructions FROM Jeedom
0004|[2023-12-26 16:15:08,085]INFO Main MainThread set_log_level() : New log level set to: ERROR
0005|[2023-12-26 16:15:11,100]ERROR JMsg.Snd MainThread send_test() : Callback test Exception (HTTPConnectionPool(host='127.0.0.1', port=80): Read timed out. (read timeout=3.0))
0006|[2023-12-26 16:15:11,101][CRITICAL] Main MainThread open_comm() : Open Comm : Failed to Open the communication channel to send informations back TO Jeedom
0007|[2023-12-26 16:15:11,593][CRITICAL] Main MainThread open_comm() : Open Comm : Closed the communication channel to get instructions FROM Jeedom
0008|[2023-12-26 16:20:08,846]INFO Main MainThread set_log_level() : New log level set to: ERROR
0009|[2023-12-26 16:20:11,861]ERROR JMsg.Snd MainThread send_test() : Callback test Exception (HTTPConnectionPool(host='127.0.0.1', port=80): Read timed out. (read timeout=3.0))
0010|[2023-12-26 16:20:11,862][CRITICAL] Main MainThread open_comm() : Open Comm : Failed to Open the communication channel to send informations back TO Jeedom
0011|[2023-12-26 16:20:12,354][CRITICAL] Main MainThread open_comm() : Open Comm : Closed the communication channel to get instructions FROM Jeedom
0012|[2023-12-26 16:25:08,039]INFO Main MainThread set_log_level() : New log level set to: ERROR
0013|[2023-12-26 16:25:11,053]ERROR JMsg.Snd MainThread send_test() : Callback test Exception (HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/jMQTT/core/php/callback.php?apikey=WHaN4NYLuLqLFnuuVraSM0RRbjc0NNfYV9sUe5C9GQBYmLKyK1Tg6Wunx92pQkNr&uid=5613:35829 (Caused by ConnectTimeoutError(, 'Connection to 127.0.0.1 timed out. (connect timeout=3.0)')))
0014|[2023-12-26 16:25:11,055][CRITICAL] Main MainThread open_comm() : Open Comm : Failed to Open the communication channel to send informations back TO Jeedom
0015|[2023-12-26 16:25:11,547][CRITICAL] Main MainThread open_comm() : Open Comm : Closed the communication channel to get instructions FROM Jeedom
0016|[2023-12-26 16:30:08,815]INFO Main MainThread set_log_level() : New log level set to: ERROR
0017|[2023-12-26 16:30:11,829]ERROR JMsg.Snd MainThread send_test() : Callback test Exception (HTTPConnectionPool(host='127.0.0.1', port=80): Max retries exceeded with url: /plugins/jMQTT/core/php/callback.php?apikey=WHaN4NYLuLqLFnuuVraSM0RRbjc0NNfYV9sUe5C9GQBYmLKyK1Tg6Wunx92pQkNr&uid=8295:45773 (Caused by ConnectTimeoutError(, 'Connection to 127.0.0.1 timed out. (connect timeout=3.0)')))
0018|[2023-12-26 16:30:11,830][CRITICAL] Main MainThread open_comm() : Open Comm : Failed to Open the communication channel to send informations back TO Jeedom
0019|[2023-12-26 16:30:12,323][CRITICAL] Main MainThread open_comm() : Open Comm : Closed the communication channel to get instructions FROM Jeedom
0020|[2023-12-26 16:35:08,062]INFO Main MainThread set_log_level() : New log level set to: ERROR
0021|[2023-12-26 22:17:28,444]INFO Main MainThread set_log_level() : New log level set to: ERROR
0022|[2023-12-27 16:37:10,764]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.025', 'qos': 0, 'retain': False}]
0023|[2023-12-27 16:37:50,663]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.024', 'qos': 0, 'retain': False}]
0024|[2023-12-27 16:38:20,742]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.024', 'qos': 0, 'retain': False}]
0025|[2023-12-27 16:44:50,625]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.026', 'qos': 0, 'retain': False}]
0026|[2023-12-27 16:48:40,718]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.027', 'qos': 0, 'retain': False}]
0027|[2023-12-27 16:58:10,712]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0028|[2023-12-27 16:58:20,676]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.028', 'qos': 0, 'retain': False}]
0029|[2023-12-27 16:58:22,129]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0030|[2023-12-27 16:58:23,857]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.521', 'qos': 0, 'retain': False}]
0031|[2023-12-27 16:58:23,941]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.647', 'qos': 0, 'retain': False}]
0032|[2023-12-27 16:58:30,750]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.028', 'qos': 0, 'retain': False}]
0033|[2023-12-27 16:58:32,100]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0034|[2023-12-27 16:58:33,925]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.518', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0035|[2023-12-27 16:58:40,760]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.028', 'qos': 0, 'retain': False}]
0036|[2023-12-27 16:58:42,111]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0037|[2023-12-27 16:58:43,766]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.516', 'qos': 0, 'retain': False}]
0038|[2023-12-27 16:58:43,820]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}]
0039|[2023-12-27 16:58:43,868]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0040|[2023-12-27 16:58:50,733]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.028', 'qos': 0, 'retain': False}]
0041|[2023-12-27 16:58:52,081]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0042|[2023-12-27 16:58:53,831]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.519', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.646', 'qos': 0, 'retain': False}]
0043|[2023-12-27 16:58:59,199]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0044|[2023-12-27 16:59:02,105]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0045|[2023-12-27 16:59:10,716]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0046|[2023-12-27 16:59:12,066]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0047|[2023-12-27 16:59:13,819]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.525', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}]
0048|[2023-12-27 16:59:13,866]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.645', 'qos': 0, 'retain': False}]
0049|[2023-12-27 16:59:20,733]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0050|[2023-12-27 16:59:22,083]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0051|[2023-12-27 16:59:23,836]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.526', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.94', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.646', 'qos': 0, 'retain': False}]
0052|[2023-12-27 16:59:30,734]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0053|[2023-12-27 16:59:32,085]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0054|[2023-12-27 16:59:33,882]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.521', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.647', 'qos': 0, 'retain': False}]
0055|[2023-12-27 16:59:40,637]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0056|[2023-12-27 16:59:42,085]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0057|[2023-12-27 16:59:43,896]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.518', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0058|[2023-12-27 16:59:49,230]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0059|[2023-12-27 16:59:50,645]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0060|[2023-12-27 16:59:52,037]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0061|[2023-12-27 16:59:53,759]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.517', 'qos': 0, 'retain': False}]
0062|[2023-12-27 16:59:53,805]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0063|[2023-12-27 16:59:53,835]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0064|[2023-12-27 17:00:00,647]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.028', 'qos': 0, 'retain': False}]
0065|[2023-12-27 17:00:02,038]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0066|[2023-12-27 17:00:03,762]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.517', 'qos': 0, 'retain': False}]
0067|[2023-12-27 17:00:03,791]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0068|[2023-12-27 17:00:03,819]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0069|[2023-12-27 17:00:10,649]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0070|[2023-12-27 17:00:11,866]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0071|[2023-12-27 17:00:12,031]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0072|[2023-12-27 17:00:13,759]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.517', 'qos': 0, 'retain': False}]
0073|[2023-12-27 17:00:13,790]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0074|[2023-12-27 17:00:13,825]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0075|[2023-12-27 17:00:20,638]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0076|[2023-12-27 17:00:22,041]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0077|[2023-12-27 17:00:23,773]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.516', 'qos': 0, 'retain': False}]
0078|[2023-12-27 17:00:23,802]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0079|[2023-12-27 17:00:23,833]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0080|[2023-12-27 17:00:30,647]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0081|[2023-12-27 17:00:32,041]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0082|[2023-12-27 17:00:33,762]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.517', 'qos': 0, 'retain': False}]
0083|[2023-12-27 17:00:33,792]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0084|[2023-12-27 17:00:33,822]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0085|[2023-12-27 17:00:34,362]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0086|[2023-12-27 17:00:40,645]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0087|[2023-12-27 17:00:42,044]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '455', 'qos': 0, 'retain': False}]
0088|[2023-12-27 17:00:43,762]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.521', 'qos': 0, 'retain': False}]
0089|[2023-12-27 17:00:43,791]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0090|[2023-12-27 17:00:43,817]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.647', 'qos': 0, 'retain': False}]
0091|[2023-12-27 17:00:50,639]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0092|[2023-12-27 17:00:52,050]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0093|[2023-12-27 17:00:53,758]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.526', 'qos': 0, 'retain': False}]
0094|[2023-12-27 17:00:53,800]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0095|[2023-12-27 17:00:53,827]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.645', 'qos': 0, 'retain': False}]
0096|[2023-12-27 17:00:56,869]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0097|[2023-12-27 17:01:02,159]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0098|[2023-12-27 17:01:03,814]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.516', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}]
0099|[2023-12-27 17:01:03,863]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0100|[2023-12-27 17:01:10,732]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0101|[2023-12-27 17:01:12,154]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0102|[2023-12-27 17:01:13,817]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.522', 'qos': 0, 'retain': False}]
0103|[2023-12-27 17:01:13,865]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.646', 'qos': 0, 'retain': False}]
0104|[2023-12-27 17:01:20,727]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0105|[2023-12-27 17:01:22,087]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '453', 'qos': 0, 'retain': False}]
0106|[2023-12-27 17:01:23,887]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.526', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.645', 'qos': 0, 'retain': False}]
0107|[2023-12-27 17:01:30,646]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0108|[2023-12-27 17:01:32,097]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '453', 'qos': 0, 'retain': False}]
0109|[2023-12-27 17:01:33,887]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.523', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.88', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.646', 'qos': 0, 'retain': False}]
0110|[2023-12-27 17:01:40,711]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.029', 'qos': 0, 'retain': False}]
0111|[2023-12-27 17:01:42,061]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '453', 'qos': 0, 'retain': False}]
0112|[2023-12-27 17:01:43,886]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.517', 'qos': 0, 'retain': False}, {'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.81', 'qos': 0, 'retain': False}]
0113|[2023-12-27 17:01:43,947]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.648', 'qos': 0, 'retain': False}]
0114|[2023-12-27 17:01:45,971]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
0115|[2023-12-27 17:01:50,647]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0116|[2023-12-27 17:01:52,049]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0117|[2023-12-27 17:01:53,762]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.521', 'qos': 0, 'retain': False}]
0118|[2023-12-27 17:01:53,799]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.81', 'qos': 0, 'retain': False}]
0119|[2023-12-27 17:01:53,826]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.647', 'qos': 0, 'retain': False}]
0120|[2023-12-27 17:02:00,641]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_volt/state', 'payload': '2.030', 'qos': 0, 'retain': False}]
0121|[2023-12-27 17:02:02,039]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/orp_piscine/state', 'payload': '454', 'qos': 0, 'retain': False}]
0122|[2023-12-27 17:02:03,765]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/ph_piscine/state', 'payload': '7.527', 'qos': 0, 'retain': False}]
0123|[2023-12-27 17:02:03,813]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/temprature_piscine/state', 'payload': '12.81', 'qos': 0, 'retain': False}]
0124|[2023-12-27 17:02:03,840]ERROR JMsg.Snd SockOut send() : COULD NOT send TO Jeedom: [{'cmd': 'messageIn', 'id': '141', 'topic': 'esp-piscine/sensor/phvolt_piscine/state', 'payload': '2.645', 'qos': 0, 'retain': False}]
0125|[2023-12-27 17:02:08,527]ERROR JMsg.Snd SndNoBlkHb send() : COULD NOT send TO Jeedom: [{'cmd': 'hb'}]
Après un redémarrage de la box , le nombre de connexion est devenu normal, pourquoi cela s’emballe au fil du temps?
