Bonjour à Tous,
Je voulais installer le plugin Onkyo pour inclure mon ampli HC dans Jeedom et j’ai un problème lors de l’installation, le demon ne démarre pas :
[2021-09-02 11:10:34][ERROR] : Impossible de lancer le démon onkyo, vérifiez le port
[2021-09-02 11:10:38][ERROR] : Erreur lors de la création du node
Voici la log lors de l’installation des dépendances :
Début de l'installation
--2021-09-02 10:33:01-- https://raw.githubusercontent.com/lunarok/jeedom_nodejs/master/nodejs.sh
Resolving raw.githubusercontent.com (raw.githubusercontent.com)... 185.199.111.133, 185.199.108.133, 185.199.109.133, ...
Connecting to raw.githubusercontent.com (raw.githubusercontent.com)|185.199.111.133|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: 1510 (1.5K) [text/plain]
Saving to: 'dependencies.sh'
0K . 100% 9.07M=0s
2021-09-02 10:33:01 (9.07 MB/s) - 'dependencies.sh' saved [1510/1510]
Nodejs non installé
Hit:1 http://security.debian.org/debian-security buster/updates InRelease
Hit:2 http://deb.debian.org/debian buster InRelease
Get:3 http://deb.debian.org/debian buster-updates InRelease [51.9 kB]
Hit:4 https://deb.nodesource.com/node_14.x buster InRelease
Fetched 51.9 kB in 1s (44.1 kB/s)
Reading package lists...
Building dependency tree...
Reading state information...
lsb-release is already the newest version (10.2019051400).
0 upgraded, 0 newly installed, 0 to remove and 148 not upgraded.
KO, version obsolète à upgrader
Suppression du Nodejs existant et installation du paquet recommandé
Package 'npm' is not installed, so not removed
The following packages will be REMOVED:
nodejs*
0 upgraded, 0 newly installed, 1 to remove and 148 not upgraded.
After this operation, 121 MB disk space will be freed.
(Reading database ...
(Reading database ... 5%
(Reading database ... 10%
(Reading database ... 15%
(Reading database ... 20%
(Reading database ... 25%
(Reading database ... 30%
(Reading database ... 35%
(Reading database ... 40%
(Reading database ... 45%
(Reading database ... 50%
(Reading database ... 55%
(Reading database ... 60%
(Reading database ... 65%
(Reading database ... 70%
(Reading database ... 75%
(Reading database ... 80%
(Reading database ... 85%
(Reading database ... 90%
(Reading database ... 95%
(Reading database ... 100%
(Reading database ... 71962 files and directories currently installed.)
Removing nodejs (14.17.6-deb-1nodesource1) ...
Processing triggers for man-db (2.8.5-2) ...
Utilisation du dépot officiel
## Installing the NodeSource Node.js 14.x repo...
## Populating apt-get cache...
+ apt-get update
Hit:1 http://deb.debian.org/debian buster InRelease
Hit:2 http://security.debian.org/debian-security buster/updates InRelease
Hit:3 http://deb.debian.org/debian buster-updates InRelease
## Confirming "buster" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_14.x/dists/buster/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
## Creating apt sources list file for the NodeSource Node.js 14.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' > /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_14.x buster main' >> /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
## Run `sudo apt-get install -y nodejs` to install Node.js 14.x and npm
## You may also need development tools to build native addons:
sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
sudo apt-get update && sudo apt-get install yarn
nodejs
debconf: unable to initialize frontend: Dialog
debconf: (Dialog frontend will not work on a dumb terminal, an emacs shell buffer, or without a controlling terminal.)
debconf: falling back to frontend: Readline
debconf: unable to initialize frontend: Readline
debconf: (This frontend requires a controlling tty.)
debconf: falling back to frontend: Teletype
dpkg-preconfigure: unable to re-open stdin:
0 upgraded, 1 newly installed, 0 to remove and 148 not upgraded.
Need to get 0 B/24.9 MB of archives.
After this operation, 121 MB of additional disk space will be used.
Selecting previously unselected package nodejs.
(Reading database ... 67032 files and directories currently installed.)
Preparing to unpack .../nodejs_14.17.6-deb-1nodesource1_amd64.deb ...
Unpacking nodejs (14.17.6-deb-1nodesource1) ...
Setting up nodejs (14.17.6-deb-1nodesource1) ...
dependencies.sh: line 51: nodejs: command not found
Version actuelle :
npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
npm WARN deprecated har-validator@5.1.5: this library is no longer supported
npm WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
added 50 packages from 61 contributors and audited 50 packages in 5.612s
2 packages are looking for funding
run `npm fund` for details
found 0 vulnerabilities
Fin de l'installation
Pourriez vous m’aider svp ? (Je débute un peu dans Jeedom)
Je suis sous Debian10 (VM sur NAS Synology) - Jeedom V4.1.25
