Oui, mais…
Pour l’instant ma sonde externe est dans l’interieur.
Oui, mais…
Et aussi la reponse /devices/meta
"endpoints": [
"error": 0,
"id": 1579811222,
"metadata": [
"enum_values": [
"ECO",
"COMFORT",
"STOP",
"ANTI_FROST"
"name": "thermicLevel",
"permission": "rw",
"type": "string"
"enum_values": [
"ECO",
"COMFORT",
"STOP",
"ANTI_FROST"
"name": "delayThermicLevel",
"permission": "w",
"type": "string"
"max": 99.9,
"min": -99.9,
"name": "temperature",
"permission": "r",
"step": 0.01,
"type": "numeric",
"unit": "degC"
"enum_values": [
"STOP",
"HEATING"
"name": "authorization",
"permission": "rw",
"type": "string"
"enum_values": [
"NORMAL",
"STOP",
"ANTI_FROST"
"name": "hvacMode",
"permission": "rw",
"type": "string"
"max": 65535,
"min": 0,
"name": "timeDelay",
"permission": "rw",
"step": 1,
"type": "numeric",
"unit": "minute"
"name": "tempoOn",
"permission": "r",
"type": "boolean",
"unit": "boolean"
"name": "antifrostOn",
"permission": "r",
"type": "boolean",
"unit": "boolean"
"name": "openingDetected",
"permission": "r",
"type": "boolean",
"unit": "boolean"
"name": "presenceDetected",
"permission": "r",
"type": "boolean",
"unit": "boolean"
"name": "absence",
"permission": "r",
"type": "boolean",
"unit": "boolean"
"name": "loadSheddingOn",
"permission": "r",
"type": "boolean",
"unit": "boolean"
Donc il y a bien la température interne
je ne pense pas que cela soit l’id de ton calybox c’est pas l’id d’un thermostat de zone plutot ?
Je crois que le Calybox a la sonde, mais il ne lui remonte pas
"data": [
"validity": "upToDate",
"value": "ECO"
"value": null
"max": 99.9,
"min": -99.9,
"name": "outTemperature",
"permission": "r",
"step": 0.01,
"type": "numeric",
"unit": "degC"
moi j'ai ca en retour sur mon tybox 2020wt
dans /devices/meta
"max": 99.9,
"min": -99.9,
"permission": "r",
"step": 0.01,
"type": "numeric",
"unit": "degC"
et
"max": 99.9,
"min": -99.9,
"permission": "r",
"step": 0.01,
"type": "numeric",
"unit": "degC"
et dans /devices/cmeta
"name": "energyIndex",
"parameters": [
"enum_values": [
"ELEC_TOTAL",
"ELEC_HEATING",
"ELEC_HOTWATER",
"ELEC_OUTLET",
"ELEC_OTHER",
"TEMP_INDOOR",
"TEMP_OUTDOOR"
"name": "dest",
"type": "string"
"name": "reset",
"type": "boolean"
"permission": "r"
Et tu a quoi en data ?
cmeta c pour la conso pas encore implanté dans jeedore
moi en data j’ai
"value": 4.4
Oui, ma point d’info cmeta c’est qu’il y a bien TEMP_INDOOR et TEMP_OUTDOOR
Dans data c’est
"data": [
"value": "ECO"
"value": null
et
"data": [
"value": 19.4
Ma sonde externe est a l’interieur pour l’instant
donc tu as bien la température de la sonde extérieure mais aucun retour sur la temp intérieure
et dans tydom ??
Exactement !
et sur l’appli tydom ? tu vois la temps intérieure ?
Non, je ne vois pas.
C’est l’inverse avec Calybox 1020 - temps intérieure - oui, mais pas de temps extérieure
Encore un defaut de Delta Dore…
Peut-être je peux installer les Tybox 5101s ?
Tybox 5101
oui tu peux !!!
Jeedore fait vendre du matériel deltadore ?
Eli
Bien évidemment !
J’ai enfin obtenu le fameux capteur de température d’ambiance tybox 5101.
Je l’ai connecté à ma Calybox 2020 WT, et maintenant je peux voir les 3 relevés de température : capteur interne de la box 2020, capteur externe et capteur d’ambiance dans la rubrique maintenance capteurs.
Cependant, le Tydom 1.0 ne voit que le capteur de température externe, car apparemment la Calybox 2020 n’exporte pas les autres capteurs… Quelqu’un a t-il une expérience avec les capteurs d’ambiance ? Enfin, quel est le dernier firmware pour la Calybox/Tybox 2020 WT ? Le mien a la version 2.00…
Hello
Pas de Calybox pour ma part mais un Tywatt 2000 (version logiciel:3.01 et version BT:2.00), qui possède également une sonde interne qui ne remonte pas non plus sur Jeedore.
Seule la sonde extérieure remonte.
Nouveau sujet - Tybox 5101
