Voici la cde depuis Jeedom avec un Bt9
0747|[2021-02-08 18:08:11]DEBUG : Message read from socket: b'{"apikey":"Doubledom","cmd":"send","data":["0B1100F100C1327A09010F77"]}'
0748|[2021-02-08 18:08:11]DEBUG : Client disconnected from [127.0.0.1:58830]
0749|[2021-02-08 18:08:11]DEBUG : Message received in socket JEEDOM_SOCKET_MESSAGE
0750|[2021-02-08 18:08:11]DEBUG : Test message: 0B1100F100C1327A09010F77
0751|[2021-02-08 18:08:11]DEBUG : flushOutput serial port
0752|[2021-02-08 18:08:11]DEBUG : flushInput serial port
0753|[2021-02-08 18:08:11]DEBUG : Write message to serial port
0754|[2021-02-08 18:08:11]DEBUG : Write data to serial port : 0b1100f100c1327a09010f77
0755|[2021-02-08 18:08:11]DEBUG : Write message ok : 0B1100F100C1327A09010F77
0756|[2021-02-08 18:08:11]DEBUG : Message: 040201f100
0757|[2021-02-08 18:08:11]DEBUG : Decode : 040201f100
0758|[2021-02-08 18:08:11]DEBUG : Test message: 040201f100
0759|[2021-02-08 18:08:11]DEBUG : PacketType: 0x02
0760|[2021-02-08 18:08:11]DEBUG : Length: 5
0761|[2021-02-08 18:08:11]DEBUG : Start decoding packet type 0x02
0762|[2021-02-08 18:08:11]DEBUG : Subtype = Reponse du Transmetteur
0763|[2021-02-08 18:08:11]DEBUG : Data : {'packetlen': '0x04', 'packettype': '0x02', 'subtype': '0x01', 'seqnbr': '0xF1', 'msg1': '0x00'}
0764|[2021-02-08 18:08:11]DEBUG : Reponse du Transmetteur = 0x00
0765|[2021-02-08 18:08:11]DEBUG : Message Transmis
Voici la réception du même code (produit par une télécde)
0762|[2021-02-08 18:15:24]DEBUG : Message: 0b11000b00c1327a09010f70
0763|[2021-02-08 18:15:24]DEBUG : Decode : 0b11000b00c1327a09010f70
0764|[2021-02-08 18:15:24]DEBUG : Test message: 0b11000b00c1327a09010f70
0765|[2021-02-08 18:15:24]DEBUG : PacketType: 0x11
0766|[2021-02-08 18:15:24]DEBUG : Length: 12
0767|[2021-02-08 18:15:24]DEBUG : Start decoding packet type 0x11
0768|[2021-02-08 18:15:24]DEBUG : Subtype = AC KlikAanKlikUit,HomeEasyUK,Chacon,NEXA,Intertechno
0769|[2021-02-08 18:15:24]DEBUG : Data : {'packetlen': '0x0B', 'packettype': '0x11', 'subtype': '0x00', 'seqnbr': '0x0B', 'id1': '0x00', 'filler1': '0x00', 'id2': '0xC1', 'id3': '0x32', 'id4': '0x7A', 'unitcode': 9, 'cmnd': 1, 'level': 15, 'filler2': 0, 'rssi': 7}
0770|[2021-02-08 18:15:24]DEBUG : Decoded info : {'packettype': '0x11', 'subtype': '0x00', 'id': '00C1327A', 'unitcode': 9, 'cmnd': 1, 'level': 100.0, 'rssi': 7}
0771|[2021-02-08 18:15:24]DEBUG : Device is known id : 00C1327A
0772|[2021-02-08 18:15:24]DEBUG : Send to jeedom : {'devices': {'00C1327A11': {'packettype': '0x11', 'subtype': '0x00', 'id': '00C1327A', 'unitcode': 9, 'cmnd': 1, 'level': 100.0, 'rssi': 7}}}
0773|[2021-02-08 18:15:24]DEBUG : Starting new HTTP connection (1): 127.0.0.1:80
0774|[2021-02-08 18:15:24]DEBUG : {"devices":{"00C1327A11":{"packettype":"0x11","subtype":"0x00","id":"00C1327A","unitcode":9,"cmnd":1,"level":100,"rssi":7}}}
