J’ai acheté cet interrupteur qui doit être très proche du modèle TS004F mais qui au final n’est pas le même (aucune commande ne fonctionne).
"ieee": "60:a4:23:ff:fe:d5:c2:05",
"nwk": 42792,
"status": 2,
"lqi": "168",
"rssi": "-58",
"last_seen": "1623858185.3654907",
"node_descriptor": "02:40:80:02:10:52:52:00:00:2c:52:00:00",
"endpoints": [
"id": 1,
"status": 1,
"device_type": 260,
"profile_id": 260,
"manufacturer": "_TZ3000_xabckq1v",
"model": "TS004F",
"output_clusters": [
"id": 25,
"name": "Ota",
"attributes": []
"id": 10,
"name": "Time",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 5,
"name": "Scenes",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 8,
"name": "Level control",
"attributes": []
"id": 4096,
"name": "LightLink",
"attributes": []
"input_clusters": [
"id": 0,
"name": "Basic",
"attributes": [
"id": 0,
"name": "zcl_version",
"value": 3
"id": 1,
"name": "app_version",
"value": 65
"id": 2,
"name": "stack_version",
"value": 0
"id": 3,
"name": "hw_version",
"value": 1
"id": 4,
"name": "manufacturer",
"value": "_TZ3000_xabckq1v"
"id": 5,
"name": "model",
"value": "TS004F"
"id": 6,
"name": "date_code",
"value": ""
"id": 7,
"name": "power_source",
"value": 3
"id": 1,
"name": "Power Configuration",
"attributes": []
"id": 3,
"name": "Identify",
"attributes": []
"id": 4,
"name": "Groups",
"attributes": []
"id": 6,
"name": "On\/Off",
"attributes": []
"id": 4096,
"attributes": []
"signature": {
"model": "TS004F",
"node_desc": {
"byte1": 2,
"byte2": 64,
"mac_capability_flags": 128,
"manufacturer_code": 4098,
"maximum_buffer_size": 82,
"maximum_incoming_transfer_size": 82,
"server_mask": 11264,
"maximum_outgoing_transfer_size": 82,
"endpoints": {
"1": {
"profile_id": 260,
"device_type": 260,
"input_clusters": [
0,
1,
3,
4,
6,
4096
25,
10,
3,
4,
5,
6,
8,
4096
"class": "zigpy.device"
Puis logs zigbee :
[2021-06-16 17:59:00][INFO] : Lancement démon zigbeed : /usr/bin/python3 /var/www/html/plugins/zigbee/resources/zigbeed/zigbeed.py --device /dev/ttyUSB0 --loglevel debug --socketport 8089 --callback http://127.0.0.1:80/plugins/zigbee/core/php/jeeZigbee.php --apikey 0GNGYrnI1vSsb1QpP2FmYBXxkc8VABSp --cycle 0.3 --pid /tmp/jeedom/zigbee/deamon_1.pid --data_folder /var/www/html/plugins/zigbee/data/1 --device_folder /var/www/html/plugins/zigbee/data/device --controller ezsp --sub_controller elelabs --channel 15 --folder_OTA /var/www/html/plugins/zigbee/data/ota
[2021-06-16 17:59:07][DEBUG] : null
[2021-06-16 17:59:16][DEBUG] : {"devices":{"00:12:4b:00:22:d2:8a:9b":{"1":{"6":[{"value":"Bool.true","cluster_name":"On\/Off"}]}}}}
[2021-06-16 17:59:16][DEBUG] : Search attribut for 00:12:4b:00:22:d2:8a:9b logicalId : 1::6::0 => Bool.true
[2021-06-16 17:59:28][DEBUG] : {"devices":{"84:fd:27:ff:fe:83:0e:8e":{"1":[{"1":{"value":"64","cluster_name":"Basic"}}]}}}
[2021-06-16 17:59:28][DEBUG] : Search attribut for 84:fd:27:ff:fe:83:0e:8e logicalId : 1::0::1 => 64
[2021-06-16 18:00:15][DEBUG] : http://127.0.0.1:8089/device/all type : GET
[2021-06-16 18:00:15][DEBUG] : null
[2021-06-16 18:00:22][DEBUG] : {"devices":{"00:12:4b:00:22:6d:7d:bb":{"1":{"6":[{"value":"Bool.false","cluster_name":"On\/Off"}]}}}}
[2021-06-16 18:00:22][DEBUG] : Search attribut for 00:12:4b:00:22:6d:7d:bb logicalId : 1::6::0 => Bool.false
[2021-06-16 18:00:42][DEBUG] : {"devices":{"84:fd:27:ff:fe:80:c3:63":{"1":[{"1":{"value":"64","cluster_name":"Basic"}}]}}}
[2021-06-16 18:00:42][DEBUG] : Search attribut for 84:fd:27:ff:fe:80:c3:63 logicalId : 1::0::1 => 64
