oui
lol, 10 caractères mini, faut broder
Point 4, réinstallation plugin Jeedom. (tu voulais dire Déconz où j’ai mal compris?)
Oui Plug in Deconz de Jeedom
Résumé
Installation deconz *
Hit:1 http://phoscon.de/apt/deconz buster InRelease
Get:2 Index of /raspbian buster InRelease [15.0 kB]
Hit:3 Index of /debian buster InRelease
Fetched 15.0 kB in 2s (8531 B/s)
Reading package lists…
Building dependency tree…
Reading state information…
libqt5serialport5 is already the newest version (5.11.3-2).
libqt5websockets5 is already the newest version (5.11.3-5).
The following packages were automatically installed and are no longer required:
python-bcrypt python-fasteners python-lockfile python-monotonic python-nacl
python-paramiko python-pexpect python-ptyprocess python-pyasn1
Use ‹ sudo apt autoremove › to remove them.
0 upgraded, 0 newly installed, 0 to remove and 133 not upgraded.
sqlite3 is already the newest version (3.27.2-3+deb10u1).
It’s armv7l, RPI
Adding user root to group dialout
–2020-12-19 23:26:35-- http://phoscon.de/apt/deconz.pub.key
Resolving phoscon.de (phoscon.de)… 144.76.96.194
Connecting to phoscon.de (phoscon.de)|144.76.96.194|:80… connected.
HTTP request sent, awaiting response… 200 OK
Length: 1692 (1.7K) [application/octet-stream]
Saving to: ‹ STDOUT ›
0K . 100% 4.58M=0s
2020-12-19 23:26:35 (4.58 MB/s) - written to stdout [1692/1692]
Warning: apt-key output should not be parsed (stdout is not a terminal)
OK
Hit:1 Index of /debian buster InRelease
Hit:2 Index of /raspbian buster InRelease
Hit:3 http://phoscon.de/apt/deconz buster InRelease
deconz is already the newest version (2.07.01-raspbian-buster-stable).
Installation terminée *
Installation déconz, tout vas bien jusqu’ici?
Yes comme il était installé auparavant la mise à jour n’a finalement pas réalisé grand chose de plus
La clef n’est pas reconnue. Pas good
Elle est bien branchée sur ta box avec une petite rallonge USB ?
Un hub USB3… (sur USB2 du RPI 3b+)
je regarde si j’ai un truc pour dépanner… ou en direct?
Essaie effectivement en direct
je l’ai mis en direct et débranché le hub. Faut redémarrer le RPI?
(à savoir que du coup, mon alim 3A gère le RPI, le SSD et la Conbee)
Théoriquement non, juste besoin de relancer le démon Deconz
pi@jeedom:~ $ GCFFlasher_internal -l
GCFFlasher V3_17 (c) dresden elektronik ingenieurtechnik gmbh
Path | Vendor | Product | Serial | Type
/dev/ttyAMA0 | 0x0000 | 0x0000 | | RaspBee
Même résultat
PAr acquis de conscience il faudrait brancher ta ConBee2 sur ton PC pour voir si elle y est visible.
avec GCFFlasher -l cette fois ci
Il faut bien sur avoir installé deCONZ sur le PC au préalable
oui, je l’ai réinstallé déjà et pas encore lancé
PAs besoin de lancer deCONZ sur le PC juste ouvrir une fenêtre de commande et taper la commande à la main comme vu beaucoup plus haut
déjà elle déco / reco sans arrêt, ça sent le flashage loupé…
Ah oui. Donc reflasher depuis le PC
Grrr!
bon je recherche le tuto plus haut dans ce post…
